    3. Einsteigerfragen
    4. ioBroker kaputt "gerettet"
      Thomas Braun Most Active @HeavyD last edited by Thomas Braun
      @heavyd sagte in ioBroker kaputt "gerettet":
      cb.apply is not a function
      Die Meldung hab ich noch nie gesehen...
      Schau dir nodeJS an:
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      HeavyD 1 Reply Last reply Reply Quote 0
      • HeavyD
        HeavyD @Thomas Braun last edited by
        HeavyD@heavydpi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        HeavyD@heavydpi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.19.1
        v14.19.1
        4.6.1
        HeavyD
        /home/HeavyD
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
        Reading package lists... Done
        Building dependency tree... Done
        All packages are up to date.
        nodejs:
          Installed: 14.19.1-deb-1nodesource1
          Candidate: 14.19.1-deb-1nodesource1
          Version table:
         *** 14.19.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.5~dfsg-2~11u1 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        HeavyD@heavydpi:~ $
          4.6.1
          Wie kommt man zu einer npm -v 4.6.1?
          Die passt nicht zu node14.
          apt policy npm
          sudo apt remove npm
          sudo apt install --reinstall nodejs
          • HeavyD
            @thomas-braun keine Ahnung! 🤷‍♂️
            HeavyD@heavydpi:~ $ apt policy npm
            npm:
              Installed: (none)
              Candidate: 7.5.2+ds-2
              Version table:
                 7.5.2+ds-2 500
                    500 http://deb.debian.org/debian bullseye/main armhf Packages
            HeavyD@heavydpi:~ $ sudo apt remove npm
            Package 'npm' is not installed, so not removed
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            HeavyD@heavydpi:~ $ sudo apt install --reinstall nodejs
            0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
            Need to get 0 B/24.8 MB of archives.
            After this operation, 0 B of additional disk space will be used.
            (Reading database ... 48496 files and directories currently installed.)
            Preparing to unpack .../nodejs_14.19.1-deb-1nodesource1_arm64.deb ...
            Unpacking nodejs (14.19.1-deb-1nodesource1) over (14.19.1-deb-1nodesource1) ...
            Setting up nodejs (14.19.1-deb-1nodesource1) ...
            Processing triggers for man-db (2.9.4-2) ...
            HeavyD@heavydpi:~ $ iobroker fix
            library: loaded
            Library version=2022-02-10
            ioBroker is not installed in /opt/iobroker! Cannot fix anything...
            HeavyD@heavydpi:~ $ cd /opt/iobroker
            HeavyD@heavydpi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
            > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
            > node lib/preinstallCheck.js
            NPM version: 6.14.16
            > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
            > node-gyp rebuild
            make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
              CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
            In file included from ../../nan/nan.h:58,
                             from ../src/unix_dgram.cc:5:
            /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
              793 |       (node::addon_register_func) (regfunc),                          \
            /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
              827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
            ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
              404 | NODE_MODULE(unix_dgram, Initialize)
              SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
              COPY Release/unix_dgram.node
            make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
            > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
            > node rebuild.js
            ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
            > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
            > node-gyp rebuild
            make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
              CXX(target) Release/obj.target/diskusage/src/main.o
                             from ../src/main.cpp:3:
            ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
               42 | NODE_MODULE(diskusage, Init)
              CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
              SOLINK_MODULE(target) Release/obj.target/diskusage.node
              COPY Release/diskusage.node
            make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
            > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
            > node iobroker.js setup first
            Successfully migrated 4344 objects to Redis Sets
            object _design/system updated
              "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nEzQOwj4NxN8zwMKGJvzzqzDUYOh5g2eFq3C0gG8okyUH2odgNkvT\r\n-----END RSA PRIVATE KEY-----\r\n",
              "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nMmyghqIkV4NjDcIDUIWSfgSpKF4hKS4/whMSRzq3VHVeBw==\r\n-----END CERTIFICATE-----\r\n"
            Update certificate defaultPrivate
            The object "system.certificates" was updated successfully.
            Update certificate defaultPublic
            > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
            > node scripts/postinstall
            > esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
            > node install.js
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
            + iobroker.js-controller@4.0.21
            added 225 packages from 182 contributors in 170.509s
            49 packages are looking for funding
              run `npm fund` for details
            HeavyD@heavydpi:/opt/iobroker $ iobroker update -i
            internal/modules/cjs/loader.js:905
              throw err;
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                at internal/main/run_main_module.js:17:47 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
              @heavyd
              Ich muss jetzt nochmal
              frisch sehen.
              • HeavyD
                HeavyD@heavydpi:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v14.19.1
                v14.19.1
                6.14.16
                HeavyD
                /opt/iobroker
                Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                nodejs:
                  Version table:
                  Jan1 @HeavyD last edited by Jan1
                  Hab ihn mir gestern auf einem PI aufgesetzt und ein paar Adapter installiert zum Testen.
                  Hm und warum eierst jetzt so lange mit nem Rettungsversuch rum und machst das Bisschen nicht einfach noch mal neu und sauber?
                  Node und NPM sieht zumindest mal wieder vernünftig aus.
                  • HeavyD
                    HeavyD @Jan1 last edited by
                    @jan1 ich hab ja nur gefragt ob da noch was zu retten ist? Wenn es halt zu aufwendig ist mach ich es neu.
                      Thomas Braun Most Active last edited by Thomas Braun
                      @heavyd
                      cd /opt/iobroker
                      iobroker start
                      iobroker status
                      • HeavyD
                        HeavyD@heavydpi:/opt/iobroker $ iobroker start
                        HeavyD@heavydpi:/opt/iobroker $ iobroker status
                        Objects type: jsonl
                        States  type: jsonl
                          Gut.
                            @heavyd
                            Wenn man eh am Anfang steht, ist das eben am einfachsten und schneller gehts auch. Retten würde auch klappen und lernen wirst auch was dabei. Bleibt Dir überlassen. Die Frage ist immer nur, was hast noch so verbastelt und wird sich das später noch bemerkbar machen.
                              rotamint @Thomas Braun last edited by
                              @thomas-braun @HeavyD Als stiller lerndender Mitleser - dankeschön, wieder was gelernt!
                                subman82 last edited by
                                ich habe wohl ähnliche Probleme wie mein Vorgänger aber leider wurden meine mit dem letzten Schritt nicht gelöst. Ich komme nicht auf die Adminseite meines iobroker.
                                Ich versuche mal den Codetag hier anzuwenden,ich hoffe es funktioniert,ist mein erster Versuch....
                                aktuell:
                                Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
                                The programs included with the Debian GNU/Linux system are free software;
                                pi@raspberrypi:~ $ npm -v
                                6.14.17
                                pi@raspberrypi:~ $ node -v
                                v14.20.0
                                Ergebnis des letzten Schrittes deiner Anleitung:
                                pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
                                npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                npm WARN checkPermissions Missing write access to /home/pi
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                npm WARN pi No description
                                npm WARN pi No repository field.
                                npm WARN pi No license field.
                                npm ERR! code EACCES
                                npm ERR! syscall access
                                npm ERR! path /home/pi
                                npm ERR! errno -13
                                npm ERR! Error: EACCES: permission denied, access '/home/pi'
                                npm ERR!  [Error: EACCES: permission denied, access '/home/pi'] {
                                npm ERR!   errno: -13,
                                npm ERR!   code: 'EACCES',
                                npm ERR!   syscall: 'access',
                                npm ERR!   path: '/home/pi'
                                npm ERR! }
                                npm ERR!
                                npm ERR! The operation was rejected by your operating system.
                                npm ERR! It is likely you do not have the permissions to access this file as the current user
                                npm ERR!
                                npm ERR! If you believe this might be a permissions issue, please double-check the
                                npm ERR! permissions of the file and its containing directories, or try running
                                npm ERR! the command again as root/Administrator.
                                npm ERR!     /home/iobroker/.npm/_logs/2022-09-10T22_20_09_875Z-debug.log
                                pi@raspberrypi:~ $ iobroker start
                                pi@raspberrypi:~ $ iobroker status
                                  throw err;
                                  requireStack: []
                                Es lief soweit alles stabil bis ich ein node update durchgeführt habe von v14 auf v16. npm war meine ich 8.1.5 als noch alles lief.
                                Ich wollte eigentlich nur den Shellyadapter updaten aber dafür musste ich Updates vom System durchführen.
                                Das hat auch ungefähr 10min funktioniert , alle Instanzen waren auch auch grün und dann wollte ich den Shellyadapter
                                updaten und seit dem komme ich nicht mehr auf die Benutzeroberfläche.
                                Wie oben dargestellt , habe ich aktuell node auf 14.20.0 und npm 6.14.17 zurückgestellt aber das half noch nicht.
                                Ich sitz hier schon 5 Stunden dran und komm nicht weiter.Ich hoffe ihr könnt mir helfen,.
                                Besten Dank vorab,Gruss Peter
                                mikeal created this issue in request/request
                                open Request’s Past, Present and Future #3142
                                  Thomas Braun Most Active @subman82 last edited by Thomas Braun
                                  @subman82 sagte in ioBroker kaputt "gerettet":
                                  Du stehst im falschen Verzeichnis.
                                  cd /opt/iobroker
                                  Und wie bist du da nun grundsätzlich unterwegs?
                                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  anschauen.
                                    subman82 @Thomas Braun last edited by
                                    Moin und danke für die schnelle Rückmeldung.
                                    Ich glaub das mit dem falschem Verzeichnis liegt daran , wenn man keine Ahnung hat und aus allen Posts etwas versucht um es zu retten....Schande über mein Haupt. Ich könnte mir auch vorstellen, dass die Versionen von nodejs,node und npm nicht kompatibel sind. Ich habe immer regelmässig upgedatet aber diesmal ist was schief gelaufen:/
                                    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                    ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                    pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    armv7l
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v14.20.0
                                    v14.20.0
                                    6.14.17
                                    pi
                                    /home/pi
                                    Danke für deine Mühe!!
                                      Vermutlich ewig keine Updates mehr eingespielt.
                                        Ich schaue wirklich regelmässig nach Updates,ich würde sagen mindestens einmal im Monat.
                                        Ich habe in den Adaptern und unter der Benutzeroberfläche unter Info immer kontrolliert dass alles aktuell ist, vielleicht habe ich aus Unwissenheit etwas vergessen?Bisher hab ich immer node.js und js-controller über Putty upgedatet meine ich . Node ist ebefalls ein separates Programm habe ich jetzt festgestellt. Ich schau später nochmal nach einer Anleitung, wie ich es zukünftig richtig mache.
                                        pi@raspberrypi:~ $ sudo apt update && apt policy nodejs
                                        OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                        OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                        OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                                        Aktualisierung für 9 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                        nodejs:
                                          Installiert:           14.20.0-deb-1nodesource1
                                          Installationskandidat: 14.20.0-deb-1nodesource1
                                          Versionstabelle:
                                         *** 14.20.0-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                             10.24.0~dfsg-1~deb10u1 500
                                        Thomas Braun S 2 Replies Last reply Reply Quote 0
                                          Aktualisier das System.
                                          Und wo klemmt es denn nun konkret?
                                            subman82 @subman82 last edited by
                                            @subman82 Die jetzt installierten Versionen habe ich nur installiert, weil ich gehofft hatte dass mit den alten Versionen es wieder laufen würde und ich könnte dann neu updaten.
                                            4758
