    4. ioBroker seit Update node.js 12 auf 14 langsam
      thorbecker @LE-R.Kelly last edited by
      und Zeile 18 bist du auf 5.5.4
        crunchip Forum Testing Most Active @LE-R.Kelly last edited by crunchip
        @le-r-kelly sagte in ioBroker seit Update node.js 12 auf 14 langsam:
        which nodes
        das war ein SchreibFehler, korrekt wäre
        which nodejs
        iobroker update -i
        hat ja funktioniert, also alles gut
          @le-r-kelly said in ioBroker seit Update node.js 12 auf 14 langsam:
          @thomas-braun sagte in ioBroker seit Update node.js 12 auf 14 langsam:
          @le-r-kelly
          iobroker repo list
          iobroker update -i
          which nodes
          which node
          which npm
          pi@raspberrypi:~ $ iobroker repo list
          Active repo(s): beta
          pi@raspberrypi:~ $ iobroker update -i
          Used repository: beta
          Adapter    "admin"        : 5.3.4    , installed 5.3.4
          Adapter    "backitup"     : 2.4.6    , installed 2.4.6
          Adapter    "ble"          : 0.12.0   , installed 0.12.0
          Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
          Adapter    "fakeroku"     : 0.2.1    , installed 0.2.1
          Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
          Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "ical"         : 1.12.1   , installed 1.12.1
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "javascript"   : 5.5.4    , installed 5.5.4
          Controller "js-controller": 4.0.21   , installed 4.0.21
          Adapter    "lovelace"     : 2.1.4    , installed 2.1.4
          Adapter    "mqtt"         : 3.0.5    , installed 3.0.5
          Adapter    "nut"          : 1.5.1    , installed 1.5.1
          Adapter    "radar2"       : 2.0.3    , installed 2.0.3
          Adapter    "sayit"        : 1.12.6   , installed 1.12.6
          Adapter    "shelly"       : 5.3.2    , installed 5.3.2
          Adapter    "simple-api"   : 2.6.4    , installed 2.6.4
          Adapter    "synology"     : 2.1.6    , installed 2.1.6
          Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
          Adapter    "telegram"     : 1.12.2   , installed 1.12.2
          Adapter    "viessmannapi" : 2.0.9    , installed 2.0.9
          Adapter    "web"          : 4.2.3    , installed 4.2.3
          Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
          pi@raspberrypi:~ $ which nodes
          /usr/bin/node
          pi@raspberrypi:~ $ which npm
          /usr/bin/npm
          pi@raspberrypi:~ $
          Zeile 7 = beta !!!!
          Homoran crunchip J 3 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @thorbecker last edited by
            @thorbecker sagte in ioBroker seit Update node.js 12 auf 14 langsam:
            Zeile 7 = beta !!!!
            das wissen wir ja schon
              crunchip Forum Testing Most Active @thorbecker last edited by
              Zeile 18 meint er
                Jan1 @thorbecker last edited by
                @thorbecker
                Ist nicht schlimm, war bei mir noch nie im Stable 😉
                Da muss man eben damit rechnen, dass ab und zu auch mal ne neue Version noch ein paar Bugs hat. Ob die dann wirklich dramatisch sind ist was anderes. Für Normal User ist aber schon Stable empfohlen.
                  LE-R.Kelly @thorbecker last edited by
                  Bis dahin kann ich nicht scrollen. Das was zur Auswahl steht hatte ich als Screenshot gezeigt.
                    LE-R.Kelly @crunchip last edited by
                    @crunchip sagte in ioBroker seit Update node.js 12 auf 14 langsam:
                    which nodes
                    which nodejs
                    iobroker update -i
                    War auch iO 🙂
                    pi@raspberrypi:~ $ which nodejs
                    /usr/bin/nodejs
                    pi@raspberrypi:~ $
                      dann können wir ja jetzt weiter machen:
                      Der Web-Server ist klar. Web socket und socket.io kann ich nicht mehr zuordnen. Es kann sein, dass ich diese für Versuche mit Visualisierungen installiert hatte. Kann ich die Abhängigkeiten irgendwie feststellen?
                      zumindest sind sie installiert
                      bei den Instanzen tauchen sie allerdings nicht auf
                        thorbecker @Jan1 last edited by
                        @jan1 said in ioBroker seit Update node.js 12 auf 14 langsam:
                        @thorbecker
                        Normalerweise ist bei mir nur stable, ob der Fehler z.B. auch mit 5.2.21 (last stable???) auftritt möchte ich jetzt erst mal nicht probieren.
                        Vom Gefühl her würde ich sagen das kam mit einer stable, probiere aber wie geschrieben schon mehrere Wochen und hatte immer in Richtung meiner Scripte gesucht und dabei.......
                          crunchip Forum Testing Most Active @Homoran last edited by
                          @homoran sagte in ioBroker seit Update node.js 12 auf 14 langsam:
                          wurde bei Einführung ja automatisch installiert, Instanz muss man selbst hinzufügen
                          bedeutet im Umkehrschluss es sollte im web.0, ** integriert** stehen
                            LE-R.Kelly @LE-R.Kelly last edited by
                            Ich muss mal doof fragen: Kann ich mir denn mehr anzeigen lassen? Ich kann nur wie auf dem Screenshot zu sehen scrollen und habe auch nichts zum Auswählen im Sinne von "zeige mehr..."
                            Hab jetzt noch ein paar mal probiert, im stable wie auch beta - mehr als was ich geschrieben habe steht nicht zur Auswahl.
                              Homoran Global Moderator Administrators @LE-R.Kelly last edited by
                              nein. Wenn man eine Grenze überschritten hat, geht's nicht mehr über den admin zurück.
                              du musst es dann über die Konsole downgraden
                                thorbecker @Homoran last edited by
                                @homoran said in ioBroker seit Update node.js 12 auf 14 langsam:
                                Das merkwürdige ist ja er sieht nur bis 5.0.x bis 5.1.3 und ist auf 5.5.4
                                Ich würde einfach die 5.1.3 probieren oder halt über konsole
                                  @thorbecker
                                  oder so?
                                  npm install iobroker.javascript@5.2.15 --production
                                    @thorbecker
                                    oder so?
                                    sieht schlüssig aus
                                      Thomas Braun Most Active @thorbecker last edited by
                                      sieht schlüssig aus
                                      Nein
                                      sudo - H -u iobroker
                                      Muss davor gesetzt werden
                                        Also
                                        sudo - H -u iobroker npm install iobroker.javascript@5.2.15 --production
                                        Und ich denke mal noch ein
                                        iobroker fix
                                        hinterher
                                          sieht schlüssig aus
                                          Nein
                                          und das Ganze unbedingt in /opt/iobroker ausführen
                                            LE-R.Kelly @Homoran last edited by
                                            So, Downgrade durchgeführt.
                                            Jetzt reagiert alles noch träger 😞
                                            2587
