    3. Einsteigerfragen
    4. ioBroker kaputt "gerettet"
    • HeavyD
      HeavyD @Thomas Braun last edited by
      login as: HeavyD
      HeavyD@192.168.1.90's password:
      Linux heavydpi 5.15.32-v8+ #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022 aarch6                 4
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Sat Apr 16 16:16:25 2022 from 192.168.1.2
      Wi-Fi is currently blocked by rfkill.
      Use raspi-config to set the country before use.
      HeavyD@heavydpi:~ $ iobroker fix
      library: loaded
      Library version=2022-02-10
      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
        Thomas Braun Most Active @HeavyD last edited by
        @heavyd
        Dann Plan B von oben.
        HeavyD 1 Reply Last reply Reply Quote 0
        • HeavyD
          Direkt beim ersten Befehl kommt:
          HeavyD@heavydpi:~ $ cd /opt/iobroker
          HeavyD@heavydpi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          npm ERR! cb.apply is not a function
          npm ERR!     /home/iobroker/.npm/_logs/2022-04-16T16_39_50_479Z-debug.log
            Thomas Braun Most Active @HeavyD last edited by Thomas Braun
            @heavyd sagte in ioBroker kaputt "gerettet":
            Die Meldung hab ich noch nie gesehen...
            Schau dir nodeJS an:
            sudo ln -s /usr/bin/node /usr/bin/nodejs
            which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            • HeavyD
              HeavyD@heavydpi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
              HeavyD@heavydpi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v14.19.1
              v14.19.1
              4.6.1
              HeavyD
              /home/HeavyD
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
              Reading package lists... Done
              Building dependency tree... Done
              All packages are up to date.
              nodejs:
                Installed: 14.19.1-deb-1nodesource1
                Candidate: 14.19.1-deb-1nodesource1
                Version table:
               *** 14.19.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
                      100 /var/lib/dpkg/status
                   12.22.5~dfsg-2~11u1 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
              HeavyD@heavydpi:~ $
                4.6.1
                Wie kommt man zu einer npm -v 4.6.1?
                Die passt nicht zu node14.
                apt policy npm
                sudo apt remove npm
                sudo apt install --reinstall nodejs
                • HeavyD
                  @thomas-braun keine Ahnung! 🤷‍♂️
                  HeavyD@heavydpi:~ $ apt policy npm
                  npm:
                    Installed: (none)
                    Candidate: 7.5.2+ds-2
                    Version table:
                       7.5.2+ds-2 500
                          500 http://deb.debian.org/debian bullseye/main armhf Packages
                  HeavyD@heavydpi:~ $ sudo apt remove npm
                  Package 'npm' is not installed, so not removed
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  HeavyD@heavydpi:~ $ sudo apt install --reinstall nodejs
                  0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
                  Need to get 0 B/24.8 MB of archives.
                  After this operation, 0 B of additional disk space will be used.
                  (Reading database ... 48496 files and directories currently installed.)
                  Preparing to unpack .../nodejs_14.19.1-deb-1nodesource1_arm64.deb ...
                  Unpacking nodejs (14.19.1-deb-1nodesource1) over (14.19.1-deb-1nodesource1) ...
                  Setting up nodejs (14.19.1-deb-1nodesource1) ...
                  Processing triggers for man-db (2.9.4-2) ...
                  library: loaded
                  > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                  > node lib/preinstallCheck.js
                  NPM version: 6.14.16
                  > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
                  > node-gyp rebuild
                  make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
                    CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                  In file included from ../../nan/nan.h:58,
                                   from ../src/unix_dgram.cc:5:
                  /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                    793 |       (node::addon_register_func) (regfunc),                          \
                  /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                    827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                  ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                    404 | NODE_MODULE(unix_dgram, Initialize)
                    SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                    COPY Release/unix_dgram.node
                  make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
                  > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                  > node rebuild.js
                  ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                  > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
                  > node-gyp rebuild
                  make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
                    CXX(target) Release/obj.target/diskusage/src/main.o
                                   from ../src/main.cpp:3:
                  ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                     42 | NODE_MODULE(diskusage, Init)
                    CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
                    SOLINK_MODULE(target) Release/obj.target/diskusage.node
                    COPY Release/diskusage.node
                  make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
                  > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
                  > node iobroker.js setup first
                  Successfully migrated 4344 objects to Redis Sets
                  object _design/system updated
                    "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\nMIIEowIBAAKCAQEAvgjmkH9uBlfuygNofjcU77tP3wzbnRo0/dK1gkirX++jBK9i\r\nbdjWbYoRqNJX2Vy/DRkbbgtcNuQDrHVrkc8tcgcAzqWZfbWvLcYwQG4lDoKuGqLk\r\n+6UGbuMdOXhV7mzq4en+/nTJlkFPuF6SM+qDQDa7pfMkcYij7E3jSi656hOWQJ1r\r\n90xZ5FCVaT2oU0AMaIWchYRckhaRO0B5FvhJyvrny+KZWGkPjuP4enPt3VjzFy0a\r\nj65IelXo0Am6BHFB1PcCFV5x8yVLbQ5rczxqo5BORfPeXfptC/1Rqkzsz3ZKoZgr\r\ns3P9Ez1hx8pYPEmnp1Dgn1dRQKfyGY/xO3qpxQIDAQABAoIBAA7kg60vT2AP5BbQ\r\nzY+WoX1oIIpKZ6uYMi7yJGdhaozKKuxjEkOpiqRq/ZdNZLUUH6TXIt8s5L0ogWEy\r\nkouKwPT+t4F6WN0RL/lWXtGt0BmjBCHyQh+2fxqRkei/FXzp7D5oKCOo42NzGtxI\r\nDQ0kg8S0hWAr/d8n5jDOqdFWeBtv6ue7IsQTogIQoSMFEyHcts/nIQk9nDjkrlFI\r\nQtzqG5y2WucEBkGXsv79se69rY5mywW3ULlY6FCDbJ+rp9h5mT8xLd4DBVp54uMw\r\nTil7OPJZKxFPGVf9G8yJGE/rkn0JOqZcj65cD+zC+5SszydqIUO+W8X2B9TpCekE\r\nMzYZQsECgYEA6KnJBANNPVOyBVb9q/e50mmWuhN2akwYmPB9w1EDrLONuDb47fg1\r\nVNi/P6gxWXgwHXGk5/wu0aqNdh3/fyAUYG3GYiVzvC0r8Ccua7hhxdARl7nqgvyu\r\nGiiutF3ZUWLjxrhF0Cxevksx8mUSVJJGQINy4uvW26YnvPQPaevMiQMCgYEA0RiF\r\nuiK7BSc3hlG9r3N1C+i0nqORQ0uHlE5rkzjyl/dtmpQrM3g6rZ4vCyRsPBE0U9Or\r\nw7CGjxCX8VhOcOqrv3g3JsGd+0gBdoi03b8r3l4n6dzgJzBUHC07O42nUzgmd/gd\r\na7siF0ODcWV9mvrldmYUPuGq1lqoJEvgauKY85cCgYEAhCf9AISHmTAzTIkvKkFa\r\nkcRcU3G+r35t8mGYbhtUhQKwm1TObQ2x7XH4oEX/UhzM58ynqQY76eiA1fkQKbul\r\nF2kDaLhxVxAphw4adiGTl/MqKw71wFWa50z4f4dXa71KOJRvQ2IQpvK7ej4i/Vrh\r\nAMApv+/KaZWluNTA9J913NUCgYB5C1wm5AImOoyvKlTH4+vHSCB/kar/LRNArKEj\r\n6hyuEqOVj97ufdRiO6d6KMyrfT4wpOHTeDZ9TZrYMUm/nmpsfjhXLFC7bfTC3OLv\r\nV8MaiKFMhfwRU63tXdXjZN6Pk3rZin3lpsBWfVPzalBrToFVqERiHpuaWYLq+C3j\r\nUmg+4wKBgDvIIc0flok4X3oQgHCnfxyQzqTH/UssT4ManrqdtzZMRimMEv2ZEjtD\r\n9J3Buwsb40rG7a1pdRV21UobsHmzqtInQGQI8JDHka54PIo2peWevVMHEw8+nkAs\r\nEzQOwj4NxN8zwMKGJvzzqzDUYOh5g2eFq3C0gG8okyUH2odgNkvT\r\n-----END RSA PRIVATE KEY-----\r\n",
                    "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nMmyghqIkV4NjDcIDUIWSfgSpKF4hKS4/whMSRzq3VHVeBw==\r\n-----END CERTIFICATE-----\r\n"
                  Update certificate defaultPrivate
                  The object "system.certificates" was updated successfully.
                  Update certificate defaultPublic
                  > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
                  > node scripts/postinstall
                  > esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
                  > node install.js
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                  + iobroker.js-controller@4.0.21
                  added 225 packages from 182 contributors in 170.509s
                  49 packages are looking for funding
                    run `npm fund` for details
                  HeavyD@heavydpi:/opt/iobroker $ iobroker update -i
                  internal/modules/cjs/loader.js:905
                    throw err;
                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                      at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                      at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                      at internal/main/run_main_module.js:17:47 {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: []
                    @heavyd
                    Ich muss jetzt nochmal
                    frisch sehen.
                    • HeavyD
                      HeavyD@heavydpi:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v14.19.1
                      v14.19.1
                      6.14.16
                      HeavyD
                      /opt/iobroker
                      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                      nodejs:
                        Version table:
                        Jan1 @HeavyD last edited by Jan1
                        Hab ihn mir gestern auf einem PI aufgesetzt und ein paar Adapter installiert zum Testen.
                        Hm und warum eierst jetzt so lange mit nem Rettungsversuch rum und machst das Bisschen nicht einfach noch mal neu und sauber?
                        Node und NPM sieht zumindest mal wieder vernünftig aus.
                        • HeavyD
                          HeavyD @Jan1 last edited by
                          @jan1 ich hab ja nur gefragt ob da noch was zu retten ist? Wenn es halt zu aufwendig ist mach ich es neu.
                            Thomas Braun Most Active last edited by Thomas Braun
                            @heavyd
                            cd /opt/iobroker
                            iobroker start
                            iobroker status
                            • HeavyD
                              HeavyD@heavydpi:/opt/iobroker $ iobroker start
                              HeavyD@heavydpi:/opt/iobroker $ iobroker status
                              Objects type: jsonl
                              States  type: jsonl
                                Gut.
                                  @heavyd
                                  Wenn man eh am Anfang steht, ist das eben am einfachsten und schneller gehts auch. Retten würde auch klappen und lernen wirst auch was dabei. Bleibt Dir überlassen. Die Frage ist immer nur, was hast noch so verbastelt und wird sich das später noch bemerkbar machen.
                                    rotamint @Thomas Braun last edited by
                                    @thomas-braun @HeavyD Als stiller lerndender Mitleser - dankeschön, wieder was gelernt!
                                      subman82 last edited by
                                      ich habe wohl ähnliche Probleme wie mein Vorgänger aber leider wurden meine mit dem letzten Schritt nicht gelöst. Ich komme nicht auf die Adminseite meines iobroker.
                                      Ich versuche mal den Codetag hier anzuwenden,ich hoffe es funktioniert,ist mein erster Versuch....
                                      aktuell:
                                      Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
                                      pi@raspberrypi:~ $ npm -v
                                      6.14.17
                                      pi@raspberrypi:~ $ node -v
                                      v14.20.0
                                      Ergebnis des letzten Schrittes deiner Anleitung:
                                      pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
                                      npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                                      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                      npm WARN checkPermissions Missing write access to /home/pi
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                      npm WARN pi No description
                                      npm WARN pi No repository field.
                                      npm WARN pi No license field.
                                      npm ERR! code EACCES
                                      npm ERR! syscall access
                                      npm ERR! path /home/pi
                                      npm ERR! errno -13
                                      npm ERR! Error: EACCES: permission denied, access '/home/pi'
                                      npm ERR!  [Error: EACCES: permission denied, access '/home/pi'] {
                                      npm ERR!   errno: -13,
                                      npm ERR!   code: 'EACCES',
                                      npm ERR!   syscall: 'access',
                                      npm ERR!   path: '/home/pi'
                                      npm ERR! }
                                      npm ERR!
                                      npm ERR! The operation was rejected by your operating system.
                                      npm ERR! It is likely you do not have the permissions to access this file as the current user
                                      npm ERR!
                                      npm ERR! If you believe this might be a permissions issue, please double-check the
                                      npm ERR! permissions of the file and its containing directories, or try running
                                      npm ERR! the command again as root/Administrator.
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-09-10T22_20_09_875Z-debug.log
                                      pi@raspberrypi:~ $ iobroker start
                                      pi@raspberrypi:~ $ iobroker status
                                        throw err;
                                        requireStack: []
                                      Es lief soweit alles stabil bis ich ein node update durchgeführt habe von v14 auf v16. npm war meine ich 8.1.5 als noch alles lief.
                                      Ich wollte eigentlich nur den Shellyadapter updaten aber dafür musste ich Updates vom System durchführen.
                                      Das hat auch ungefähr 10min funktioniert , alle Instanzen waren auch auch grün und dann wollte ich den Shellyadapter
                                      updaten und seit dem komme ich nicht mehr auf die Benutzeroberfläche.
                                      Wie oben dargestellt , habe ich aktuell node auf 14.20.0 und npm 6.14.17 zurückgestellt aber das half noch nicht.
                                      Ich sitz hier schon 5 Stunden dran und komm nicht weiter.Ich hoffe ihr könnt mir helfen,.
                                      Besten Dank vorab,Gruss Peter
                                      mikeal created this issue in request/request
                                      open Request’s Past, Present and Future #3142
                                        Thomas Braun Most Active @subman82 last edited by Thomas Braun
                                        @subman82 sagte in ioBroker kaputt "gerettet":
                                        Du stehst im falschen Verzeichnis.
                                        cd /opt/iobroker
                                        Und wie bist du da nun grundsätzlich unterwegs?
                                        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                        anschauen.
                                          subman82 @Thomas Braun last edited by
                                          Moin und danke für die schnelle Rückmeldung.
                                          Ich glaub das mit dem falschem Verzeichnis liegt daran , wenn man keine Ahnung hat und aus allen Posts etwas versucht um es zu retten....Schande über mein Haupt. Ich könnte mir auch vorstellen, dass die Versionen von nodejs,node und npm nicht kompatibel sind. Ich habe immer regelmässig upgedatet aber diesmal ist was schief gelaufen:/
                                          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                          ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                          pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                          armv7l
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v14.20.0
                                          v14.20.0
                                          6.14.17
                                          pi
                                          /home/pi
                                          Danke für deine Mühe!!
                                            Vermutlich ewig keine Updates mehr eingespielt.
                                            4761
