    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      Gruter @tombox last edited by
      @tombox
      Ja, jetzt passt es wieder, Danke!
      • draexler
        draexler @tombox last edited by
        @tombox Das hat funktioniert. Danke ☺️
          senior1418 @tombox last edited by senior1418
          @tombox
          ich kann leider nicht genau sagen seit wann aber seit einiger Zeit erhalte ich keine Meldungen über PushOver.
          pushover.3 2022-04-08 10:58:38.042	error	Error from Pushover: message cannot be blank
          pushover.3 2022-04-08 10:58:37.882	info	Send pushover notification: {"user":"","text":"📦 Amazon EU SARL\nZustellung erfolgreich","title":"Parcel","priority":0,"message":""}
          :Nachtrag v0.0.13
            tombox @senior1418 last edited by
            @senior1418 ist gefixt
            • Horst Böttcher
              Horst Böttcher @tombox last edited by
              @tombox habe den adapter Installier und er bleibt rot
              host.raspberrypi	2022-04-08 12:14:32.446	info	Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
              host.raspberrypi	2022-04-08 12:14:32.445	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi	2022-04-08 12:14:32.444	error	Caught by controller[0]: }
              host.raspberrypi	2022-04-08 12:14:32.443	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
              host.raspberrypi	2022-04-08 12:14:32.443	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
              host.raspberrypi	2022-04-08 12:14:32.442	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
              host.raspberrypi	2022-04-08 12:14:32.442	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
              host.raspberrypi	2022-04-08 12:14:32.441	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
              host.raspberrypi	2022-04-08 12:14:32.441	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
              host.raspberrypi	2022-04-08 12:14:32.440	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
              host.raspberrypi	2022-04-08 12:14:32.440	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
              host.raspberrypi	2022-04-08 12:14:32.439	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
              host.raspberrypi	2022-04-08 12:14:32.439	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
              host.raspberrypi	2022-04-08 12:14:32.438	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
              host.raspberrypi	2022-04-08 12:14:32.438	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
              host.raspberrypi	2022-04-08 12:14:32.437	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
              host.raspberrypi	2022-04-08 12:14:32.437	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
              host.raspberrypi	2022-04-08 12:14:32.436	error	Caught by controller[0]: was compiled against a different Node.js version using
              host.raspberrypi	2022-04-08 12:14:32.435	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
              host.raspberrypi	2022-04-08 12:14:32.435	error	Caught by controller[0]: ^
              host.raspberrypi	2022-04-08 12:14:32.434	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
              host.raspberrypi	2022-04-08 12:14:32.433	error	Caught by controller[0]: internal/modules/cjs/loader.js:1144
              host.raspberrypi	2022-04-08 12:14:28.563	info	instance system.adapter.parcel.0 started with pid 2182
              host.raspberrypi	2022-04-08 12:14:27.736	info	"system.adapter.parcel.0" enabled
              • DJMarc75
                DJMarc75 @Horst Böttcher last edited by
                @horst-böttcher
                https://forum.iobroker.net/post/787171
                • Horst Böttcher
                  @tombox sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                  @draexler
                  cd /opt/iobroker/
                  npm install canvas
                  ich arbeite daran das es gefixt wird
                  pi@raspberrypi:/opt/iobroker $ iobroker stop
                  pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/
                  pi@raspberrypi:/opt/iobroker $ sudo npm install canvas
                  > canvas@2.9.1 install /opt/iobroker/node_modules/canvas
                  > node-pre-gyp install --fallback-to-build
                  node-pre-gyp WARN Pre-built binaries not installable for canvas@2.9.1 and node@14.18.1 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
                  node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
                  gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/14.18.1"
                  gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
                  gyp ERR! configure error
                  gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
                  gyp ERR! System Linux 5.10.17-v7l+
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
                  gyp ERR! cwd /opt/iobroker/node_modules/canvas
                  gyp ERR! node -v v14.18.1
                  gyp ERR! node-gyp -v v5.1.0
                  gyp ERR! not ok
                  node-pre-gyp ERR! build error
                  node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
                  node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
                  node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                  node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1058:16)
                  node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
                  node-pre-gyp ERR! System Linux 5.10.17-v7l+
                  node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                  node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                  node-pre-gyp ERR! node -v v14.18.1
                  node-pre-gyp ERR! node-pre-gyp -v v1.0.6
                  node-pre-gyp ERR! not ok
                  npm WARN @rollup/plugin-inject@4.0.4 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
                  npm WARN @rollup/pluginutils@3.1.0 requires a peer of rollup@^1.20.0||^2.0.0 but none is installed. You must install peer dependencies yourself.
                  npm WARN http-cookie-agent@1.0.5 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
                  npm WARN rollup-plugin-polyfill-node@0.8.0 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! canvas@2.9.1 install: `node-pre-gyp install --fallback-to-build`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the canvas@2.9.1 install script.
                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR!     /root/.npm/_logs/2022-04-08T14_22_43_117Z-debug.log
                    Thomas Braun Most Active @Horst Böttcher last edited by Thomas Braun
                    @horst-böttcher sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                    NICHT mit sudo hantieren an der Stelle.
                    Stand aber auch offenbar so nicht in der Anleitung. Warum macht man das also dann doch?
                    System auf Stand halten.
                    sudo apt update
                    sudo apt full-upgrade
                    sudo reboot
                    Danach als user:
                    cd /opt/iobroker
                    npm install canvas
                    Horst Böttcher 1 Reply Last reply Reply Quote 2
                    • Horst Böttcher
                      Horst Böttcher @Thomas Braun last edited by
                      ich hatte es vorher ohne sudo gemacht
                        @horst-böttcher
                        Hast du jetzt die Hausaufgaben erledigt? System auf Stand?
                        cd /opt/iobroker
                        npm ls canvas
                        liefert?
                          ist gefixt
                          herzlichen Dank ! Es funktioniert wieder .
                            basty2 @tombox last edited by
                            @tombox Ich wollte nach dem aktuellen Stand nachfragen. Bei mir funktioniert die Darstellung der voraussichtlichen Lieferung und der Anzahl der Stopps nur bei Amazon. Die Infos gibt es bspw. teilweise auch bei der DHL. Ich fände es klasse, wenn diese Infos auch bei den anderen Unternehmen im JSON landen würden.
                              tombox @basty2 last edited by
                              @basty2 Also wenn sie nicht im rohen JSON sind wird es schwer darauf zuzugreifen. Ich habe bisher keine DHL mit Stop gehabt
                              DJMarc75 B 2 Replies Last reply Reply Quote 0
                              • DJMarc75
                                DJMarc75 @tombox last edited by
                                @tombox
                                Ich hatte schon einige Lieferungen von DHL welche im Livetracking auch die Stopps angezeigt haben - allerdings nur in der Ordnerstruktur. Ich habe aber davon abgesehen dies zu visualisieren oder anders zu verarbeiten da sich die Anzahl der Stopps und eigentlich alle Daten im Livetracking ja auch nur ändern wenn sich die Instanz die Daten holt. In meinem Fall alle 15 Minuten und zwischen den Intervallen sind deutliche Abweichungen im Vergleich zur APP von DHL zu erkennen.
                                Habe im Moment leider keine Lieferung von DHL um auch mal zu sehen ob da was in der rohen JSON eingetragen wird.
                                  @djmarc75 @tombox Spannend, bei mir sind ca. 95% der Lieferungen mit Livetracking. Deshalb aktualisiere ich auch aller 5 Minuten. Es reicht ja meistens zu sehen, dass die Stopps angezeigt werden.
                                  ich kann aktuell keine Bilder hochladen. Kann Euch aber die Werte sagen. Vielleicht können andere das ergänzen oder eigene Erfahrungen mit einbringen.
                                  Anzahl der Stopps sind die beiden Elemente wichtig:
                                  parcel.0.dhl.sendungen03.sendungsdetails.liveTracking.countdownTextKey (hier steht aber immer ein CD davor)
                                  Ich werde morgen mal schauen, welcher der beiden Werte wirklich die nächsten Stopps anzeigt.
                                  Die nächsten beiden Werte haben meist nur einen Dummy: die Uhrzeit 0:00 Uhr, aber manchmal waren da auch schon Uhrzeiten mit Zeitfenstern.
                                  parcel.0.dhl.sendungen03.sendungsdetails.zustellung.zustellzeitfensterVon
                                  Die Werte des liveTracking bleiben auch bestehen, wenn schon zugestellt wurde. D.h. es wird nicht mit 0 oder so überschrieben.
                                  jetzt ging doch der Upload.
                                    @basty2 Einfach den inhalt von
                                    parcel.0.dhl.json
                                    per pn
                                    • Ro75
                                      Ro75 last edited by
                                      Moin. Zuerst, klasse Adapter. Ich habe heute den Parcel-Adapter von der Version 0.0.12 auf die Version 0.0.15 aktualisiert. Soweit alles gut. Allerdings bekomme ich heute eine Amazon-Sendung angezeigt, welche "verspätet" ist. Allerdings ist diese Sendung tatsächlich zugestellt (16.03.), nur in den Daten nicht.
                                            "id": "304-3xxxxxx-xxxxxxx",
                                            "name": "Türdichtung Türgummi universal für Backofen E-Herd kompatibel passend für AEG Electrolux Siemens Neff Miele Bosch Küppersbusch Günstig Ersatz",
                                            "status": "Unterwegs, aber verspätet",
                                            "detailedState": {
                                              "deviceType": "desktop",
                                              "isLexicalExceptionMessagePresent": true,
                                              "orderId": "304-xxxxxx-xxxxxxx",
                                              "shortStatus": "IN_TRANSIT",
                                              "promise": {
                                                "secondaryPromiseIdentifier": "NONE",
                                                "promiseMessage": "Unterwegs, aber verspätet"
                                              "isApp": false,
                                              "themeParameters": "o=304-3xxxxxx-xxxxxxx&s=DFL4rxxxx&i=kjkosqnqornwqr",
                                              "itemId": "kjkosqnqornwqr",
                                              "signInRedirectUrl": "/progress-tracker/package/ref=ppx_yo_dt_b_track_package?itemId=kjkosqnqornwqr&orderId=304-xxxxxx-xxxxxxx&_encoding=UTF8&shipmentId=DFL4rxxxx&disableCsd=missing-library&vt=YOUR_ORDERS",
                                              "isMfn": true,
                                              "shipmentId": "DFL4rcxxx",
                                              "keepSecondaryUntouched": true,
                                              "customerId": "A2M65VYxxxxxxx",
                                              "realm": "GBAmazon",
                                              "visitTrigger": "YOUR_ORDERS",
                                              "trackingId": ""
                                      Schon mal dickes Danke an Euch.
                                        tombox @Ro75 last edited by
                                        @ro75 Da kann man nichts machen wenn Amazon die Zustellung nicht erfassen kann das passiert manchmal bei Briefsendungen
                                        • Ro75
                                          Ro75 last edited by Ro75
                                          Alles klar. Ich gehe davon aus, dass die Sendung dann irgendwann aus der Liste verschwindet. Danke.
                                          • DJMarc75
                                            DJMarc75 last edited by
                                            @basty2
                                            Hast Du heute bei deinem Paket die Einträge im JSON verfolgen können ?
                                            Ich bekomme am Samstag eins per DHL, werde dann auch mal das LiveTracking verfolgen.
                                            17track amazon briefe dhl dpd gls ups
                                            122
                                            1534
                                            527383
