    4. Adapter für Buderus KM200 (und eventuell auch anderen KMxxx)
      mwolle @tp1de last edited by
      @tp1de sieht eigentlich vernünftig aus:
        "common": {
          "name": "heatingCircuits.hc2.activeSwitchProgram",
          "read": true,
          "write": true,
          "state": "state",
          "role": "level",
          "type": "number",
          "unit": "",
          "states": "0:A;1:B;2:C;3:D;4:E;5:F",
          "min": 0,
          "max": 5
        "type": "state",
        "_id": "km200.0.heatingCircuits.hc2.activeSwitchProgram",
        "native": {
          "km200": {
            "id": "/heatingCircuits/hc2/activeSwitchProgram",
            "type": "stringValue",
            "writeable": 1,
            "recordable": 1,
            "value": "F",
            "allowedValues": [
              "A",
              "B",
              "C",
              "D",
              "E",
              "F"
            "valIs": "states"
        "from": "system.adapter.km200.0",
        "user": "system.user.admin",
        "ts": 1646935809160,
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
      Dein EMS Adapter sagt:
        "type": "state",
        "id": "heatingCircuits.hc2.activeSwitchProgram",
        "common": {
          "name": "km200:heatingCircuits.hc2.activeSwitchProgram",
          "type": "number",
          "unit": "",
          "read": true,
          "write": true,
          "role": "level",
          "min": 0,
          "max": 5
        "native": {
          "km200": {
            "writeable": 1,
            "recordable": 1,
            "value": "D",
            "allowedValues": [
              "A",
              "B",
              "C",
              "D",
              "E",
              "F"
            "valIs": "states"
          "ems_km200": "heatingCircuits.hc2.activeSwitchProgram"
        "_id": "ems-esp.0.heatingCircuits.hc2.activeSwitchProgram",
        "from": "system.adapter.ems-esp.0",
        "ts": 1645340442038,
        "acl": {
          "object": 1636,
          "state": 1636,
      Dennoch
      km200.0
      2022-04-04 20:26:47.780	info	Could not find state for heatingCircuits.hc2.activeSwitchProgram
      km200.0
      2022-04-04 20:26:45.770	info	Set km200.0.heatingCircuits.hc2.activeSwitchProgram to 3
        tp1de @mwolle last edited by
        @mwolle wenn die States neu angelegt wurden und das Schreiben nicht geht, dann ist das ein Fehler im Gateway.
          @tp1de danke für den Tipp, Neu angelegt, ich habe den mal gelöscht und neu anlegen lassen...nun geht es wieder...verrückt.
            @mwolle ne nicht verrückt... nach meiner Erfahrung notwendig nach Firmware Updates.
              mwolle @tp1de last edited by mwolle
              @tp1de : Anbei mal meine Config um die Statistiken zu bekommen mit dem KM200:
              Im EMS-ESP:
              Protokoll:
              ems-esp.0
              2022-04-06 21:49:27.115	error	error read efficiency:TypeError: Cannot read property 'val' of null
              sql.0
              2022-04-06 21:49:27.114	info	No Data
              sql.0
              2022-04-06 21:49:27.111	info	No Data
              sql.0
              2022-04-06 21:49:27.109	info	No Data
              Ich würde das tatsächlich gerne komplett zum Laufen bekommen.
                @mwolle
                So wie es aussieht benutzt Du nicht die letzte Version 1.4.0. Dann sollte die States-Struktur so aussehen:
                Aber unabhängig davon, sollten mySQL-Datensätze im dem _Months, _Days, _Hours States da sein. Die könntest Du mit Flot oder Grafana darstellen. Überprüfe mal die Monatswerte _Months in den benutzerdefinierten Einstellungen im Objekt-Browser .
                Das sollte dann so aussehen:
                  @tp1de also die 1.4.0 Version ist installiert und ich habe auch die gleiche State Struktur wie du. Ich glaube was mir noch fehlt, welche Werte müssen in die SQL DB rein, damit die Berechnung klappt. Sind das die km200 recordings (die allesamt in die SQL DB müssen)? Oder welche müssen in der SQL Datenbank historisiert werden?
                  Die Statistics über Brennerstarts etc. läuft wie? Da habe ich auch nur 0 Werte.
                    tp1de @mwolle last edited by tp1de
                    @mwolle
                    wir sollten die Diskussion im ems-esp Forum weiterführen:
                    https://forum.iobroker.net/topic/45862/neuer-adapter-ems-esp-für-bosch-heizungen/180?_=1649329552411
                    Torsten Schwaar 1 Reply Last reply Reply Quote 0
                    • Torsten Schwaar
                      Torsten Schwaar @tp1de last edited by
                      Hallo Kann mir jemand sagen wie ich im blockly dem Wert "km200.0.heatingCircuits.hc1.temporaryRoomSetpoint" den Wert 0,-1 oder off setzen kann?
                      bei den Zahlen 0 und -1 wird der Wert 5 gesetzt, bei "off" als string bekomme ich auch einen Fehler:
                        tp1de @Torsten Schwaar last edited by
                        @torsten-schwaar sagte in Adapter für Buderus KM200 (und eventuell auch anderen KMxxx):
                        Ändere den erlaubten Minimalwert des States auf -1.
                        • Torsten Schwaar
                          @tp1de
                          Das Problem ist wenn der adapter neu Startet ist der Wert auch zurück gesetzt. Wenn ich den Wert in Objekte auf -1 setzte steht sofort "off" da. Wird das selbe im Skript gemacht kommt ein Fehler....
                            @torsten-schwaar und du hast im common Bereich des States min: auf -1 gesetzt?
                            • Torsten Schwaar
                              @tp1de im common würde ich gerne die 5 drin stehen lassen. Weil wenn ich den Adapter neu starte wieder 5 drin steht. Drehe ich an der Heizung am Rad auf "off" steht im Iobroker eine -1 drin. Also muss doch die -1 erlaubt sein. Ich bekomme Sie nur nicht per skript rein...
                                @torsten-schwaar genau im Script wird auf den Wertebereich geprüft. Das ist einer der Gründe warum ich den km200-Adapter nicht mehr verwende. Kannst ja meinen ems-esp Adapter mal probieren ...
                                Torsten Schwaar 2 Replies Last reply Reply Quote 1
                                • Torsten Schwaar
                                  @tp1de Danke! probiere ich.
                                  Omnedon 1 Reply Last reply Reply Quote 0
                                  • Omnedon
                                    Omnedon @Torsten Schwaar last edited by
                                    @frankjoke
                                    wie sieht es mit der Kompatibilität mit js-controller 4 aus?
                                    Ist das geplant?
                                    Zur Zeit ist das Issue auf Github noch offen.
                                    Viele Grüße
                                    • Torsten Schwaar
                                      @tp1de Vielen Dank für den Tip, sieht so aus als ob es jetzt geht.
                                        Ja ich setzte im Adapter für diese States den Minimalwert auf -1 !
                                        Ich musste im ems-esp Adapter Einiges anpassen für den js-contoller 4.x, da nun Wertebereiche strikt geprüft werden.
                                        Diese Anpassungen sind z.T. für den km200 Adapter noch offen.
                                          Henry 1 @Bostil last edited by Henry 1
                                          @bostil
                                          Hast du das mit dem Extrawasser hinbekommen?
                                          Ich sitzte momentan genau an der gleichen Stelle
                                            Rosi8818 last edited by Rosi8818
                                            ich habe jetzt auch endlich meine neue Bosch Heizung Cerapur_ZSB_14-5.2c mit dem MB LAN 2 und dem Adapter zum laufen gebracht.
                                            War super leicht einzurichten, vorab über EasyRemote von Bosch Zugang geholt und persönliches Passwort festgelet. Danach ging es erst im Adapter.
                                            Etwas Geduld und der Erfolg war sichtbar 🙂
                                            Warum ich das hier vorab schreibe, damit es in der Suche gefunden wird, ich tat mich echt schwer damit etwas passendes zu finden.
                                            Jetzt zur eigentlichen Frage:
                                            Ein wenig tu ich mich schwer mit den Objektbaum, gibt es da eine Art Aufstellung/ Übersetzung wofür was ist?
                                            Bspw.
                                            • würde ich gerne wie andere Punkte schon im Einsatz sind mit SourceAnaltytix den Verbrauch messen (ich hab Grafana und influxdb im Einsatz)
                                            • Verlauf wann das Warmwasser aufheizt und wie lange
                                            • Verlauf wann die Heizung aufheizt und wie lange
                                            • Heizung von Nachtmodus/ Nachtabsenkung auf Dauer einschalten (bspw. bei Besuch der länger bleibt)
                                            • Heizung manuell ein/ aus
                                            hat da jemand eine Idee?
                                            Ralf
                                            686
                                            185913
