    4. [neuer Adapter] smartgarden adapter for Gardena smart system
      Pino72 @jpgorganizer last edited by Pino72
      Hallo Zusammen,
      hatte das ganze letzte Jahr den Adapter ganz gut am Laufen, bis auf die ca alle 3 Monate nervige Key Änderung. (Ist das jetzt gelöst?)
      Aktuell hab ich allerdings seltsame Probleme, der Adapter läuft ganz normal an:
      smartgarden.0
      	2022-04-04 09:49:35.827	info	2/ parseMessage: COMMON found
      smartgarden.0
      	2022-04-04 09:49:35.797	info	2/ parseMessage: MOWER found
      smartgarden.0
      	2022-04-04 09:49:35.763	info	2/ parseMessage: COMMON found
      smartgarden.0
      	2022-04-04 09:49:35.746	info	2/ parseMessage: SENSOR found
      smartgarden.0
      	2022-04-04 09:49:35.716	info	2/ parseMessage: COMMON found
      smartgarden.0
      	2022-04-04 09:49:35.703	info	2/ parseMessage: SENSOR found
      smartgarden.0
      	2022-04-04 09:49:35.699	info	2/ parseMessage: DEVICE found
      smartgarden.0
      	2022-04-04 09:49:35.693	info	2/ parseMessage: DEVICE found
      smartgarden.0
      	2022-04-04 09:49:35.687	info	2/ parseMessage: DEVICE found
      smartgarden.0
      	2022-04-04 09:49:35.680	info	2/ parseMessage: LOCATION found
      smartgarden.0
      	2022-04-04 09:49:35.344	info	2/ on_open: ### connected ###
      smartgarden.0
      	2022-04-04 09:49:35.132	info	2/ get_websocket ... websocket ok
      smartgarden.0
      	2022-04-04 09:49:35.121	info	2/ get_websocket successful: response.statusCode/Message=201/Created
      smartgarden.0
      	2022-04-04 09:49:35.011	info	2/ get_websocket ...
      smartgarden.0
      	2022-04-04 09:49:35.010	info	2/ get_locations ... locations={"data":[{"id":"b86717d4-8633-4241-9686-e64473790757","type":"LOCATION","attributes":{"name":"My Garden"}}]}
      smartgarden.0
      	2022-04-04 09:49:35.009	info	2/ get_locations: successful / response.statusMessage: OK
      smartgarden.0
      	2022-04-04 09:49:34.792	info	2/ get_locations ...
      smartgarden.0
      	2022-04-04 09:49:34.790	info	2/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
      smartgarden.0
      	2022-04-04 09:49:34.788	info	2/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
      smartgarden.0
      	2022-04-04 09:49:34.788	info	2/ Connection: successful: response.statusCode / statusMessage=200 / OK
      smartgarden.0
      	2022-04-04 09:49:34.291	info	2/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
      smartgarden.0
      	2022-04-04 09:49:34.290	info	2/ connecting to Gardena Smart System Service ...
      smartgarden.0
      	2022-04-04 09:49:34.288	info	2/ connectToGardena...
      smartgarden.0
      	2022-04-04 09:49:34.286	info	2/ getConnection...
      smartgarden.0
      	2022-04-04 09:49:34.204	info	starting. Version 1.0.5 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.smartgarden, node: v14.18.0, js-controller: 4.0.21
      smartgarden.0
      	2022-04-04 09:49:33.762	debug	States connected to redis: 127.0.0.1:9010
      smartgarden.0
      	2022-04-04 09:49:33.703	debug	States create User PubSub Client
      smartgarden.0
      	2022-04-04 09:49:33.702	debug	States create System PubSub Client
      smartgarden.0
      	2022-04-04 09:49:33.664	debug	Redis States: Use Redis connection: 127.0.0.1:9010
      smartgarden.0
      	2022-04-04 09:49:33.599	debug	Objects connected to redis: 127.0.0.1:9011
      smartgarden.0
      	2022-04-04 09:49:33.581	debug	Objects client initialize lua scripts
      smartgarden.0
      	2022-04-04 09:49:33.452	debug	Objects create User PubSub Client
      smartgarden.0
      	2022-04-04 09:49:33.450	debug	Objects create System PubSub Client
      smartgarden.0
      	2022-04-04 09:49:33.447	debug	Objects client ready ... initialize now
      smartgarden.0
      	2022-04-04 09:49:33.321	debug	Redis Objects: Use Redis connection: 127.0.0.1:9011
      smartgarden.0
      	2022-04-04 09:49:23.184	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      smartgarden.0
      	2022-04-04 09:49:23.182	info	terminating
      smartgarden.0
      	2022-04-04 09:49:23.181	info	3/ cleaned everything up...
      smartgarden.0
      	2022-04-04 09:49:23.152	info	Got terminate signal TERMINATE_YOURSELF
      Aber nach wenigen Stunden trennt er sich von selber, warum?:
      smartgarden.0
      	2022-04-04 12:04:05.516	info	2/ on_close: ### closed ### close.code=1001 close.reason=Going away
      smartgarden.0
      	2022-04-04 12:00:46.038	info	2/ on_pong: ++ pong'ed ++
      smartgarden.0
      	2022-04-04 11:57:26.034	info	2/ on_pong: ++ pong'ed ++
      smartgarden.0
      	2022-04-04 11:54:06.031	info	2/ on_pong: ++ pong'ed ++
      smartgarden.0
      	2022-04-04 11:50:46.019	info	2/ on_pong: ++ pong'ed ++
      smartgarden.0
      	2022-04-04 11:50:38.102	info	2/ setServiceStates: relationship searching
      smartgarden.0
      	2022-04-04 11:50:38.101	info	2/ parseMessage: COMMON found
      smartgarden.0
      	2022-04-04 11:50:38.088	info	2/ setServiceStates: relationship searching
      smartgarden.0
      	2022-04-04 11:50:38.088	info	2/ parseMessage: MOWER found
      smartgarden.0
      	2022-04-04 11:47:26.007	info	2/ on_pong: ++ pong'ed ++
      smartgarden.0
      	2022-04-04 11:44:05.983	info	2/ on_pong: ++ pong'ed ++
      smartgarden.0
      	2022-04-04 11:40:45.977	info	2/ on_pong: ++ pong'ed ++
      smartgarden.0
      	2022-04-04 11:37:25.977	info	2/ on_pong: ++ pong'ed ++
      smartgarden.0
      	2022-04-04 11:34:05.963	info	2/ on_pong: ++ pong'ed ++
      smartgarden.0
      	2022-04-04 11:30:45.959	info	2/ on_pong: ++ pong'ed ++
      smartgarden.0
      	2022-04-04 11:27:25.949	info	2/ on_pong: ++ pong'ed ++
      2022-04-04 12_34_54-instances - NUC(SmartHome2).png 2022-04-04 12_34_13-instances - NUC(SmartHome2).png
        Pino72 @Pino72 last edited by Pino72
        Ich denke es hat sich erledigt, hatte den Ping auf 200 statt 150 Sekunden gesetzt...jetzt mit 150 Sekunden scheint es durch zu laufen.
        jpgorganizer P 2 Replies Last reply Reply Quote 0
        • jpgorganizer
          jpgorganizer @Pino72 last edited by jpgorganizer
          @pino72 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
          hätte ich jetzt nicht erwartet. Hab gerade nochmals nachgesehen. Gardena empfiehlt zwar 150 sec, aber das Maximum liegt bei 300 sec. Somit sollte es mit 200 sec eigentlich funktionieren. Aber man weiß ja nie.
          • premo
            premo last edited by
            Hallo
            Habe in den letzten Jahren den Gardena Adapter ohne Probleme am Laufen.
            Leider funktioniert dieser nicht mehr.
            Nun habe ich mal den SmartGarden Adapter installiert.
            Mit diesem Adapter komme ich nicht zurecht.
            Auf der Husqvarna Seite bekomme ich folgenden Fehler angezeigt.
            Soll ja heißen das Wartungsarbeiten im Developer Portal vorübergehend deaktiviert ist.
            jpgorganizer 1 Reply Last reply Reply Quote 0
            • jpgorganizer
              jpgorganizer @premo last edited by
              @premo
              und was verstehst du da jetzt nicht?
              Steht doch alles da. Augenblicklich kannst du dich nicht registrieren.
              premo 1 Reply Last reply Reply Quote 0
              • premo
                premo @jpgorganizer last edited by
                @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                Danke für die Antwort.
                Habe gerade nochmal probiert und jetzt geht es.
                • premo
                  Hallo
                  Habe jetzt einen API Key bekommen und eingetragen. Leider wird der smartGarden
                  Adapter nur in Gelb angezeigt.
                  Log Ausgabe wird so ausgegeben.
                  2022-04-08 10:57:17.076  - info: smartgarden.0 (5116) starting. Version 1.0.5 in C:/Program Files/iobroker/IOBroker/node_modules/iobroker.smartgarden, node: v14.18.1
                  2022-04-08 10:57:17.128  - info: smartgarden.0 (5116) 3/ getConnection...
                  2022-04-08 10:57:17.129  - info: smartgarden.0 (5116) 3/ connectToGardena...
                  2022-04-08 10:57:17.132  - info: smartgarden.0 (5116) 3/ sgSetState: info.connection value=false ack=true
                  2022-04-08 10:57:17.134  - info: smartgarden.0 (5116) 3/ connecting to Gardena Smart System Service ...
                  2022-04-08 10:57:17.134  - info: smartgarden.0 (5116) 3/ Gardena Smart System Service hosts at: smart_host: https://smart.gardena.com authentication_host: https://ssp.dss.husqvarnagroup.com
                  2022-04-08 10:57:17.221  - info: smartgarden.0 (5116) 3/ sgSetState: info.revision value=Main: 2495 / API: 2506 ack=true
                  2022-04-08 10:57:17.232  - info: smartgarden.0 (5116) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                  2022-04-08 10:57:17.236  - info: smartgarden.0 (5116) 3/ ---> State change by device: state sg.0.info.revision changed: Main: 2495 / API: 2506 (ack = true)
                  2022-04-08 10:57:17.237  - info: smartgarden.0 (5116) 3/ ---> State change by device: state sg.0.info.adapterversion changed: 1.0.5 (ack = true)
                  2022-04-08 10:57:17.332  - info: smartgarden.0 (5116) 3/ sgSetState: info.connection value=false ack=true
                  2022-04-08 10:57:17.333  - info: smartgarden.0 (5116) 3/ Connection failure.response.statusCode/Message=403/Forbidden
                  2022-04-08 10:57:17.334  - info: smartgarden.0 (5116) 3/ Connection failure:..return with error
                  2022-04-08 10:57:17.334  - error: smartgarden.0 (5116) Error: request returned 403 Forbidden
                  2022-04-08 10:57:17.335  - info: smartgarden.0 (5116) 3/ sgSetState: info.connection value=false ack=true
                  2022-04-08 10:57:17.336  - info: smartgarden.0 (5116) 3/ getConnection: returned connection error: request returned 403 Forbidden
                  2022-04-08 10:57:17.336  - info: smartgarden.0 (5116) 3/ getConnection: trying to connect again in 300 seconds
                  2022-04-08 10:57:17.344  - info: smartgarden.0 (5116) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                  2022-04-08 10:57:17.345  - info: smartgarden.0 (5116) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                  • jpgorganizer
                    jpgorganizer @premo last edited by jpgorganizer
                    @premo sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                    dein Account sagt " du kommst hier nicht rein " 🙂
                    Passwort, Username, API Key kontrollieren
                    API's verknüpft?
                    Und was ist das?
                    Der Default sieht mal anders aus
                    Authentication host URL; default: https://api.authentication.husqvarnagroup.dev
                    • premo
                      Danke für die bisherige Hilfe.
                      Passen alle soweit
                      API's verknüpft?
                      GARDENA smart system API ist verknüpft
                      Und was ist das?
                      Habe so im Adapter stehen lassen.
                      Neuer Log :
                      2022-04-08 17:27:39.139  - info: smartgarden.0 (6652) Got terminate signal TERMINATE_YOURSELF
                      2022-04-08 17:27:39.141  - info: smartgarden.0 (6652) 3/ cleaned everything up...
                      2022-04-08 17:27:39.141  - info: smartgarden.0 (6652) terminating
                      2022-04-08 17:27:39.142  - info: smartgarden.0 (6652) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                      2022-04-08 17:27:39.720  - info: host.DESKTOP-VCLNP9G(IOBroker) instance system.adapter.smartgarden.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                      2022-04-08 17:27:41.665  - info: host.DESKTOP-VCLNP9G(IOBroker) instance system.adapter.smartgarden.0 started with pid 11592
                      2022-04-08 17:27:43.593  - info: smartgarden.0 (11592) starting. Version 1.0.5 in C:/Program Files/iobroker/IOBroker/node_modules/iobroker.smartgarden, node: v14.18.1
                      2022-04-08 17:27:43.626  - info: smartgarden.0 (11592) 3/ getConnection...
                      2022-04-08 17:27:43.627  - info: smartgarden.0 (11592) 3/ connectToGardena...
                      2022-04-08 17:27:43.630  - info: smartgarden.0 (11592) 3/ sgSetState: info.connection value=false ack=true
                      2022-04-08 17:27:43.632  - info: smartgarden.0 (11592) 3/ connecting to Gardena Smart System Service ...
                      2022-04-08 17:27:43.633  - info: smartgarden.0 (11592) 3/ Gardena Smart System Service hosts at: smart_host: https://smart.gardena.com authentication_host: https://api.authentication.husqvarnagroup.dev
                      2022-04-08 17:27:43.713  - info: smartgarden.0 (11592) 3/ sgSetState: info.revision value=Main: 2495 / API: 2506 ack=true
                      2022-04-08 17:27:43.720  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                      2022-04-08 17:27:43.726  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.revision changed: Main: 2495 / API: 2506 (ack = true)
                      2022-04-08 17:27:43.727  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.adapterversion changed: 1.0.5 (ack = true)
                      2022-04-08 17:27:44.062  - info: smartgarden.0 (11592) 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
                      2022-04-08 17:27:44.062  - info: smartgarden.0 (11592) 3/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
                      2022-04-08 17:27:44.063  - info: smartgarden.0 (11592) 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXX-XXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
                      2022-04-08 17:27:44.064  - info: smartgarden.0 (11592) 3/ get_locations ...
                      2022-04-08 17:27:44.271  - info: smartgarden.0 (11592) 3/ sgSetState: info.connection value=false ack=true
                      2022-04-08 17:27:44.272  - info: smartgarden.0 (11592) 3/ get_locations failure: response.statusCode/Message=400/Bad Request
                      2022-04-08 17:27:44.272  - info: smartgarden.0 (11592) 3/ get_locations failure:..return with error
                      2022-04-08 17:27:44.273  - error: smartgarden.0 (11592) Error: request returned 400 Bad Request
                      2022-04-08 17:27:44.273  - info: smartgarden.0 (11592) 3/ sgSetState: info.connection value=false ack=true
                      2022-04-08 17:27:44.273  - info: smartgarden.0 (11592) 3/ getConnection: returned connection error: request returned 400 Bad Request
                      2022-04-08 17:27:44.274  - info: smartgarden.0 (11592) 3/ getConnection: trying to connect again in 300 seconds
                      2022-04-08 17:27:44.372  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                      2022-04-08 17:27:44.374  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                      • jpgorganizer
                        vergleich mal deine Eingaben der Webadressen mit den Angaben in der Doku
                        • premo
                          Danke, jetzt läuft es .
                            @pino72 said in [neuer Adapter] smartgarden adapter for Gardena smart system:
                            Hab mich zu früh gefreut, seit gestern wieder die regelmäßigen Abbrüche wie vorher, Ping ist auf 150. Hab es jetzt mal auf 100 gesetzt mal sehen ob das was ändert.
                            Scheint ja irgendwie noch nicht klar warum Gardena die Verbindung einfach so trennt ohne ersichtlichen Grund.
                              berndpehome last edited by
                              Bei mir auch Gelb, Ping auf 200 brachte gestern Grün und Heute wieder Gelb.
                              Letztes Jahr lief der Adapter ohne Probleme
                              • jpgorganizer
                                jpgorganizer @berndpehome last edited by
                                Lässt sich eigentlich die Verbindung dann sofort wieder aufbauen? Oder geht das nicht?
                                  BlueBook @Pino72 last edited by
                                  same here. Über den Winter hatte ich den Adapter aus.
                                  Seit 2-3 Wochen nun diese Probleme.
                                  Die Verbindung wird nach (ich weiß es noch nicht genau) irgendwas zwischen 3-5 Stunden gekappt.
                                  Der Adapter geht dann auf gelb.
                                  Ping hatte ich 150, dann auf 200 - nach dem oberen Forumseintrag.
                                  Jetzt auf 100 - mal schauen, ob es hilft.
                                    BlueBook @jpgorganizer last edited by BlueBook
                                    @jpgorganizer Fehler wird durch einen Neustart bei mir direkt behoben.
                                    Wobei ich den bisher immer erst deutlich später machen - weil mir der Fehler erst später auffällt.
                                    Leider ist das log dann meist schon wieder leer geräumt, daher kann ich es nicht genau sagen
                                    Btw: Danke für den tollen Adapter!! 🙂
                                      stevie77 @BlueBook last edited by
                                      @bluebook Genau das Problem habe ich auch seit ein paar Tagen. Läuft ein paar Stunden und dann geht die Instanz auf gelb. Log muss ich nachreichen, heute Nacht sah es so aus, als hätte ich einen Restart gemacht, bin mir aber nicht mehr ganz sicher.
                                        Folgendes konnte ich gerade aus dem lo fischen.
                                        Ping bei 100
                                        smartgarden.0 2022-04-10 13:35:13.281 info (2029) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                                        smartgarden.0 2022-04-10 13:35:13.260 info (2029) 3/ sgSetState: info.connection value=false ack=true
                                        smartgarden.0 2022-04-10 13:35:13.259 info (2029) 3/ on_close: ### closed ### close.code=1001 close.reason=Going away
                                          stevie77 @BlueBook last edited by stevie77
                                          Kann ich bestätigen. Ich hatte das heruntergeladene Logfile anfangs falschherum gelesen. 😉
                                          2022-04-10 04:12:35.352  - info: smartgarden.0 (16350) 2/ get_locations: successful / response.statusMessage: OK
                                          2022-04-10 04:12:35.353  - info: smartgarden.0 (16350) 2/ get_locations ... locations={"data":[{"id":"5feeadcd-2e5a[xyz]48f082f6","type":"LOCATION","attributes":{"name":"My Garden"}}]}
                                          2022-04-10 04:12:35.355  - info: smartgarden.0 (16350) 2/ get_websocket ...
                                          2022-04-10 04:12:35.694  - info: smartgarden.0 (16350) 2/ get_websocket successful: response.statusCode/Message=201/Created
                                          2022-04-10 04:12:35.707  - info: smartgarden.0 (16350) 2/ get_websocket ... websocket ok
                                          2022-04-10 04:12:35.912  - info: smartgarden.0 (16350) 2/ on_open: ### connected ###
                                          2022-04-10 04:12:36.459  - info: smartgarden.0 (16350) 2/ parseMessage: LOCATION found
                                          2022-04-10 04:12:36.466  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                                          2022-04-10 04:12:36.472  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                                          2022-04-10 04:12:36.482  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                                          2022-04-10 04:12:36.496  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                                          2022-04-10 04:12:36.615  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                                          2022-04-10 04:12:36.626  - info: smartgarden.0 (16350) 2/ parseMessage: POWER_SOCKET found
                                          2022-04-10 04:12:36.642  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                                          2022-04-10 04:12:36.650  - info: smartgarden.0 (16350) 2/ parseMessage: SENSOR found
                                          2022-04-10 04:12:36.658  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                                          2022-04-10 04:12:36.673  - info: smartgarden.0 (16350) 2/ parseMessage: MOWER found
                                          2022-04-10 04:12:36.698  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                                          2022-04-10 04:12:36.723  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE_SET found
                                          2022-04-10 04:12:36.729  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE found
                                          2022-04-10 04:12:36.736  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                                          2022-04-10 04:12:36.742  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE_SET found
                                          2022-04-10 04:12:36.748  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE found
                                          2022-04-10 04:12:36.755  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                                          Danach wird gepongt und anderes...
                                          2022-04-10 05:57:35.973  - info: smartgarden.0 (16350) 2/ on_pong: ++ pong'ed ++
                                          2022-04-10 05:57:36.335  - info: smartgarden.0 (16350) 2/ parseMessage: MOWER found
                                          2022-04-10 05:57:36.335  - info: smartgarden.0 (16350) 2/ setServiceStates: relationship searching
                                          2022-04-10 05:57:36.348  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                                          2022-04-10 05:57:36.349  - info: smartgarden.0 (16350) 2/ setServiceStates: relationship searching
                                          Und dann exakt 2 Stunden nach dem Start nur die eine Zeile (und danach keine Pongs mehr):
                                          2022-04-10 06:12:35.884  - info: smartgarden.0 (16350) 2/ on_close: ### closed ### close.code=1001 close.reason=Going away
                                          • premo
                                            premo @stevie77 last edited by premo
                                            @stevie77 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                            Hallo
                                            Habe auch das Problem und bis es eine Lösung gibt ein Blockly angelegt
                                            der den Datenpunkt Device or service connected von false auf true schaltet.
                                            Mit der Eventlist Instanz sehe wann die Verbindung abbricht.
                                            gardena smart system smartgarden
                                            108
                                            1080
                                            282697
