    3. Einsteigerfragen
    4. ioBroker kaputt "gerettet"
      Thomas Braun Most Active @HeavyD last edited by Thomas Braun
      @heavyd sagte in ioBroker kaputt "gerettet":
      4.6.1
      Wie kommt man zu einer npm -v 4.6.1?
      Die passt nicht zu node14.
      apt policy npm
      sudo apt remove npm
      sudo apt install --reinstall nodejs
      HeavyD 1 Reply Last reply Reply Quote 0
      • HeavyD
        HeavyD @Thomas Braun last edited by
        @thomas-braun keine Ahnung! 🤷‍♂️
        HeavyD@heavydpi:~ $ apt policy npm
        npm:
          Installed: (none)
          Candidate: 7.5.2+ds-2
          Version table:
             7.5.2+ds-2 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://deb.debian.org/debian bullseye/main armhf Packages
        HeavyD@heavydpi:~ $ sudo apt remove npm
        Reading package lists... Done
        Building dependency tree... Done
        Package 'npm' is not installed, so not removed
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        HeavyD@heavydpi:~ $ sudo apt install --reinstall nodejs
        0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
        Need to get 0 B/24.8 MB of archives.
        After this operation, 0 B of additional disk space will be used.
        (Reading database ... 48496 files and directories currently installed.)
        Preparing to unpack .../nodejs_14.19.1-deb-1nodesource1_arm64.deb ...
        Unpacking nodejs (14.19.1-deb-1nodesource1) over (14.19.1-deb-1nodesource1) ...
        Setting up nodejs (14.19.1-deb-1nodesource1) ...
        Processing triggers for man-db (2.9.4-2) ...
        HeavyD@heavydpi:~ $ iobroker fix
        library: loaded
        Library version=2022-02-10
        ioBroker is not installed in /opt/iobroker! Cannot fix anything...
        HeavyD@heavydpi:~ $ cd /opt/iobroker
        HeavyD@heavydpi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.16
        > unix-dgram@2.0.4 install /opt/iobroker/node_modules/unix-dgram
        > node-gyp rebuild
        make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
        In file included from ../../nan/nan.h:58,
                         from ../src/unix_dgram.cc:5:
        /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
          793 |       (node::addon_register_func) (regfunc),                          \
        /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
          827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
          404 | NODE_MODULE(unix_dgram, Initialize)
          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
          COPY Release/unix_dgram.node
        make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
        > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
        > node rebuild.js
        ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
        > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
        > node-gyp rebuild
        make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
          CXX(target) Release/obj.target/diskusage/src/main.o
                         from ../src/main.cpp:3:
        ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
           42 | NODE_MODULE(diskusage, Init)
          CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
          SOLINK_MODULE(target) Release/obj.target/diskusage.node
          COPY Release/diskusage.node
        make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
        > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        Successfully migrated 4344 objects to Redis Sets
        object _design/system updated
          "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nEzQOwj4NxN8zwMKGJvzzqzDUYOh5g2eFq3C0gG8okyUH2odgNkvT\r\n-----END RSA PRIVATE KEY-----\r\n",
          "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nMmyghqIkV4NjDcIDUIWSfgSpKF4hKS4/whMSRzq3VHVeBw==\r\n-----END CERTIFICATE-----\r\n"
        Update certificate defaultPrivate
        The object "system.certificates" was updated successfully.
        Update certificate defaultPublic
        > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
        > node scripts/postinstall
        > esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
        > node install.js
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
        + iobroker.js-controller@4.0.21
        added 225 packages from 182 contributors in 170.509s
        49 packages are looking for funding
          run `npm fund` for details
        HeavyD@heavydpi:/opt/iobroker $ iobroker update -i
        internal/modules/cjs/loader.js:905
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
            at Function.Module._load (internal/modules/cjs/loader.js:746:27)
            at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
            at internal/main/run_main_module.js:17:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
          @heavyd
          Ich muss jetzt nochmal
          which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          frisch sehen.
          • HeavyD
            HeavyD@heavydpi:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.19.1
            v14.19.1
            6.14.16
            HeavyD
            /opt/iobroker
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
            All packages are up to date.
            nodejs:
              Installed: 14.19.1-deb-1nodesource1
              Candidate: 14.19.1-deb-1nodesource1
              Version table:
             *** 14.19.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
                    100 /var/lib/dpkg/status
                 12.22.5~dfsg-2~11u1 500
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
              Jan1 @HeavyD last edited by Jan1
              Hab ihn mir gestern auf einem PI aufgesetzt und ein paar Adapter installiert zum Testen.
              Hm und warum eierst jetzt so lange mit nem Rettungsversuch rum und machst das Bisschen nicht einfach noch mal neu und sauber?
              Node und NPM sieht zumindest mal wieder vernünftig aus.
              • HeavyD
                HeavyD @Jan1 last edited by
                @jan1 ich hab ja nur gefragt ob da noch was zu retten ist? Wenn es halt zu aufwendig ist mach ich es neu.
                  Thomas Braun Most Active last edited by Thomas Braun
                  @heavyd
                  cd /opt/iobroker
                  iobroker start
                  iobroker status
                  • HeavyD
                    HeavyD@heavydpi:/opt/iobroker $ iobroker start
                    HeavyD@heavydpi:/opt/iobroker $ iobroker status
                    Objects type: jsonl
                    States  type: jsonl
                      Gut.
                        @heavyd
                        Wenn man eh am Anfang steht, ist das eben am einfachsten und schneller gehts auch. Retten würde auch klappen und lernen wirst auch was dabei. Bleibt Dir überlassen. Die Frage ist immer nur, was hast noch so verbastelt und wird sich das später noch bemerkbar machen.
                          rotamint @Thomas Braun last edited by
                          @thomas-braun @HeavyD Als stiller lerndender Mitleser - dankeschön, wieder was gelernt!
                            subman82 last edited by
                            ich habe wohl ähnliche Probleme wie mein Vorgänger aber leider wurden meine mit dem letzten Schritt nicht gelöst. Ich komme nicht auf die Adminseite meines iobroker.
                            Ich versuche mal den Codetag hier anzuwenden,ich hoffe es funktioniert,ist mein erster Versuch....
                            aktuell:
                            Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
                            The programs included with the Debian GNU/Linux system are free software;
                            pi@raspberrypi:~ $ npm -v
                            6.14.17
                            pi@raspberrypi:~ $ node -v
                            v14.20.0
                            Ergebnis des letzten Schrittes deiner Anleitung:
                            pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
                            npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                            npm WARN checkPermissions Missing write access to /home/pi
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                            npm WARN pi No description
                            npm WARN pi No repository field.
                            npm WARN pi No license field.
                            npm ERR! code EACCES
                            npm ERR! syscall access
                            npm ERR! path /home/pi
                            npm ERR! errno -13
                            npm ERR! Error: EACCES: permission denied, access '/home/pi'
                            npm ERR!  [Error: EACCES: permission denied, access '/home/pi'] {
                            npm ERR!   errno: -13,
                            npm ERR!   code: 'EACCES',
                            npm ERR!   syscall: 'access',
                            npm ERR!   path: '/home/pi'
                            npm ERR! }
                            npm ERR!
                            npm ERR! The operation was rejected by your operating system.
                            npm ERR! It is likely you do not have the permissions to access this file as the current user
                            npm ERR!
                            npm ERR! If you believe this might be a permissions issue, please double-check the
                            npm ERR! permissions of the file and its containing directories, or try running
                            npm ERR! the command again as root/Administrator.
                            npm ERR!     /home/iobroker/.npm/_logs/2022-09-10T22_20_09_875Z-debug.log
                            pi@raspberrypi:~ $ iobroker start
                            pi@raspberrypi:~ $ iobroker status
                              throw err;
                              requireStack: []
                            Es lief soweit alles stabil bis ich ein node update durchgeführt habe von v14 auf v16. npm war meine ich 8.1.5 als noch alles lief.
                            Ich wollte eigentlich nur den Shellyadapter updaten aber dafür musste ich Updates vom System durchführen.
                            Das hat auch ungefähr 10min funktioniert , alle Instanzen waren auch auch grün und dann wollte ich den Shellyadapter
                            updaten und seit dem komme ich nicht mehr auf die Benutzeroberfläche.
                            Wie oben dargestellt , habe ich aktuell node auf 14.20.0 und npm 6.14.17 zurückgestellt aber das half noch nicht.
                            Ich sitz hier schon 5 Stunden dran und komm nicht weiter.Ich hoffe ihr könnt mir helfen,.
                            Besten Dank vorab,Gruss Peter
                            mikeal created this issue in request/request
                            open Request’s Past, Present and Future #3142
                              Thomas Braun Most Active @subman82 last edited by Thomas Braun
                              @subman82 sagte in ioBroker kaputt "gerettet":
                              Du stehst im falschen Verzeichnis.
                              cd /opt/iobroker
                              Und wie bist du da nun grundsätzlich unterwegs?
                              sudo ln -s /usr/bin/node /usr/bin/nodejs
                              uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              anschauen.
                                subman82 @Thomas Braun last edited by
                                Moin und danke für die schnelle Rückmeldung.
                                Ich glaub das mit dem falschem Verzeichnis liegt daran , wenn man keine Ahnung hat und aus allen Posts etwas versucht um es zu retten....Schande über mein Haupt. Ich könnte mir auch vorstellen, dass die Versionen von nodejs,node und npm nicht kompatibel sind. Ich habe immer regelmässig upgedatet aber diesmal ist was schief gelaufen:/
                                pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                armv7l
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v14.20.0
                                v14.20.0
                                6.14.17
                                pi
                                /home/pi
                                Danke für deine Mühe!!
                                  Vermutlich ewig keine Updates mehr eingespielt.
                                    Ich schaue wirklich regelmässig nach Updates,ich würde sagen mindestens einmal im Monat.
                                    Ich habe in den Adaptern und unter der Benutzeroberfläche unter Info immer kontrolliert dass alles aktuell ist, vielleicht habe ich aus Unwissenheit etwas vergessen?Bisher hab ich immer node.js und js-controller über Putty upgedatet meine ich . Node ist ebefalls ein separates Programm habe ich jetzt festgestellt. Ich schau später nochmal nach einer Anleitung, wie ich es zukünftig richtig mache.
                                    pi@raspberrypi:~ $ sudo apt update && apt policy nodejs
                                    OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                    OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                                    Aktualisierung für 9 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                    nodejs:
                                      Installiert:           14.20.0-deb-1nodesource1
                                      Installationskandidat: 14.20.0-deb-1nodesource1
                                      Versionstabelle:
                                     *** 14.20.0-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                         10.24.0~dfsg-1~deb10u1 500
                                    Thomas Braun S 2 Replies Last reply Reply Quote 0
                                      Aktualisier das System.
                                      Und wo klemmt es denn nun konkret?
                                        subman82 @subman82 last edited by
                                        @subman82 Die jetzt installierten Versionen habe ich nur installiert, weil ich gehofft hatte dass mit den alten Versionen es wieder laufen würde und ich könnte dann neu updaten.
                                          @subman82
                                          Und konkret bedeutet das? Läuft der iobroker? Wenn nicht, mit welchen Meldungen?
                                            ich suche gleich nochmal alle 3 aktuellen Versionen raus und installiere sie neu.
                                            Aktuell komme ich nicht auf die Benützeroberfläche über die IP. Laut Fritzbox ist es aber die richtige IP.
                                            Bringt es jetzt noch etwas aus dem Backup über Putty wiederherzustellen? Oder habe ich schon zu viel verändert?
                                            Thomas Braun J 2 Replies Last reply Reply Quote 0
                                            4762
