    4. Sonoff NSPanel
    Sonoff NSPanel
    • Mikewolf
      Mikewolf @Armilar last edited by
      @armilar
      Soweit alles gemacht im Display (konsole kommt )
      mqtt.0.panel1.cmnd.CustomSend10:11:24.683 MQT: panel1/STATE = {"Time":"2022-04-14T10:11:24","Uptime":"0T00:05:10","UptimeSec":310,"Heap":169,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":1,"Berry":{"HeapUsed":14,"Objects":220},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"UbiNes1","BSSId":"E0:63:DA:BA:48:54","Channel":13,"Mode":"11n","RSSI":82,"Signal":-59,"LinkCount":1,"Downtime":"0T00:00:04"}}
      10:11:24.744 MQT: panel1/SENSOR = {"Time":"2022-04-14T10:11:24","ANALOG":{"Temperature1":23.6},"ESP32":{"Temperature":46.7},"TempUnit":"C"}
      10:11:28.326 MQT: panel1/RESULT = {"Command":"Unknown"}
      10:11:28.828 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
      10:11:28.876 MQT: panel1/RESULT = {"Command":"Unknown"}
      10:11:28.919 MQT: panel1/RESULT = {"Command":"Unknown"}
      10:11:28.975 MQT: panel1/RESULT = {"Command":"Unknown"}
      10:11:29.024 MQT: panel1/RESULT = {"Command":"Unknown"}
      10:11:29.078 MQT: panel1/RESULT = {"Command":"Unknown"}
      10:11:29.126 MQT: panel1/RESULT = {"Command":"Unknown"}
      10:11:34.731 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
      Im Display steht waiting for Content
      This take longer ...
      Mit freundlichen Grüßen
      mikewolf
        holgerwolf @Mikewolf last edited by
        @mikewolf Hast du den MQTT Explorer laufen?
        Dann setze mal unter CustomSend z Bsp den Topic "time, 10:32" ab.
        Mikewolf 1 Reply Last reply Reply Quote 0
        • Mikewolf
          Mikewolf @holgerwolf last edited by
          @holgerwolf said in Sonoff NSPanel:
          "time, 10:32"
          hallo habe mit Mqtt Explorer gesendet
          10:41:56.641 MQT: panel1/STATE = {"Time":"2022-04-14T10:41:56","Uptime":"0T00:15:10","UptimeSec":910,"Heap":168,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":14,"Objects":220},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"UbiNes1","BSSId":"E0:63:DA:BA:48:54","Channel":13,"Mode":"11n","RSSI":86,"Signal":-57,"LinkCount":1,"Downtime":"0T00:00:04"}}
          10:41:56.675 MQT: panel1/SENSOR = {"Time":"2022-04-14T10:41:56","ANALOG":{"Temperature1":27.5},"ESP32":{"Temperature":51.7},"TempUnit":"C"}
          10:42:00.422 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
          10:42:06.319 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
          10:42:08.464 MQT: panel1/RESULT = {"Command":"Unknown"}
          10:42:11.666 MQT: panel1/RESULT = {"Command":"Unknown"}
          10:42:12.317 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
          10:42:17.115 MQT: panel1/RESULT = {"Command":"Unknown"}
          10:42:18.217 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
          10:42:21.131 MQT: panel1/RESULT = {"CustomSend":"Done"}
          10:42:24.116 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
          10:42:25.332 MQT: panel1/RESULT = {"CustomSend":"Done"}
          10:42:28.830 MQT: panel1/RESULT = {"CustomSend":"Done"}
          10:42:30.122 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
          10:42:36.030 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
          10:42:41.919 MQT: panel1/RESULT = {"CustomRecv":"event,startup,31,eu"}
          mein Panel heißt panel1
          habe alle namen auch in Mqtt und Tasmota auf panel1 gesetzt um irrtümer zu vermeiden
          H Armilar 2 Replies Last reply Reply Quote 0
            @mikewolf Also das muss im MQTT Explorer so aussehen:
            Und dann unter "CustomSend" mal einen beliebigen time Befehl abgeben.
            Der sollte in der Tasmota Console dann auch auftauchen.
            Mikewolf H 2 Replies Last reply Reply Quote 0
            • Mikewolf
              Mikewolf @holgerwolf last edited by Mikewolf
              @holgerwolf
              Danke das Du mir hilfst !
              Wenn ich mit Mqtt explorer Befehls absetze kommt in Tasmota console
              11:57:51.154 MQT: panel1/RESULT = {"CustomSend":"Done"}
              Display weiterhin waiting for content...
              und kenne mich leider mit scipt nicht wirklich aus , bin eher HW fest
              H R Armilar britzelpuf 4 Replies Last reply Reply Quote 0
                @mikewolf Das war leider nur ein erfolgloser Versuch, weil ich auch die Problem nach dem Neustart des iobroker mqtt Adapters hab und die Kommunikation einen "Anschubser" über den Explorer braucht.
                Jetzt bin ich mit meiner Weisheit dann auch am Ende. Veilleicht hat @Armilar noch ne Idee...
                  ronny130286 @Mikewolf last edited by
                  @mikewolf
                  Du hast aber auch alles genau so gemacht wie es @Armilar hier
                  @armilar said in Sonoff NSPanel:
                  @armilar sagte in Sonoff NSPanel:
                  @mikewolf sagte in Sonoff NSPanel:
                  Hallo wenn ich ts script starte kommt
                  Javascript.0 (1002) script.js.HPCLTEST.Skript_3NS: TypeScript compilation failed: var Icons = new IconsSelector(); ^ ERROR: Cannot find name 'IconsSelector'.
                  Gibts eine step by step anleitung ?? probiere seit über einer Woche das zum laufen zu bekommen,
                  und dieser Thread ist etwas unübersichtlich geworden ..Speziell für nen neuanfang !
                  mikewolf
                  Ich versuche es mal:
                  • Tasmota flashen (analog Anleitung @haus-automatisierung) Die ist schon echt super erklärt! - Vielleicht macht er ja hierzu auch ein Video 😉
                  • autoexec.be in Tasmota Konsole/Verwalte Dateisystem anlegen
                  • Nachfolgenden Befehl in Tasmota-Konsole ausführen
                  Backlog UpdateDriverVersion https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be; Restart 1
                  • NSPanel TFT Flashen mit (aktuelle Version 2.0.7):
                  FlashNextion http://nspanel.pky.eu/lui-release.tft
                  Das NSPanel kurz rebooten - kann nicht schaden - Danach wartet es auf Infos von ioBroker
                  • TypeScript unter ioBroker/Skripte anlegen analog Britzelpuf auf Github https://github.com/joBr99/nspanel-lovelace-ui/tree/main/ioBroker Inhalt aus der NsPanelTs.ts übernehmen oder mein Script verwenden:
                  (@britzelpuf hat eine Anpassung auf das letzte Release 1.9.1 auf 2.0.7 von @joBr99 gemacht. Daher dringend das neueste TS-Script verwenden, sonst läuft es nicht)
                  const Months = ["Januar", "Februar", "März", "April", "Mai", "Juni", "Juli", "August", "September", "Oktober", "November", "Dezember"];
                  const Days = ["Sonntag", "Montag", "Dienstag", "Mittwoch", "Donnerstag", "Freitag", "Samstag"];
                  const Red: RGB = { red: 255, green: 0, blue: 0 };
                  const White: RGB = { red: 255, green: 255, blue: 255 };
                  const Off: RGB = { red: 68, green: 115, blue: 158 };
                  const On: RGB = { red: 253, green: 216, blue: 53 };
                  const BatteryFull: RGB = { red: 96, green: 176, blue: 62 }
                  const BatteryEmpty: RGB = { red: 179, green: 45, blue: 25 }
                  //----Möglichkeit, im Screensaver zwischen Accu-Weather Forcast oder selbstdefinierten Werten zu wählen---------------------------------
                  var weatherForecast = true; //true = WheatherForecast 5 Days --- false = Config --> firstScreensaverEntity - fourthScreensaverEntity ...
                  //Spotify Instanz
                  var spotifyInstanz = "spotify-premium.0"
                  var Buero_Seite_1: PageEntities =
                      "type": "cardEntities",
                      "heading": "Büro",
                      "useColor": true,
                      "items": [
                          <PageItem>{ id: "alias.0.NSPanel_1.Schreibtischlampe"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Deckenbeleuchtung"},
                          <PageItem>{ id: "alias.0.NSPanel_1.MyTestbutton", icon: "lightbulb", offColor: Off, onColor: On, name: "Taster"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Luftreiniger", icon: "power" }
                  var Buero_Seite_2: PageGrid =
                      "type": "cardGrid",
                      "heading": "Büro",
                      "useColor": true,
                      "items": [
                          <PageItem>{ id: "alias.0.NSPanel_1.Schreibtischlampe", name: "Schreibtisch"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Deckenbeleuchtung", name: "Deckenlampe"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Testlampe2"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Luftreiniger", icon: "power"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Radio.TuneIn", icon: "play"}
                  var Spotify: PageMedia =
                      "type": "cardMedia",
                      "heading": "Spotify",
                      "useColor": false,
                      "items": [<PageItem>{ id: "alias.0.NSPanel_1.Spotify" }]
                  var Buero_Themostat: PageThermo =
                      "type": "cardThermo",
                      "heading": "Thermostat",
                      "useColor": true,
                      "items": [<PageItem>{ id: "alias.0.NSPanel_1.Thermostat_Büro" }]
                  var Buero_Alarm: PageAlarm =
                      "type": "cardAlarm",
                      "heading": "Alarm",
                      "useColor": true,
                      "items": [<PageItem>{ id: "alias.0.NSPanel_1.Alarm" }]
                  var button1Page: PageGrid =
                      "type": "cardGrid",
                      "heading": "Radio",
                      "useColor": true,
                      "items": [
                          <PageItem>{ id: "alias.0.Radio.NJoy" },
                          <PageItem>{ id: "alias.0.Radio.Delta_Radio" },
                          <PageItem>{ id: "alias.0.Radio.NDR2" },
                  var button2Page: PageEntities =
                      "heading": "Knopf2",
                      "useColor": true,
                      "items": [
                          <PageItem>{ id: "alias.0.Schlafen" },
                          <PageItem>{ id: "alias.0.Stern" }
                  export const config: Config = {
                      panelRecvTopic: "mqtt.0.SmartHome.NSPanel_1.tele.RESULT",       //anpassen
                      panelSendTopic: "mqtt.0.SmartHome.NSPanel_1.cmnd.CustomSend",   //anpassen
                      firstScreensaverEntity: { ScreensaverEntity: "hmip.0.devices.3014F711A000185BE9922BCF.channels.1.humidity", ScreensaverEntityIcon: "water-percent", ScreensaverEntityText: "Luft", ScreensaverEntityUnitText: "%" },
                      secondScreensaverEntity: { ScreensaverEntity: "accuweather.0.Daily.Day1.Day.PrecipitationProbability", ScreensaverEntityIcon: "weather-pouring", ScreensaverEntityText: "Regen", ScreensaverEntityUnitText: "%" },
                      thirdScreensaverEntity: { ScreensaverEntity: "0_userdata.0.Wetter.Windstaerke_homaticIP", ScreensaverEntityIcon: "weather-windy", ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: "bft" },
                      fourthScreensaverEntity: { ScreensaverEntity: "accuweather.0.Current.UVIndex", ScreensaverEntityIcon: "solar-power", ScreensaverEntityText: "UV", ScreensaverEntityUnitText: "" },
                      timeoutScreensaver: 15,
                      dimmode: 8,
                      screenSaverDoubleClick: false,
                      locale: "de_DE",
                      timeFormat: "%H:%M",
                      dateFormat: "%A, %d. %B %Y",
                      weatherEntity: "alias.0.Wetter.Wetter",
                      defaultOffColor: Off,
                      defaultOnColor: On,
                      defaultColor: Off,
                      temperatureUnit: "°C",
                      pages: [Buero_Seite_1,
                              Buero_Seite_2,
                              Spotify,
                              Buero_Themostat,
                              Buero_Alarm
                      button1Page: button1Page,
                      button2Page: button2Page
                  // _________________________________ Ab hier keine Konfiguration mehr _____________________________________
                  var subscriptions: any = {};
                  var screensaverEnabled : boolean = false;
                  var pageId = 0;
                  schedule("* * * * *", function () {
                      SendTime();
                  schedule("0 * * * *", function () {
                      SendDate();
                  // Only monitor the extra nodes if present
                  var updateArray: string[] = [];
                  if (config.firstScreensaverEntity !== null && config.firstScreensaverEntity.ScreensaverEntity != null && existsState(config.firstScreensaverEntity.ScreensaverEntity)) {
                      updateArray.push(config.firstScreensaverEntity.ScreensaverEntity)
                  if (config.secondScreensaverEntity !== null && config.secondScreensaverEntity.ScreensaverEntity != null && existsState(config.secondScreensaverEntity.ScreensaverEntity)) {
                      updateArray.push(config.secondScreensaverEntity.ScreensaverEntity)
                  if (config.thirdScreensaverEntity !== null && config.thirdScreensaverEntity.ScreensaverEntity != null && existsState(config.thirdScreensaverEntity.ScreensaverEntity)) {
                      updateArray.push(config.thirdScreensaverEntity.ScreensaverEntity)
                  if (config.fourthScreensaverEntity !== null && config.fourthScreensaverEntity.ScreensaverEntity != null && existsState(config.fourthScreensaverEntity.ScreensaverEntity)) {
                      updateArray.push(config.fourthScreensaverEntity.ScreensaverEntity)
                  if (updateArray.length > 0) {
                      on(updateArray, function () {
                          HandleScreensaverUpdate();
                  on({ id: config.panelRecvTopic }, function (obj) {
                      if (obj.state.val.startsWith('\{"CustomRecv":')) {
                          var json = JSON.parse(obj.state.val);
                          var split = json.CustomRecv.split(",");
                          HandleMessage(split[0], split[1], parseInt(split[2]), split);
                  function SendToPanel(val: Payload | Payload[]): void {
                      if (Array.isArray(val)) {
                          val.forEach(function (id, i) {
                              setState(config.panelSendTopic, id.payload);
                      else
                          setState(config.panelSendTopic, val.payload);
                  function HandleMessage(typ: string, method: string, page: number, words: Array<string>): void {
                      if (typ == "event") {
                          switch (method) {
                              case "startup":
                                  screensaverEnabled = false;
                                  UnsubscribeWatcher();
                                  HandleStartupProcess();
                                  pageId = 0;
                                  GeneratePage(config.pages[0]);
                                  break;
                              case "sleepReached":
                                  screensaverEnabled = true;
                                  HandleScreensaver();
                                  break;
                              case "pageOpenDetail":
                                  let pageItem = config.pages[pageId].items.find(e => e.id === words[3]);
                                  if (pageItem !== undefined)
                                      SendToPanel(GenerateDetailPage(words[2], pageItem));
                              case "buttonPress2":
                                  HandleButtonEvent(words);
                                  break;
                              case "button1":
                              case "button2":
                                  HandleHardwareButton(method);
                              default:
                                  break;
                  function GeneratePage(page: Page): void {
                      switch (page.type) {
                          case "cardEntities":
                              SendToPanel(GenerateEntitiesPage(<PageEntities>page));
                              break;
                          case "cardThermo":
                              SendToPanel(GenerateThermoPage(<PageThermo>page));
                              break;
                          case "cardGrid":
                              SendToPanel(GenerateGridPage(<PageGrid>page));
                              break;
                          case "cardMedia":
                              SendToPanel(GenerateMediaPage(<PageMedia>page));
                              break;
                          case "cardAlarm":
                              SendToPanel(GenerateAlarmPage(<PageAlarm>page));
                              break;
                  function HandleHardwareButton(method: string): void {
                      let page: (PageThermo | PageMedia | PageAlarm | PageEntities | PageGrid);
                      if (config.button1Page !== null && method == "button1") {
                          page = config.button1Page;
                      else if (config.button2Page !== null && method == "button2") {
                          page = config.button2Page;
                      else {
                          return;
                      // Set pageId to -1, because of the navigation arrows
                      let tempPageId = pageId;
                      pageId = -1;
                      GeneratePage(page);
                      pageId = tempPageId;
                  function HandleStartupProcess(): void {
                      SendDate();
                      SendTime();
                      SendToPanel({ payload: "timeout~" + config.timeoutScreensaver });
                      SendToPanel({ payload: "dimmode~" + config.dimmode });
                  function SendDate(): void {
                      var d = new Date();
                      var day = Days[d.getDay()];
                      var date = d.getDate();
                      var month = Months[d.getMonth()];
                      var year = d.getFullYear();
                      var _sendDate = "date~" + day + " " + date + " " + month + " " + year;
                      SendToPanel(<Payload>{ payload: _sendDate });
                  function SendTime(): void {
                      var d = new Date();
                      var hr = d.getHours().toString();
                      var min = d.getMinutes().toString();
                      if (d.getHours() < 10) {
                          hr = "0" + d.getHours().toString();
                      if (d.getMinutes() < 10) {
                          min = "0" + d.getMinutes().toString();
                      SendToPanel(<Payload>{ payload: "time~" + hr + ":" + min });
                  function GenerateEntitiesPage(page: PageEntities): Payload[] {
                      var out_msgs: Array<Payload> = [];
                      out_msgs = [{ payload: "pageType~cardEntities" }]
                      out_msgs.push({ payload: GeneratePageElements(page) });
                      return out_msgs
                  function GenerateGridPage(page: PageGrid): Payload[] {
                      out_msgs = [{ payload: "pageType~cardGrid" }]
                      return out_msgs
                  function GeneratePageElements(page: Page): string {
                      let maxItems = 0;
                          case "cardThermo":
                              maxItems = 1;
                              break;
                          case "cardAlarm":
                              maxItems = 1;
                              break;
                          case "cardMedia":
                              maxItems = 1;
                              break;
                              maxItems = 4;
                              break;
                          case "cardGrid":
                              maxItems = 6;
                              break;
                      let pageData = "entityUpd~" + page.heading + "~" + GetNavigationString(pageId)
                      for (let index = 0; index < maxItems; index++) {
                          if (page.items[index] !== undefined) {
                              pageData += CreateEntity(page.items[index], index + 1, page.useColor);
                          else {
                              pageData += CreateEntity(<PageItem>{ id: "delete" }, index + 1);
                      return pageData;
                  function CreateEntity(pageItem: PageItem, placeId: number, useColors: boolean = false): string {
                      var iconId = "0"
                      if (pageItem.id == "delete") {
                          return "~delete~~~~~"
                      var name: string;
                      var type: string;
                      // ioBroker
                      if (existsObject(pageItem.id)) {
                          let o = getObject(pageItem.id)
                          var val = null;
                          name = pageItem.name !== undefined ? pageItem.name : o.common.name.de
                          if (existsState(pageItem.id + ".GET")) {
                              val = getState(pageItem.id + ".GET").val;
                              RegisterEntityWatcher(pageItem.id + ".GET");
                          else if (existsState(pageItem.id + ".SET")) {
                              val = getState(pageItem.id + ".SET").val;
                              RegisterEntityWatcher(pageItem.id + ".SET");
                          var iconColor = rgb_dec565(config.defaultColor);
                          switch (o.common.role) {
                              case "light":
                                  type = "light"
                                  iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon("lightbulb");
                                  var optVal = "0"
                                  if (val === true || val === "true") {
                                      optVal = "1"
                                      iconColor = GetIconColor(pageItem, true, useColors);
                                  return "~" + type + "~" + pageItem.id + "~" + iconId + "~" + iconColor + "~" + name + "~" + optVal;
                              case "dimmer":
                                  type = "light"
                                  var optVal = "0"
                                  if (existsState(pageItem.id + ".ON_ACTUAL")) {
                                      val = getState(pageItem.id + ".ON_ACTUAL").val;
                                      RegisterEntityWatcher(pageItem.id + ".ON_ACTUAL");
                                  else if (existsState(pageItem.id + ".ON_SET")) {
                                      val = getState(pageItem.id + ".ON_SET").val;
                                      RegisterEntityWatcher(pageItem.id + ".ON_SET");
                                      optVal = "1"
                                      iconColor = GetIconColor(pageItem, existsState(pageItem.id + ".ACTUAL") ? getState(pageItem.id + ".ACTUAL").val : true, useColors);
                              case "blind":
                                  type = "shutter"
                                  iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon("window-open");
                              case "info":
                              case "value.temperature":
                              case "thermostat":
                                  type = "text";
                                  iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : o.common.role == "value.temperature" || o.common.role == "thermostat" ? Icons.GetIcon("thermometer") : Icons.GetIcon("information-outline");
                                  let unit = "";
                                  var optVal = "0"
                                      optVal = getState(pageItem.id + ".ON_ACTUAL").val;
                                      unit = GetUnitOfMeasurement(pageItem.id + ".ON_ACTUAL");
                                  else if (existsState(pageItem.id + ".ACTUAL")) {
                                      optVal = getState(pageItem.id + ".ACTUAL").val;
                                      unit = GetUnitOfMeasurement(pageItem.id + ".ACTUAL");
                                      RegisterEntityWatcher(pageItem.id + ".ACTUAL");
                                  if (o.common.role == "value.temperature") {
                                      iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon("thermometer");
                                  iconColor = GetIconColor(pageItem, parseInt(optVal), useColors);
                                  return "~" + type + "~" + pageItem.id + "~" + iconId + "~" + iconColor + "~" + name + "~" + optVal + " " + unit;
                              case "button":
                                  type = "button";
                                  iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon("gesture-tap-button");
                                  let buttonText = pageItem.name !== undefined ? pageItem.name : "PRESS";
                                  return "~" + type + "~" + pageItem.id + "~" + iconId + "~" + + iconColor + "~" + name + "~" + buttonText;
                              default:
                                  return "~delete~~~~~";
                  function GetIconColor(pageItem: PageItem, value: (boolean | number), useColors: boolean): number {
                      // dimmer
                      if ((pageItem.useColor || useColors) && pageItem.interpolateColor && typeof (value) === "number") {
                          let maxValue = pageItem.maxValue !== undefined ? pageItem.maxValue : 100;
                          let minValue = pageItem.minValue !== undefined ? pageItem.minValue : 0;
                          value = value > maxValue ? maxValue : value;
                          value = value < minValue ? minValue : value;
                          return rgb_dec565(
                              Interpolate(
                                  pageItem.offColor !== undefined ? pageItem.offColor : config.defaultOffColor,
                                  pageItem.onColor !== undefined ? pageItem.onColor : config.defaultOnColor,
                                  scale(value, minValue, maxValue, 0, 1)
                      if ((pageItem.useColor || useColors) && ((typeof (value) === "boolean" && value) || value > (pageItem.minValue !== undefined ? pageItem.minValue : 0))) {
                          return rgb_dec565(pageItem.onColor !== undefined ? pageItem.onColor : config.defaultOnColor)
                      return rgb_dec565(pageItem.offColor !== undefined ? pageItem.offColor : config.defaultOffColor);
                  function RegisterEntityWatcher(id: string): void {
                      if (subscriptions.hasOwnProperty(id)) {
                          return;
                      subscriptions[id] = (on({ id: id, change: 'any' }, function (data) {
                          SendToPanel({ payload: GeneratePageElements(config.pages[pageId]) });
                  function RegisterDetailEntityWatcher(id: string, pageItem: PageItem, type: string): void {
                          return;
                      subscriptions[id] = (on({ id: id, change: 'any' }, function () {
                          SendToPanel(GenerateDetailPage(type, pageItem));
                  function GetUnitOfMeasurement(id: string): string {
                      if (!existsObject(id))
                          return "";
                      let obj = getObject(id);
                      if (typeof obj.common.unit !== 'undefined') {
                          return obj.common.unit
                      if (typeof obj.common.alias !== 'undefined' && typeof obj.common.alias.id !== 'undefined') {
                          return GetUnitOfMeasurement(obj.common.alias.id);
                      return "";
                  function GenerateThermoPage(page: PageThermo): Payload[] {
                      var id = page.items[0].id
                      out_msgs.push({ payload: "pageType~cardThermo" });
                      // ioBroker
                      if (existsObject(id)) {
                          let o = getObject(id)
                          let name = page.items[0].name !== undefined ? page.items[0].name : o.common.name.de
                          let currentTemp = 0;
                          if (existsState(id + ".ACTUAL"))
                              currentTemp = (Math.round(parseFloat(getState(id + ".ACTUAL").val) * 10)/10)*10;
                          let destTemp = 0;
                          if (existsState(id + ".SET")) {
                              destTemp = getState(id + ".SET").val.toFixed(2) * 10;
                              log(id + ".SET " + destTemp)
                          let status = ""
                          if (existsState(id + ".MODE"))
                              status = getState(id + ".MODE").val;
                          let minTemp = 50 //Min Temp 5°C
                          let maxTemp = 300 //Max Temp 30°C
                          let stepTemp = 5
                          //0-4 verwendet bei ungerader Anzahl Parametern
                          let bt0 = "~~~~"; //verwendet bei ungleichen Parametern
                          let bt1 = "~~~~"; //verwendet bei ungleichen Parametern
                          let bt2 = "~~~~"; //verwendet bei ungleichen Parametern
                          let bt3 = "~~~~"; //verwendet bei ungleichen Parametern
                          let bt4 = "~~~~"; //verwendet bei ungleichen Parametern
                          //5-8 verwendet bei gerader Anzahl Parametern
                          let bt5 = Icons.GetIcon("water-percent") + "~0~1~~";
                          let bt6 = Icons.GetIcon("fire") + "~0~1~~";
                          let bt7 = Icons.GetIcon("wifi") + "~0~1~~";
                          let bt8 = Icons.GetIcon("battery-high") + "~0~1~~";
                          if (existsState(id + ".HUMIDITY")){
                              console.log(parseInt(getState(id + ".HUMIDITY").val));
                              bt5 =  Icons.GetIcon("water-percent") + "~2016~1~bt8~";
                              if (parseInt(getState(id + ".HUMIDITY").val) < 40) {
                                  bt5 =  Icons.GetIcon("water-percent") + "~65504~1~bt8~";
                              } else if (parseInt(getState(id + ".HUMIDITY").val) < 30) {
                                  bt5 =  Icons.GetIcon("water-percent") + "~63488~1~bt8~";
                              } else if (parseInt(getState(id + ".HUMIDITY").val) > 65) {
                              } else if (parseInt(getState(id + ".HUMIDITY").val) > 75) {
                          if (existsState(id + ".MAINTAIN")){
                              if (getState(id + ".MAINTAIN").val >> .1) {
                                  bt6 =  Icons.GetIcon("fire") + "~60897~1~bt8~";
                              } else {
                                  bt6 =  Icons.GetIcon("fire") + "~33840~0~bt8~";
                          if (existsState(id + ".UNREACH")){
                              if (getState(id + ".UNREACH").val) {
                                  bt7 =  Icons.GetIcon("wifi-off") + "~63488~1~bt8~";
                              } else {
                                  bt7 =  Icons.GetIcon("wifi") + "~2016~1~bt8~";
                          if (existsState(id + ".LOWBAT")){
                              if (getState(id + ".LOWBAT").val) {
                                  bt8 =  Icons.GetIcon("battery-low") + "~63488~1~bt8~";
                              } else {
                                  bt8 =  Icons.GetIcon("battery-high") + "~2016~1~bt8~";
                          let icon_res = bt0 + bt1 + bt2 + bt3 + bt4 + bt5 + bt6 + bt7 + bt8;
                          out_msgs.push({ payload: "entityUpd~" + name + "~" + GetNavigationString(pageId) + "~" + id + "~" + currentTemp + "~" + destTemp + "~" + status + "~" + minTemp + "~" + maxTemp + "~" + stepTemp + "~" +icon_res})
                      return out_msgs
                  function GenerateMediaPage(page: PageMedia): Payload[] {
                      out_msgs.push({ payload: "pageType~cardMedia" });
                          let o = getObject(id);
                          //let name = o.common.name.de;
                          let name = getState(spotifyInstanz + ".player.contextDescription").val;
                          let media_icon = Icons.GetIcon("spotify");
                          let title = getState(spotifyInstanz + ".player.trackName").val;
                          let author = getState(spotifyInstanz + ".player.artistName").val
                          let volume = getState(spotifyInstanz + ".player.volume").val;
                          var iconplaypause = Icons.GetIcon("pause"); //pause
                          if (getState(spotifyInstanz + ".player.isPlaying").val) {
                          } else {
                              iconplaypause = Icons.GetIcon("play"); //play
                          let currentSpeaker = getState(spotifyInstanz + ".player.device.name").val
                          let speakerlist = getState(spotifyInstanz + ".devices.deviceListString").val.replace(/;/g,"?");
                          let onoffbutton = 1;
                                                    name + "~" +
                                                    id + "~" +
                                                    media_icon + "~" +
                                                    title + "~" +
                                                    author + "~" +
                                                    volume + "~" +
                                                    iconplaypause + "~" +
                                                    currentSpeaker + "~" +
                                                    speakerlist + "~" +
                                                    onoffbutton});
                      return out_msgs
                  function GenerateAlarmPage(page: PageAlarm): Payload[] {
                      out_msgs.push({ payload: "pageType~cardAlarm" });
                      var armed: boolean = false;
                      if (armed) {
                          var arm1 = "Deaktivieren";                  //arm1*~*
                          var arm1ActionName = "D1";                  //arm1ActionName*~*
                          var arm2 = "";                              //arm2*~*
                          var arm2ActionName = "";                    //arm2ActionName*~*
                          var arm3 = "";                              //arm3*~*
                          var arm3ActionName = "";                    //arm3ActionName*~*
                          var arm4 = "";                              //arm4*~*
                          var arm4ActionName = "";                    //arm4ActionName*~*
                          var icon = Icons.GetIcon("shield-home");    //icon*~*
                          var iconcolor = 63488;                      //iconcolor*~*
                          var numpadStatus = 1;                       //numpadStatus*~*
                          var flashing = 1;                           //flashing*
                      else {
                          var arm1 = "Alarm 1";                       //arm1*~*
                          var arm1ActionName = "A1";                  //arm1ActionName*~*
                          var arm2 = "Alarm 2";                       //arm2*~*
                          var arm2ActionName = "A2";                  //arm2ActionName*~*
                          var arm3 = "Alarm 3";                       //arm3*~*
                          var arm3ActionName = "A3";                  //arm3ActionName*~*
                          var arm4 = "Alarm 4";                       //arm4*~*
                          var arm4ActionName = "A4";                  //arm4ActionName*~*
                          var icon = Icons.GetIcon("shield-off");     //icon*~*
                          var iconcolor = 2016;                       //iconcolor*~*
                      out_msgs.push({ payload:    "entityUpd~" +             //entityUpd~*
                                                  id + "~" +                 //internalNameEntity*~* //navigation*~*
                                                  arm1 + "~" +               //arm1*~*
                                                  arm1ActionName + "~" +     //arm1ActionName*~*
                                                  arm2 + "~" +               //arm2*~*
                                                  arm2ActionName + "~" +     //arm2ActionName*~*
                                                  arm3 + "~" +               //arm3*~*
                                                  arm3ActionName + "~" +     //arm3ActionName*~*
                                                  arm4 + "~" +               //arm4*~*
                                                  arm4ActionName + "~" +     //arm4ActionName*~*
                                                  icon + "~" +               //icon*~* 39=Disarmed 35=Shield_Home, 40
                                                  iconcolor + "~" +          //iconcolor*~* 2016=green  63488=red
                                                  numpadStatus + "~" +       //numpadStatus*~*
                                                  flashing});                //flashing*
                      return out_msgs
                  function setIfExists(id: string, value: any, type: string | null = null): boolean {
                      if (type === null) {
                          if (existsState(id)) {
                              setState(id, value);
                              return true;
                      else {
                          if (existsState(id) && obj.common.type !== undefined && obj.common.type === type) {
                              return true;
                      return false;
                  function toggleState(id: string): boolean {
                      if (existsState(id) && obj.common.type !== undefined && obj.common.type === "boolean") {
                          setState(id, !getState(id).val);
                          return true;
                      return false;
                  function HandleButtonEvent(words): void {
                      let id = words[2]
                      let buttonAction = words[3];
                      switch (buttonAction) {
                          case "bNext":
                              var pageNum = ((pageId + 1) % config.pages.length);
                              pageId = Math.abs(pageNum);
                              GeneratePage(config.pages[pageId]);
                              break;
                          case "bPrev":
                              var pageNum = ((pageId - 1) % config.pages.length);
                              break;
                          case "bExit":
                              if (config.screenSaverDoubleClick) {
                                  if (words[4] == 2)
                              else
                              break;
                          case "OnOff":
                                  var action = false
                                  if (words[4] == "1")
                                      action = true
                                      case "light":
                                          setIfExists(id + ".SET", action);
                                          break;
                                      case "dimmer":
                                          setIfExists(id + ".ON_SET", action) ? true : setIfExists(id + ".ON_ACTUAL", action);
                              break;
                          case "up":
                              setIfExists(id + ".OPEN", true)
                              break;
                          case "stop":
                              setIfExists(id + ".STOP", true)
                              break;
                          case "down":
                              setIfExists(id + ".CLOSE", true)
                              break;
                          case "button":
                              toggleState(id + ".SET") ? true : toggleState(id + ".ON_SET")
                              break;
                          case "positionSlider":
                          case "brightnessSlider":
                              setIfExists(id + ".SET", parseInt(words[4])) ? true : setIfExists(id + ".ACTUAL", parseInt(words[4]));
                              break;
                          case "tempUpd":
                              setIfExists(id + ".SET", parseInt(words[4]) / 10)
                              break;
                          case "media-back":
                              setIfExists(spotifyInstanz + ".player.skipMinus", true)
                              break;
                          case "media-pause":
                              if (getState(spotifyInstanz + ".player.isPlaying").val === true) {
                                  setIfExists(spotifyInstanz + ".player.pause", true)
                              } else {
                                  setIfExists(spotifyInstanz + ".player.play", true)
                              break;
                          case "media-next":
                              setIfExists(spotifyInstanz + ".player.skipPlus", true)
                              break;
                          case "volumeSlider":
                              setIfExists(spotifyInstanz + ".player.volume", parseInt(words[4]))
                              break;
                          case "speaker-sel":
                              console.log("auf mediaCard - speaker-sel - Wert: " + words[4] + " - reagieren - noch nicht implementiert");
                              break;
                          case "A1": //Alarm-Page Alarm 1 aktivieren
                              console.log("auf mediaAlarm - Alarm 1 - Wert: " + words[4] + " - reagieren - noch nicht implementiert");
                              break;
                          case "A2": //Alarm-Page Alarm 2 aktivieren
                              break;
                          case "A3": //Alarm-Page Alarm 3 aktivieren
                              break;
                          case "A4": //Alarm-Page Alarm 4 aktivieren
                              break;
                          case "D1": //Alarm-Page Alarm Deaktivieren
                              break;
                          default:
                              break;
                  function GetNavigationString(pageId: number): string {
                      switch (pageId) {
                          case 0:
                              return "0|1";
                          case config.pages.length - 1:
                              return "1|0";
                          case -1:
                              return "0|0";
                          default:
                              return "1|1";
                  function GenerateDetailPage(type: string, pageItem: PageItem): Payload[] {
                      let id = pageItem.id
                          var o = getObject(id)
                          var val: (boolean | number) = 0;
                          let icon = Icons.GetIcon("lightbulb");
                          if (type == "popupLight") {
                              let switchVal = "0"
                              if (o.common.role == "light") {
                                  if (existsState(id + ".GET")) {
                                      val = getState(id + ".GET").val;
                                      RegisterDetailEntityWatcher(id + ".GET", pageItem, type);
                                  else if (existsState(id + ".SET")) {
                                      val = getState(id + ".SET").val;
                                      RegisterDetailEntityWatcher(id + ".SET", pageItem, type);
                                  if (val) {
                                      switchVal = "1";
                                      iconColor = GetIconColor(pageItem, true, false);
                                  out_msgs.push({ payload: "entityUpdateDetail~" + icon + "~" + + iconColor + "~" + switchVal + ",disable,disable,disable" })
                              if (o.common.role == "dimmer") {
                                  if (existsState(id + ".ON_ACTUAL")) {
                                      val = getState(id + ".ON_ACTUAL").val;
                                      RegisterDetailEntityWatcher(id + ".ON_ACTUAL", pageItem, type);
                                  else if (existsState(id + ".ON_SET")) {
                                      val = getState(id + ".ON_SET").val;
                                      RegisterDetailEntityWatcher(id + ".ON_SET", pageItem, type);
                                  if (val === true) {
                                      var iconColor = GetIconColor(pageItem, val, false);
                                      switchVal = "1"
                                  let brightness = 0;
                                  if (existsState(id + ".ACTUAL")) {
                                      brightness = Math.trunc(scale(getState(id + ".ACTUAL").val, 0, 100, 0, 100))
                                      iconColor = GetIconColor(pageItem, brightness, false);
                                      RegisterDetailEntityWatcher(id + ".ACTUAL", pageItem, type);
                                  let colorTemp = "disable"
                                  let colorMode = "disable"
                                  //let attr_support_color = attr.supported_color_modes
                                  //if (attr_support_color.includes("color_temp"))
                                  // colortemp = Math.trunc(scale(attr.color_temp, attr.min_mireds, attr.max_mireds, 0, 100))
                                  out_msgs.push({ payload: "entityUpdateDetail~" + icon + "~" + iconColor + "~" + switchVal + "~" + brightness + "~" + colorTemp + "~" + colorMode })
                          if (type == "popupShutter") {
                                  val = getState(id + ".ACTUAL").val;
                              out_msgs.push({ payload: "entityUpdateDetail," + val })
                      return out_msgs
                  function scale(number: number, inMin: number, inMax: number, outMin: number, outMax: number): number {
                      return (number - inMin) * (outMax - outMin) / (inMax - inMin) + outMin;
                  function UnsubscribeWatcher(): void {
                      for (const [key, value] of Object.entries(subscriptions)) {
                          unsubscribe(value);
                          delete subscriptions[key]
                  function HandleScreensaver(): void {
                      SendToPanel({ payload: "pageType~screensaver"})
                  function HandleScreensaverUpdate(): void {
                      if (screensaverEnabled && config.weatherEntity != null && existsObject(config.weatherEntity)) {
                          var icon = getState(config.weatherEntity + ".ICON").val;
                          let temperature: string =
                              existsState(config.weatherEntity + ".ACTUAL") ? getState(config.weatherEntity + ".ACTUAL").val :
                                  existsState(config.weatherEntity + ".TEMP") ? getState(config.weatherEntity + ".TEMP").val : "null";
                          let payloadString =
                              "weatherUpdate~" + Icons.GetIcon(GetAccuWeatherIcon(parseInt(icon))) + "~"
                              + temperature + " " + config.temperatureUnit + "~"
                          if (weatherForecast == true) {
                              // Accu-Weather Forecast Tag 2 - Tag 5 -- Wenn weatherForecast = true
                              for (let i = 2; i < 6; i++) {
                                  let TempMax = getState("accuweather.0.Summary.TempMax_d" + i).val;
                                  let DayOfWeek = getState("accuweather.0.Summary.DayOfWeek_d" + i).val;
                                  let WeatherIcon = GetAccuWeatherIcon(getState("accuweather.0.Summary.WeatherIcon_d" + i).val);
                                  payloadString += DayOfWeek + "~" + Icons.GetIcon(WeatherIcon) + "~" + TempMax + " °C~";
                          else {
                              //In Config definierte Zustände wenn weatherForecast = false
                              payloadString += GetScreenSaverEntityString(config.firstScreensaverEntity);
                              payloadString += GetScreenSaverEntityString(config.secondScreensaverEntity);
                              payloadString += GetScreenSaverEntityString(config.thirdScreensaverEntity);
                              payloadString += GetScreenSaverEntityString(config.fourthScreensaverEntity);
                          SendToPanel(<Payload>{ payload: payloadString });
                  function GetScreenSaverEntityString(configElement: ScreenSaverElement | null): string {
                      if (configElement != null && configElement.ScreensaverEntity != null && existsState(configElement.ScreensaverEntity)) {
                          let u1 = getState(configElement.ScreensaverEntity).val;
                          return configElement.ScreensaverEntityText + "~" + Icons.GetIcon(configElement.ScreensaverEntityIcon) + "~" + u1 + " " + configElement.ScreensaverEntityUnitText + "~";
                      else {
                          return "~~~";
                  function GetAccuWeatherIcon(icon: number): string {
                      switch (icon) {
                          case 24:        // Ice
                          case 30:        // Hot
                          case 31:        // Cold
                              return "window-open";  // exceptional
                          case 7:         // Cloudy
                          case 8:         // Dreary (Overcast)
                          case 38:        // Mostly Cloudy
                              return "weather-cloudy";  // cloudy
                          case 11:        // fog
                              return "weather-fog";  // fog
                          case 25:        // Sleet
                              return "weather-hail";  // Hail
                          case 15:        // T-Storms
                              return "weather-lightning";  // lightning
                          case 16:        // Mostly Cloudy w/ T-Storms
                          case 17:        // Partly Sunny w/ T-Storms
                          case 41:        // Partly Cloudy w/ T-Storms
                          case 42:        // Mostly Cloudy w/ T-Storms
                              return "weather-lightning-rainy";  // lightning-rainy
                          case 33:        // Clear
                          case 34:        // Mostly Clear
                          case 37:        // Hazy Moonlight
                              return "weather-night";
                          case 3:         // Partly Sunny
                          case 4:         // Intermittent Clouds
                          case 6:         // Mostly Cloudy
                          case 35: 	    // Partly Cloudy
                          case 36: 	    // Intermittent Clouds
                              return "weather-partly-cloudy";  // partlycloudy
                          case 18:        // pouring
                              return "weather-pouring";  // pouring
                          case 12:        // Showers
                          case 13:        // Mostly Cloudy w/ Showers
                          case 14:        // Partly Sunny w/ Showers
                          case 26:        // Freezing Rain
                          case 39:        // Partly Cloudy w/ Showers
                          case 40:        // Mostly Cloudy w/ Showers
                              return "weather-rainy";  // rainy
                          case 19:        // Flurries
                          case 20:        // Mostly Cloudy w/ Flurries
                          case 21:        // Partly Sunny w/ Flurries
                          case 22:        // Snow
                          case 23:        // Mostly Cloudy w/ Snow
                          case 43:        // Mostly Cloudy w/ Flurries
                          case 44:        // Mostly Cloudy w/ Snow
                              return "weather-snowy";  // snowy
                          case 29:        // Rain and Snow
                              return "weather-snowy-rainy";  // snowy-rainy
                          case 1:         // Sunny
                          case 2: 	    // Mostly Sunny
                          case 5:         // Hazy Sunshine
                              return "weather-sunny";  // sunny
                          case 32:        // windy
                              return "weather-windy";  // windy
                          default:
                              return "alert-circle-outline";
                  function GetBlendedColor(percentage: number): RGB {
                      if (percentage < 50)
                          return Interpolate(config.defaultOffColor, config.defaultOnColor, percentage / 50.0);
                      return Interpolate(Red, White, (percentage - 50) / 50.0);
                  function Interpolate(color1: RGB, color2: RGB, fraction: number): RGB {
                      var r: number = InterpolateNum(color1.red, color2.red, fraction);
                      var g: number = InterpolateNum(color1.green, color2.green, fraction);
                      var b: number = InterpolateNum(color1.blue, color2.blue, fraction);
                      return <RGB>{ red: Math.round(r), green: Math.round(g), blue: Math.round(b) };
                  function InterpolateNum(d1: number, d2: number, fraction: number): number {
                      return d1 + (d2 - d1) * fraction;
                  function rgb_dec565(rgb: RGB): number {
                      return ((Math.floor(rgb.red / 255 * 31) << 11) | (Math.floor(rgb.green / 255 * 63) << 5) | (Math.floor(rgb.blue / 255 * 31)));
                  type RGB = {
                      red: number,
                      green: number,
                      blue: number
                  type Payload = {
                      payload: string;
                  type Page = {
                      type: string,
                      heading: string,
                      items: PageItem[],
                      useColor: boolean
                  interface PageEntities extends Page {
                      type: "cardEntities",
                      items: PageItem[],
                  interface PageGrid extends Page {
                      type: "cardGrid",
                      items: PageItem[],
                  interface PageThermo extends Page {
                      type: "cardThermo",
                      items: PageItem[],
                  interface PageMedia extends Page {
                      type: "cardMedia",
                      items: PageItem[],
                  interface PageAlarm extends Page {
                      type: "cardAlarm",
                      items: PageItem[],
                  type PageItem = {
                      icon: (string | undefined),
                      onColor: (RGB | undefined),
                      offColor: (RGB | undefined),
                      useColor: (boolean | undefined),
                      interpolateColor: (boolean | undefined),
                      minValue: (number | undefined),
                      maxValue: (number | undefined),
                      name: (string | undefined)
                  type Config = {
                      panelRecvTopic: string,
                      panelSendTopic: string,
                      timeoutScreensaver: number,
                      dimmode: number,
                      //brightnessScreensaver:
                      locale: string,
                      timeFormat: string,
                      dateFormat: string,
                      weatherEntity: string | null,
                      screenSaverDoubleClick: boolean,
                      temperatureUnit: string,
                      firstScreensaverEntity: ScreenSaverElement | null,
                      secondScreensaverEntity: ScreenSaverElement | null,
                      thirdScreensaverEntity: ScreenSaverElement | null,
                      fourthScreensaverEntity: ScreenSaverElement | null,
                      defaultColor: RGB,
                      defaultOnColor: RGB,
                      defaultOffColor: RGB,
                      pages: (PageThermo | PageMedia | PageAlarm | PageEntities | PageGrid)[],
                      button1Page: (PageThermo | PageMedia | PageAlarm | PageEntities | PageGrid | null),
                      button2Page: (PageThermo | PageMedia | PageAlarm | PageEntities | PageGrid | null),
                  type ScreenSaverElement = {
                      ScreensaverEntity: string | null,
                      ScreensaverEntityIcon: string | null,
                      ScreensaverEntityText: string | null,
                      ScreensaverEntityUnitText: string | null,
                  • Unter ioBroker/Skripte weiteres Type-Script unter global !!!! (nicht common, etc) anlegen (Name: Blabla oder NSPanel_icon_mapping, etc)
                  • Inhalt aus Datei icon_mapping.ts von Github https://github.com/joBr99/nspanel-lovelace-ui/tree/main/ioBroker (nicht wundern, wenn die etwas zerrissen aussieht - Fragezeichen, etc.) einfügen und speichern
                  • Beide Skripte starten nicht vergessen
                  Ab jetzt holt sich das Hauptscript (Inhalt der NsPanelTs.ts) die Icons aus der Mapping-Datei.
                  Jetzt noch NSPanel-Parameter (ALIASE, MQTT-anpassen, Datenpunkte) anpassen oder weitere Seiten gestalten und einfügen
                  Sollten weitere oder andere Icons gewünscht sein dann auf https://htmlpreview.github.io/?https://github.com/joBr99/nspanel-lovelace-ui/blob/main/HMI/icon-cheatsheet.html nachsehen und den Namen entsprechend an der Stelle des Icons im Script tauschen.
                  Ich hoffe das hilft 👍
                  beschrieben hat?
                  Das "Waiting for Content" kommt meist wenn etwas mit dem Skript nicht stimmt. (Poste mal dein Script)
                    holgerwolf @holgerwolf last edited by
                    @Mikewolf Oder schau auch mal, ob beim Ausführen des Scriptes irgendwelche Fehler im iobroker auftauchen. Da sind sind viele Beispiel Objekte drin, die alle ersetzt werden müssen.
                    • Armilar
                      Armilar Most Active Forum Testing @Mikewolf last edited by
                      @holgerwolf
                      sieh mal nach, ob bei dir so ein Eintrag ist. Das wäre der Parameter unter Config im Script
                      Dann mal den Haken bei
                      rausnehmen.
                      • Armilar
                        Armilar Most Active Forum Testing @Armilar last edited by Armilar
                        @holgerwolf
                        rausnehmen.
                        Sind MQTT-Adapter und Tasmota-MQTT auf dem selben Port?
                        Das sind die Datenpunkte im Script. Die müssen analog deiner Tasmota Prefix/Topics angepasst werden. Habe da bei dir etwas mit panel1 statt bei mir SmartHome.NSPanel_1 gelesen
                        Ansonsten brauchen wir mal kurz einen Screen vom ioBroker Script (am Besten mit Sicht auf die Config und MQTT panel1 unter Objekte...
                        • Armilar
                          Armilar Most Active Forum Testing @Mikewolf last edited by Armilar
                          "time, 10:32"
                          Der Time Payload heißt jetzt: CustomSend time~15:42 (ohne Komma, aber mit Kringel als Delimiter)
                          Wenn du den in der Konsole absetzt, sollte sofort das Panel umspringen und zumindest die Zeit anzeigen
                          ich habe hinter prefix und topic noch tele, stat, etc. stehen, bevor /RESULT oder /STATE kommt. Vielleicht doch ein Fehler in der Tasmota MQTT-Einstellung????
                          Bei mir
                          • britzelpuf
                            britzelpuf @Mikewolf last edited by
                            @mikewolf
                            Ich vermute mal, dass du noch die alte Version des Skriptes verwendest.
                            Aktualisiere mal bitte die Version und packe die icon mapping ts ins global verzeichnis
                            Dann nur noch die Konfig anpassen und eigentlich sollte es dann gehen.
                            • Armilar
                              Armilar Most Active Forum Testing @britzelpuf last edited by Armilar
                              @britzelpuf
                              Ich hatte heute im Übrigen auch den Fehler das er nicht in den Screensaver zurückgegangen ist. Habe mit den Hardware-Buttons gespielt und ein paar Radiosender eingebaut. Ich denke es passiert im Zusammenhang mit den Panel-Tasten. Eigensinnig ist auch das Verhalten, dass wenn ich einen Sender wähle springt er anschließend in die zuvor aktive Seite und zerreißt sie komplett
                              Beispiel:
                              dann Sender wählen und dann kommt
                              Dann springt das Panel wieder in den Screensaver und alles ist top
                              Die eigentliche cardGrid sieht aber so aus:
                              und die Frage ist: Warum springt er überhaupt auf die cardGrid? Hast du auch so ein Verhalten? Und das sin im Übrigen die Einträge aus der
                                  "heading": "Büro",
                                  "useColor": true,
                                  "items": [
                              Der Taster existiert aktuell nicht als ALIAS - somit wäre also die cardEntities eigentlich richtiger als die cardGrid.
                              PS.: Der gewählte Sender wird aber analog ALIAS korrekt abgespielt ...
                              britzelpuf 1 Reply Last reply Reply Quote 0
                              • britzelpuf
                                britzelpuf @Armilar last edited by
                                @armilar Wenn die Objekte nicht existieren, dann wird ein Delete geschickt.
                                https://github.com/joBr99/nspanel-lovelace-ui/blob/58da8efc0c70cb1ddf1f9a1b7d532b3187dce21f/ioBroker/NsPanelTs.ts#L376
                                Ich kann es gerade nicht debuggen, aber ich vermute, dass hier das Problem liegt.
                                https://github.com/joBr99/nspanel-lovelace-ui/blob/58da8efc0c70cb1ddf1f9a1b7d532b3187dce21f/ioBroker/NsPanelTs.ts#L411
                                Sobald sich ein Wert ändert schickt es nämlich ein Update und hat dabei die falsche PageId im Bauch. Die HW Buttons sind ja ohne eindeutige ID.
                                Ich könnte mir jetzt folgendes vorstellen, man deaktiviert für HW Buttons die Updateregel, finde ich doof weil eigentlich ist das ein tolles Feature.
                                Alternativ setzt man die pageId auf -1 für Button1 und -2 für Button2 und sobald der Screensaver kommt wieder auf 0. Dann kann man aber die Seite referenzieren.
                                • Armilar
                                  @britzelpuf sagte in Sonoff NSPanel:
                                  Ich finde Variante 2 definitv besser. Updateregel ausschalten würde ich auch nicht... mit -1 und mit -2 kann man leben...
                                  • britzelpuf
                                    @armilar So ich habe das mit den HW Buttons mal angepasst. Kannst ja mal schauen ob das jetzt bei dir geht.
                                      ronny130286 last edited by ronny130286
                                      @britzelpuf
                                      Ich habe es auch übernommen, aber ich glaube es muss noch an einer anderen Stelle auftreten, bis jetzt hatte ich die Hardwarebutton über die Rule nicht implementiert, da ich die Button hardwareseitig verwende und hatte das Problem ebenfalls.
                                      • Armilar
                                        Moin Britzelpuf,
                                        Einwandfrei 👍 👍 👍
                                        VG
                                        Armilar
                                          mameier1234 @Armilar last edited by
                                          @armilar
                                          bei mir will der Umstieg einfach nicht klappen....
                                          ich habe jetzt Tasmota 11.1.0 auf meinem Panel... und noch die alte NSPanel, die am Anfang dieses Threads besprochen wurde...
                                          Wenn ich jetzt die Befehle Backlog ... und Flashnextion ausführe passiert einfach nix.. Unknown command in der Konsole...
                                          Dann habe ich das autoexec.be Script von Hand eingebaut, neu gebootet, bei Flashnextion kommt aber immer noch Unknown Command
                                          Was mache ich wohl falsch ?
                                            joBr99 @mameier1234 last edited by
                                            @mameier1234 der backlog command ist nur zum updaten von dem Berry Skript, wenn es schon installiert war.
                                            https://github.com/joBr99/nspanel-lovelace-ui#upload-berry-driver-to-tasmota
                                            https://github.com/joBr99/nspanel-lovelace-ui/blob/main/tasmota/autoexec.be
                                            Einfach den Inhalt von der autoexec.be in tasmota kopieren/hochladen, neustarten und dann hast du den FlashNextion Command und kannst das Display mit folgendem command flashen
                                            1548
                                            635828
