    4. ioBroker seit Update node.js 12 auf 14 langsam
      thorbecker @LE-R.Kelly last edited by
      @le-r-kelly said in ioBroker seit Update node.js 12 auf 14 langsam:
      @thomas-braun sagte in ioBroker seit Update node.js 12 auf 14 langsam:
      @le-r-kelly
      iobroker repo list
      iobroker update -i
      which nodes
      which node
      which npm
      pi@raspberrypi:~ $ iobroker repo list
      Active repo(s): beta
      pi@raspberrypi:~ $ iobroker update -i
      Used repository: beta
      Adapter    "admin"        : 5.3.4    , installed 5.3.4
      Adapter    "backitup"     : 2.4.6    , installed 2.4.6
      Adapter    "ble"          : 0.12.0   , installed 0.12.0
      Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
      Adapter    "fakeroku"     : 0.2.1    , installed 0.2.1
      Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "ical"         : 1.12.1   , installed 1.12.1
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "javascript"   : 5.5.4    , installed 5.5.4
      Controller "js-controller": 4.0.21   , installed 4.0.21
      Adapter    "lovelace"     : 2.1.4    , installed 2.1.4
      Adapter    "mqtt"         : 3.0.5    , installed 3.0.5
      Adapter    "nut"          : 1.5.1    , installed 1.5.1
      Adapter    "radar2"       : 2.0.3    , installed 2.0.3
      Adapter    "sayit"        : 1.12.6   , installed 1.12.6
      Adapter    "shelly"       : 5.3.2    , installed 5.3.2
      Adapter    "simple-api"   : 2.6.4    , installed 2.6.4
      Adapter    "synology"     : 2.1.6    , installed 2.1.6
      Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
      Adapter    "telegram"     : 1.12.2   , installed 1.12.2
      Adapter    "viessmannapi" : 2.0.9    , installed 2.0.9
      Adapter    "web"          : 4.2.3    , installed 4.2.3
      Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
      pi@raspberrypi:~ $ which nodes
      /usr/bin/node
      pi@raspberrypi:~ $ which npm
      /usr/bin/npm
      pi@raspberrypi:~ $
      Zeile 7 = beta !!!!
      Homoran crunchip J 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @thorbecker last edited by
        @thorbecker sagte in ioBroker seit Update node.js 12 auf 14 langsam:
        Zeile 7 = beta !!!!
        das wissen wir ja schon
          crunchip Forum Testing Most Active @thorbecker last edited by
          Zeile 18 meint er
            Jan1 @thorbecker last edited by
            @thorbecker
            Ist nicht schlimm, war bei mir noch nie im Stable 😉
            Da muss man eben damit rechnen, dass ab und zu auch mal ne neue Version noch ein paar Bugs hat. Ob die dann wirklich dramatisch sind ist was anderes. Für Normal User ist aber schon Stable empfohlen.
              LE-R.Kelly @thorbecker last edited by
              und Zeile 18 bist du auf 5.5.4
              Bis dahin kann ich nicht scrollen. Das was zur Auswahl steht hatte ich als Screenshot gezeigt.
                LE-R.Kelly @crunchip last edited by
                @crunchip sagte in ioBroker seit Update node.js 12 auf 14 langsam:
                @le-r-kelly sagte in ioBroker seit Update node.js 12 auf 14 langsam:
                which nodes
                das war ein SchreibFehler, korrekt wäre
                which nodejs
                iobroker update -i
                hat ja funktioniert, also alles gut
                War auch iO 🙂
                pi@raspberrypi:~ $ which nodejs
                /usr/bin/nodejs
                pi@raspberrypi:~ $
                  dann können wir ja jetzt weiter machen:
                  Der Web-Server ist klar. Web socket und socket.io kann ich nicht mehr zuordnen. Es kann sein, dass ich diese für Versuche mit Visualisierungen installiert hatte. Kann ich die Abhängigkeiten irgendwie feststellen?
                  zumindest sind sie installiert
                  bei den Instanzen tauchen sie allerdings nicht auf
                    thorbecker @Jan1 last edited by
                    @jan1 said in ioBroker seit Update node.js 12 auf 14 langsam:
                    @thorbecker
                    Normalerweise ist bei mir nur stable, ob der Fehler z.B. auch mit 5.2.21 (last stable???) auftritt möchte ich jetzt erst mal nicht probieren.
                    Vom Gefühl her würde ich sagen das kam mit einer stable, probiere aber wie geschrieben schon mehrere Wochen und hatte immer in Richtung meiner Scripte gesucht und dabei.......
                      crunchip Forum Testing Most Active @Homoran last edited by
                      @homoran sagte in ioBroker seit Update node.js 12 auf 14 langsam:
                      wurde bei Einführung ja automatisch installiert, Instanz muss man selbst hinzufügen
                      bedeutet im Umkehrschluss es sollte im web.0, ** integriert** stehen
                        LE-R.Kelly @LE-R.Kelly last edited by
                        Ich muss mal doof fragen: Kann ich mir denn mehr anzeigen lassen? Ich kann nur wie auf dem Screenshot zu sehen scrollen und habe auch nichts zum Auswählen im Sinne von "zeige mehr..."
                        Hab jetzt noch ein paar mal probiert, im stable wie auch beta - mehr als was ich geschrieben habe steht nicht zur Auswahl.
                          Homoran Global Moderator Administrators @LE-R.Kelly last edited by
                          nein. Wenn man eine Grenze überschritten hat, geht's nicht mehr über den admin zurück.
                          du musst es dann über die Konsole downgraden
                            thorbecker @Homoran last edited by
                            @homoran said in ioBroker seit Update node.js 12 auf 14 langsam:
                            Das merkwürdige ist ja er sieht nur bis 5.0.x bis 5.1.3 und ist auf 5.5.4
                            Ich würde einfach die 5.1.3 probieren oder halt über konsole
                              @thorbecker
                              oder so?
                              npm install iobroker.javascript@5.2.15 --production
                                @thorbecker
                                oder so?
                                sieht schlüssig aus
                                  Thomas Braun Most Active @thorbecker last edited by
                                  sieht schlüssig aus
                                  Nein
                                  sudo - H -u iobroker
                                  Muss davor gesetzt werden
                                    Also
                                    sudo - H -u iobroker npm install iobroker.javascript@5.2.15 --production
                                    Und ich denke mal noch ein
                                    iobroker fix
                                    hinterher
                                      sieht schlüssig aus
                                      Nein
                                      und das Ganze unbedingt in /opt/iobroker ausführen
                                        LE-R.Kelly @Homoran last edited by
                                        So, Downgrade durchgeführt.
                                        Jetzt reagiert alles noch träger 😞
                                          Ich hab jetzt so etwas im Log des ioBroker:
                                          • host.raspberrypi 2022-04-10 21:01:05.461 warn instance system.adapter.web.0 terminated due to SIGSEGV
                                          • host.raspberrypi 2022-04-10 21:01:05.461 error Caught by controller[0]: FATAL ERROR: MarkCompactCollector: young object promotion failed Allocation failed - JavaScript heap out of memory
                                          • host.raspberrypi 2022-04-10 21:01:05.461 error Caught by controller[0]: <--- JS stacktrace --->
                                          • host.raspberrypi 2022-04-10 21:01:05.460 error Caught by controller[0]: [1439:0x5573da8] 54982 ms: Scavenge (reduce) 777.0 (876.3) -> 776.8 (878.6) MB, 10.8 / 0.0 ms (average mu = 0.989, current mu = 0.990) allocation failure
                                          • host.raspberrypi 2022-04-10 21:01:05.460 error Caught by controller[0]: [1439:0x5573da8] 54959 ms: Scavenge (reduce) 775.2 (862.6) -> 775.0 (868.8) MB, 10.8 / 0.0 ms (average mu = 0.989, current mu = 0.990) allocation failure
                                          • host.raspberrypi 2022-04-10 21:01:05.460 error Caught by controller[0]: [1439:0x5573da8] 54937 ms: Scavenge (reduce) 773.3 (872.3) -> 773.1 (874.3) MB, 11.2 / 0.0 ms (average mu = 0.989, current mu = 0.990) allocation failure
                                          • host.raspberrypi 2022-04-10 21:01:05.459 error Caught by controller[0]: <--- Last few GCs --->
                                          Leider kann ich die nicht deuten
                                            Thomas Braun Most Active @LE-R.Kelly last edited by
                                            @le-r-kelly
                                            Ich würde sagen, da läuft ein Skript falsch.
                                            L Homoran 2 Replies Last reply Reply Quote 0
                                            2587
