    4. [neuer Adapter] smartgarden adapter for Gardena smart system
      jack99n @jpgorganizer last edited by
      @jpgorganizer
      Danke dir,da wäre ich ja nie drauf gekommen.
        stevie77 @jpgorganizer last edited by stevie77
        Moin zusammen,
        hab' nur ich ein Problem seit 1-2 Tagen mit der Verbindung zu Gardena oder basteln die gerade in der Winterpause? Kann den Fehler nicht so wirklich einordnen...
        Edit: Hmmm, scheinbar habe ich zu viele Requests geschickt, allerdings habe ich die letzten Wochen nicht wirklich was verändert. Eher Geräte in den Winterschlaf versetzt, die jetzt keine Aktionen mehr auslösen sollten?!
        smartgarden.0
        2021-12-19 23:41:30.316	info	2/ getConnection: trying to connect again in 300 seconds
        smartgarden.0
        2021-12-19 23:41:30.316	info	2/ getConnection: returned connection error: request returned 429
        smartgarden.0
        2021-12-19 23:41:30.314	error	Error: request returned 429
        smartgarden.0
        2021-12-19 23:41:30.312	info	2/ get_locations failure:..return with error
        smartgarden.0
        2021-12-19 23:41:30.311	info	2/ get_locations failure: response.statusCode/Message=429/
        smartgarden.0
        2021-12-19 23:41:30.114	info	2/ get_locations ...
        smartgarden.0
        2021-12-19 23:41:30.112	info	2/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXX
        smartgarden.0
        2021-12-19 23:41:30.110	info	2/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
        smartgarden.0
        2021-12-19 23:41:30.107	info	2/ Connection: successful: response.statusCode / statusMessage=200 / OK
        smartgarden.0
        2021-12-19 23:41:28.311	info	2/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
        smartgarden.0
        2021-12-19 23:41:28.309	info	2/ connecting to Gardena Smart System Service ...
        smartgarden.0
        2021-12-19 23:41:28.305	info	2/ connectToGardena...
        smartgarden.0
        2021-12-19 23:41:28.302	info	2/ getConnection...
        smartgarden.0
        2021-12-19 23:41:28.046	info	starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v14.18.2, js-controller: 3.3.21
        smartgarden.0
        2021-12-19 23:41:10.772	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        smartgarden.0
        2021-12-19 23:41:10.770	info	terminating
        smartgarden.0
        2021-12-19 23:41:10.769	info	2/ cleaned everything up...
        smartgarden.0
        2021-12-19 23:41:10.766	info	Got terminate signal TERMINATE_YOURSELF
        smartgarden.0
        2021-12-19 23:40:00.035	error	Error: sendCommand: command not send, because not connected to Gardena Webservice
        jpgorganizer 1 Reply Last reply Reply Quote 0
        • jpgorganizer
          jpgorganizer @stevie77 last edited by
          @stevie77
          irgendwas stoppt deinen Adapter
          schalte mal Loglevel auf 3 in den Adapter-Einstellungen
          VG jpgorganizer
            @jpgorganizer Loglevel 3 = DEBUG?
            Ich hatte gestern Node.js und js-controller upgedatet. Aber ich meine das Problem bestand schon vorher...
            Edit: Ich glaub' aber das ist ein Fehlalarm mit dem Terminieren. Ich hatte zuvor halt mal versucht den Adapter zu restarten über das entsprechende Symbol. Ich glaube das hat nichts zu bedeuten...wird auch ausgegeben, wenn ich den Loglevel ändere, weil der Adapter dann neu startet.
            Edit2: Ja, mit SILLY bekomme ich eine riesige Liste mit den Zugriffszahlen seit Oktober 2020. Da werden für die letzten 31 Tage ziemlich viele Zugriffe angezeigt, warum auch immer. Wo lag gleich die Grenze?
            Fehler 429 würde auch passen, das HTTP-Code 429 = Too Many Requests.
            {\"count\":24},\"09\":{\"count\":24}},\"2021-12-20\":{\"count\":14,\"00\":{\"count\":14}}}},\"last30days\":{\"count\":4689},\"last31days\":{\"count\":4691}}
            Edit3: Hat sich bestätigt. Ich hatte im Frühjahr/Sommer das Problem schonmal und daraufhin alle Skripte umgestellt um Abfragen zu reduzieren. Leider habe ich dabei das eine Skript übersehen, das im Teich den Eisfreihalter steuert (mit ner Gardena-Steckdose). Das ist das einzige Gardena-Winterskript. 😉 Und da wird noch alle 5 min stur der Ein- oder Ausschalten-Befehl geschickt...
            Somit ist das geklärt. Den Counter kann ich nur zurücksetzen, indem ich mir den "Zugang" (was genau?) neu generiere? Oder bekomme ich am nächsten Tag schon wieder ein kleines "Zugriffsguthaben"? Oder erst nach 31 Tagen?
            smartgarden.0
            2021-12-20 01:26:40.809	info	2/ getConnection: trying to connect again in 300 seconds
            smartgarden.0
            2021-12-20 01:26:40.808	info	2/ getConnection: returned connection error: request returned 429
            smartgarden.0
            2021-12-20 01:26:40.806	error	Error: request returned 429
            smartgarden.0
            2021-12-20 01:26:40.805	info	2/ get_locations failure:..return with error
            smartgarden.0
            2021-12-20 01:26:40.803	info	2/ get_locations failure: response.statusCode/Message=429/
            smartgarden.0
            2021-12-20 01:26:40.571	info	2/ get_locations ...
            smartgarden.0
            2021-12-20 01:26:40.569	info	2/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX--XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
            smartgarden.0
            2021-12-20 01:26:40.566	info	2/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
            smartgarden.0
            2021-12-20 01:26:40.564	info	2/ Connection: successful: response.statusCode / statusMessage=200 / OK
            smartgarden.0
            2021-12-20 01:26:40.050	info	2/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
            smartgarden.0
            2021-12-20 01:26:40.049	info	2/ connecting to Gardena Smart System Service ...
            smartgarden.0
            2021-12-20 01:26:40.039	info	2/ connectToGardena...
            smartgarden.0
            2021-12-20 01:26:40.037	info	2/ getConnection...
            smartgarden.0
            2021-12-20 01:26:39.707	info	starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v14.18.2, js-controller: 3.3.21
            smartgarden.0
            2021-12-20 01:26:39.133	debug	statesDB connected
            smartgarden.0
            2021-12-20 01:26:39.131	debug	States connected to redis: 127.0.0.1:9000
            smartgarden.0
            2021-12-20 01:26:39.106	debug	States create User PubSub Client
            smartgarden.0
            2021-12-20 01:26:39.104	debug	States create System PubSub Client
            smartgarden.0
            2021-12-20 01:26:39.074	debug	Redis States: Use Redis connection: 127.0.0.1:9000
            smartgarden.0
            2021-12-20 01:26:39.067	debug	objectDB connected
            smartgarden.0
            2021-12-20 01:26:39.046	debug	Objects connected to redis: 127.0.0.1:9001
            smartgarden.0
            2021-12-20 01:26:38.960	debug	Objects client initialize lua scripts
            smartgarden.0
            2021-12-20 01:26:38.957	debug	Objects create User PubSub Client
            smartgarden.0
            2021-12-20 01:26:38.951	debug	Objects create System PubSub Client
            smartgarden.0
            2021-12-20 01:26:38.931	debug	Objects client ready ... initialize now
            smartgarden.0
            2021-12-20 01:26:38.733	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
            smartgarden.0
            2021-12-20 01:26:32.156	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            smartgarden.0
            2021-12-20 01:26:32.154	info	terminating
            smartgarden.0
            2021-12-20 01:26:32.152	info	2/ cleaned everything up...
            smartgarden.0
            2021-12-20 01:26:32.150	info	Got terminate signal TERMINATE_YOURSELF
              StefanA 0 @stevie77 last edited by StefanA 0
              @stevie77
              ich habe in der Nacht vom 16.12. auf 17.12. gemerkt, dass plötzlich nur noch "Bad Request" (400) gekommen ist. Erst dachte ich, ich hätte bei meinen Tests, weitere Datenpunkte abzufragen, etwas versemmelt oder zu oft das falsche Secret angegeben.
              Eingrenzen kann ich das insofern, dass es bis ca. 23:30 Uhr noch funktionierte und ab ca. 1:00 Uhr nicht mehr.
              Als erstes habe ich den Key revoked und erneuert. Kein Erfolg. Dann dachte ich, vielleicht ist die Plattform wegen Wartungsarbeiten down. Als das am Freitag Morgen immer noch nicht lief, kontaktierte ich den Support und von da kam die Empfehlung das Gerät komplett zu löschen und neu anzulegen. Das klappte aber auch nicht.
              Wenn man das automatisch erzeugte Testkommando mit dem korrekten Secret in einer CMD startete, kam ebenso der Fehler, wie auch im SWAGGER-Bereich.
              Ich habe ein neues Konto mit einer anderen meiner E-Mailadressen angelegt und nur die Authentication aktiviert, um auszuschließen, dass wegen der ganzen Tests was blockiert wurde. Auch beim neuen Account das gleiche Bild.
              Leider ist der Supporter seit dem WE in Urlaub und seine Kollegen antworten nicht. Auch ein Anruf mit zig Weiterleitungen und dem Versprechen, man sucht einen Vertreter, war bisher erfolglos.
              Edit 2:
              Es funktioniert wieder. Ich habe nochmal alle Passwörter geändert, auch in der Gardena-App. So richtig erklären kann ich es nicht, aber seitdem ist alles wieder grün und lässt sich auch steuern.
              Grüße,
              Stefan
              • jpgorganizer
                @stevie77 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                das ist eine BucketList, da hast du 3000 Abfragen pro Monat und durchschnittlich darfst du nicht mehr wie eine Abfrage pro 15 min haben.
                Ich vermute, dass alle 15 Minuten ein Token in die BucketList gelegt wird (bis max. 3000 Token) und für jede Abfrage geht ein Token wieder raus. Wenn die BucketListe leer ist, dann geht halt nichts mehr.
                Für die, die es interessiert, die können gerne bei AWS nachlesen, wie es genau funktioniert. 🙂
                VG jpgorganizer
                noch schöne Weihnachten für euch
                • jpgorganizer
                  @stefana-0 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                  für das nächste Mal:
                  hier kann man zum Test alternativ auch das Python Test Script nehmen ... ist manchmal einfacher wie das Swagger .....
                  https://github.com/jpgorganizer/test4smartgarden/tree/master/apitestscript
                  Aber jetzt geht's ja wieder.
                  Viele Grüße jpgorganizer
                  Frohe Weihnachten
                    Pino72 @jpgorganizer last edited by Pino72
                    Hallo Zusammen,
                    hatte das ganze letzte Jahr den Adapter ganz gut am Laufen, bis auf die ca alle 3 Monate nervige Key Änderung. (Ist das jetzt gelöst?)
                    Aktuell hab ich allerdings seltsame Probleme, der Adapter läuft ganz normal an:
                    smartgarden.0
                    	2022-04-04 09:49:35.827	info	2/ parseMessage: COMMON found
                    smartgarden.0
                    	2022-04-04 09:49:35.797	info	2/ parseMessage: MOWER found
                    smartgarden.0
                    	2022-04-04 09:49:35.763	info	2/ parseMessage: COMMON found
                    smartgarden.0
                    	2022-04-04 09:49:35.746	info	2/ parseMessage: SENSOR found
                    smartgarden.0
                    	2022-04-04 09:49:35.716	info	2/ parseMessage: COMMON found
                    smartgarden.0
                    	2022-04-04 09:49:35.703	info	2/ parseMessage: SENSOR found
                    smartgarden.0
                    	2022-04-04 09:49:35.699	info	2/ parseMessage: DEVICE found
                    smartgarden.0
                    	2022-04-04 09:49:35.693	info	2/ parseMessage: DEVICE found
                    smartgarden.0
                    	2022-04-04 09:49:35.687	info	2/ parseMessage: DEVICE found
                    smartgarden.0
                    	2022-04-04 09:49:35.680	info	2/ parseMessage: LOCATION found
                    smartgarden.0
                    	2022-04-04 09:49:35.344	info	2/ on_open: ### connected ###
                    smartgarden.0
                    	2022-04-04 09:49:35.132	info	2/ get_websocket ... websocket ok
                    smartgarden.0
                    	2022-04-04 09:49:35.121	info	2/ get_websocket successful: response.statusCode/Message=201/Created
                    smartgarden.0
                    	2022-04-04 09:49:35.011	info	2/ get_websocket ...
                    smartgarden.0
                    	2022-04-04 09:49:35.010	info	2/ get_locations ... locations={"data":[{"id":"b86717d4-8633-4241-9686-e64473790757","type":"LOCATION","attributes":{"name":"My Garden"}}]}
                    smartgarden.0
                    	2022-04-04 09:49:35.009	info	2/ get_locations: successful / response.statusMessage: OK
                    smartgarden.0
                    	2022-04-04 09:49:34.792	info	2/ get_locations ...
                    smartgarden.0
                    	2022-04-04 09:49:34.790	info	2/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                    smartgarden.0
                    	2022-04-04 09:49:34.788	info	2/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
                    smartgarden.0
                    	2022-04-04 09:49:34.788	info	2/ Connection: successful: response.statusCode / statusMessage=200 / OK
                    smartgarden.0
                    	2022-04-04 09:49:34.291	info	2/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
                    smartgarden.0
                    	2022-04-04 09:49:34.290	info	2/ connecting to Gardena Smart System Service ...
                    smartgarden.0
                    	2022-04-04 09:49:34.288	info	2/ connectToGardena...
                    smartgarden.0
                    	2022-04-04 09:49:34.286	info	2/ getConnection...
                    smartgarden.0
                    	2022-04-04 09:49:34.204	info	starting. Version 1.0.5 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.smartgarden, node: v14.18.0, js-controller: 4.0.21
                    smartgarden.0
                    	2022-04-04 09:49:33.762	debug	States connected to redis: 127.0.0.1:9010
                    smartgarden.0
                    	2022-04-04 09:49:33.703	debug	States create User PubSub Client
                    smartgarden.0
                    	2022-04-04 09:49:33.702	debug	States create System PubSub Client
                    smartgarden.0
                    	2022-04-04 09:49:33.664	debug	Redis States: Use Redis connection: 127.0.0.1:9010
                    smartgarden.0
                    	2022-04-04 09:49:33.599	debug	Objects connected to redis: 127.0.0.1:9011
                    smartgarden.0
                    	2022-04-04 09:49:33.581	debug	Objects client initialize lua scripts
                    smartgarden.0
                    	2022-04-04 09:49:33.452	debug	Objects create User PubSub Client
                    smartgarden.0
                    	2022-04-04 09:49:33.450	debug	Objects create System PubSub Client
                    smartgarden.0
                    	2022-04-04 09:49:33.447	debug	Objects client ready ... initialize now
                    smartgarden.0
                    	2022-04-04 09:49:33.321	debug	Redis Objects: Use Redis connection: 127.0.0.1:9011
                    smartgarden.0
                    	2022-04-04 09:49:23.184	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    smartgarden.0
                    	2022-04-04 09:49:23.182	info	terminating
                    smartgarden.0
                    	2022-04-04 09:49:23.181	info	3/ cleaned everything up...
                    smartgarden.0
                    	2022-04-04 09:49:23.152	info	Got terminate signal TERMINATE_YOURSELF
                    Aber nach wenigen Stunden trennt er sich von selber, warum?:
                    smartgarden.0
                    	2022-04-04 12:04:05.516	info	2/ on_close: ### closed ### close.code=1001 close.reason=Going away
                    smartgarden.0
                    	2022-04-04 12:00:46.038	info	2/ on_pong: ++ pong'ed ++
                    smartgarden.0
                    	2022-04-04 11:57:26.034	info	2/ on_pong: ++ pong'ed ++
                    smartgarden.0
                    	2022-04-04 11:54:06.031	info	2/ on_pong: ++ pong'ed ++
                    smartgarden.0
                    	2022-04-04 11:50:46.019	info	2/ on_pong: ++ pong'ed ++
                    smartgarden.0
                    	2022-04-04 11:50:38.102	info	2/ setServiceStates: relationship searching
                    smartgarden.0
                    	2022-04-04 11:50:38.101	info	2/ parseMessage: COMMON found
                    smartgarden.0
                    	2022-04-04 11:50:38.088	info	2/ setServiceStates: relationship searching
                    smartgarden.0
                    	2022-04-04 11:50:38.088	info	2/ parseMessage: MOWER found
                    smartgarden.0
                    	2022-04-04 11:47:26.007	info	2/ on_pong: ++ pong'ed ++
                    smartgarden.0
                    	2022-04-04 11:44:05.983	info	2/ on_pong: ++ pong'ed ++
                    smartgarden.0
                    	2022-04-04 11:40:45.977	info	2/ on_pong: ++ pong'ed ++
                    smartgarden.0
                    	2022-04-04 11:37:25.977	info	2/ on_pong: ++ pong'ed ++
                    smartgarden.0
                    	2022-04-04 11:34:05.963	info	2/ on_pong: ++ pong'ed ++
                    smartgarden.0
                    	2022-04-04 11:30:45.959	info	2/ on_pong: ++ pong'ed ++
                    smartgarden.0
                    	2022-04-04 11:27:25.949	info	2/ on_pong: ++ pong'ed ++
                    2022-04-04 12_34_54-instances - NUC(SmartHome2).png 2022-04-04 12_34_13-instances - NUC(SmartHome2).png
                      Pino72 @Pino72 last edited by Pino72
                      Ich denke es hat sich erledigt, hatte den Ping auf 200 statt 150 Sekunden gesetzt...jetzt mit 150 Sekunden scheint es durch zu laufen.
                      jpgorganizer P 2 Replies Last reply Reply Quote 0
                      • jpgorganizer
                        jpgorganizer @Pino72 last edited by jpgorganizer
                        @pino72 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                        hätte ich jetzt nicht erwartet. Hab gerade nochmals nachgesehen. Gardena empfiehlt zwar 150 sec, aber das Maximum liegt bei 300 sec. Somit sollte es mit 200 sec eigentlich funktionieren. Aber man weiß ja nie.
                        • premo
                          premo last edited by
                          Hallo
                          Habe in den letzten Jahren den Gardena Adapter ohne Probleme am Laufen.
                          Leider funktioniert dieser nicht mehr.
                          Nun habe ich mal den SmartGarden Adapter installiert.
                          Mit diesem Adapter komme ich nicht zurecht.
                          Auf der Husqvarna Seite bekomme ich folgenden Fehler angezeigt.
                          Soll ja heißen das Wartungsarbeiten im Developer Portal vorübergehend deaktiviert ist.
                          • jpgorganizer
                            jpgorganizer @premo last edited by
                            @premo
                            und was verstehst du da jetzt nicht?
                            Steht doch alles da. Augenblicklich kannst du dich nicht registrieren.
                            premo 1 Reply Last reply Reply Quote 0
                            • premo
                              premo @jpgorganizer last edited by
                              @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                              Danke für die Antwort.
                              Habe gerade nochmal probiert und jetzt geht es.
                              • premo
                                Hallo
                                Habe jetzt einen API Key bekommen und eingetragen. Leider wird der smartGarden
                                Adapter nur in Gelb angezeigt.
                                Log Ausgabe wird so ausgegeben.
                                2022-04-08 10:57:17.076  - info: smartgarden.0 (5116) starting. Version 1.0.5 in C:/Program Files/iobroker/IOBroker/node_modules/iobroker.smartgarden, node: v14.18.1
                                2022-04-08 10:57:17.128  - info: smartgarden.0 (5116) 3/ getConnection...
                                2022-04-08 10:57:17.129  - info: smartgarden.0 (5116) 3/ connectToGardena...
                                2022-04-08 10:57:17.132  - info: smartgarden.0 (5116) 3/ sgSetState: info.connection value=false ack=true
                                2022-04-08 10:57:17.134  - info: smartgarden.0 (5116) 3/ connecting to Gardena Smart System Service ...
                                2022-04-08 10:57:17.134  - info: smartgarden.0 (5116) 3/ Gardena Smart System Service hosts at: smart_host: https://smart.gardena.com authentication_host: https://ssp.dss.husqvarnagroup.com
                                2022-04-08 10:57:17.221  - info: smartgarden.0 (5116) 3/ sgSetState: info.revision value=Main: 2495 / API: 2506 ack=true
                                2022-04-08 10:57:17.232  - info: smartgarden.0 (5116) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                                2022-04-08 10:57:17.236  - info: smartgarden.0 (5116) 3/ ---> State change by device: state sg.0.info.revision changed: Main: 2495 / API: 2506 (ack = true)
                                2022-04-08 10:57:17.237  - info: smartgarden.0 (5116) 3/ ---> State change by device: state sg.0.info.adapterversion changed: 1.0.5 (ack = true)
                                2022-04-08 10:57:17.332  - info: smartgarden.0 (5116) 3/ sgSetState: info.connection value=false ack=true
                                2022-04-08 10:57:17.333  - info: smartgarden.0 (5116) 3/ Connection failure.response.statusCode/Message=403/Forbidden
                                2022-04-08 10:57:17.334  - info: smartgarden.0 (5116) 3/ Connection failure:..return with error
                                2022-04-08 10:57:17.334  - error: smartgarden.0 (5116) Error: request returned 403 Forbidden
                                2022-04-08 10:57:17.335  - info: smartgarden.0 (5116) 3/ sgSetState: info.connection value=false ack=true
                                2022-04-08 10:57:17.336  - info: smartgarden.0 (5116) 3/ getConnection: returned connection error: request returned 403 Forbidden
                                2022-04-08 10:57:17.336  - info: smartgarden.0 (5116) 3/ getConnection: trying to connect again in 300 seconds
                                2022-04-08 10:57:17.344  - info: smartgarden.0 (5116) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                                2022-04-08 10:57:17.345  - info: smartgarden.0 (5116) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                                • jpgorganizer
                                  jpgorganizer @premo last edited by jpgorganizer
                                  @premo sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                  dein Account sagt " du kommst hier nicht rein " 🙂
                                  Passwort, Username, API Key kontrollieren
                                  API's verknüpft?
                                  Und was ist das?
                                  Der Default sieht mal anders aus
                                  Authentication host URL; default: https://api.authentication.husqvarnagroup.dev
                                  • premo
                                    Danke für die bisherige Hilfe.
                                    Passen alle soweit
                                    API's verknüpft?
                                    GARDENA smart system API ist verknüpft
                                    Und was ist das?
                                    Habe so im Adapter stehen lassen.
                                    Neuer Log :
                                    2022-04-08 17:27:39.139  - info: smartgarden.0 (6652) Got terminate signal TERMINATE_YOURSELF
                                    2022-04-08 17:27:39.141  - info: smartgarden.0 (6652) 3/ cleaned everything up...
                                    2022-04-08 17:27:39.141  - info: smartgarden.0 (6652) terminating
                                    2022-04-08 17:27:39.142  - info: smartgarden.0 (6652) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2022-04-08 17:27:39.720  - info: host.DESKTOP-VCLNP9G(IOBroker) instance system.adapter.smartgarden.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                                    2022-04-08 17:27:41.665  - info: host.DESKTOP-VCLNP9G(IOBroker) instance system.adapter.smartgarden.0 started with pid 11592
                                    2022-04-08 17:27:43.593  - info: smartgarden.0 (11592) starting. Version 1.0.5 in C:/Program Files/iobroker/IOBroker/node_modules/iobroker.smartgarden, node: v14.18.1
                                    2022-04-08 17:27:43.626  - info: smartgarden.0 (11592) 3/ getConnection...
                                    2022-04-08 17:27:43.627  - info: smartgarden.0 (11592) 3/ connectToGardena...
                                    2022-04-08 17:27:43.630  - info: smartgarden.0 (11592) 3/ sgSetState: info.connection value=false ack=true
                                    2022-04-08 17:27:43.632  - info: smartgarden.0 (11592) 3/ connecting to Gardena Smart System Service ...
                                    2022-04-08 17:27:43.633  - info: smartgarden.0 (11592) 3/ Gardena Smart System Service hosts at: smart_host: https://smart.gardena.com authentication_host: https://api.authentication.husqvarnagroup.dev
                                    2022-04-08 17:27:43.713  - info: smartgarden.0 (11592) 3/ sgSetState: info.revision value=Main: 2495 / API: 2506 ack=true
                                    2022-04-08 17:27:43.720  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                                    2022-04-08 17:27:43.726  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.revision changed: Main: 2495 / API: 2506 (ack = true)
                                    2022-04-08 17:27:43.727  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.adapterversion changed: 1.0.5 (ack = true)
                                    2022-04-08 17:27:44.062  - info: smartgarden.0 (11592) 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
                                    2022-04-08 17:27:44.062  - info: smartgarden.0 (11592) 3/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
                                    2022-04-08 17:27:44.063  - info: smartgarden.0 (11592) 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXX-XXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                                    2022-04-08 17:27:44.064  - info: smartgarden.0 (11592) 3/ get_locations ...
                                    2022-04-08 17:27:44.271  - info: smartgarden.0 (11592) 3/ sgSetState: info.connection value=false ack=true
                                    2022-04-08 17:27:44.272  - info: smartgarden.0 (11592) 3/ get_locations failure: response.statusCode/Message=400/Bad Request
                                    2022-04-08 17:27:44.272  - info: smartgarden.0 (11592) 3/ get_locations failure:..return with error
                                    2022-04-08 17:27:44.273  - error: smartgarden.0 (11592) Error: request returned 400 Bad Request
                                    2022-04-08 17:27:44.273  - info: smartgarden.0 (11592) 3/ sgSetState: info.connection value=false ack=true
                                    2022-04-08 17:27:44.273  - info: smartgarden.0 (11592) 3/ getConnection: returned connection error: request returned 400 Bad Request
                                    2022-04-08 17:27:44.274  - info: smartgarden.0 (11592) 3/ getConnection: trying to connect again in 300 seconds
                                    2022-04-08 17:27:44.372  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                                    2022-04-08 17:27:44.374  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                                    • jpgorganizer
                                      vergleich mal deine Eingaben der Webadressen mit den Angaben in der Doku
                                      • premo
                                        Danke, jetzt läuft es .
                                          @pino72 said in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                          Hab mich zu früh gefreut, seit gestern wieder die regelmäßigen Abbrüche wie vorher, Ping ist auf 150. Hab es jetzt mal auf 100 gesetzt mal sehen ob das was ändert.
                                          Scheint ja irgendwie noch nicht klar warum Gardena die Verbindung einfach so trennt ohne ersichtlichen Grund.
                                            berndpehome last edited by
                                            Bei mir auch Gelb, Ping auf 200 brachte gestern Grün und Heute wieder Gelb.
                                            Letztes Jahr lief der Adapter ohne Probleme
                                            gardena smart system smartgarden
                                            108
                                            1080
                                            282825
