    4. Neuer Adapter EMS-ESP für Bosch Heizungen
      mwolle @tp1de last edited by
      @tp1de nee heißt bei mir auch iobroker, nur der Username ist ein anderer.
      Ich habe jetzt die recordings entfernt und neu starten lassen (alles), bekomme folgende Meldungen:
      ms-esp.0
      2022-04-18 18:47:43.587	info	km200:true 300 secs
      ems-esp.0
      2022-04-18 18:47:43.585	info	end of initializing km200 states
      ems-esp.0
      2022-04-18 18:47:33.926	warn	http km200 datafield not existing:system.bus
      ems-esp.0
      2022-04-18 18:47:23.911	warn	http km200 datafield not existing:system.brand
      km200.0
      2022-04-18 18:47:10.830	info	Update State 32 err: TypeError: Cannot read property 'allowedValues' of undefinedat C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.km200\km200.js:554:36at runMicrotasks (<anonymous>)at processTicksAndRejections (internal/process/task_queues.js:93:5)
      km200.0
      2022-04-18 18:47:10.829	warn	Skip service data of /heatingCircuits/hc1/activeSwitchProgram
      ems-esp.0
      2022-04-18 18:46:55.337	warn	http km200 datafield not existing:heatSources.supplyTemperatureSetpoint
      ems-esp.0
      2022-04-18 18:46:42.583	info	start initializing km200 states
      ems-esp.0
      2022-04-18 18:46:42.578	info	write km200 file:C:\Program Files\iobroker\SmartHomeneu\iobroker-data\/ems-esp/0/km200.csv
      ems-esp.0
      2022-04-18 18:46:42.577	info	End reading km200 data-structure: 107 fields found
      km200.0
      2022-04-18 18:46:29.135	info	Update State 29 err: TypeError: Cannot read property 'value' of undefinedat C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.km200\km200.js:556:35at runMicrotasks (<anonymous>)at processTicksAndRejections (internal/process/task_queues.js:93:5)
      km200.0
      2022-04-18 18:46:29.133	warn	Skip service data of /heatSources/workingTime/centralHeating
      sql.0
      2022-04-18 18:49:03.137	info	No Data
      ems-esp.0
      2022-04-18 18:48:03.116	info	recordings:true hour
      wireless-mbus.0
      2022-04-18 18:47:46.082	error	Unknown VIFExt 0x13
      sql.0
      2022-04-18 18:47:44.581	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464331}
      sql.0
      2022-04-18 18:47:44.580	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464331}
      sql.0
      2022-04-18 18:47:44.579	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464331}
      sql.0
      2022-04-18 18:47:44.578	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464331}
      sql.0
      2022-04-18 18:47:44.577	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464330}
      sql.0
      2022-04-18 18:47:44.576	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464326}
      sql.0
      2022-04-18 18:47:44.575	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464326}
      sql.0
      2022-04-18 18:47:44.574	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464326}
      sql.0
      2022-04-18 18:47:44.573	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464326}
      sql.0
      2022-04-18 18:47:44.572	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464326}
      sql.0
      2022-04-18 18:47:44.571	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464326}
      sql.0
      2022-04-18 18:47:44.570	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464326}
      sql.0
      2022-04-18 18:47:44.569	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464326}
      sql.0
      2022-04-18 18:47:44.567	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464325}
      sql.0
      2022-04-18 18:47:44.522	info	enabled logging of ems-esp.0.recordings.heatingCircuits.hc2.roomtemperature._Months, Alias=false
      sql.0
      2022-04-18 18:47:44.518	info	enabled logging of ems-esp.0.recordings.heatingCircuits.hc2.roomtemperature._Days, Alias=false
      sql.0
      2022-04-18 18:47:44.507	info	enabled logging of ems-esp.0.recordings.heatingCircuits.hc2.roomtemperature._Hours, Alias=false
      sql.0
      2022-04-18 18:47:44.502	info	enabled logging of ems-esp.0.recordings.heatingCircuits.hc1.roomtemperature._Months, Alias=false
      sql.0
      2022-04-18 18:47:44.499	info	enabled logging of ems-esp.0.recordings.heatingCircuits.hc1.roomtemperature._Days, Alias=false
      sql.0
      2022-04-18 18:47:44.490	info	enabled logging of ems-esp.0.recordings.heatingCircuits.hc1.roomtemperature._Hours, Alias=false
      sql.0
      2022-04-18 18:47:44.481	info	enabled logging of ems-esp.0.recordings.heatSources.actualDHWPower._Months, Alias=false
      sql.0
      2022-04-18 18:47:44.473	info	enabled logging of ems-esp.0.recordings.heatSources.actualDHWPower._Days, Alias=false
      sql.0
      2022-04-18 18:47:44.468	info	enabled logging of ems-esp.0.recordings.heatSources.actualDHWPower._Hours, Alias=false
      sql.0
      2022-04-18 18:47:44.461	info	enabled logging of ems-esp.0.recordings.heatSources.actualCHPower._Months, Alias=false
      sql.0
      2022-04-18 18:47:44.455	info	enabled logging of ems-esp.0.recordings.heatSources.actualCHPower._Days, Alias=false
      sql.0
      2022-04-18 18:47:44.446	info	enabled logging of ems-esp.0.recordings.heatSources.actualCHPower._Hours, Alias=false
      sql.0
      2022-04-18 18:47:44.436	info	enabled logging of ems-esp.0.recordings.heatSources.actualPower._Months, Alias=false
      sql.0
      2022-04-18 18:47:44.427	info	enabled logging of ems-esp.0.recordings.heatSources.actualPower._Days, Alias=false
      sql.0
      2022-04-18 18:47:44.378	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464239}
      sql.0
      2022-04-18 18:47:44.372	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464239}
      sql.0
      2022-04-18 18:47:44.371	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464239}
      sql.0
      2022-04-18 18:47:44.323	info	enabled logging of ems-esp.0.recordings.heatSources.actualPower._Hours, Alias=false
      sql.0
      2022-04-18 18:47:44.318	info	enabled logging of ems-esp.0.recordings.system.sensors.temperatures.outdoor_t1._Months, Alias=false
      sql.0
      2022-04-18 18:47:44.313	info	enabled logging of ems-esp.0.recordings.system.sensors.temperatures.outdoor_t1._Days, Alias=false
      sql.0
      2022-04-18 18:47:44.310	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464232}
      sql.0
      2022-04-18 18:47:44.309	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464228}
      sql.0
      2022-04-18 18:47:44.279	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464226}
      sql.0
      2022-04-18 18:47:44.278	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464226}
      sql.0
      2022-04-18 18:47:44.277	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464225}
      sql.0
      2022-04-18 18:47:44.274	info	enabled logging of ems-esp.0.recordings.system.sensors.temperatures.outdoor_t1._Hours, Alias=false
      sql.0
      2022-04-18 18:47:44.270	info	enabled logging of ems-esp.0.recordings.solarCircuits.sc1.solarYield._Months, Alias=false
      sql.0
      2022-04-18 18:47:44.253	info	enabled logging of ems-esp.0.recordings.solarCircuits.sc1.solarYield._Days, Alias=false
      sql.0
      2022-04-18 18:47:44.249	info	enabled logging of ems-esp.0.recordings.solarCircuits.sc1.solarYield._Hours, Alias=false
      sql.0
      2022-04-18 18:47:44.247	info	enabled logging of ems-esp.0.recordings.solarYield._Months, Alias=false
      sql.0
      2022-04-18 18:47:44.241	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464221}
      sql.0
      2022-04-18 18:47:44.239	info	{"common":{"custom":{"sql.0":{"changesOnly":false,"debounce":0,"retention":0,"changesRelogInterval":0,"maxLength":3,"changesMinDelta":0,"aliasId":"","enabled":true}}},"from":"system.adapter.sql.0","user":"system.user.admin","ts":1650300464219}
      sql.0
      2022-04-18 18:47:44.236	info	enabled logging of ems-esp.0.recordings.solarYield._Days, Alias=false
      sql.0
      2022-04-18 18:47:44.230	info	enabled logging of ems-esp.0.recordings.solarYield._Hours, Alias=false
      sql.0
      2022-04-18 18:47:44.151	info	disabled logging of ems-esp.0.recordings.heatingCircuits.hc2.roomtemperature._Months
      sql.0
      2022-04-18 18:47:44.140	info	disabled logging of ems-esp.0.recordings.heatingCircuits.hc2.roomtemperature._Days
      sql.0
      2022-04-18 18:47:44.127	info	disabled logging of ems-esp.0.recordings.heatingCircuits.hc2.roomtemperature._Hours
      sql.0
      2022-04-18 18:47:44.078	info	disabled logging of ems-esp.0.recordings.heatingCircuits.hc1.roomtemperature._Months
      sql.0
      2022-04-18 18:47:44.066	info	disabled logging of ems-esp.0.recordings.heatingCircuits.hc1.roomtemperature._Days
      sql.0
      2022-04-18 18:47:44.053	info	disabled logging of ems-esp.0.recordings.heatingCircuits.hc1.roomtemperature._Hours
      sql.0
      2022-04-18 18:47:44.004	info	disabled logging of ems-esp.0.recordings.heatSources.actualDHWPower._Months
      sql.0
      2022-04-18 18:47:43.990	info	disabled logging of ems-esp.0.recordings.heatSources.actualDHWPower._Days
      sql.0
      2022-04-18 18:47:43.978	info	disabled logging of ems-esp.0.recordings.heatSources.actualDHWPower._Hours
      sql.0
      2022-04-18 18:47:43.927	info	disabled logging of ems-esp.0.recordings.heatSources.actualCHPower._Months
      sql.0
      2022-04-18 18:47:43.912	info	disabled logging of ems-esp.0.recordings.heatSources.actualCHPower._Days
      sql.0
      2022-04-18 18:47:43.902	info	disabled logging of ems-esp.0.recordings.heatSources.actualCHPower._Hours
      sql.0
      2022-04-18 18:47:43.821	info	disabled logging of ems-esp.0.recordings.heatSources.actualPower._Months
      sql.0
      2022-04-18 18:47:43.808	info	disabled logging of ems-esp.0.recordings.heatSources.actualPower._Days
      sql.0
      2022-04-18 18:47:43.798	info	disabled logging of ems-esp.0.recordings.heatSources.actualPower._Hours
      sql.0
      2022-04-18 18:47:43.756	info	disabled logging of ems-esp.0.recordings.system.sensors.temperatures.outdoor_t1._Months
      sql.0
      2022-04-18 18:47:43.745	info	disabled logging of ems-esp.0.recordings.system.sensors.temperatures.outdoor_t1._Days
      sql.0
      2022-04-18 18:47:43.734	info	disabled logging of ems-esp.0.recordings.system.sensors.temperatures.outdoor_t1._Hours
      sql.0
      2022-04-18 18:47:43.691	info	disabled logging of ems-esp.0.recordings.solarCircuits.sc1.solarYield._Months
      sql.0
      2022-04-18 18:47:43.680	info	disabled logging of ems-esp.0.recordings.solarCircuits.sc1.solarYield._Days
      sql.0
      2022-04-18 18:47:43.669	info	disabled logging of ems-esp.0.recordings.solarCircuits.sc1.solarYield._Hours
      sql.0
      2022-04-18 18:47:43.628	info	disabled logging of ems-esp.0.recordings.solarYield._Months
      sql.0
      2022-04-18 18:47:43.618	info	disabled logging of ems-esp.0.recordings.solarYield._Days
      sql.0
      2022-04-18 18:47:43.608	info	disabled logging of ems-esp.0.recordings.solarYield._Hours
        @tp1de ich habe mal den Wert 1 eingetragen, keine Änderung?!
          tp1de @mwolle last edited by tp1de
          @mwolle irgendwas ist bei Dir merkwürdig. Die Fehlermeldungen aus dem 1. Block passen nicht zum aktuellen Coding der Beta-Version 1.9. Der 2. Block gibt nur als Info aus, dass die States für mySQL enabled werden. (nur einmal).
          Wäre es möglich die Instanzen und den Adapter komplett zu löschen und den Adapter aus Github ganz neu zu installieren?
          Speichere Dir vorher die Adapter-Config, dann must du die nur einmal neu laden ...
          Und mir fällt gerade auf, dass Du scheinbar unter Windows arbeitest. Kann das sein?
          Bei Windows muss Du den Adapter erst stoppen und sicherstellen, dass keiner der Files im entsprechenden node-modules Directory gesperrt ist bevor Du eine neue Version aus dem repro oder Github installierst.
          Woher kommen eigentlich die disabled Meldungen von sql.0 ???
          Läuft die mySQL Server-Instanz auch unter Windows?
          ....und schalte mal den parallel laufenden km200 Adapter aus
          T M 2 Replies Last reply Reply Quote 0
            tp1de @tp1de last edited by
            @mwolle
            installierst Du so?
              @tp1de
              nein, ich mache das über benutzerdefiniert und kopiere den Link aus github rein.
                @tp1de ja läuft beides auf einem Win 10 Rechner. Ja lösche das einmal und dann installiere ich das neu.
                  mwolle @mwolle last edited by
                  @mwolle neu installiert:
                  ems-esp.0
                  2022-04-18 21:10:41.294	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                  ems-esp.0
                  2022-04-18 21:10:41.291	info	terminating
                  ems-esp.0
                  2022-04-18 21:10:41.282	error	Cannot read property 'length' of undefined
                  ems-esp.0
                  2022-04-18 21:10:41.282	error	TypeError: Cannot read property 'length' of undefined at C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.ems-esp\main.js:429:34 at Immediate.<anonymous> (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.js-controller\lib\adapter.js:5760:70) at processImmediate (internal/timers.js:461:21)
                  ems-esp.0
                  2022-04-18 21:10:41.280	error	uncaught exception: Cannot read property 'length' of undefined
                  ems-esp.0
                  2022-04-18 21:10:41.277	error	Cannot read property 'length' of undefined
                  ems-esp.0
                  2022-04-18 21:10:41.277	error	TypeError: Cannot read property 'length' of undefined at C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.ems-esp\main.js:451:30 at Immediate.<anonymous> (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.js-controller\lib\adapter.js:5760:70) at processImmediate (internal/timers.js:461:21)
                  ems-esp.0
                  2022-04-18 21:10:41.275	error	uncaught exception: Cannot read property 'length' of undefined
                  ems-esp.0
                  2022-04-18 21:10:41.272	error	Cannot read property 'length' of undefined
                  ems-esp.0
                  2022-04-18 21:10:41.271	error	TypeError: Cannot read property 'length' of undefined at C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.ems-esp\main.js:451:30 at Immediate.<anonymous> (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.js-controller\lib\adapter.js:5760:70) at processImmediate (internal/timers.js:461:21)
                  ems-esp.0
                  2022-04-18 21:10:41.265	error	uncaught exception: Cannot read property 'length' of undefined
                    @mwolle das betrifft das Statistik Modul. Schalt mal alles aus bis auf Recordings...
                      @tp1de
                        @mwolle und immer noch keine Daten?
                          @tp1de leider nein
                            @mwolle auch mit der aktuellsten Github Version nicht?
                              @tp1de es bleibt leider dabei:
                                @mwolle Bist Du sicher, dass in der Datenbank keine Daten sind? Falls ja, fällt mir nichts mehr ein.
                                Lass mal das JS-Script laufen und pass ggfs. den Feldnamen an ...
                                script.txt
                                Es sollte dann eine Liste mit ID und den Datensätzen erstellt werden.
                                  @tp1de ```
                                  javascript.0
                                  2022-04-19 18:10:04.704 info script.js.common.ems: [{'id':24,'ts':1600120800000,'val':3728.9,'ack':1,'_from':2,'q':0},{'id':24,'ts':1602720000000,'val':7315.5,'ack':1,'_from':2,'q':0},{'id':24,'ts':1605398400000,'val':11061.8,'ack':1,'_from':2,'q':0},{'id':24,'ts':1607990400000,'val':17418.7,'ack':1,'_from':2,'q':0},{'id':24,'ts':1610665200000,'val':105245.1,'ack':1,'_from':2,'q':0},{'id':24,'ts':1613343600000,'val':15301,'ack':1,'_from':2,'q':0},{'id':24,'ts':1615762800000,'val':61811.5,'ack':1,'_from':2,'q':0},{'id':24,'ts':1618437600000,'val':8936.7,'ack':1,'_from':2,'q':0},{'id':24,'ts':1621029600000,'val':6096.9,'ack':1,'_from':2,'q':0},{'id':24,'ts':1623708000000,'val':2051.4,'ack':1,'_from':2,'q':0},{'id':24,'ts':1626300000000,'val':1221.3,'ack':1,'_from':2,'q':0},{'id':24,'ts':1628978400000,'val':2052,'ack':1,'_from':2,'q':0},{'id':24,'ts':1631656800000,'val':2595.9,'ack':1,'_from':2,'q':0},{'id':24,'ts':1634256000000,'val':5404.3,'ack':1,'_from':2,'q':0},{'id':24,'ts':1636934400000,'val':9200,'ack':1,'_from':2,'q':0},{'id':24,'ts':1639526400000,'val':17273.4,'ack':1,'_from':2,'q':0},{'id':24,'ts':1642201200000,'val':170790.9,'ack':1,'_from':2,'q':0},{'id':24,'ts':1644879600000,'val':14715.5,'ack':1,'_from':2,'q':0},{'id':24,'ts':1647298800000,'val':30629.4,'ack':1,'_from':2,'q':0},{'id':24,'ts':1649189443253,'val':null,'ack':1,'_from':0,'q':64},{'id':24,'ts':1649190282412,'val':null,'ack':0,'_from':1,'q':64},{'id':24,'ts':1649190305661,'val':null,'ack':1,'_from':1,'q':64},{'id':24,'ts':1649274568572,'val':null,'ack':0,'_from':1,'q':64},{'id':24,'ts':1649274578763,'val':null,'ack':1,'_from':1,'q':64},{'id':24,'ts':1649973600000,'val':5116,'ack':1,'_from':2,'q':0},{'id':24,'ts':1650300342482,'val':null,'ack':0,'_from':1,'q':64},{'id':24,'ts':1650300342483,'val':null,'ack':0,'_from':1,'q':64},{'id':24,'ts':1650308258323,'val':null,'ack':0,'_from':1,'q':64},{'id':24,'ts':1650308650119,'val':null,'ack':0,'_from':1,'q':64},{'id':24,'ts':1650380778655,'val':null,'ack':0,'_from':1,'q':64}]
                                    @mwolle sag ich doch - die Datensätze sind da. Warum siehst Du die nicht im Objekt-Browser ????
                                    ... sind aber irgendwie durcheinander ...
                                    Hier ein Script welches alle Datensätze zu den recordings löscht:
                                    Lass 2-3 Mal laufen
                                    script1.txt
                                      @tp1de habe ich gemacht und der hat alles schön gelöscht.
                                        @mwolle dann starte mal den Adapter neu. Beim ersten Durchlauf musst du dann Protokoll-Einträge für die recordings haben und damit auch Datensätze die du im Objekt-Browser sehen kannst. Dauert bei mir immer 1-2 Minuten, bis die angezeigt werden. (Verlaufsdaten oder Diagramm - musst nur den Zeitraum anpassen)
                                          Ich suche Beta-Tester für die neue Wärmebedarfs-Steuerung in der Adapter-Version 1.9.x.
                                          Diese ist von GitHub installierbar.
                                          Ziel dieser Funktionserweiterung ist es in der aktuellen Übergangszeit den Heizbedarf zu ermitteln und dann einzelne Heizkreise ab- und wieder anzuschalten. Ansonsten taktet die Heizung bei mir sehr häufig trotz Modulation.
                                          Vielleicht hat jemand Lust mit zu testen. Hier eine Funktionsbeschreibung:
                                          https://github.com/tp1de/ioBroker.ems-esp/wiki
                                          Adapterfehler oder Anregungen bitte im Github als issue anlegen:
                                          https://github.com/tp1de/ioBroker.ems-esp/issues
                                            @tp1de leider verbleibt der Stand wie vorher, keine Werte zu sehen.
                                            api bosch buderus ems-esp heizungssteuerung junkers km200 netfit
                                            60
                                            741
                                            180500
