    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    • DJMarc75
      DJMarc75 @Horst Böttcher last edited by
      @horst-böttcher
      https://forum.iobroker.net/post/787171
      • Horst Böttcher
        Horst Böttcher @tombox last edited by
        @tombox sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
        @draexler
        cd /opt/iobroker/
        npm install canvas
        ich arbeite daran das es gefixt wird
        pi@raspberrypi:/opt/iobroker $ iobroker stop
        pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/
        pi@raspberrypi:/opt/iobroker $ sudo npm install canvas
        > canvas@2.9.1 install /opt/iobroker/node_modules/canvas
        > node-pre-gyp install --fallback-to-build
        node-pre-gyp WARN Pre-built binaries not installable for canvas@2.9.1 and node@14.18.1 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
        node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
        gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/14.18.1"
        gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
        gyp ERR! configure error
        gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
        gyp ERR! System Linux 5.10.17-v7l+
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
        gyp ERR! cwd /opt/iobroker/node_modules/canvas
        gyp ERR! node -v v14.18.1
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        node-pre-gyp ERR! build error
        node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
        node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
        node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
        node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1058:16)
        node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
        node-pre-gyp ERR! System Linux 5.10.17-v7l+
        node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
        node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
        node-pre-gyp ERR! node -v v14.18.1
        node-pre-gyp ERR! node-pre-gyp -v v1.0.6
        node-pre-gyp ERR! not ok
        npm WARN @rollup/plugin-inject@4.0.4 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN @rollup/pluginutils@3.1.0 requires a peer of rollup@^1.20.0||^2.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN http-cookie-agent@1.0.5 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN rollup-plugin-polyfill-node@0.8.0 requires a peer of rollup@^1.20.0 || ^2.0.0 but none is installed. You must install peer dependencies yourself.
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! canvas@2.9.1 install: `node-pre-gyp install --fallback-to-build`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the canvas@2.9.1 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /root/.npm/_logs/2022-04-08T14_22_43_117Z-debug.log
          Thomas Braun Most Active @Horst Böttcher last edited by Thomas Braun
          @horst-böttcher sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
          NICHT mit sudo hantieren an der Stelle.
          Stand aber auch offenbar so nicht in der Anleitung. Warum macht man das also dann doch?
          System auf Stand halten.
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          Danach als user:
          cd /opt/iobroker
          npm install canvas
          Horst Böttcher 1 Reply Last reply Reply Quote 2
          • Horst Böttcher
            Horst Böttcher @Thomas Braun last edited by
            ich hatte es vorher ohne sudo gemacht
              @horst-böttcher
              Hast du jetzt die Hausaufgaben erledigt? System auf Stand?
              cd /opt/iobroker
              npm ls canvas
              liefert?
                senior1418 @tombox last edited by
                ist gefixt
                herzlichen Dank ! Es funktioniert wieder .
                  basty2 @tombox last edited by
                  @tombox Ich wollte nach dem aktuellen Stand nachfragen. Bei mir funktioniert die Darstellung der voraussichtlichen Lieferung und der Anzahl der Stopps nur bei Amazon. Die Infos gibt es bspw. teilweise auch bei der DHL. Ich fände es klasse, wenn diese Infos auch bei den anderen Unternehmen im JSON landen würden.
                    tombox @basty2 last edited by
                    @basty2 Also wenn sie nicht im rohen JSON sind wird es schwer darauf zuzugreifen. Ich habe bisher keine DHL mit Stop gehabt
                    DJMarc75 B 2 Replies Last reply Reply Quote 0
                    • DJMarc75
                      DJMarc75 @tombox last edited by
                      @tombox
                      Ich hatte schon einige Lieferungen von DHL welche im Livetracking auch die Stopps angezeigt haben - allerdings nur in der Ordnerstruktur. Ich habe aber davon abgesehen dies zu visualisieren oder anders zu verarbeiten da sich die Anzahl der Stopps und eigentlich alle Daten im Livetracking ja auch nur ändern wenn sich die Instanz die Daten holt. In meinem Fall alle 15 Minuten und zwischen den Intervallen sind deutliche Abweichungen im Vergleich zur APP von DHL zu erkennen.
                      Habe im Moment leider keine Lieferung von DHL um auch mal zu sehen ob da was in der rohen JSON eingetragen wird.
                        @djmarc75 @tombox Spannend, bei mir sind ca. 95% der Lieferungen mit Livetracking. Deshalb aktualisiere ich auch aller 5 Minuten. Es reicht ja meistens zu sehen, dass die Stopps angezeigt werden.
                        ich kann aktuell keine Bilder hochladen. Kann Euch aber die Werte sagen. Vielleicht können andere das ergänzen oder eigene Erfahrungen mit einbringen.
                        Anzahl der Stopps sind die beiden Elemente wichtig:
                        parcel.0.dhl.sendungen03.sendungsdetails.liveTracking.countdownTextKey (hier steht aber immer ein CD davor)
                        Ich werde morgen mal schauen, welcher der beiden Werte wirklich die nächsten Stopps anzeigt.
                        Die nächsten beiden Werte haben meist nur einen Dummy: die Uhrzeit 0:00 Uhr, aber manchmal waren da auch schon Uhrzeiten mit Zeitfenstern.
                        parcel.0.dhl.sendungen03.sendungsdetails.zustellung.zustellzeitfensterVon
                        Die Werte des liveTracking bleiben auch bestehen, wenn schon zugestellt wurde. D.h. es wird nicht mit 0 oder so überschrieben.
                        jetzt ging doch der Upload.
                          @basty2 Einfach den inhalt von
                          parcel.0.dhl.json
                          per pn
                          • Ro75
                            Ro75 last edited by
                            Moin. Zuerst, klasse Adapter. Ich habe heute den Parcel-Adapter von der Version 0.0.12 auf die Version 0.0.15 aktualisiert. Soweit alles gut. Allerdings bekomme ich heute eine Amazon-Sendung angezeigt, welche "verspätet" ist. Allerdings ist diese Sendung tatsächlich zugestellt (16.03.), nur in den Daten nicht.
                                  "id": "304-3xxxxxx-xxxxxxx",
                                  "name": "Türdichtung Türgummi universal für Backofen E-Herd kompatibel passend für AEG Electrolux Siemens Neff Miele Bosch Küppersbusch Günstig Ersatz",
                                  "status": "Unterwegs, aber verspätet",
                                  "detailedState": {
                                    "deviceType": "desktop",
                                    "isLexicalExceptionMessagePresent": true,
                                    "orderId": "304-xxxxxx-xxxxxxx",
                                    "shortStatus": "IN_TRANSIT",
                                    "promise": {
                                      "secondaryPromiseIdentifier": "NONE",
                                      "promiseMessage": "Unterwegs, aber verspätet"
                                    "isApp": false,
                                    "themeParameters": "o=304-3xxxxxx-xxxxxxx&s=DFL4rxxxx&i=kjkosqnqornwqr",
                                    "itemId": "kjkosqnqornwqr",
                                    "signInRedirectUrl": "/progress-tracker/package/ref=ppx_yo_dt_b_track_package?itemId=kjkosqnqornwqr&orderId=304-xxxxxx-xxxxxxx&_encoding=UTF8&shipmentId=DFL4rxxxx&disableCsd=missing-library&vt=YOUR_ORDERS",
                                    "isMfn": true,
                                    "shipmentId": "DFL4rcxxx",
                                    "keepSecondaryUntouched": true,
                                    "customerId": "A2M65VYxxxxxxx",
                                    "realm": "GBAmazon",
                                    "visitTrigger": "YOUR_ORDERS",
                                    "trackingId": ""
                            Schon mal dickes Danke an Euch.
                              tombox @Ro75 last edited by
                              @ro75 Da kann man nichts machen wenn Amazon die Zustellung nicht erfassen kann das passiert manchmal bei Briefsendungen
                              • Ro75
                                Ro75 last edited by Ro75
                                Alles klar. Ich gehe davon aus, dass die Sendung dann irgendwann aus der Liste verschwindet. Danke.
                                • DJMarc75
                                  DJMarc75 last edited by
                                  @basty2
                                  Hast Du heute bei deinem Paket die Einträge im JSON verfolgen können ?
                                  Ich bekomme am Samstag eins per DHL, werde dann auch mal das LiveTracking verfolgen.
                                    tombox @DJMarc75 last edited by
                                    @djmarc75 Livetracking sollte in der aktuelle github version drin sein
                                    B DJMarc75 2 Replies Last reply Reply Quote 2
                                      basty2 @tombox last edited by basty2
                                      @tombox Hallo, ich hatte am Donnerstag das Paket bereits erhalten. Heute geht es bereits sehr gut. Aber die Anzahl der Stopps sind beim Namen hinterlegt. Wäre es möglich es hinter "In Zustellung" zu schreiben?
                                          "id": "xxxx",
                                          "name": "xxxx GmbH 4 Stopps",
                                          "status": "In Zustellung",
                                          "source": "DHL",
                                          "delivery_status": 40,
                                          "inDelivery": true,
                                          "direction": "ANKOMMEND"
                                      • DJMarc75
                                        DJMarc75 @tombox last edited by DJMarc75
                                        @tombox said in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                        Funktioniert, danke dafür.
                                        Aber ich pflichte @basty2 bei. Besser wäre es tatsächlich hinter In Zustellung (vll mit einem Bindestrich) zu schreiben, da es so in der VIS über das Widget besser ersichtlich ist.
                                          @basty2 Ja muss natürlich in den status habe ich korrigiert
                                          haselchen 1 Reply Last reply Reply Quote 3
                                          • haselchen
                                            haselchen Most Active @tombox last edited by
                                            Hier tut sich so schnell, so viel, dass man gar nicht mehr hinterherkommt 🙂
                                            Ist in der Zwischenzeit was an den DPD Datenpunkten gemacht worden?
                                            Der JSON Eintrag ist alles , was ich da habe.
                                            Adapter Version 0.0.15
                                            1.0k
                                            17track amazon briefe dhl dpd gls ups
                                            122
                                            1534
                                            527396
