    4. ioBroker seit Update node.js 12 auf 14 langsam
      LE-R.Kelly @Homoran last edited by
      @homoran sagte in ioBroker seit Update node.js 12 auf 14 langsam:
      iobroker list instances
      Da kommt mehr...
      pi@raspberrypi:~ $ iobroker list instances
      + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0
      + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
      + system.adapter.ble.0                    : ble                   : raspberrypi        -  enabled
      + system.adapter.chromecast.0             : chromecast            : raspberrypi        -  enabled
      + system.adapter.fakeroku.0               : fakeroku              : raspberrypi        -  enabled
      + system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi        -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi        -  enabled
        system.adapter.habpanel.0               : habpanel              : raspberrypi        - disabled
        system.adapter.ical.0                   : ical                  : raspberrypi        -  enabled
      + system.adapter.info.0                   : info                  : raspberrypi        -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
        system.adapter.lovelace.0               : lovelace              : raspberrypi        - disabled, port: 8091, bind: 0.0.0.0, run as: admi        n
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi        -  enabled, port: 1883, bind: 192.168.178.85
      + system.adapter.nut.0                    : nut                   : raspberrypi        -  enabled
      + system.adapter.radar2.0                 : radar2                : raspberrypi        -  enabled
      + system.adapter.sayit.0                  : sayit                 : raspberrypi        -  enabled, port: 0
      + system.adapter.sayit.1                  : sayit                 : raspberrypi        -  enabled, port: 0
      + system.adapter.sayit.2                  : sayit                 : raspberrypi        -  enabled, port: 0
      + system.adapter.sayit.3                  : sayit                 : raspberrypi        -  enabled, port: 0
      + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.synology.0               : synology              : raspberrypi        -  enabled, port: 5000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi        -  enabled
      + system.adapter.telegram.1               : telegram              : raspberrypi        -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi        -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi        -  enabled, port: /dev/serial/by-id/usb-Silicon_Lab        s_CP2102N_USB_to_UART_Bridge_Controller_4ace38115493eb11a4e2194f3d98b6d1-if00-po        rt0
      + instance is alive
      pi@raspberrypi:~ $
      Homoran L 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @LE-R.Kelly last edited by
        @le-r-kelly sagte in ioBroker seit Update node.js 12 auf 14 langsam:
        Da kommt mehr...
        gottseidank.
        was hast du als Repo eingestellt?
          LE-R.Kelly @LE-R.Kelly last edited by
          Da kommt mehr...
          + instance is alive
          pi@raspberrypi:~ $
          Das der sayit-Adapter viermal installiert wurde ist io. Der Adapter kann nicht richtig mit Gruppen umgehen, so dass ich anders meine Steuerung bzw. Ansagen nicht umsetzen konnte (je nach Zeit erfolgt die Sprachausgabe auf verschiedenen Google Home).
            Hilf mir mal bitte:; Was meinst Du mit Repo?
              crunchip Forum Testing Most Active @LE-R.Kelly last edited by crunchip
              @le-r-kelly https://www.iobroker.net/#de/documentation/basics/repositories.md
              sollte doch da sein?
                Homoran Global Moderator Administrators @crunchip last edited by
                @crunchip sagte in ioBroker seit Update node.js 12 auf 14 langsam:
                ich glaube in den neueren Versionen ist es jetzt unter Repos zum anhaken.
                Hab ich selber noch nicht, aber in Screenshots gesehen.
                Damit die Verwirrung endlich aufhört
                crunchip Feuersturm 2 Replies Last reply Reply Quote 0
                  crunchip Forum Testing Most Active @Homoran last edited by
                  @homoran habs gerade gemerkt, hatte da auch ewig nicht mehr rein gesehen, deshalb war ich gerade etwas verwundert.
                    ging mir so mit der von dir verlinkten Doku 👍
                      LE-R.Kelly @crunchip last edited by
                      Ist beta eingestellt - schon seit Jahren.
                        thorbecker last edited by
                        mach den javascript zurück auf 5.2.15
                        Ich hab jetzt wochenlang gesucht, immer wieder sporadisch die Eingabeereignisse von javascript, jarvis, influxdb und history auf 3000 bis 12000 hochgezählt
                        Dann war auch kaum noch irgendwas aufrufbar, die Scripte nicht oder nur verzögert funktioniert.
                        VIS ging nicht oder nur verzögert. Teilweise hat sich System selbst neu gestartet oder ich habe selbst einen reboot gemacht.
                        System mehrfach neu aufgesetzt (verschiedene Raspberrys, Proxmox), Backup nur das nötigste übernommen, Scripte komplett neu implementiert
                        -->Fehler kam immer wieder, in den logs (auch mit debug) nichts auffälliges ausser langsame DB-Connections wenn schon nix mehr ging
                        Heute morgen dann Downgrade VIS probiert -> trotzdem Fehler
                        Downgrade Javascript von 5.5.4 ?? auf 5.2.15 -> endlich wieder Ruhe bis jetzt -> Eingabeereignisse auf max. 1600 wie vorher
                        Gruß Thorsten
                          LE-R.Kelly @thorbecker last edited by
                          @thorbecker sagte in ioBroker seit Update node.js 12 auf 14 langsam:
                          Gruß Thorsten
                          Das klingt nachvollziehbar. Ich komme aber über die Adapter-Installation nur bis Version 5.4.3 😕
                            dann bist du Beta-Tester mit allen Unwägbarkeiten die dazu gehören.
                            Aber warum die Konsole das nicht zeigt macht es nicht unbedingt besser.
                            es hätte das Repo und alle Versionen gezeigt werden müssen.
                            ggf. liegt noch mehr im Argen, z.B. die node Installation.
                              thorbecker @LE-R.Kelly last edited by
                              Im Adapter als Expert rechts unten Version auswählen, vorher Repo auf stable
                                Das mit dem Beta-Tester ist mir bewusst. Wenn etwas nicht mehr richtig funktioniert hat ließ sich das bisher immer feststellen. Aber diesmal kam es schleichend, so dass es ich die Ursache nicht mehr feststellen kann 😞
                                  Thomas Braun Most Active @LE-R.Kelly last edited by Thomas Braun
                                  @le-r-kelly
                                  iobroker repo list
                                  iobroker update -i
                                  which nodes
                                  which node
                                  which npm
                                    5.2.15 ist nicht, er bietet von 5.0.11 bis 5.1.3 an.
                                    Ich denke mal die 5.1.3 wird es auch tun
                                      @le-r-kelly said in ioBroker seit Update node.js 12 auf 14 langsam:
                                      JAVASCRIPT nicht Admin
                                        @le-r-kelly versuch noch einmal iobroker update -i
                                        wenn das klappt gut, wenn nicht ist was faul, dann ist es keine gute Idee an allen möglichen Stellen zu schrauben, bevor nicht die Basis stimmt.
                                        B7n da auch nicht ganz fit dr7n, am Handy schon gar nicht.
                                        Vielleicht liest @Thomas-Braun mit
                                          LE-R.Kelly @Thomas Braun last edited by
                                          @thomas-braun sagte in ioBroker seit Update node.js 12 auf 14 langsam:
                                          @le-r-kelly
                                          iobroker repo list
                                          iobroker update -i
                                          which nodes
                                          which node
                                          which npm
                                          pi@raspberrypi:~ $ iobroker repo list
                                          Active repo(s): beta
                                          pi@raspberrypi:~ $ iobroker update -i
                                          Used repository: beta
                                          Adapter    "admin"        : 5.3.4    , installed 5.3.4
                                          Adapter    "backitup"     : 2.4.6    , installed 2.4.6
                                          Adapter    "ble"          : 0.12.0   , installed 0.12.0
                                          Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
                                          Adapter    "fakeroku"     : 0.2.1    , installed 0.2.1
                                          Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
                                          Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                                          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                          Adapter    "ical"         : 1.12.1   , installed 1.12.1
                                          Adapter    "info"         : 1.9.19   , installed 1.9.19
                                          Adapter    "javascript"   : 5.5.4    , installed 5.5.4
                                          Controller "js-controller": 4.0.21   , installed 4.0.21
                                          Adapter    "lovelace"     : 2.1.4    , installed 2.1.4
                                          Adapter    "mqtt"         : 3.0.5    , installed 3.0.5
                                          Adapter    "nut"          : 1.5.1    , installed 1.5.1
                                          Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                                          Adapter    "sayit"        : 1.12.6   , installed 1.12.6
                                          Adapter    "shelly"       : 5.3.2    , installed 5.3.2
                                          Adapter    "simple-api"   : 2.6.4    , installed 2.6.4
                                          Adapter    "synology"     : 2.1.6    , installed 2.1.6
                                          Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                          Adapter    "telegram"     : 1.12.2   , installed 1.12.2
                                          Adapter    "viessmannapi" : 2.0.9    , installed 2.0.9
                                          Adapter    "web"          : 4.2.3    , installed 4.2.3
                                          Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
                                          pi@raspberrypi:~ $ which nodes
                                          /usr/bin/node
                                          pi@raspberrypi:~ $ which npm
                                          /usr/bin/npm
                                          pi@raspberrypi:~ $
                                          crunchip T 2 Replies Last reply Reply Quote 0
                                            Ist JAVASCRIPT:
                                            2587
