    4. ioBroker seit Update node.js 12 auf 14 langsam
      Homoran Global Moderator Administrators @LE-R.Kelly last edited by
      @le-r-kelly versuch noch einmal iobroker update -i
      wenn das klappt gut, wenn nicht ist was faul, dann ist es keine gute Idee an allen möglichen Stellen zu schrauben, bevor nicht die Basis stimmt.
      B7n da auch nicht ganz fit dr7n, am Handy schon gar nicht.
      Vielleicht liest @Thomas-Braun mit
        LE-R.Kelly @Thomas Braun last edited by
        @thomas-braun sagte in ioBroker seit Update node.js 12 auf 14 langsam:
        @le-r-kelly
        iobroker repo list
        iobroker update -i
        which nodes
        which node
        which npm
        pi@raspberrypi:~ $ iobroker repo list
        Active repo(s): beta
        pi@raspberrypi:~ $ iobroker update -i
        Used repository: beta
        Adapter    "admin"        : 5.3.4    , installed 5.3.4
        Adapter    "backitup"     : 2.4.6    , installed 2.4.6
        Adapter    "ble"          : 0.12.0   , installed 0.12.0
        Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
        Adapter    "fakeroku"     : 0.2.1    , installed 0.2.1
        Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "ical"         : 1.12.1   , installed 1.12.1
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "javascript"   : 5.5.4    , installed 5.5.4
        Controller "js-controller": 4.0.21   , installed 4.0.21
        Adapter    "lovelace"     : 2.1.4    , installed 2.1.4
        Adapter    "mqtt"         : 3.0.5    , installed 3.0.5
        Adapter    "nut"          : 1.5.1    , installed 1.5.1
        Adapter    "radar2"       : 2.0.3    , installed 2.0.3
        Adapter    "sayit"        : 1.12.6   , installed 1.12.6
        Adapter    "shelly"       : 5.3.2    , installed 5.3.2
        Adapter    "simple-api"   : 2.6.4    , installed 2.6.4
        Adapter    "synology"     : 2.1.6    , installed 2.1.6
        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
        Adapter    "telegram"     : 1.12.2   , installed 1.12.2
        Adapter    "viessmannapi" : 2.0.9    , installed 2.0.9
        Adapter    "web"          : 4.2.3    , installed 4.2.3
        Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
        pi@raspberrypi:~ $ which nodes
        /usr/bin/node
        pi@raspberrypi:~ $ which npm
        /usr/bin/npm
        pi@raspberrypi:~ $
        crunchip T 2 Replies Last reply Reply Quote 0
          LE-R.Kelly @thorbecker last edited by
          @thorbecker sagte in ioBroker seit Update node.js 12 auf 14 langsam:
          @le-r-kelly said in ioBroker seit Update node.js 12 auf 14 langsam:
          Das klingt nachvollziehbar. Ich komme aber über die Adapter-Installation nur bis Version 5.4.3 😕
          Im Adapter als Expert rechts unten Version auswählen, vorher Repo auf stable
          5.2.15 ist nicht, er bietet von 5.0.11 bis 5.1.3 an.
          Ich denke mal die 5.1.3 wird es auch tun
          JAVASCRIPT nicht Admin
          Ist JAVASCRIPT:
            thorbecker @LE-R.Kelly last edited by
            und Zeile 18 bist du auf 5.5.4
              crunchip Forum Testing Most Active @LE-R.Kelly last edited by crunchip
              @le-r-kelly sagte in ioBroker seit Update node.js 12 auf 14 langsam:
              which nodes
              das war ein SchreibFehler, korrekt wäre
              which nodejs
              iobroker update -i
              hat ja funktioniert, also alles gut
                @le-r-kelly
                iobroker repo list
                iobroker update -i
                which nodes
                which node
                which npm
                /usr/bin/node
                /usr/bin/npm
                pi@raspberrypi:~ $
                Zeile 7 = beta !!!!
                Homoran crunchip J 3 Replies Last reply Reply Quote 0
                  Homoran Global Moderator Administrators @thorbecker last edited by
                  Zeile 7 = beta !!!!
                  das wissen wir ja schon
                    crunchip Forum Testing Most Active @thorbecker last edited by
                    Zeile 18 meint er
                      Jan1 @thorbecker last edited by
                      @thorbecker
                      Ist nicht schlimm, war bei mir noch nie im Stable 😉
                      Da muss man eben damit rechnen, dass ab und zu auch mal ne neue Version noch ein paar Bugs hat. Ob die dann wirklich dramatisch sind ist was anderes. Für Normal User ist aber schon Stable empfohlen.
                        Bis dahin kann ich nicht scrollen. Das was zur Auswahl steht hatte ich als Screenshot gezeigt.
                          LE-R.Kelly @crunchip last edited by
                          @crunchip sagte in ioBroker seit Update node.js 12 auf 14 langsam:
                          which nodes
                          which nodejs
                          iobroker update -i
                          War auch iO 🙂
                          pi@raspberrypi:~ $ which nodejs
                          /usr/bin/nodejs
                          pi@raspberrypi:~ $
                            dann können wir ja jetzt weiter machen:
                            Der Web-Server ist klar. Web socket und socket.io kann ich nicht mehr zuordnen. Es kann sein, dass ich diese für Versuche mit Visualisierungen installiert hatte. Kann ich die Abhängigkeiten irgendwie feststellen?
                            zumindest sind sie installiert
                            bei den Instanzen tauchen sie allerdings nicht auf
                              thorbecker @Jan1 last edited by
                              @jan1 said in ioBroker seit Update node.js 12 auf 14 langsam:
                              @thorbecker
                              Normalerweise ist bei mir nur stable, ob der Fehler z.B. auch mit 5.2.21 (last stable???) auftritt möchte ich jetzt erst mal nicht probieren.
                              Vom Gefühl her würde ich sagen das kam mit einer stable, probiere aber wie geschrieben schon mehrere Wochen und hatte immer in Richtung meiner Scripte gesucht und dabei.......
                                crunchip Forum Testing Most Active @Homoran last edited by
                                @homoran sagte in ioBroker seit Update node.js 12 auf 14 langsam:
                                wurde bei Einführung ja automatisch installiert, Instanz muss man selbst hinzufügen
                                bedeutet im Umkehrschluss es sollte im web.0, ** integriert** stehen
                                  LE-R.Kelly @LE-R.Kelly last edited by
                                  Ich muss mal doof fragen: Kann ich mir denn mehr anzeigen lassen? Ich kann nur wie auf dem Screenshot zu sehen scrollen und habe auch nichts zum Auswählen im Sinne von "zeige mehr..."
                                  Hab jetzt noch ein paar mal probiert, im stable wie auch beta - mehr als was ich geschrieben habe steht nicht zur Auswahl.
                                    nein. Wenn man eine Grenze überschritten hat, geht's nicht mehr über den admin zurück.
                                    du musst es dann über die Konsole downgraden
                                      thorbecker @Homoran last edited by
                                      @homoran said in ioBroker seit Update node.js 12 auf 14 langsam:
                                      Das merkwürdige ist ja er sieht nur bis 5.0.x bis 5.1.3 und ist auf 5.5.4
                                      Ich würde einfach die 5.1.3 probieren oder halt über konsole
                                        @thorbecker
                                        oder so?
                                        npm install iobroker.javascript@5.2.15 --production
                                          @thorbecker
                                          oder so?
                                          sieht schlüssig aus
                                            Thomas Braun Most Active @thorbecker last edited by
                                            sieht schlüssig aus
                                            Nein
                                            sudo - H -u iobroker
                                            Muss davor gesetzt werden
                                            2587
