    4. [neuer Adapter] smartgarden adapter for Gardena smart system
    • jpgorganizer
      jpgorganizer @premo last edited by jpgorganizer
      @premo sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
      Connection failure.response.statusCode/Message=403/Forbidden
      dein Account sagt " du kommst hier nicht rein " 🙂
      Passwort, Username, API Key kontrollieren
      API's verknüpft?
      Und was ist das?
      authentication_host: https://ssp.dss.husqvarnagroup.com
      Der Default sieht mal anders aus
      Authentication host URL; default: https://api.authentication.husqvarnagroup.dev
      • premo
        Danke für die bisherige Hilfe.
        @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
        Passen alle soweit
        API's verknüpft?
        GARDENA smart system API ist verknüpft
        Und was ist das?
        Habe so im Adapter stehen lassen.
        Neuer Log :
        2022-04-08 17:27:39.139  - info: smartgarden.0 (6652) Got terminate signal TERMINATE_YOURSELF
        2022-04-08 17:27:39.141  - info: smartgarden.0 (6652) 3/ cleaned everything up...
        2022-04-08 17:27:39.141  - info: smartgarden.0 (6652) terminating
        2022-04-08 17:27:39.142  - info: smartgarden.0 (6652) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2022-04-08 17:27:39.720  - info: host.DESKTOP-VCLNP9G(IOBroker) instance system.adapter.smartgarden.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
        2022-04-08 17:27:41.665  - info: host.DESKTOP-VCLNP9G(IOBroker) instance system.adapter.smartgarden.0 started with pid 11592
        2022-04-08 17:27:43.593  - info: smartgarden.0 (11592) starting. Version 1.0.5 in C:/Program Files/iobroker/IOBroker/node_modules/iobroker.smartgarden, node: v14.18.1
        2022-04-08 17:27:43.626  - info: smartgarden.0 (11592) 3/ getConnection...
        2022-04-08 17:27:43.627  - info: smartgarden.0 (11592) 3/ connectToGardena...
        2022-04-08 17:27:43.630  - info: smartgarden.0 (11592) 3/ sgSetState: info.connection value=false ack=true
        2022-04-08 17:27:43.632  - info: smartgarden.0 (11592) 3/ connecting to Gardena Smart System Service ...
        2022-04-08 17:27:43.633  - info: smartgarden.0 (11592) 3/ Gardena Smart System Service hosts at: smart_host: https://smart.gardena.com authentication_host: https://api.authentication.husqvarnagroup.dev
        2022-04-08 17:27:43.713  - info: smartgarden.0 (11592) 3/ sgSetState: info.revision value=Main: 2495 / API: 2506 ack=true
        2022-04-08 17:27:43.720  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
        2022-04-08 17:27:43.726  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.revision changed: Main: 2495 / API: 2506 (ack = true)
        2022-04-08 17:27:43.727  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.adapterversion changed: 1.0.5 (ack = true)
        2022-04-08 17:27:44.062  - info: smartgarden.0 (11592) 3/ Connection: successful: response.statusCode / statusMessage=200 / OK
        2022-04-08 17:27:44.062  - info: smartgarden.0 (11592) 3/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
        2022-04-08 17:27:44.063  - info: smartgarden.0 (11592) 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXX-XXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
        2022-04-08 17:27:44.064  - info: smartgarden.0 (11592) 3/ get_locations ...
        2022-04-08 17:27:44.271  - info: smartgarden.0 (11592) 3/ sgSetState: info.connection value=false ack=true
        2022-04-08 17:27:44.272  - info: smartgarden.0 (11592) 3/ get_locations failure: response.statusCode/Message=400/Bad Request
        2022-04-08 17:27:44.272  - info: smartgarden.0 (11592) 3/ get_locations failure:..return with error
        2022-04-08 17:27:44.273  - error: smartgarden.0 (11592) Error: request returned 400 Bad Request
        2022-04-08 17:27:44.273  - info: smartgarden.0 (11592) 3/ sgSetState: info.connection value=false ack=true
        2022-04-08 17:27:44.273  - info: smartgarden.0 (11592) 3/ getConnection: returned connection error: request returned 400 Bad Request
        2022-04-08 17:27:44.274  - info: smartgarden.0 (11592) 3/ getConnection: trying to connect again in 300 seconds
        2022-04-08 17:27:44.372  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
        2022-04-08 17:27:44.374  - info: smartgarden.0 (11592) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
        jpgorganizer 1 Reply Last reply Reply Quote 0
        • jpgorganizer
          vergleich mal deine Eingaben der Webadressen mit den Angaben in der Doku
          premo 1 Reply Last reply Reply Quote 0
          • premo
            premo @jpgorganizer last edited by
            Danke, jetzt läuft es .
              Pino72 @Pino72 last edited by
              @pino72 said in [neuer Adapter] smartgarden adapter for Gardena smart system:
              Ich denke es hat sich erledigt, hatte den Ping auf 200 statt 150 Sekunden gesetzt...jetzt mit 150 Sekunden scheint es durch zu laufen.
              Hab mich zu früh gefreut, seit gestern wieder die regelmäßigen Abbrüche wie vorher, Ping ist auf 150. Hab es jetzt mal auf 100 gesetzt mal sehen ob das was ändert.
              Scheint ja irgendwie noch nicht klar warum Gardena die Verbindung einfach so trennt ohne ersichtlichen Grund.
                berndpehome last edited by
                Bei mir auch Gelb, Ping auf 200 brachte gestern Grün und Heute wieder Gelb.
                Letztes Jahr lief der Adapter ohne Probleme
                • jpgorganizer
                  jpgorganizer @berndpehome last edited by
                  Lässt sich eigentlich die Verbindung dann sofort wieder aufbauen? Oder geht das nicht?
                    BlueBook @Pino72 last edited by
                    same here. Über den Winter hatte ich den Adapter aus.
                    Seit 2-3 Wochen nun diese Probleme.
                    Die Verbindung wird nach (ich weiß es noch nicht genau) irgendwas zwischen 3-5 Stunden gekappt.
                    Der Adapter geht dann auf gelb.
                    Ping hatte ich 150, dann auf 200 - nach dem oberen Forumseintrag.
                    Jetzt auf 100 - mal schauen, ob es hilft.
                      BlueBook @jpgorganizer last edited by BlueBook
                      @jpgorganizer Fehler wird durch einen Neustart bei mir direkt behoben.
                      Wobei ich den bisher immer erst deutlich später machen - weil mir der Fehler erst später auffällt.
                      Leider ist das log dann meist schon wieder leer geräumt, daher kann ich es nicht genau sagen
                      Btw: Danke für den tollen Adapter!! 🙂
                        stevie77 @BlueBook last edited by
                        @bluebook Genau das Problem habe ich auch seit ein paar Tagen. Läuft ein paar Stunden und dann geht die Instanz auf gelb. Log muss ich nachreichen, heute Nacht sah es so aus, als hätte ich einen Restart gemacht, bin mir aber nicht mehr ganz sicher.
                          Folgendes konnte ich gerade aus dem lo fischen.
                          Ping bei 100
                          smartgarden.0 2022-04-10 13:35:13.281 info (2029) 3/ ---> State change by device: state sg.0.info.connection changed: false (ack = true)
                          smartgarden.0 2022-04-10 13:35:13.260 info (2029) 3/ sgSetState: info.connection value=false ack=true
                          smartgarden.0 2022-04-10 13:35:13.259 info (2029) 3/ on_close: ### closed ### close.code=1001 close.reason=Going away
                            stevie77 @BlueBook last edited by stevie77
                            Kann ich bestätigen. Ich hatte das heruntergeladene Logfile anfangs falschherum gelesen. 😉
                            2022-04-10 04:12:35.352  - info: smartgarden.0 (16350) 2/ get_locations: successful / response.statusMessage: OK
                            2022-04-10 04:12:35.353  - info: smartgarden.0 (16350) 2/ get_locations ... locations={"data":[{"id":"5feeadcd-2e5a[xyz]48f082f6","type":"LOCATION","attributes":{"name":"My Garden"}}]}
                            2022-04-10 04:12:35.355  - info: smartgarden.0 (16350) 2/ get_websocket ...
                            2022-04-10 04:12:35.694  - info: smartgarden.0 (16350) 2/ get_websocket successful: response.statusCode/Message=201/Created
                            2022-04-10 04:12:35.707  - info: smartgarden.0 (16350) 2/ get_websocket ... websocket ok
                            2022-04-10 04:12:35.912  - info: smartgarden.0 (16350) 2/ on_open: ### connected ###
                            2022-04-10 04:12:36.459  - info: smartgarden.0 (16350) 2/ parseMessage: LOCATION found
                            2022-04-10 04:12:36.466  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                            2022-04-10 04:12:36.472  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                            2022-04-10 04:12:36.482  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                            2022-04-10 04:12:36.496  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                            2022-04-10 04:12:36.615  - info: smartgarden.0 (16350) 2/ parseMessage: DEVICE found
                            2022-04-10 04:12:36.626  - info: smartgarden.0 (16350) 2/ parseMessage: POWER_SOCKET found
                            2022-04-10 04:12:36.642  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                            2022-04-10 04:12:36.650  - info: smartgarden.0 (16350) 2/ parseMessage: SENSOR found
                            2022-04-10 04:12:36.658  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                            2022-04-10 04:12:36.673  - info: smartgarden.0 (16350) 2/ parseMessage: MOWER found
                            2022-04-10 04:12:36.698  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                            2022-04-10 04:12:36.723  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE_SET found
                            2022-04-10 04:12:36.729  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE found
                            2022-04-10 04:12:36.736  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                            2022-04-10 04:12:36.742  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE_SET found
                            2022-04-10 04:12:36.748  - info: smartgarden.0 (16350) 2/ parseMessage: VALVE found
                            2022-04-10 04:12:36.755  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                            Danach wird gepongt und anderes...
                            2022-04-10 05:57:35.973  - info: smartgarden.0 (16350) 2/ on_pong: ++ pong'ed ++
                            2022-04-10 05:57:36.335  - info: smartgarden.0 (16350) 2/ parseMessage: MOWER found
                            2022-04-10 05:57:36.335  - info: smartgarden.0 (16350) 2/ setServiceStates: relationship searching
                            2022-04-10 05:57:36.348  - info: smartgarden.0 (16350) 2/ parseMessage: COMMON found
                            2022-04-10 05:57:36.349  - info: smartgarden.0 (16350) 2/ setServiceStates: relationship searching
                            Und dann exakt 2 Stunden nach dem Start nur die eine Zeile (und danach keine Pongs mehr):
                            2022-04-10 06:12:35.884  - info: smartgarden.0 (16350) 2/ on_close: ### closed ### close.code=1001 close.reason=Going away
                            • premo
                              premo @stevie77 last edited by premo
                              @stevie77 sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                              Hallo
                              Habe auch das Problem und bis es eine Lösung gibt ein Blockly angelegt
                              der den Datenpunkt Device or service connected von false auf true schaltet.
                              Mit der Eventlist Instanz sehe wann die Verbindung abbricht.
                              • jpgorganizer
                                Hallo
                                das nützt aber wohl nix, da hast du nur den Farbeimer rausgeholt.
                                • jpgorganizer
                                  jpgorganizer @jpgorganizer last edited by
                                  schaut mal hier. Wäre hilfreich, wenn ihr mit-testen würdet
                                  https://github.com/jpgorganizer/ioBroker.smartgarden/issues/43#issuecomment-1094299783
                                  andre-bu created this issue in jpgorganizer/ioBroker.smartgarden
                                  closed Verbindungsprobleme #43
                                    Habe jetzt bei Version 1.0.5 die Api Version ausgetauscht, bleibt Gelb.
                                    Downgrade auf Version auf 1.0.4 macht den Adapter wieder Grün, wenn ich auf Aktualisieren der Instanz gehe wird er wieder Gelb und bleibt auch Gelb,
                                    neustarten macht ihn aber wieder Grün, das funktioniert bei Version 1.0.5 nicht.
                                      Cosmicbase last edited by Cosmicbase
                                      Hallo, in der Gardena Smart Garden App kann man doch die aktuelle Temperatur und Bodenfeuchte durch "Swipe to Refresh" aktualisieren.
                                      Damit wird auch der Timestamp im Adapter neu gesetzt.
                                      Kann ich das Szenario auch im Adapter durchführen.
                                      Ich will den manuellen Refresh nicht immer in der App machen.
                                      Vielen Dank für die Hilfe.
                                      • jpgorganizer
                                        jpgorganizer @Cosmicbase last edited by
                                        @cosmicbase sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                        da geht es um den Sensor? wenn ja, dann nein. Meines wissens hat der Sensor über die Public API keine Abfragemöglichkeit.
                                        • jpgorganizer
                                          @berndpehome sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                          sorry, aber das ist mir zu wirr
                                            Cosmicbase @jpgorganizer last edited by
                                            @jpgorganizer
                                            Ja ich meinte den Sensor. In der App kann man bei der Temp. und Bodenfeuchte einen refresh machen.
                                            Hätte gedacht das es im Adapter auch möglich ist. Wäre durchaus sinnvoll um kurzfristig neue Werte zu bekommen.
                                            gardena smart system smartgarden
                                            108
                                            1080
                                            277789
