    3. Einsteigerfragen
    4. ioBroker kaputt "gerettet"
    • HeavyD
      HeavyD @Thomas Braun last edited by
      HeavyD@heavydpi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      HeavyD@heavydpi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.19.1
      v14.19.1
      4.6.1
      HeavyD
      /home/HeavyD
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      nodejs:
        Installed: 14.19.1-deb-1nodesource1
        Candidate: 14.19.1-deb-1nodesource1
        Version table:
       *** 14.19.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      HeavyD@heavydpi:~ $
        Thomas Braun Most Active @HeavyD last edited by Thomas Braun
        @heavyd sagte in ioBroker kaputt "gerettet":
        4.6.1
        Wie kommt man zu einer npm -v 4.6.1?
        Die passt nicht zu node14.
        apt policy npm
        sudo apt remove npm
        sudo apt install --reinstall nodejs
        HeavyD 1 Reply Last reply Reply Quote 0
        • HeavyD
          @thomas-braun keine Ahnung! 🤷‍♂️
          HeavyD@heavydpi:~ $ apt policy npm
          npm:
            Installed: (none)
            Candidate: 7.5.2+ds-2
            Version table:
               7.5.2+ds-2 500
                  500 http://deb.debian.org/debian bullseye/main armhf Packages
          HeavyD@heavydpi:~ $ sudo apt remove npm
          Package 'npm' is not installed, so not removed
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          HeavyD@heavydpi:~ $ sudo apt install --reinstall nodejs
          0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
          Need to get 0 B/24.8 MB of archives.
          After this operation, 0 B of additional disk space will be used.
          (Reading database ... 48496 files and directories currently installed.)
          Preparing to unpack .../nodejs_14.19.1-deb-1nodesource1_arm64.deb ...
          Unpacking nodejs (14.19.1-deb-1nodesource1) over (14.19.1-deb-1nodesource1) ...
          Setting up nodejs (14.19.1-deb-1nodesource1) ...
          Processing triggers for man-db (2.9.4-2) ...
          HeavyD@heavydpi:~ $ iobroker fix
          library: loaded
          Library version=2022-02-10
          ioBroker is not installed in /opt/iobroker! Cannot fix anything...
          HeavyD@heavydpi:~ $ cd /opt/iobroker
          HeavyD@heavydpi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
          > node lib/preinstallCheck.js
          NPM version: 6.14.16
          > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
          > node-gyp rebuild
          make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
            CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
          In file included from ../../nan/nan.h:58,
                           from ../src/unix_dgram.cc:5:
          /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
            793 |       (node::addon_register_func) (regfunc),                          \
          /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
            827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
          ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
            404 | NODE_MODULE(unix_dgram, Initialize)
            SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
            COPY Release/unix_dgram.node
          make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
          > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
          > node rebuild.js
          ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
          > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
          > node-gyp rebuild
          make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
            CXX(target) Release/obj.target/diskusage/src/main.o
                           from ../src/main.cpp:3:
          ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
             42 | NODE_MODULE(diskusage, Init)
            CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
            SOLINK_MODULE(target) Release/obj.target/diskusage.node
            COPY Release/diskusage.node
          make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
          > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
          > node iobroker.js setup first
          Successfully migrated 4344 objects to Redis Sets
          object _design/system updated
            "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nEzQOwj4NxN8zwMKGJvzzqzDUYOh5g2eFq3C0gG8okyUH2odgNkvT\r\n-----END RSA PRIVATE KEY-----\r\n",
            "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nMmyghqIkV4NjDcIDUIWSfgSpKF4hKS4/whMSRzq3VHVeBw==\r\n-----END CERTIFICATE-----\r\n"
          Update certificate defaultPrivate
          The object "system.certificates" was updated successfully.
          Update certificate defaultPublic
          > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
          > node scripts/postinstall
          > esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
          > node install.js
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
          + iobroker.js-controller@4.0.21
          added 225 packages from 182 contributors in 170.509s
          49 packages are looking for funding
            run `npm fund` for details
          HeavyD@heavydpi:/opt/iobroker $ iobroker update -i
          internal/modules/cjs/loader.js:905
            throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
              at Function.Module._load (internal/modules/cjs/loader.js:746:27)
              at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
              at internal/main/run_main_module.js:17:47 {
            code: 'MODULE_NOT_FOUND',
            requireStack: []
            @heavyd
            Ich muss jetzt nochmal
            frisch sehen.
            • HeavyD
              HeavyD@heavydpi:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v14.19.1
              v14.19.1
              6.14.16
              HeavyD
              /opt/iobroker
              Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
              nodejs:
                Version table:
                Jan1 @HeavyD last edited by Jan1
                Hab ihn mir gestern auf einem PI aufgesetzt und ein paar Adapter installiert zum Testen.
                Hm und warum eierst jetzt so lange mit nem Rettungsversuch rum und machst das Bisschen nicht einfach noch mal neu und sauber?
                Node und NPM sieht zumindest mal wieder vernünftig aus.
                • HeavyD
                  HeavyD @Jan1 last edited by
                  @jan1 ich hab ja nur gefragt ob da noch was zu retten ist? Wenn es halt zu aufwendig ist mach ich es neu.
                    Thomas Braun Most Active last edited by Thomas Braun
                    @heavyd
                    cd /opt/iobroker
                    iobroker start
                    iobroker status
                    • HeavyD
                      HeavyD@heavydpi:/opt/iobroker $ iobroker start
                      HeavyD@heavydpi:/opt/iobroker $ iobroker status
                      Objects type: jsonl
                      States  type: jsonl
                        Gut.
                          @heavyd
                          Wenn man eh am Anfang steht, ist das eben am einfachsten und schneller gehts auch. Retten würde auch klappen und lernen wirst auch was dabei. Bleibt Dir überlassen. Die Frage ist immer nur, was hast noch so verbastelt und wird sich das später noch bemerkbar machen.
                            rotamint @Thomas Braun last edited by
                            @thomas-braun @HeavyD Als stiller lerndender Mitleser - dankeschön, wieder was gelernt!
                              subman82 last edited by
                              ich habe wohl ähnliche Probleme wie mein Vorgänger aber leider wurden meine mit dem letzten Schritt nicht gelöst. Ich komme nicht auf die Adminseite meines iobroker.
                              Ich versuche mal den Codetag hier anzuwenden,ich hoffe es funktioniert,ist mein erster Versuch....
                              aktuell:
                              Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
                              The programs included with the Debian GNU/Linux system are free software;
                              pi@raspberrypi:~ $ npm -v
                              6.14.17
                              pi@raspberrypi:~ $ node -v
                              v14.20.0
                              Ergebnis des letzten Schrittes deiner Anleitung:
                              pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
                              npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                              npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                              npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                              npm WARN checkPermissions Missing write access to /home/pi
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                              npm WARN pi No description
                              npm WARN pi No repository field.
                              npm WARN pi No license field.
                              npm ERR! code EACCES
                              npm ERR! syscall access
                              npm ERR! path /home/pi
                              npm ERR! errno -13
                              npm ERR! Error: EACCES: permission denied, access '/home/pi'
                              npm ERR!  [Error: EACCES: permission denied, access '/home/pi'] {
                              npm ERR!   errno: -13,
                              npm ERR!   code: 'EACCES',
                              npm ERR!   syscall: 'access',
                              npm ERR!   path: '/home/pi'
                              npm ERR! }
                              npm ERR!
                              npm ERR! The operation was rejected by your operating system.
                              npm ERR! It is likely you do not have the permissions to access this file as the current user
                              npm ERR!
                              npm ERR! If you believe this might be a permissions issue, please double-check the
                              npm ERR! permissions of the file and its containing directories, or try running
                              npm ERR! the command again as root/Administrator.
                              npm ERR!     /home/iobroker/.npm/_logs/2022-09-10T22_20_09_875Z-debug.log
                              pi@raspberrypi:~ $ iobroker start
                              pi@raspberrypi:~ $ iobroker status
                                throw err;
                                requireStack: []
                              Es lief soweit alles stabil bis ich ein node update durchgeführt habe von v14 auf v16. npm war meine ich 8.1.5 als noch alles lief.
                              Ich wollte eigentlich nur den Shellyadapter updaten aber dafür musste ich Updates vom System durchführen.
                              Das hat auch ungefähr 10min funktioniert , alle Instanzen waren auch auch grün und dann wollte ich den Shellyadapter
                              updaten und seit dem komme ich nicht mehr auf die Benutzeroberfläche.
                              Wie oben dargestellt , habe ich aktuell node auf 14.20.0 und npm 6.14.17 zurückgestellt aber das half noch nicht.
                              Ich sitz hier schon 5 Stunden dran und komm nicht weiter.Ich hoffe ihr könnt mir helfen,.
                              Besten Dank vorab,Gruss Peter
                              mikeal created this issue in request/request
                              open Request’s Past, Present and Future #3142
                                Thomas Braun Most Active @subman82 last edited by Thomas Braun
                                @subman82 sagte in ioBroker kaputt "gerettet":
                                Du stehst im falschen Verzeichnis.
                                cd /opt/iobroker
                                Und wie bist du da nun grundsätzlich unterwegs?
                                uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                anschauen.
                                  subman82 @Thomas Braun last edited by
                                  Moin und danke für die schnelle Rückmeldung.
                                  Ich glaub das mit dem falschem Verzeichnis liegt daran , wenn man keine Ahnung hat und aus allen Posts etwas versucht um es zu retten....Schande über mein Haupt. Ich könnte mir auch vorstellen, dass die Versionen von nodejs,node und npm nicht kompatibel sind. Ich habe immer regelmässig upgedatet aber diesmal ist was schief gelaufen:/
                                  pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                  ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                  pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v14.20.0
                                  v14.20.0
                                  6.14.17
                                  pi
                                  /home/pi
                                  Danke für deine Mühe!!
                                    Vermutlich ewig keine Updates mehr eingespielt.
                                      Ich schaue wirklich regelmässig nach Updates,ich würde sagen mindestens einmal im Monat.
                                      Ich habe in den Adaptern und unter der Benutzeroberfläche unter Info immer kontrolliert dass alles aktuell ist, vielleicht habe ich aus Unwissenheit etwas vergessen?Bisher hab ich immer node.js und js-controller über Putty upgedatet meine ich . Node ist ebefalls ein separates Programm habe ich jetzt festgestellt. Ich schau später nochmal nach einer Anleitung, wie ich es zukünftig richtig mache.
                                      pi@raspberrypi:~ $ sudo apt update && apt policy nodejs
                                      OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                      OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                                      Aktualisierung für 9 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                      nodejs:
                                        Installiert:           14.20.0-deb-1nodesource1
                                        Installationskandidat: 14.20.0-deb-1nodesource1
                                        Versionstabelle:
                                       *** 14.20.0-deb-1nodesource1 500
                                              500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                           10.24.0~dfsg-1~deb10u1 500
                                      Thomas Braun S 2 Replies Last reply Reply Quote 0
                                        Aktualisier das System.
                                        Und wo klemmt es denn nun konkret?
                                          subman82 @subman82 last edited by
                                          @subman82 Die jetzt installierten Versionen habe ich nur installiert, weil ich gehofft hatte dass mit den alten Versionen es wieder laufen würde und ich könnte dann neu updaten.
                                            @subman82
                                            Und konkret bedeutet das? Läuft der iobroker? Wenn nicht, mit welchen Meldungen?
                                            4758
