    4. Test Adapter wireless-mbus v0.10.x
    • hg6806
      hg6806 Most Active last edited by hg6806
      Leider bekomme ich noch immer keine Daten.
      NanoCUL iPerl Wasserzähler.
      Ich habe parallel wmbusmeters erfolgreich laufen und dies vorher per
       sudo systemctl stop wmbusmeters.service
      gestoppt. Müsste doch ausreichen, oder?
      Nach dem Starten sieht es auch gut aus:
      wireless-mbus.0
      2022-04-07 11:33:27.659	debug	connected set to true
      wireless-mbus.0
      2022-04-07 11:33:27.656	debug	connected set to true
      wireless-mbus.0
      2022-04-07 11:33:27.580	debug	CUL: Receiver set to T-MODE and data reporting with RSSI
      wireless-mbus.0
      2022-04-07 11:33:27.555	debug	Created device of type: CUL (untested)
      wireless-mbus.0
      2022-04-07 11:33:27.402	info	starting. Version 0.7.8 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.1, js-controller: 4.0.21
      wireless-mbus.0
      2022-04-07 11:33:26.164	debug	States connected to redis: 127.0.0.1:9000
      wireless-mbus.0
      2022-04-07 11:33:26.028	debug	States create User PubSub Client
      wireless-mbus.0
      2022-04-07 11:33:26.026	debug	States create System PubSub Client
      wireless-mbus.0
      2022-04-07 11:33:25.948	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      wireless-mbus.0
      2022-04-07 11:33:25.796	debug	Objects connected to redis: 127.0.0.1:9001
      wireless-mbus.0
      2022-04-07 11:33:25.778	debug	Objects client initialize lua scripts
      wireless-mbus.0
      2022-04-07 11:33:25.392	debug	Objects create User PubSub Client
      wireless-mbus.0
      2022-04-07 11:33:25.389	debug	Objects create System PubSub Client
      wireless-mbus.0
      2022-04-07 11:33:25.327	debug	Objects client ready ... initialize now
      wireless-mbus.0
      2022-04-07 11:33:25.161	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      wireless-mbus.0
      2022-04-07 11:33:17.472	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      wireless-mbus.0
      2022-04-07 11:33:17.470	info	terminating
      wireless-mbus.0
      2022-04-07 11:33:17.467	info	Got terminate signal TERMINATE_YOURSELF
      Aber es kommen einfach keine Daten. Da müssten alle 1-3h Daten kommen.
      Ich habe folgende Firmware geflashed:
      https://github.com/smarthomeagentur/culfw1/releases/tag/180dcb5
      Datenpunkte werden angelegt, connected is auch:
      Hier sind die Settings:
      Als "Geräte Adresse" habe ich die ID eingetragen. Ist das überhaupt richtig?
        Michi_Pi @hg6806 last edited by
        @hg6806 verwende mal eine andere baudrate, ich musste die 57600 einstellen.
        • hg6806
          Es läuft jetzt.
          Nach einiger Zeit kam dann vom Wasserzähler eine Übermittlung.
          Im Adapter wurde dann angezeigt, dass von SEN-xxxxx des AES Key fehlt.
          Somit hatte ich dann auch den Gerätenamen, denn ich eins drüber dann korrigiert habe.
          @Michi_Pi und zwar bei mir auf 9600
          M L 2 Replies Last reply Reply Quote 0
            marsmännchen @hg6806 last edited by marsmännchen
            Bei mir leider immer noch der selbe Error.
            Hab versucht 9600,38400,57600 bei allem der gleiche Fehler.
            Einzig wenn ich den Port auf /dev/ttyAMA0 stelle dann kommt nur:
            wireless-mbus.0
            2022-04-07 18:49:03.180	debug	connected set to true
            wireless-mbus.0
            2022-04-07 18:49:03.178	debug	connected set to true
            wireless-mbus.0
            2022-04-07 18:49:03.163	debug	Created device of type: CUL (untested)
            wireless-mbus.0
            2022-04-07 18:49:03.098	info	starting. Version 0.7.8 (non-npm: lvogt/ioBroker.wireless-mbus#ece83640b64ef90971e96e03b229f236dd2d2b0a) in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.0, js-controller: 4.0.19
            Ohne dem Error, aber auch ohne Werte. Mein ArduinoNano hängt aber am USB Port.
            Und außerdem, wenn ich im Adapter die Baudrate ändere und dann Speichern&Schliessen klicke, reicht das aus, oder sollte ich dann noch etwas neu starten?
            Muss ich die Geräteadresse eintragen? Bei wmbusmaster hatte ich keine in Verwendung, und AES Schlüssel brauch ich scheinbar auch nicht.
            Sorry die dummen Fragen, ich will mir nur nicht irgendeinen Fehler einbauen.
              lvogt @hg6806 last edited by
              @hg6806 said in Test Adapter wireless-mbus v0.7.x:
              Es läuft jetzt.
              Hattest du jetzt noch was geändert oder einfach nur gewartet? Aber schön das es funktioniert.
              @marsmännchen said in Test Adapter wireless-mbus v0.7.x:
              Da kommt zwar der Fehler nicht - aber auc keine Erfolgsmeldung die eigentlich kommen müsste... Kombiniert damit dass der Port eigentlich keinen Sinn ergibt dürfte das wohl nicht der richtige Weg sein...
              Nein, wenn man die Einstellungen ändert, startet ioBroker einen Adapter sowieso immer neu.
              Nein die sind nur nötig wenn man AES Schlüssel braucht - und auch dann ist es einfacher da erst was einzutragen wenn man mal ein verschlüsseltes Telegramm empfangen hat (das taucht dann im (Debug) Log auf)
              In meinem Augen ist das Problem immer noch wahlweise falscher Port / falsche Baudrate oder eine "merkwürdige" Firmware (aber ich denke wenn wmbusmeters funktioniert dann sollte die Firmware ok sein - aber ka 🤷 )
              • hg6806
                hg6806 Most Active @marsmännchen last edited by
                @marsmännchen
                Schau doch erst einmal per
                 ls -la /dev/serial/by-id
                wo der Stick hängt.
                Hast du auch einen nanoCUL und iPerl? Und hat es mit wmbusmeters funktioniert?
                Dann sollte es jetzt auch funktionieren.
                Geräteadresse ist immer xxx-ID, Bei meinem iPerl ist es SEN-xxxxxxx
                Es dauert auch manchmal Stunden bis der Wasserzähler überhaupt was sendet.
                Ich weiß jetzt gar nicht wie die Stadtwerke das machen. Ob die einen Impuls aussenden können, der den Wasserzähler anregt was auszusenden.
                Ich finde es sowieso spannend dass die überhaupt was empfangen können.
                Der Wasserzähler ist im Betonkeller verbaut, auf dem Lichtschacht ist ein feinmaschiges Edelstahlgitter gelegt. Das Haus ist bis zur Strasse bzw. Wendehammer nochmal 15m entfernt.
                  @hg6806
                   ls -l /dev/ttyUSB*
                  Habe ich immer wieder mal gemacht, da findet er auch den cul:
                  crw-rw---- 1 root dialout 188, 0  6. Apr 19:41 /dev/ttyUSB0
                  Ich hab keinen bestimmten stick. Meine Hardware besteht aus einem ArduinoNano und dem TI-CC1101.
                  Auf einem anderen Raspberry habe ich wmbusmeters installiert, dort hat der Wasserzähler alle 15sec seinen Wert gesendet.(Oder wmbusmeters hat ihn alle 15sec. abgefragt,keine Ahnung) Zumindest habe ich alle 15 sec in der Console den aktuellen Zählerstand gesehen.
                  Muss man auf dem Raspberry noch irgendetwas extra installieren damit der Adapter funktioniert? Mosquitto oder sowas?
                  • hg6806
                    hg6806 Most Active @marsmännchen last edited by hg6806
                    @marsmännchen
                    Der Stick findet sich bei mir aber wie folgt:
                    lrwxrwxrwx 1 root root  13  3. Apr 09:42 usb-SHA_CUL868-if00 -> ../../ttyACM0
                    Welchen Wasserzähler hast du?
                    Bei 15 Sk. sollte das Try/error Spiel ja recht einfach sein.
                    Und nein, sonst muss nichts anderes installiert sein. Auch kein Mosquitto.
                      @hg6806 sagte in Test Adapter wireless-mbus v0.7.x:
                      @marsmännchen
                      Interressant, das wäre mal ein Ansatz dem ich nachgehen sollte.
                      Was aber im widerspruch zum funktionierenden wmbusmeters am anderen Raspberry steht, wo es genauso angezeigt wird. Liegt vielleicht nur an der Hardware.
                      Try/Error besteht bei mir darin alle Baudraten einmal ausprobiert zu haben. Mehr Try's sind mir bis jetzt noch nicht eingefallen
                        HKF8770 @lvogt last edited by
                        @lvogt 2022-04-10 16:26:07.921 -
                        Habe den Adapter auf debug gestellt und bekomme das folgende.
                        info: wireless-mbus.0 (8517) Got terminate signal TERMINATE_YOURSELF
                        2022-04-10 16:26:07.925 - info: wireless-mbus.0 (8517) terminating
                        2022-04-10 16:26:07.927 - info: wireless-mbus.0 (8517) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2022-04-10 16:26:08.497 - info: host.iobrokerserver instance system.adapter.wireless-mbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2022-04-10 16:26:11.038 - info: host.iobrokerserver instance system.adapter.wireless-mbus.0 started with pid 9481
                        2022-04-10 16:26:12.370 - debug: wireless-mbus.0 (9481) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2022-04-10 16:26:12.442 - debug: wireless-mbus.0 (9481) Objects client ready ... initialize now
                        2022-04-10 16:26:12.445 - debug: wireless-mbus.0 (9481) Objects create System PubSub Client
                        2022-04-10 16:26:12.446 - debug: wireless-mbus.0 (9481) Objects create User PubSub Client
                        2022-04-10 16:26:12.531 - debug: wireless-mbus.0 (9481) Objects client initialize lua scripts
                        2022-04-10 16:26:12.538 - debug: wireless-mbus.0 (9481) Objects connected to redis: 127.0.0.1:9001
                        2022-04-10 16:26:12.577 - debug: wireless-mbus.0 (9481) Redis States: Use Redis connection: 127.0.0.1:9000
                        2022-04-10 16:26:12.595 - debug: wireless-mbus.0 (9481) States create System PubSub Client
                        2022-04-10 16:26:12.597 - debug: wireless-mbus.0 (9481) States create User PubSub Client
                        2022-04-10 16:26:12.647 - debug: wireless-mbus.0 (9481) States connected to redis: 127.0.0.1:9000
                        2022-04-10 16:26:12.973 - warn: wireless-mbus.0 (9481) Object wireless-mbus.0.info.rawdata is invalid: Default value has to be type "string" but received type "boolean"
                        2022-04-10 16:26:12.975 - warn: wireless-mbus.0 (9481) This object will not be created in future versions. Please report this to the developer.
                        2022-04-10 16:26:12.989 - info: wireless-mbus.0 (9481) starting. Version 0.7.6 (non-npm: Apollon77/ioBroker.wireless-mbus#9054a4b6bf7ce4bf92f0804e60323dbece905460) in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.0, js-controller: 4.0.21
                        2022-04-10 16:26:13.079 - debug: wireless-mbus.0 (9481) Created device of type: IMST iM871A
                        2022-04-10 16:26:13.102 - debug: wireless-mbus.0 (9481) IMST: Receiver mode set to CA mode
                        2022-04-10 16:26:13.104 - debug: wireless-mbus.0 (9481) connected set to true
                        2022-04-10 16:26:13.105 - debug: wireless-mbus.0 (9481) connected set to true
                        Wenn ich in das Feld "wireless-mbus.0.info.rawdata" gehe sieht das so aus
                        Ist also der Wert true / false.
                        Das Gerät ist eine Zenner Wasseruhr
                        https://www.energie-zaehler.com/epages/61422236.sf/de_DE/?ObjectPath=/Shops/61422236/Products/ETW-MM-DN20130-wMBUS
                          lvogt @HKF8770 last edited by
                          @hkf8770
                          Damit ich es nicht falsch einsortiere: Bei dir ging es nur um den "VIFExt 0x13" Fehler, ja?
                          Falls ja, dann wäre natürlich auch Logauszug bei dem der Fehler auftaucht nötig...
                          Das Handbuch des verlinkten Zählers gibt natürlich keine exakte Telegrammcodierung an, behauptet aber dem OMS 4.0.2 Standard zu folgen. Die VIF Extension ist aber definitiv nicht Teil des Standards - evtl. aber nur eine "Zenner interne" Zusatzinformation. Dem Handbuch nach scheint es aber sowieso nur mit Vormonatswerten zusammen zu hängen und ist damit für dich vermutlich sowieso uninteressant...
                          Kurzer Hinweis: Wie auch immer du dazu kommst: Du hast den Adapter weder aus dem "unstable / beta" Repository installiert, noch aus meinem Github Repository, sondern aus einem (nicht mehr aktuellen) Fork von Apollon. Wenn du die aktuelle Version hättest - wäre zB auch der (unwichtige) Hinweis auf den rawdata State nicht mehr da gewesen...
                            @lvogt ...woher ich den hatte von appollo kann ich nicht mehr sagen, ist aber auf deinen nun upgedatet. Jetzt habe ich die unrealistischen daten auch weg. Das 4-8 ist jetzt 1,828 m², das könnte der Vormonat sein. Da der erst 20 tage eingebaut ist, wird der 5-8 in einem Weilchen kommen ad7e40e9-e21b-43ef-b441-2feb2e06b91d-image.png
                            Echt super Adapter.
                            Blöde Frage. Ich nutze jetzt den C1 Modus bei der Abfrage.
                            Das muss ich ja im Adapter einstellen.
                            Wenn ich jetzt weitere Geräte kaufen die auf T1 senden, bedeutet dass das ich einen weitere Instanz installieren muss, also wireless-mbus.1.
                            Kann der dann auf den gleichen USB Stick zugreifen, oder benötige ich 2 Sticks?
                              lvogt @HKF8770 last edited by lvogt
                              @hkf8770 said in Test Adapter wireless-mbus v0.7.x:
                              Wenn du zwei Instanzen erzeugst braucht auch jede einen echten Stick, den sie anspricht.
                              Der AMBER Stick hat einen Mode der gleichzeitig C und T empfängt - aber im reinen C-Mode hatte ich auch schon mal öfter das Problem dass der Stick(!) irgendwann crasht und vom Strom bzw. USB getrennt werden muss (ob das Problem auch den gemischten Mode betrifft erinnere ich mich nicht mehr...)
                              Als Kompromis könnte man überlegen ob man den Tag über mal ne Weile im C Mode und dann wieder ne Weile im T Mode lauscht. Aber das kann der Adapter selber nicht - könnte man aber "von außen" über ein kleines Script einbauen. Man müsste halt nur den Mode in der Config setzen und ioBroker würde den Adapter dann ja sowieso neustarten.
                                marsmännchen @lvogt last edited by
                                Ok, ich gebe auf mit meiner ArduinoUno TI-CC1101 combo.
                                Ich kann mir mein Problem nur mit der nicht unterstützten Hardware erklären. Mit wmbusmeter gehts, mit dem Adapter eben nicht.
                                Ist es erlaubt das mir jemand eine Kaufempfehlung gibt für einen CUL Stick der die Anforderungen erfüllt, und wo er ihn gekauft hat?
                                MfG
                                Patrick
                                  lvogt @marsmännchen last edited by
                                  @marsmännchen
                                  Du könntest noch ein paar Infos con wbusmeters posten, vl können wir dann weiter helfen.
                                  Also zb die Konfiguration und mal einen Aufruf auf mit Ausgabe von wbusmeters wenn auch Daten ankommen.
                                  Ob das wirklich hilft weiß ich natürlich nicht...
                                    Vielen Dank für die Hilfe, ich hab das schon abgebrochen, und wmbusmeters deinstalliert. Ich warte jetzt erst mal auf :
                                    "eQ3 INNOGY RWE SmartHome USB Empfangseinheit Stromzähler Empfangs Einheit iM871A"
                                    Wenn's damit nicht geht bau ich mir einen Durchflussmesser in die Leitung der in die Wago PFC200 geht. Damit geht's dann sicher. Die Konstellation vom Smartmeter Adapter - Landis+Gyr E450 - Hichi USB Lesekopf hat auch nie funktioniert, musste dann auch auf Eigenbau umsteigen.
                                    Aber mal abwarten ob das mit dem iM871A was bringt.
                                    Danke trotzdem:👍 👍
                                    G Michael Uray M 3 Replies Last reply Reply Quote 0
                                      gizmodlx @marsmännchen last edited by gizmodlx
                                      Also da hatten wir wohl die gleiche Idee. Leider hat der Stick von RWE eine andere USB PID (87ED) als der originale iMST iM871A. Und damit wird er (zumindest bei mir) leider nicht erkannt. Hab auch die originale Firmware von iMST drüber geflasht - hat aber auch nicht geholfen. Wenn du damit weiterkommst, sag bitte mal Bescheid 🙂
                                      Bin drauf und dran mir einen DVB-T Stick in Verbindung mit rtl-wmbus zuzulegen. Da lassen sich sogar alle Modi (C, T und S) gleichzeitig abfragen. @Ivogt: Wäre es möglich den rtl-wmbus auch in deinem Adapter unterstützten?
                                        marsmännchen @gizmodlx last edited by
                                        @gizmodlx
                                        Na toll 😩
                                        Das wird ja immer besser!
                                        ICH HASSE FUNK!!
                                          lvogt @gizmodlx last edited by
                                          @gizmodlx
                                          Ich habe mit einem solchen Stick damals deb Adapter getestet. Das geht also schon.
                                          Ich weiß leider nicht mehr genau was man tun musste. Ich glaube man muss udev händisch mitteilen welchen (standard) Treiber das Gerät verwenden soll. Lässt sich bestimmt auch in eine udev Regel gießen...
                                          rtl-wmbus ließe sich schon einbauen. Ist aber halt ein ziemlicher CPU Fresser...
                                            gizmodlx @lvogt last edited by gizmodlx
                                            @lvogt said in Test Adapter wireless-mbus v0.7.x:
                                            @gizmodlx
                                            Hmm...da muss ich mich erst mal selbst schlau machen. Sagt mir alles so leider wenig.
                                            wmbusmeters spricht den rtl-wmbus wohl direkt über dessen Kommandozeile an. Das wäre echt klasse, wenn das dein Adapter auch unterstützen würde. Für die CPU-Auslastung gibt es wohl auch mehrere Ansätze, diese zu begrenzen: https://github.com/weetmuts/wmbusmeters/issues/290
                                            pswiatki created this issue in weetmuts/wmbusmeters
                                            closed Cutting down rtl_wmbus CPU utilization from wmbusmeters' level #290
                                            mbus wireless wm-bus wmbus
                                            64
                                            567
                                            172874
