    4. Test Adapter radar2 v1.2.x GitHub
      SlipKoRn_DH88 last edited by
      ich nutze seit 2 Wochen den Radar2 Adapter für die Anwesenheitserkennung via Bluetooth und Gigaset G-Tags für zwei Personen.
      Ich habe leider das Problem, dass die G-Tags immer wieder nicht als anwesend erkannt werden. Mal der eine, mal der andere. Mal für wenige Minuten, mal für mehrere Stunden. Beide G-Tags liegen nebeneinander an der gleichen Stelle. Ein Reichweitenproblem vermute ich nicht. Die Entfernung um Raspberry Pi 4 beträgt 3m.
      Hier einmal das Protokoll:
      2022-04-17 00:00:20.137 - info: radar2.0 (16075) debug: radar2 found uIP's: []
      2022-04-17 00:00:20.226 - info: radar2.0 (16075) debug: ChangeState ack:true of _uBTs = ["00:51:7e:1f:e9:d3","00:7c:2d:af:a8:ee","04:fc:63:5e:c2:13","24:fc:e5:6b:36:1b","47:34:4c:6b:f0:df","a4:30:7a:01:1c:ab","cd:70:b4:98:05:17","d2:31:1a:a6:c2:99","dd:6f:90:45:73:f6","e1:a1:99:03:55:9a","ed:ed:70:6f:56:1f","f3:33:37:ec:a2:db","f3:33:97:99:72:0e"]
      2022-04-17 00:00:22.726 - info: radar2.0 (16075) debug: started #1664 hciconfig hci0 down
      2022-04-17 00:00:22.862 - info: radar2.0 (16075) debug: started #1665 hciconfig hci0 up
      2022-04-17 00:00:23.121 - info: radar2.0 (16075) debug: started #1666 hcitool -i hci0 lescan --duplicates
      2022-04-17 00:00:23.145 - info: radar2.0 (16075) debug: started #1667 l2ping -i hci0 -c 1 58:9e:c6:20:3f:00
      2022-04-17 00:00:27.184 - info: radar2.0 (16075) debug: started #1668 l2ping -i hci0 -c 1 58:9e:c6:20:48:50
      2022-04-17 00:00:48.152 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"00:7c:2d:af:a8:ee","btName":"(unknown)","btVendor":"Samsung Electronics Co, Ltd"}
      2022-04-17 00:00:48.153 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"e1:a1:99:03:55:9a","btName":"(unknown)","btVendor":"N/A"}
      2022-04-17 00:00:48.154 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"f3:33:37:ec:a2:db","btName":"(unknown)","btVendor":"N/A"}
      2022-04-17 00:00:48.162 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"f3:33:97:99:72:0e","btName":"(unknown)","btVendor":"N/A"}
      2022-04-17 00:00:48.168 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"ed:ed:70:6f:56:1f","btName":"(unknown)","btVendor":"N/A"}
      2022-04-17 00:00:48.176 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"47:34:4c:6b:f0:df","btName":"(unknown)","btVendor":"N/A"}
      2022-04-17 00:00:48.181 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"a4:30:7a:01:1c:ab","btName":"(unknown)","btVendor":"Samsung Electronics Co, Ltd"}
      2022-04-17 00:00:48.184 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"cd:70:b4:98:05:17","btName":"(unknown)","btVendor":"N/A"}
      2022-04-17 00:00:48.186 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"00:51:7e:1f:e9:d3","btName":"(unknown)","btVendor":"N/A"}
      2022-04-17 00:00:48.189 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"04:fc:63:5e:c2:13","btName":"(unknown)","btVendor":"N/A"}
      2022-04-17 00:00:48.192 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"24:fc:e5:6b:36:1b","btName":"(unknown)","btVendor":"Samsung Electronics Co, Ltd"}
      2022-04-17 00:00:48.194 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"d2:31:1a:a6:c2:99","btName":"(unknown)","btVendor":"N/A"}
      2022-04-17 00:00:48.204 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"dd:6f:90:45:73:f6","btName":"(unknown)","btVendor":"N/A"}
      2022-04-17 00:00:48.207 - info: radar2.0 (16075) debug: -BtFound unknown with {"by":"lescan","address":"43:34:3c:4f:3c:dd","btName":"(unknown)","btVendor":"N/A"}
      2022-04-17 00:00:50.132 - info: radar2.0 (16075) debug: ChangeState ack:true of GTagAnnika._nHere = 18
      2022-04-17 00:00:50.135 - info: radar2.0 (16075) debug: radar2 found here (GTagAnnika)
      2022-04-17 00:00:50.136 - info: radar2.0 (16075) debug: and who here (GTagAnnika)
      2022-04-17 00:00:50.136 - info: radar2.0 (16075) debug: and not here (GTagNico)
      2022-04-17 00:00:50.137 - info: radar2.0 (16075) debug: radar2 found uBT's: [ '00:51:7e:1f:e9:d3', '00:7c:2d:af:a8:ee', '04:fc:63:5e:c2:13', '24:fc:e5:6b:36:1b', '43:34:3c:4f:3c:dd', '47:34:4c:6b:f0:df', 'a4:30:7a:01:1c:ab', 'cd:70:b4:98:05:17', 'd2:31:1a:a6:c2:99', 'dd:6f:90:45:73:f6', 'e1:a1:99:03:55:9a', 'ed:ed:70:6f:56:1f', 'f3:33:37:ec:a2:db', 'f3:33:97:99:72:0e'
      Und hier die Einstelllungen des Radar2 Adapters.
      Ich habe bereits mit verschiedenen Abfrageintervallen herumexperimentiert und zwischen hcitool lescan und Nobel gewechselt.
      Node-JS: 14.19.0
      Admin: 5.3.8
      Host: 4.0.21
      NPM: 6.14.16
      Hat jemand eine Idee? Danke!
        Matthes @SlipKoRn_DH88 last edited by
        @slipkorn_dh88
        Die G-Tags dürfen nicht gepairt sein - z. B. Smartphone usw. Wenn doch, diese Verbindung lösen.
        Mit dem internen Bluetooth hatte ich auch Probleme - allerdings Beelink B3. Mit einen externen BT-Adapter Version 4 läuft es bisher stabil seit ca. 3 Wochen.
        Grüße aus dem Sauerland.
          SlipKoRn_DH88 @Matthes last edited by
          @matthes
          @matthes sagte in Test Adapter radar2 v1.2.x GitHub:
          @slipkorn_dh88
          Danke dir schon einmal für die Info. Die G-Tags sind beide nicht mit anderen Geräten gepairt. Das können wir schon einmal ausschließen.
          Ich hatte noch die Batterien in verdacht. Trotz das die G-Tags neu sind, haben die Batterien möglicherweise nicht mehr genug Saft. Werde hier mal die Tage neue testen.
          Ich habe hier noch einen Bluetooth 4.0 USB Stick. Das könnte ich testen. Hier einfach den Stick einstecken und das wars?
          • Diginix
            Diginix @SlipKoRn_DH88 last edited by
            @slipkorn_dh88 Mind der Treiber für den Stick muss geladen werden und dann sollte der Dongle in der Kommandozeile mit hcitool dev als zB hci1 erscheinen. Diese ID musst du dann in der radar2 Instanz eintragen, damit der Adapter auch darüber scannt.
              SlipKoRn_DH88 @Diginix last edited by
              @diginix sagte in Test Adapter radar2 v1.2.x GitHub:
              Mit "lsusb" wird mit der Stick mit folgendem Namen angezeigt: Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
              Mit "hcitool dev" sehe ich einmal ein hci0 und hci1. Ich gehe davon aus, dass hci0 Bluetooth vom PI ist und hci1 Bluetooth vom Stick?
              Ich verstehe aber nicht, wo die ID in der radar2 Instanz eingetragen werden muss.
              Einen Treiber für den Stick habe ich leider nicht gefunden.
              Thomas Braun Diginix 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @SlipKoRn_DH88 last edited by
                @slipkorn_dh88 sagte in Test Adapter radar2 v1.2.x GitHub:
                Wird in der Regel auch nicht benötigt, die meisten Treiber sind als kernel modul schon bei 'Linux' dabei.
                • Diginix
                  Da musst du die 1 eintragen.
                    @diginix
                    Achso, das meintest du mit der ID. Das habe ich bereits eingetragen. Leider bricht die Verbindung auch mit dem USB Dongle regelmäßig ab.
                    Diginix haselchen 2 Replies Last reply Reply Quote 0
                    • Diginix
                      @slipkorn_dh88 Dann liegt es eher nicht an der Hardware serverseitig sondern die Tags sind wohl wirklich nicht zu "sehen".
                      • haselchen
                        haselchen Most Active @SlipKoRn_DH88 last edited by haselchen
                        @slipkorn_dh88
                        Ich habe die Gigaset Dinger auch.
                        Vielleicht übernimmst du meine Einstellungen und guckst wie es läuft.
                        Ich habe oben links 29sek genommen, weil er laut Log 26sek braucht um den Tag zu scannen.
                        Und BT Adressen , die bekannt sind......leer lassen.
                        Und diesen Tipp hatte ich auch in der Konsole ausgeführt:
                        sudo setcap 'cap_net_admin,cap_net_bind_service,cap_net_raw+eip' $(eval readlink -f `which node`)
                          SlipKoRn_DH88 @haselchen last edited by
                          @haselchen
                          Danke für deine Unterstützung. Ich hab alles nach deiner Vorgabe umgesetzt. Aber auch damit leider kein Erfolg. Ich werde mir jetzt einfach mal frische Batterien für die Dinger besorgen und dann nochmal testen.
                          Viele Grüße
                          • haselchen
                            @slipkorn_dh88
                            Kein Erfolg, bedeutet?
                              @haselchen Das bedeutet, dass die G-Tags weiterhin unregelmäßig nicht als anwesend erkannt werden.
                              • haselchen
                                @slipkorn_dh88
                                Hast du noch den BLE Adapter nebenher laufen ?
                                Das birgt Probleme. Das hatte ich auch .
                                Habe dann ein ESP32 Board an den USB gehängt , bespielt mit ESP Software. Gibt auch einen entsprechenden Adapter dazu.
                                Und weg war das Problem.
                                  @haselchen
                                  Nachdem ich mit dem BLE Adapter die Bluetooth-Adressen der beiden Tags ermittelt hatte, habe ich den BLE Adapter entfernt. Bis auf den Radar2 Adapter habe ich nichts mit Bluetooth als Instanz installiert.
                                  Besteht die Möglichkeit, dass das Raspberry eigene Bluetooth dem Bluetooth Dongle in die Quere kommt? Das ist mit eben noch so eingefallen. Ich weiß nur nicht, wie ich Bluetooth vom Raspberry deaktiviere
                                    @slipkorn_dh88
                                    rfkill
                                    Und dann das Interface deaktivieren.
                                      SlipKoRn_DH88 @Thomas Braun last edited by
                                      @thomas-braun sagte in Test Adapter radar2 v1.2.x GitHub:
                                      @slipkorn_dh88
                                      rfkill
                                      Was genau bedeutet das deaktivieren des Interfaces? Sorry, soweit bin ich noch nicht in der Materie.
                                        Thomas Braun Most Active @SlipKoRn_DH88 last edited by Thomas Braun
                                        @slipkorn_dh88
                                        echad@chet:~ $ rfkill
                                        ID TYPE      DEVICE      SOFT      HARD
                                         0 wlan      phy0   unblocked unblocked
                                         1 bluetooth hci0   unblocked unblocked
                                        Unter ID 1 firmiert also hier bluetooth.
                                        Mit
                                        sudo rfkill block 1
                                        kann man es blockieren:
                                        echad@chet:~ $ sudo rfkill block 1
                                         1 bluetooth hci0     blocked unblocked
                                          Danke dir! Ich werde beobachten wie nun die Stabilität der Anwesenheitserkennung mit dem Bluetooth Dongle ist.
                                            @slipkorn_dh88
                                            Musst mal schauen, wie sich das nach einem reboot verhält. Ggf. muss das dann noch fix verdrahtet werden.
                                            radar2 adapter
                                            49
                                            244
                                            37015
