    4. Test Adapter hekr wisen elro App v0.0.x
      biker1602 last edited by biker1602
      @lucky_esa
      Ich habe jetzt alle Drei Varianten mit 1, 10, und 11 versucht aber keine funktioniert. Adapter habe ich nach jeder Änderung neu gestartet.
      Wenn ich das RGB Licht mit dem Smartphone anschalte, dann spingt bei RGB_Sw die Zahl von 0 auf 1 und da unter Statue von 1 auf 2.
      Wenn ich ausschalte dann springt RGB_Sw von 1 auf 0 und Statue von 2 auf 1
        SpacerX last edited by
        Ich hab seit neuestem folgende Debugmeldungen vom Adapter.
        2022-03-17 00:00:53.070 - debug: hekr.0 (24693) WS received:{"msgId":206152,"action":"devSend","params":{"devTid":"ESP_2M_8CCE4ED63F3B","appTid":[],"subDevTid":null,"ctrlKey":"3deccd8e236d40d6a8eab99174aa7084","data":{"cleaning":0,"B":0,"RGB_Sw":0,"sw":0,"G":0,"raw":"481101E701000000000000000000000042","light_Sw":0,"speed":0,"tm_Minutes":0,"R":0,"cmdId":1,"Statue":0,"fitter":0}}}
        2022-03-17 00:00:53.071 - error: hekr.0 (24693) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2022-03-17 00:00:53.071 - error: hekr.0 (24693) unhandled promise rejection: Bad number
        2022-03-17 00:00:53.071 - error: hekr.0 (24693) Bad number
        2022-03-17 00:00:53.122 - info: hekr.0 (24693) terminating
        2022-03-17 00:00:53.122 - debug: hekr.0 (24693) Plugin sentry destroyed
        2022-03-17 00:00:53.123 - warn: hekr.0 (24693) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2022-03-17 00:00:53.645 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2022-03-17 00:00:53.647 - error: host.ioBroker Caught by controller[1]: {
        2022-03-17 00:00:53.647 - error: host.ioBroker Caught by controller[1]: name: 'SyntaxError',
        2022-03-17 00:00:53.648 - error: host.ioBroker Caught by controller[1]: message: 'Bad number',
        2022-03-17 00:00:53.648 - error: host.ioBroker Caught by controller[1]: at: 35,
        2022-03-17 00:00:53.648 - error: host.ioBroker Caught by controller[1]: text: '481101E701000000000000000000000042'
        2022-03-17 00:00:53.648 - error: host.ioBroker Caught by controller[1]: }
        2022-03-17 00:00:53.648 - error: host.ioBroker instance system.adapter.hekr.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2022-03-17 00:00:53.648 - info: host.ioBroker Restart adapter system.adapter.hekr.0 because enabled
        2022-03-17 00:00:53.648 - warn: host.ioBroker Do not restart adapter system.adapter.hekr.0 because restart loop detected
        PlatformBetriebssystem:linux
        Architektur:x64
        CPUs:2
        Geschwindigkeit:3000 MHz
        Modell:Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
        RAM:7.4 GB
        System-Betriebszeit:38 T. 18:43:31
        Node.js:v14.19.0
        time:1647542366613
        timeOffset:-60
        Adapter-Anzahl:401
        NPM:6.14.16
        Datenträgergröße:31.2 GB
        freier Festplattenspeicher:27.9 GB
        Betriebszeit:1 T. 23:32:51
        Aktive Instanzen:13
        Pfad:/opt/iobroker/
        Jemand eine Idee?
        MfG Ralf
          Lucky_ESA Developer Most Active last edited by
          Irgenwoher kenne ich diesen Fehler und ich bin der Meinung, dass ich diesen bei mir behoben habe...Wenn du mal Zeit hast würde ich dir gerne meine Dateien geben. Kannst dich ja per Chat melden.
            SpacerX @Lucky_ESA last edited by
            @lucky_esa
            Wenn du den Fehler auch schon hattest, warum dann nicht einfach eine neue Version auf github.
            Dann bin ich bestimmt nicht der einzigste den das betrifft.
            Ich wollte ja auch schon länger mal weiter sniffen. Sorry @Lucky_ESA ich weis im Moment einfach nicht was ich zu erst machen soll.
            MfG Ralf
              Werde tombox fragen ob er die Änderungen übernimmt. Es wäre dann ein neuer Datenpunkt vorhanden in dem man selber den Raw probieren kann.
              Eine Frage noch...Welche Datenpunkte funktionieren überhaupt bei dir?
              light_Sw
              speed
              sw
              tm_Minutes
              Gruß//Lucky
                @lucky_esa
                Das kann ich die Tage mal Durchtesten.
                Bin bis Montag nicht Daheim.
                  SpacerX @SpacerX last edited by
                  Habe gerade getestet. Es funktionieren folgende Datenpunkte:
                  sw = 1 und 0 funktioniert
                  speed = 0, 1, 2 ,3 funktioniert
                  lightSw = 1 und 0 funktioniert
                  tm_Minutes = 1 funktioniert, schaltet nach einer Minute ab.
                  RGB_Sw = 1 funktioniert nicht, wird aber beim Schalten über die App richtig gesetzt. Zusätzlich wird beim RGB_Sw auf 1 schalten mit der App noch der Datenpunkt Statue auf 2 gesetzt. Beim ausschalten der Hg-Beleuchtung über App, wird korrekt RGB_Sw wieder auf 0 gesetzt und Statue wieder auf 1.
                  Die Farbwerte R, G, B und rgb werden nicht richtig gesetzt und lassen sich auch nicht steuern.
                  MfG Ralf
                    Hallo SpacerX,
                    danke für die Info.
                    Gruß//Lucky
                      biker1602 @Lucky_ESA last edited by
                      @lucky_esa
                      Ist bei euch die App seit heute auch tot? Keine Registrierung und Dunstabzugshaube auch aus WLAN herausgeworfen.
                      Wieso geht eigentlich die KKT Kolbe App nicht?
                        Fam3xCE last edited by
                        bei mir hat alles soweit funktioniert, nur werden bei mir die Datenpunkte .SW etc. unter Status nicht angezeigt. Bei mir gibt es nur die Punkte status.raw_manually, status.time und status.rgb angezeigt.
                        Woran könnte das liegen? Habe eine Abzugshaube von KKT im einsatz und über die APP geht alles.
                        Danke schon mal im Voraus.
                        Christian
                          SpacerX @biker1602 last edited by
                          @biker1602
                          Nö nichts Auffälliges. Alles so wie immer. Wisen App kann auch auf das Gerät zugreifen.
                            Lucky_ESA Developer Most Active last edited by Lucky_ESA
                            Hallo ihr drei,
                            hatte auch gerade Probleme mit der APP. Jetzt scheint es wieder zu funktionieren.
                            @Fam3xCE Wahrscheinlich hatte HEKR ein Problem mit dem Server. Einchfach den Adapter neu starten.
                            Der neu Datenpunkt raw_manually ist für euch zum testen, welcher RAW versendet werden muss. Genaue Anleitung poste ich hier zeitnah.
                            Gruß//Lucky
                              So, jetzt versuche ich mal mein Glück. Ihr gehört zu den glücklichen die die Strahler und das RGB Licht getrennt schalten könnt. Natürlich kenne ich meinen RAW aber ich kann leider nur alles zusammen einschalten. Folglich muss euer RAW ein anderer sein und nun müssen wir leider raten, wie dieser aussehen könnte (oder ihr sniffert).
                              Zu der Nummerierung aller Schalter:
                              sw: 2
                              light_Sw: 3
                              speed: 4
                              tm_Minutes: 5
                              cleaning: 6
                              R: 7
                              B: 7
                              G: 7
                              time: 8
                              RGB_Sw: 9 -> Das könnte auch 1 oder 10 sein
                              Nun zu meinen RAW für das ändern von Farben.
                              480902000700c3ff00
                              48 -> Vorgabe KKT Kolbe
                              09 -> Hex Länge
                              02 -> Einzelner Befehl könnte allerdings bei euch 03 sein
                              6c -> Fortlaufender Counter kann 00 bleiben
                              07 -> Schalter für RGB (siehe oben)
                              00c3ff -> RGB Hex
                              88 -> Fortlaufender Counter kann 00 bleiben
                              Laut eurem Template wird das Einschalten in der APP so übergeben.
                              cmdTag: "set_Rgbw",
                              R: 255,
                              G: 255,
                              B: 255,
                              RGB_Sw: 1
                              Bei mir so:
                              cmdTag: "set_Rgbw",
                              R: 255,
                              G: 255,
                              B: 255
                              Folglich gehe ich davon aus, dass das 01 für ON hinter dem RGB HEX kommt. Nun gilt es zu klären, ob auch die Nummerierung mitgesendet werden muss.
                              Ihr könnt nun mal probieren.
                              481002000700c3ff0100 ->Piepst es dann?
                              Oder:
                              48100200070100c3ff00
                              Oder mit Nummer:
                              481102000700c3ff090100 ->Piepst es dann?
                              48110200070900c3ff0100 ->Piepst es dann?
                              4811020007090100c3ff00 ->Piepst es dann?
                              4811020009010700c3ff00 ->Piepst es dann?
                              Oder statt der 09 eine 01 oder 0A...
                              Da zwei Befehle gesendet werden kann es auch so anfangen.
                              481003
                              481103 -> Mit Nummerierung
                              Versucht es mal...Viel Spaß beim testen:-)
                              Gruß//Lucky
                                Fam3xCE @Lucky_ESA last edited by
                                @lucky_esa Danke für deine Antwort,
                                leider hat das aber nichts geändert und die Datenpunkte werden mir weiterhin nicht angezeigt.
                                Christian
                                  Dann bitte bei dem Adapter den Debug Modus unter Instanzen aktivieren und das Resultat mir per Chat zusenden.
                                  Gruß//Lucky
                                    der_timo @Lucky_ESA last edited by
                                    der Adapter läuft bei mir bisher echt gut.
                                    Was passiert denn aber, wenn hekr / wisen den online Service abschaltet? Läuft der Adapter komplett lokal?
                                    Weil so eine Dunstabzugshaube kauft man ja auch nicht jeden Tag.
                                    Besten Dank für die tolle Arbeit!
                                    Timo
                                      Hallo der_timo,
                                      sollte der Service eingestellt werden kann man im Adapter die Abfragen deaktivieren. Aber dann kann man nur noch schalten und bekommt eine Infos mehr. Das der Service eingestellt wird kann ich mir nicht vorstellen. Es gibt ja noch die KKT Kolbe APP...
                                      Gruß//Lucky
                                        @lucky_esa said in Test Adapter hekr wisen elro App v0.0.x:
                                        Leider wird unter der die Dunstabzugshaube nicht gefunden. Ich verstehe nicht das die mit der KKT Kolbe App nicht kompatibel ist.
                                          Die APP hatte ich nie ausprobiert da ich Angst hatte nicht mehr zurück auf die Wisen APP zu kommen. Aber gut zu wissen das es mit der APP nicht funktioniert...
                                          Gruß//Lucky
                                            torroHome @Lucky_ESA last edited by torroHome
                                            @lucky_esa
                                            Ich habe inzwischen auch eine Kolbe Abzugshaube und habe alles ausprobiert.
                                            Mein RAW sieht erst einmal so aus
                                            4811020007090000ff010000FF2A01001E ->piepst und RGB ist #0000ff also blau
                                            48110200070900ff00010000FF2A01001E ->piepst und RGB ist #00ff00 also grün
                                            481102000709ff0000010000FF2A01001E ->piepst und RGB ist #ff0000 also rot
                                            481102000709000000010000FF2A01001E ->piepst und RGB ist #000000 RGB aus
                                            D.h., der raw sieht definitiv anders aus. Ich habe versucht nach Deiner Vorgabe das einzuordnen.
                                            11 -> Hex Länge
                                            02 -> ist bei mir immer 02
                                            00 -> Fortlaufender Counter kann 00 bleiben
                                            09-> keine Ahnung was das ist, wird aber benötigt
                                            00c3ff -> RGB Hex
                                            010000FF2A01001E->keine Ahnung was das ist, wird aber so benötigt
                                            Jetzt muss ich den Templates das versuchen zu ändern, damit ich den Befehl ein/aus mit RGB Werten über den RGB_Sw steuern kann. Richtig?
                                            31.7k
                                            79.8k
                                            106
                                            7532
