    4. Neuer Adapter EMS-ESP für Bosch Heizungen
      mwolle @tp1de last edited by
      @tp1de ja läuft beides auf einem Win 10 Rechner. Ja lösche das einmal und dann installiere ich das neu.
        mwolle @mwolle last edited by
        @mwolle neu installiert:
        ems-esp.0
        2022-04-18 21:10:41.294	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        ems-esp.0
        2022-04-18 21:10:41.291	info	terminating
        ems-esp.0
        2022-04-18 21:10:41.282	error	Cannot read property 'length' of undefined
        ems-esp.0
        2022-04-18 21:10:41.282	error	TypeError: Cannot read property 'length' of undefined at C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.ems-esp\main.js:429:34 at Immediate.<anonymous> (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.js-controller\lib\adapter.js:5760:70) at processImmediate (internal/timers.js:461:21)
        ems-esp.0
        2022-04-18 21:10:41.280	error	uncaught exception: Cannot read property 'length' of undefined
        ems-esp.0
        2022-04-18 21:10:41.277	error	Cannot read property 'length' of undefined
        ems-esp.0
        2022-04-18 21:10:41.277	error	TypeError: Cannot read property 'length' of undefined at C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.ems-esp\main.js:451:30 at Immediate.<anonymous> (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.js-controller\lib\adapter.js:5760:70) at processImmediate (internal/timers.js:461:21)
        ems-esp.0
        2022-04-18 21:10:41.275	error	uncaught exception: Cannot read property 'length' of undefined
        ems-esp.0
        2022-04-18 21:10:41.272	error	Cannot read property 'length' of undefined
        ems-esp.0
        2022-04-18 21:10:41.271	error	TypeError: Cannot read property 'length' of undefined at C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.ems-esp\main.js:451:30 at Immediate.<anonymous> (C:\Program Files\iobroker\SmartHomeneu\node_modules\iobroker.js-controller\lib\adapter.js:5760:70) at processImmediate (internal/timers.js:461:21)
        ems-esp.0
        2022-04-18 21:10:41.265	error	uncaught exception: Cannot read property 'length' of undefined
          tp1de @mwolle last edited by
          @mwolle das betrifft das Statistik Modul. Schalt mal alles aus bis auf Recordings...
            @tp1de
              @mwolle und immer noch keine Daten?
                @tp1de leider nein
                  @mwolle auch mit der aktuellsten Github Version nicht?
                    @tp1de es bleibt leider dabei:
                      tp1de @mwolle last edited by tp1de
                      @mwolle Bist Du sicher, dass in der Datenbank keine Daten sind? Falls ja, fällt mir nichts mehr ein.
                      Lass mal das JS-Script laufen und pass ggfs. den Feldnamen an ...
                      script.txt
                      Es sollte dann eine Liste mit ID und den Datensätzen erstellt werden.
                        @tp1de ```
                        javascript.0
                        2022-04-19 18:10:04.704 info script.js.common.ems: [{'id':24,'ts':1600120800000,'val':3728.9,'ack':1,'_from':2,'q':0},{'id':24,'ts':1602720000000,'val':7315.5,'ack':1,'_from':2,'q':0},{'id':24,'ts':1605398400000,'val':11061.8,'ack':1,'_from':2,'q':0},{'id':24,'ts':1607990400000,'val':17418.7,'ack':1,'_from':2,'q':0},{'id':24,'ts':1610665200000,'val':105245.1,'ack':1,'_from':2,'q':0},{'id':24,'ts':1613343600000,'val':15301,'ack':1,'_from':2,'q':0},{'id':24,'ts':1615762800000,'val':61811.5,'ack':1,'_from':2,'q':0},{'id':24,'ts':1618437600000,'val':8936.7,'ack':1,'_from':2,'q':0},{'id':24,'ts':1621029600000,'val':6096.9,'ack':1,'_from':2,'q':0},{'id':24,'ts':1623708000000,'val':2051.4,'ack':1,'_from':2,'q':0},{'id':24,'ts':1626300000000,'val':1221.3,'ack':1,'_from':2,'q':0},{'id':24,'ts':1628978400000,'val':2052,'ack':1,'_from':2,'q':0},{'id':24,'ts':1631656800000,'val':2595.9,'ack':1,'_from':2,'q':0},{'id':24,'ts':1634256000000,'val':5404.3,'ack':1,'_from':2,'q':0},{'id':24,'ts':1636934400000,'val':9200,'ack':1,'_from':2,'q':0},{'id':24,'ts':1639526400000,'val':17273.4,'ack':1,'_from':2,'q':0},{'id':24,'ts':1642201200000,'val':170790.9,'ack':1,'_from':2,'q':0},{'id':24,'ts':1644879600000,'val':14715.5,'ack':1,'_from':2,'q':0},{'id':24,'ts':1647298800000,'val':30629.4,'ack':1,'_from':2,'q':0},{'id':24,'ts':1649189443253,'val':null,'ack':1,'_from':0,'q':64},{'id':24,'ts':1649190282412,'val':null,'ack':0,'_from':1,'q':64},{'id':24,'ts':1649190305661,'val':null,'ack':1,'_from':1,'q':64},{'id':24,'ts':1649274568572,'val':null,'ack':0,'_from':1,'q':64},{'id':24,'ts':1649274578763,'val':null,'ack':1,'_from':1,'q':64},{'id':24,'ts':1649973600000,'val':5116,'ack':1,'_from':2,'q':0},{'id':24,'ts':1650300342482,'val':null,'ack':0,'_from':1,'q':64},{'id':24,'ts':1650300342483,'val':null,'ack':0,'_from':1,'q':64},{'id':24,'ts':1650308258323,'val':null,'ack':0,'_from':1,'q':64},{'id':24,'ts':1650308650119,'val':null,'ack':0,'_from':1,'q':64},{'id':24,'ts':1650380778655,'val':null,'ack':0,'_from':1,'q':64}]
                          @mwolle sag ich doch - die Datensätze sind da. Warum siehst Du die nicht im Objekt-Browser ????
                          ... sind aber irgendwie durcheinander ...
                          Hier ein Script welches alle Datensätze zu den recordings löscht:
                          Lass 2-3 Mal laufen
                          script1.txt
                            @tp1de habe ich gemacht und der hat alles schön gelöscht.
                              @mwolle dann starte mal den Adapter neu. Beim ersten Durchlauf musst du dann Protokoll-Einträge für die recordings haben und damit auch Datensätze die du im Objekt-Browser sehen kannst. Dauert bei mir immer 1-2 Minuten, bis die angezeigt werden. (Verlaufsdaten oder Diagramm - musst nur den Zeitraum anpassen)
                              T M 2 Replies Last reply Reply Quote 0
                                tp1de @tp1de last edited by
                                Ich suche Beta-Tester für die neue Wärmebedarfs-Steuerung in der Adapter-Version 1.9.x.
                                Diese ist von GitHub installierbar.
                                Ziel dieser Funktionserweiterung ist es in der aktuellen Übergangszeit den Heizbedarf zu ermitteln und dann einzelne Heizkreise ab- und wieder anzuschalten. Ansonsten taktet die Heizung bei mir sehr häufig trotz Modulation.
                                Vielleicht hat jemand Lust mit zu testen. Hier eine Funktionsbeschreibung:
                                https://github.com/tp1de/ioBroker.ems-esp/wiki
                                Adapterfehler oder Anregungen bitte im Github als issue anlegen:
                                https://github.com/tp1de/ioBroker.ems-esp/issues
                                  @tp1de leider verbleibt der Stand wie vorher, keine Werte zu sehen.
                                    @mwolle also nochmal für alle, seit dem 18.04. werden die Werte gespeichert, anschauen kann man diese bei mir nur unter flot. Da werden die Grafiken angezeigt. Bei mit mit einem MB LAN 2 sind aber die Warmwasserwerte nicht plausibel...liegt aber nicht am Adapter das sieht jetzt gut aus:
                                      marsmännchen @mwolle last edited by
                                      @mwolle
                                      Sag mal, bekommst du jetzt Werte bei diversen _Days, _Hours, _Months?
                                      Bei mir kommt nämlich gar nichts mehr. Ich bilde mir zwar ein es hat bei mir mal einen Tag funktioniert, aber da sieht es jetzt aus wie bei deinem Screenshot "(null) kWh"
                                      MfG
                                      Patrick
                                        Titanflex last edited by
                                        da ich gelesen habe das es ein neuen Adapter gibt habe ich diesen auch gleich installiert.
                                        Allergings kommen diese Fehlermeldungen siehe Screenshot.
                                        Kann mir jemand sagen, wo der Fehler liegt ?
                                          tp1de @Titanflex last edited by tp1de
                                          @titanflex welche Version?
                                          Ich vermute mal, dass du die Wirkungsgrad-Ermittlung eingeschaltet hast und bei Deiner Anlage die zu lesenden States nicht vorhanden sind. In der aktuellen Github-Version 1.9. sind die 3 States eingabefähig und diese Fehler werden sauber abgefangen (hoffentlich). Teste mal.
                                            tp1de @marsmännchen last edited by
                                            @marsmännchen Ich habe bereits mehrfach versucht zu erklären, dass die Recordings ja historische Werte sind.
                                            Um diese zu speichern, verwende ich ich für mySQL direkte SQL-Befehle und nicht die ioBroker internen storeState Funktionen. Das Resultat sind die unter Objekte angezeigten null()-Werte. Das ist soweit normal, die Daten sind trotzdem in den Datenbank und können mit Flot oder Grafana angezeigt werden. Falls nicht, mach bitte unter Github ein "issue" auf.
                                            api bosch buderus ems-esp heizungssteuerung junkers km200 netfit
                                            60
                                            741
                                            180454
