    3. Entwicklung
    4. Adapter: Luxtronik 1 - Wärmepumpensteuerung
      Thorsten73 last edited by
      @forelleblau
      Ich erhalten im Logfile die folgenden Meldungen nachdem ich den Adapter durchgestartet:
      	2022-02-17 13:34:45.935	info	[START] Starting luxtronik adapter
      luxtronik1.0
      2022-02-17 13:34:45.835	info	starting. Version 0.3.4 in /opt/iobroker/node_modules/iobroker.luxtronik1, node: v16.14.0, js-controller: 4.0.10
      luxtronik1.0
      2022-02-17 13:34:44.821	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:44.820	warn	Object luxtronik1.0.control.ModusHeizung is invalid: Default value has to be type "number" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:44.739	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:44.738	warn	Object luxtronik1.0.control.NachtAbs is invalid: Default value has to be type "number" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:44.506	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:44.504	warn	Object luxtronik1.0.heizkurve.NachtAbs is invalid: Default value has to be type "number" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:44.374	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:44.373	warn	Object luxtronik1.0.heizkurve.Endpunkt is invalid: Default value has to be type "number" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:43.719	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:43.715	warn	Object luxtronik1.0.status.SW is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:43.624	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:43.621	warn	Object luxtronik1.0.status.WPtyp is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:43.567	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:43.564	warn	Object luxtronik1.0.status.ANL is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:43.449	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:43.448	warn	Object luxtronik1.0.abschaltungen.5 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:43.374	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:43.372	warn	Object luxtronik1.0.abschaltungen.4 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:43.283	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:43.276	warn	Object luxtronik1.0.abschaltungen.3 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:43.219	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:43.218	warn	Object luxtronik1.0.abschaltungen.2 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:43.167	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:43.164	warn	Object luxtronik1.0.abschaltungen.1 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:43.074	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:43.072	warn	Object luxtronik1.0.fehler.5 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:42.981	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:42.980	warn	Object luxtronik1.0.fehler.4 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:42.925	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:42.924	warn	Object luxtronik1.0.fehler.3 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:42.844	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:42.843	warn	Object luxtronik1.0.fehler.2 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:42.793	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:42.792	warn	Object luxtronik1.0.fehler.1 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:42.694	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:42.692	warn	Object luxtronik1.0.betriebsstunden.WP is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:42.607	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:42.605	warn	Object luxtronik1.0.betriebsstunden.ZWE2 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:42.533	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:42.531	warn	Object luxtronik1.0.betriebsstunden.ZWE1 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:42.465	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:42.463	warn	Object luxtronik1.0.betriebsstunden.AvVD2 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:42.418	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:42.415	warn	Object luxtronik1.0.betriebsstunden.Imp2 is invalid: Default value has to be type "string" but received type "number"
      luxtronik1.0
      2022-02-17 13:34:42.372	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:42.368	warn	Object luxtronik1.0.betriebsstunden.VD2 is invalid: Default value has to be type "string" but received type "number"
      luxtronik1.0
      2022-02-17 13:34:42.321	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:42.319	warn	Object luxtronik1.0.betriebsstunden.AvVD1 is invalid: Default value has to be type "string" but received type "boolean"
      luxtronik1.0
      2022-02-17 13:34:42.267	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:42.263	warn	Object luxtronik1.0.betriebsstunden.Imp1 is invalid: Default value has to be type "string" but received type "number"
      luxtronik1.0
      2022-02-17 13:34:42.214	warn	This object will not be created in future versions. Please report this to the developer.
      luxtronik1.0
      2022-02-17 13:34:42.207	warn	Object luxtronik1.0.betriebsstunden.VD1 is invalid: Default value has to be type "string" but received type "number"
      luxtronik1.0
      2022-02-17 13:34:29.100	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      luxtronik1.0
      2022-02-17 13:34:29.079	info	terminating
      Da stimmen irgendwie die Daten Typen nicht, betrifft das nur zukünftige Versionen des JS-controller's?
      Danke für Deine Antwort!
        Stobli @Thorsten73 last edited by
        @thorsten73
        Hallo ich habe genau den gleiche Fehler bei mir im System stehen.
        Keiner eine Idee ?
        @forelleblau ???
          forelleblau @Stobli last edited by
          @stobli ist schon in Arbeit. Hängt mit dem js-Controller Update zusammen
            Stobli @forelleblau last edited by
            @forelleblau
            Alles klar - Danke für die Rückmeldung.
              @stobli @Thorsten73
              Hallo. Version 0.3.5 ist auf Github verfügbar und so ab morgen auch im latest - repo.
              Die Fehler sollten damit nicht mehr auftauchen.
              Herzliche Grüsse
              forelleblau
                LutzM last edited by
                @forelleblau
                Bei mir sind die Fehler trotz Version 0.3.5 immer noch da. Alle Adapter sind auf aktuellem Stand (lt. Beta repo). Z.B. Admin 5.3.1, JavaScript 5.3.3.
                  forelleblau @LutzM last edited by
                  @lutzm hallo lutz. Du musst wahrscheinlich die betroffenen Datenpunkte löschen und den Adapter nochmals installieren, damit diese neu angelegt werden. Grüsse Forelleblau
                    @forelleblau Hat funktioniert!
                      argus @forelleblau last edited by
                      @forelleblau
                      also bei mir funktioniert es mittlerweile super. Habe auch keine Probleme mit dem Moxa.
                      Ich steuere mittlerweile mit ein paar Scripten die WW-Erzeugung über ZWE von der Solaranlage. Es lassen sich dabei auch Temperaturen von mehr als 65! erreichen, ich gehe regelmäßig auf 75°C.
                      Eine Anregung hätte ich noch, es betrifft den Haupt Button bzw. die Beseitigung einer Störung mittels Adapter.
                      Wäre es möglich eine Störung (normalerweise 10 Sekunden drücken des Drehknopfes am Bedienteil) mittels dem Luxtronik Adapters zu quittieren und somit den Fehler zu resetten?
                      Hab ab und an mal Drehfeldfehler und muss den resetten. Wäre gut wenn das von unterwegs aus möglich wäre.
                      Liebe Grüße,
                      Holger
                        @argus Hallo Holger. Ich nehme deine Anregung mal als Issue auf bei Github. Kenne die Lösung grad nicht. Werde aber bei Gelegenheit die LUX-PC-Software wieder mal anschliessen und suchen, ob es eine Möglichkeit für einen Software - Reset gibt. Oder kennt ev. @Willi-Wunder die Lösung?
                        Grüsse Forelleblau
                          @forelleblau
                          von der Sache her muss ja der Bedienknopf für 5-10 Sekunden oder so gedrückt werden.
                          Evtl. gibts dafür einen Befehl?!
                          Im IObroker erscheint bei so einem Fehler der Wert "true" bei (luxtronik1.0.ausgaenge.Zweiter_Waermeerzeuger_2_Sammelstoerung) welcher normal bei "false" liegt.
                            forelleblau @argus last edited by
                            @argus ...und genau das ist die Knacknuss, den Befehl zu kriegen. Sobald ich den habe, ist die Umsetzung dann nicht mehr so eine Sache.
                            Grüsse forelleblau
                              Willi-Wunder @forelleblau last edited by
                              @forelleblau
                              Hi, sorry, war im Urlaub. Den Befehl kenne ich leider nicht.
                              @argus
                              Bin zwar kein Heizungsbauer oder Elektriker, aber meinst du solltest nicht dein eigentliches Problem mit dem "Drehfeldfehler" beheben? Ständig resetten zu müssen kann eigentlich auch nicht gewollt sein.
                                SirWillfried last edited by SirWillfried
                                @forelleblau
                                Hallo forelleblau. Erstmal ein dickes Lob für die Arbeit an dem Adapter für Iobroker. Ich habe mich jetzt im Zuge der Installation einer Solaranlage dazu entschieden, meiner inzwischen 16 Jahre alten Luxtronik 1.0 doch mal ein paar Daten zu entlocken 😊 um ggf. darauf zu reagieren. Ich habe dazu ein kleines WEMOS D1 Mini Board mit espeasy geflasht und dort den Serial-Adapter drauf installiert. Nun hat die Anlage einen WLAN Anschluss. Die Daten, die ich empfange, sind alle störungsfrei und sinnvoll. Leider habe ich auch hier das Problem, dass ich beim Setzen der BWsoll Temperatur eine 0 in der Heizung selber erhalte. Ich hatte in diesem Forum schon mehrfach dazu Beiträge gelesen, bin aber nicht ganz schlüssig daraus gewoden, was genau der Grund war.
                                Es gibt im Io-Broker im Log den Eintrag, dass anscheinend die Gegenseite vorzeitig die Verbindung kappt. Genaueres setze ich bei Bedarf gerne noch hier rein. Die Lösung bei vorangegangenen Beiträgen war der Umstieg auf den USR Serial-LAN Adapter. Den habe ich jetzt bestellt, um zumindest eine Lösung zu haben.... hoffentlich... . Allerdings finde ich die WLAN Anbindung auch sehr reizvoll.
                                Zweiter Punkt: Meine Firmware auf der Luxtronik ist noch die 2.20. Leider ist mein Heizungsmonteur sehr schwer ranzubekommen bzw. denke ich nicht, dass er da überhaupt Lust zu hat, bei der Anlage noch ein Update zu machen. Wenn ich das selber machen möchte, wie müsste ich da vorgehen und was brauche ich dazu alles? Danke Euch.
                                  forelleblau @SirWillfried last edited by
                                  @sirwillfried Hallo SirWillfried
                                  Sorry, da kann ich dir wohl nicht allzu mächtig weiterhelfen. Ja, ich bin auch der Meinung, dass das beschriebene Problem irgendwie mit dem Timing zusammenhängt, hatte ich glaub auch schon erwähnt. Da bin ich aber technisch zu wenig versiert, um sagen zu können wie es genau sein sollte. Von USR gibt es übrigens auch WLAN to RS232 - Adapter, der würde vielleicht auch gehen...
                                  Was die Firmware angeht würde ich wohl eher die Finger davon lassen. Meine ist 2.34, ich würde aber bei einer Heizung, die schon so lange (hoffentlich problemlos) läuft nichts mehr ändern, das nicht unbedingt nötig ist.
                                  Grüsse forelleblau
                                  S B 2 Replies Last reply Reply Quote 0
                                    SirWillfried @forelleblau last edited by
                                    @forelleblau Hallo forelleblau,
                                    Ist nicht schlimm. Ich probiere mich noch ein wenig durch und wenn der USR Adapter ankommt, wird hoffentlich alles gut. So ganz problemlos läuft die 2.20 nicht in den letzten 16 Jahren. Ich habe regelmäßig Hochdruckstörung und sie regelt sich die BW Solltemperatur auch gerne Stück für Stück runter, wenn das Aufheizen mal etwas länger dauert. Egal.
                                    Gestern hatte ich die Luxtronik dann nochmal auf Terminal zurückgestellt und musste feststellen, dass ich regelmäßig leicht verstümmelte Menü-Auflistungen bekomme, als ob dabei auch schon Zeichen verloren gehen. Einfach x mal Enter gedrückt und das Menü sah hin und wieder fehlerhaft aus. Ich denke einfach, dass die RS-232->WLAN Bridge über das ESP8266-Board nicht stabil genug läuft, um 57600baud zu übertragen. Handshake gibt's da auch nicht. Ich bleibe am Ball und berichte.
                                    Viele Grüße SirWillfried
                                      bummbadabumm @forelleblau last edited by bummbadabumm
                                      ich habe aufgrund deiner hier angebotenen Luxtronik1 Steuerung zum ioBroker gefunden.
                                      Dank deinem tollen Einsatz und des Modules, habe ich es mit ein paar Anlaufschwierigkeiten nun geschafft, dass unsere "Siemens (Novelan) LIC 8MW" nun auch geloggt werden kann.
                                      Ich wollte gerne einmal unsere Wärmepumpe optimieren, das war aber aufgrund der fehlenden Logs mit der Luxtronik1 kaum machbar.
                                      Ich wollte also eigentlich nur einmal DANKE sagen, denn nun kann ich mit ioBroker in Kombination von influxDB und Grafana die Daten sinnvoll aufbereiten!
                                      Kleiner Hinweis in Bezug auf das notwendige Kabel:
                                      in der vormals schon verlinkten Anleitung (https://wiki.fhem.de/wiki/Luxtronik_1_in_FHEM) sieht man, dass die PINs so belegt sind:
                                      2 = RXD / 3 = TXD / 5 = GND
                                      Moxa Nport (z.B. NPort 5110, NPort 5150, NPort 5210, etc.):
                                      hier sollte ein serielles (Straight-through) Kabel funktionieren, denn laut Anleitung liegt die gleiche Belegung vor:
                                      USR tcp232-302 RS232-Ethernet Converter:
                                      benötigt ein Nullmodem-Kabel, denn hier ist laut Anleitung folgende Belegung vorhanden:
                                      2 = TXD / 3 = RXD / 5 = GND (TXD & RXD verdreht)
                                      Ich habe den USR tcp232-302 RS232-Ethernet Converter mit Nullmodem-Kabel und es läuft einwandfrei, mit einem normalen seriellen Kabel kamen keine Daten an!
                                      Also immer schön in die Anleitung reinschauen, und die PIN Belegung prüfen, dann sollte es mit dem richtigen Kabel auch gleich auf Anhieb klappen und auch kein Löten notwendig sein - das nur mal als Hinweis für spätere Interessenten 🙂
                                      Alles Gute
                                      bummbadabumm
                                        forelleblau @bummbadabumm last edited by
                                        @bummbadabumm Danke vielmal!
                                          @forelleblau
                                          Jetzt muss ich doch noch mal einen Fehler melden - auch bei mir tritt seit einiger Zeit immer mal wieder der Fehler "unvollständiger Datensatz" auf - meist "unvollständiger Datensatz 1800", manches Mal aber auch "unvollständiger Datensatz 3405"
                                          Dazu kommen hin und wieder dann "State value to set..." Warnings mit falschen Werten, die außerhalb des erlaubten Bereiches sind.
                                          2022-10-17 01:24:40.725 - warn: luxtronik1.0 (10895) Verbindungsprobleme, starte Adapter neu
                                          2022-10-17 01:24:40.802 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 (force=false, process=true)
                                          2022-10-17 01:24:40.826 - info: luxtronik1.0 (10895) Got terminate signal TERMINATE_YOURSELF
                                          2022-10-17 01:24:40.828 - info: luxtronik1.0 (10895) [END] Stopping luxtronik adapter...
                                          2022-10-17 01:24:40.829 - info: luxtronik1.0 (10895) terminating
                                          2022-10-17 01:24:40.830 - info: luxtronik1.0 (10895) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2022-10-17 01:24:40.855 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 send kill signal
                                          2022-10-17 01:24:41.366 - info: host.iobroker instance system.adapter.luxtronik1.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-10-17 01:24:43.877 - info: host.iobroker instance system.adapter.luxtronik1.0 started with pid 16484
                                          2022-10-17 01:24:45.567 - info: luxtronik1.0 (16484) starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.luxtronik1, node: v16.17.1, js-controller: 4.0.23
                                          2022-10-17 01:24:45.591 - info: luxtronik1.0 (16484) [START] Starting luxtronik adapter
                                          2022-10-17 01:24:53.628 - warn: luxtronik1.0 (16484) State value to set for "luxtronik1.0.control.HystHKs" has value "32" greater than max "3"
                                          2022-10-17 01:24:53.630 - warn: luxtronik1.0 (16484) State value to set for "luxtronik1.0.control.HystBWs" has value "0" less than min "1"
                                          2022-10-17 01:44:45.621 - warn: luxtronik1.0 (16484) Achtung, mehrfach unvollständiger Datensatz 1800
                                          2022-10-17 01:44:45.622 - warn: luxtronik1.0 (16484) Adapter wird neu gestartet
                                          2022-10-17 01:44:45.665 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 (force=false, process=true)
                                          2022-10-17 01:44:45.669 - info: luxtronik1.0 (16484) Got terminate signal TERMINATE_YOURSELF
                                          2022-10-17 01:44:45.670 - info: luxtronik1.0 (16484) [END] Stopping luxtronik adapter...
                                          2022-10-17 01:44:45.671 - info: luxtronik1.0 (16484) terminating
                                          2022-10-17 01:44:45.672 - info: luxtronik1.0 (16484) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2022-10-17 01:44:45.707 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 send kill signal
                                          2022-10-17 01:44:46.202 - info: host.iobroker instance system.adapter.luxtronik1.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-10-17 01:44:48.725 - info: host.iobroker instance system.adapter.luxtronik1.0 started with pid 17527
                                          2022-10-17 01:44:50.371 - info: luxtronik1.0 (17527) starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.luxtronik1, node: v16.17.1, js-controller: 4.0.23
                                          2022-10-17 01:44:50.398 - info: luxtronik1.0 (17527) [START] Starting luxtronik adapter
                                          2022-10-17 02:04:50.430 - warn: luxtronik1.0 (17527) Achtung, mehrfach unvollständiger Datensatz 1800
                                          2022-10-17 02:04:50.431 - warn: luxtronik1.0 (17527) Adapter wird neu gestartet
                                          2022-10-17 02:04:50.475 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 (force=false, process=true)
                                          2022-10-17 02:04:50.484 - info: luxtronik1.0 (17527) Got terminate signal TERMINATE_YOURSELF
                                          2022-10-17 02:04:50.488 - info: luxtronik1.0 (17527) [END] Stopping luxtronik adapter...
                                          2022-10-17 02:04:50.490 - info: luxtronik1.0 (17527) terminating
                                          2022-10-17 02:04:50.493 - info: luxtronik1.0 (17527) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2022-10-17 02:04:50.519 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 send kill signal
                                          2022-10-17 02:04:51.031 - info: host.iobroker instance system.adapter.luxtronik1.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-10-17 02:04:53.541 - info: host.iobroker instance system.adapter.luxtronik1.0 started with pid 18564
                                          2022-10-17 02:04:55.261 - info: luxtronik1.0 (18564) starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.luxtronik1, node: v16.17.1, js-controller: 4.0.23
                                          2022-10-17 02:04:55.285 - info: luxtronik1.0 (18564) [START] Starting luxtronik adapter
                                          2022-10-17 02:09:37.855 - info: host.iobroker Delete log file iobroker.2022-10-09.log.gz
                                          2022-10-17 02:24:55.322 - warn: luxtronik1.0 (18564) Achtung, mehrfach unvollständiger Datensatz 1800
                                          2022-10-17 02:24:55.323 - warn: luxtronik1.0 (18564) Adapter wird neu gestartet
                                          2022-10-17 02:24:55.363 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 (force=false, process=true)
                                          2022-10-17 02:24:55.368 - info: luxtronik1.0 (18564) Got terminate signal TERMINATE_YOURSELF
                                          2022-10-17 02:24:55.369 - info: luxtronik1.0 (18564) [END] Stopping luxtronik adapter...
                                          2022-10-17 02:24:55.370 - info: luxtronik1.0 (18564) terminating
                                          2022-10-17 02:24:55.371 - info: luxtronik1.0 (18564) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2022-10-17 02:24:55.407 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 send kill signal
                                          2022-10-17 02:24:55.904 - info: host.iobroker instance system.adapter.luxtronik1.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-10-17 02:24:58.424 - info: host.iobroker instance system.adapter.luxtronik1.0 started with pid 19593
                                          2022-10-17 02:25:00.099 - info: luxtronik1.0 (19593) starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.luxtronik1, node: v16.17.1, js-controller: 4.0.23
                                          2022-10-17 02:25:00.124 - info: luxtronik1.0 (19593) [START] Starting luxtronik adapter
                                          2022-10-17 02:45:00.151 - warn: luxtronik1.0 (19593) Achtung, mehrfach unvollständiger Datensatz 1800
                                          2022-10-17 02:45:00.152 - warn: luxtronik1.0 (19593) Adapter wird neu gestartet
                                          2022-10-17 02:45:00.194 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 (force=false, process=true)
                                          2022-10-17 02:45:00.200 - info: luxtronik1.0 (19593) Got terminate signal TERMINATE_YOURSELF
                                          2022-10-17 02:45:00.201 - info: luxtronik1.0 (19593) [END] Stopping luxtronik adapter...
                                          2022-10-17 02:45:00.202 - info: luxtronik1.0 (19593) terminating
                                          2022-10-17 02:45:00.203 - info: luxtronik1.0 (19593) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2022-10-17 02:45:00.239 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 send kill signal
                                          2022-10-17 02:45:00.738 - info: host.iobroker instance system.adapter.luxtronik1.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-10-17 02:45:03.263 - info: host.iobroker instance system.adapter.luxtronik1.0 started with pid 20640
                                          2022-10-17 02:45:04.968 - info: luxtronik1.0 (20640) starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.luxtronik1, node: v16.17.1, js-controller: 4.0.23
                                          2022-10-17 02:45:04.993 - info: luxtronik1.0 (20640) [START] Starting luxtronik adapter
                                          2022-10-17 03:05:05.039 - warn: luxtronik1.0 (20640) Achtung, mehrfach unvollständiger Datensatz 1800
                                          2022-10-17 03:05:05.040 - warn: luxtronik1.0 (20640) Adapter wird neu gestartet
                                          2022-10-17 03:05:05.080 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 (force=false, process=true)
                                          2022-10-17 03:05:05.084 - info: luxtronik1.0 (20640) Got terminate signal TERMINATE_YOURSELF
                                          2022-10-17 03:05:05.085 - info: luxtronik1.0 (20640) [END] Stopping luxtronik adapter...
                                          2022-10-17 03:05:05.086 - info: luxtronik1.0 (20640) terminating
                                          2022-10-17 03:05:05.087 - info: luxtronik1.0 (20640) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2022-10-17 03:05:05.123 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 send kill signal
                                          2022-10-17 03:05:05.630 - info: host.iobroker instance system.adapter.luxtronik1.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-10-17 03:05:08.141 - info: host.iobroker instance system.adapter.luxtronik1.0 started with pid 21662
                                          2022-10-17 03:05:09.828 - info: luxtronik1.0 (21662) starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.luxtronik1, node: v16.17.1, js-controller: 4.0.23
                                          2022-10-17 03:05:09.852 - info: luxtronik1.0 (21662) [START] Starting luxtronik adapter
                                          2022-10-17 03:05:09.896 - warn: luxtronik1.0 (21662) State value to set for "luxtronik1.0.control.BWs" has value "0" less than min "30"
                                          2022-10-17 03:25:19.878 - warn: luxtronik1.0 (21662) Achtung, mehrfach unvollständiger Datensatz 3405
                                          2022-10-17 03:25:19.879 - warn: luxtronik1.0 (21662) Adapter wird neu gestartet
                                          2022-10-17 03:25:19.965 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 (force=false, process=true)
                                          2022-10-17 03:25:19.970 - info: luxtronik1.0 (21662) Got terminate signal TERMINATE_YOURSELF
                                          2022-10-17 03:25:19.971 - info: luxtronik1.0 (21662) [END] Stopping luxtronik adapter...
                                          2022-10-17 03:25:19.972 - info: luxtronik1.0 (21662) terminating
                                          2022-10-17 03:25:19.973 - info: luxtronik1.0 (21662) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2022-10-17 03:25:20.009 - info: host.iobroker stopInstance system.adapter.luxtronik1.0 send kill signal
                                          2022-10-17 03:25:20.509 - info: host.iobroker instance system.adapter.luxtronik1.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-10-17 03:25:23.032 - info: host.iobroker instance system.adapter.luxtronik1.0 started with pid 22689
                                          2022-10-17 03:25:24.732 - info: luxtronik1.0 (22689) starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.luxtronik1, node: v16.17.1, js-controller: 4.0.23
                                          2022-10-17 03:25:24.758 - info: luxtronik1.0 (22689) [START] Starting luxtronik adapter
                                          Aktuell läuft bei mir die Version v0.3.5
                                          Woran könnte das liegen?
                                          Wenn ich Ethernet/RS232 Converter & luxtronik in ioBroker neustarte, läuft es erstmal wieder rund, bis nach ein/zwei Tagen die Fehler wieder auftreten.
                                          Ach ja, falls von Bedeutung:
                                          den USR tcp232-302 habe ich bei "Local IP Config" auf DHCP eingestellt, und über die Fritzbox lasse ich immer die gleiche IP zuordnen...
                                          bummbadabumm
                                            @forelleblau Mahlzeit,
                                            der USR Adapter ist endlich da. Ich habe ihn so wie in einigen vorangegangenen Screenshots konfiguriert und erhalte auch die Daten der Heizung. Leider wird die BW-Solltemperatur immernoch auf 0°C gesetzt, wenn ich einen vernünftigen Wert einstellen will.
                                            Hier mal der Verlauf im Protokoll:
                                            luxtronik1.0
                                            	2022-10-27 18:21:20.493	warn	State value to set for "luxtronik1.0.control.BWs" has value "0" less than min "30"
                                            luxtronik1.0
                                            	2022-10-27 18:21:05.506	warn	State value to set for "luxtronik1.0.control.BWs" has value "0" less than min "30"
                                            luxtronik1.0
                                            	2022-10-27 18:21:05.295	info	[START] Starting luxtronik adapter
                                            luxtronik1.0
                                            	2022-10-27 18:21:05.254	info	starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.luxtronik1, node: v14.18.2, js-controller: 4.0.23
                                            luxtronik1.0
                                            	2022-10-27 18:21:02.906	warn	Got terminate signal. Checking desired PID: 18109 vs own PID 18000
                                            luxtronik1.0
                                            	2022-10-27 18:21:02.848	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            luxtronik1.0
                                            	2022-10-27 18:21:02.847	info	terminating
                                            luxtronik1.0
                                            	2022-10-27 18:21:02.846	info	[END] Stopping luxtronik adapter...
                                            luxtronik1.0
                                            	2022-10-27 18:21:02.845	warn	Got terminate signal. Checking desired PID: 0 vs own PID 18000
                                            luxtronik1.0
                                            	2022-10-27 18:21:02.709	warn	Verbindungsprobleme, starte Adapter neu
                                            luxtronik1.0
                                            	2022-10-27 18:20:44.922	info	BW-Solltemperatur nicht korrekt gesetzt, Vorgang wird wiederholt
                                            luxtronik1.0
                                            	2022-10-27 18:20:42.946	warn	State value to set for "luxtronik1.0.control.BWs" has value "0" less than min "30"
                                            luxtronik1.0
                                            	2022-10-27 18:20:25.965	info	ack is not set!
                                            Irgend eine Idee, was ich noch probieren könnte? Wäre schade, wenn ich die Heizung "nur" auslesen könnte.
                                            Danke Dir/Euch.
                                            1.0k
                                            210
                                            30448
