    4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
    • Damrak2022
      Damrak2022 @Thomas Braun last edited by
      @thomas-braun So, ich hoffe das ich das nun richtig gemacht habe.
      Last login: Wed Apr 20 09:05:04 on ttys000
      damrak2021@Andreass-iMac ~ % ssh pi@homebridge
      pi@homebridge's password:
      Linux homebridge 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Wed Apr 20 08:05:22 2022 from 2a02:908:171:e900:303c:c240:9f73:977d
      pi@homebridge:~ $ /etc/apt/sources.list.d/ookla_speedtest-cli.list
      -bash: /etc/apt/sources.list.d/ookla_speedtest-cli.list: No such file or directory
      pi@homebridge:~ $ sudo nano /etc/apt/sources.list.d/ookla_speedtest-cli.list
      pi@homebridge:~ $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 8E61C2AB9A6D1557
      Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
      Executing: /tmp/apt-key-gpghome.9TwcOtjpDI/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 8E61C2AB9A6D1557
      gpg: key 31EB3981E723ACAA: "https://packagecloud.io/ookla/speedtest-cli (https://packagecloud.io/docs#gpg_signing) <support@packagecloud.io>" not changed
      gpg: Total number processed: 1
      gpg:              unchanged: 1
      pi@homebridge:~ $ sudo apt update
      Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://packages.grafana.com/enterprise/deb stable InRelease
      Hit:4 https://repos.influxdata.com/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_12.x bullseye InRelease
      Get:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease [24.5 kB]
      Get:7 https://packagecloud.io/ookla/speedtest-cli/debian bullseye/main armhf Packages [988 B]
      Fetched 40.4 kB in 4s (10.6 kB/s)
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      pi@homebridge:~ $ sudo apt install speedtest
      The following NEW packages will be installed:
        speedtest
      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
      Need to get 989 kB of archives.
      After this operation, 2,232 kB of additional disk space will be used.
      Get:1 https://packagecloud.io/ookla/speedtest-cli/debian bullseye/main armhf speedtest armhf 1.1.1.28-1.c732eb82cf [989 kB]
      Fetched 989 kB in 1s (973 kB/s)
      Selecting previously unselected package speedtest.
      (Reading database ... 62192 files and directories currently installed.)
      Preparing to unpack .../speedtest_1.1.1.28-1.c732eb82cf_armhf.deb ...
      Unpacking speedtest (1.1.1.28-1.c732eb82cf) ...
      Setting up speedtest (1.1.1.28-1.c732eb82cf) ...
      Processing triggers for man-db (2.9.4-2) ...
      pi@homebridge:~ $ curl -s https://install.speedtest.net/app/cli/install.deb.sh | sudo bash
      This distribution version is not currently supported via package management, please use the direct download builds per architecture found at https://www.speedtest.net/apps/cli
      pi@homebridge:~ $
        Thomas Braun Most Active @Damrak2022 last edited by
        @damrak2022
        apt policy speedtest
        • Damrak2022
          @thomas-braun sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
          Da kommt folgendes
          pi@homebridge:~ $ apt policy speedtest
          speedtest:
            Installed: 1.1.1.28-1.c732eb82cf
            Candidate: 1.1.1.28-1.c732eb82cf
            Version table:
           *** 1.1.1.28-1.c732eb82cf 500
                  500 https://packagecloud.io/ookla/speedtest-cli/debian bullseye/main armhf Packages
                  100 /var/lib/dpkg/status
               1.1.0.75-1.810304edbd 500
               1.0.0.2-1.5ae238b 500
          Danke für Deine Geduld
            Thomas Braun Most Active @Damrak2022 last edited by Thomas Braun
            @damrak2022
            Auf nodeJS@14 könntest du in jetzt in einem auch springen, wenn du eh die *.list files pflegst.
            In /etc/apt/sources.list.d/nodesource.list die 12 durch eine 14 ersetzen.
            Node12 erreicht in wenigen Tagen das EndOfLife.
            • Negalein
              Negalein Global Moderator last edited by Negalein
              Doch, gibt es wohl.
              Habe die Datei angepasst.
              # this file was generated by packagecloud.io for
              # the repository at https://packagecloud.io/ookla/speedtest-cli
              deb https://packagecloud.io/ookla/speedtest-cli/ubuntu/ jammy main
              deb-src https://packagecloud.io/ookla/speedtest-cli/ubuntu/ jammy bullseye main
              Dann
              sudo apt update
              Und da kommt dann
              nega@ioBroker:~$ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 8E61C2AB9A6D1557
              Executing: /tmp/apt-key-gpghome.ZjkZwFOrNP/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 8E61C2AB9A6D1557
              gpg: key 31EB3981E723ACAA: public key "https://packagecloud.io/ookla/speedtest-cli (https://packagecloud.io/docs#gpg_signing) <support@packagecloud.io>" imported
              gpg:               imported: 1
              nega@ioBroker:~$ sudo apt update
              Hit:1 https://deb.nodesource.com/node_14.x focal InRelease
              Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
              Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
              Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
              Ign:5 https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy InRelease
              Err:6 https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy Release
                404  Not Found [IP: 50.18.207.89 443]
              E: The repository 'https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy Release' does not have a Release file.
              N: Updating from such a repository can't be done securely, and is therefore disabled by default.
              N: See apt-secure(8) manpage for repository creation and user configuration details.
              nega@ioBroker:~$ sudo apt install speedtest
              E: Unable to locate package speedtest
              nega@ioBroker:~$ nano /etc/apt/sources.list.d/ookla_speedtest-cli.list
              Script liefert immer noch
              09:32:13.219	error	javascript.0 (408896) script.js.Netzwerk.Speedtest: SyntaxError: Unexpected end of JSON input
              09:32:13.219	error	javascript.0 (408896) at generiere_array (script.js.Netzwerk.Speedtest:181:14)
              09:32:13.219	error	javascript.0 (408896) at script.js.Netzwerk.Speedtest:229:12
              09:32:13.342	error	host.ioBroker Caught by controller[0]: at generiere_array (script.js.Netzwerk.Speedtest:182:14)
              09:32:13.342	error	host.ioBroker Caught by controller[0]: at script.js.Netzwerk.Speedtest:230:12
              Speedtest funktioniert aber
              nega@ioBroker:~$ speedtest
              Retrieving speedtest.net configuration...
              Testing from Fonira Telekom GmbH (185.129.173.57)...
              Retrieving speedtest.net server list...
              Selecting best server based on ping...
              Hosted by Netprotect (Vienna) [214.89 km]: 13.606 ms
              Testing download speed................................................................................
              Download: 751.51 Mbit/s
              Testing upload speed......................................................................................................
              Upload: 85.11 Mbit/s
              nega@ioBroker:~$
                @damrak2022
                Gut,
                speedtest
                ist also jetzt installiert und sollte Ergebnisse liefern.
                  Thomas Braun Most Active @Negalein last edited by
                  @negalein sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                  Die Zeile ist falsch, das bullseye gehört raus.
                  Offenbar ist das Repo aber noch nicht gefüllt, wie gesagt, Ubuntu 22.04 ist noch nicht offiziell freigegeben.
                  • Damrak2022
                    Das wollte ich gerade machen, aber da bekomme ich das, oder muss ich da wieder irgendwo rein und wenn ja mit welchem Befehl?
                    pi@homebridge:~ $ /etc/apt/sources.list.d/nodesource.list
                    -bash: /etc/apt/sources.list.d/nodesource.list: Permission denied
                      Das ist aber soweit ich das sehe das alte/falsche speedtest.
                      sudo apt update
                      Damrak2022 Negalein 2 Replies Last reply Reply Quote 0
                        @damrak2022 sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                        Das ist halt Quatsch. Du musst schon sagen, mit welchem Befehl du die Datei anpacken willst.
                        sudo nano /etc/apt/sources.list.d/nodesource.list
                        Wäre eine einfache Transferleistung, die /etc/apt/sources.list.d/ookla_speedtest-cli.list
                        hast du doch genauso angepackt.
                        Damrak2022 1 Reply Last reply Reply Quote 1
                        • Damrak2022
                          Jetzt sieht es so aus:
                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                          speedtest:
                            Version table:
                          pi@homebridge:~ $
                          Wieso kann ich mein node js nicht upgraden. Wieso habe ich hier Permission denied
                          • Negalein
                            Negalein Global Moderator @Thomas Braun last edited by
                            sudo apt update
                              404  Not Found [IP: 184.72.30.82 443]
                            nega@ioBroker:~$ apt policy speedtest
                            N: Unable to locate package speedtest
                            nega@ioBroker:~$
                            also kann ich das Script derzeit nicht nutzen?
                              @negalein
                              Das ist auch wieder Kraut und Rüben...
                              Was hast du denn da nun? Focal (20.04) oder Jammy (22.04)
                              Die Releases dürfen nicht vermischt werden, das gibt nur Chaos.
                              Erstmal prüfen, wo du da überhaupt unterwegs bist:
                              lsb_release -a
                              • Negalein
                                Upps sorry, meinte 20.04
                                nega@ioBroker:~$ lsb_release -a
                                No LSB modules are available.
                                Distributor ID: Ubuntu
                                Description:    Ubuntu 20.04.2 LTS
                                Release:        20.04
                                Codename:       focal
                                  @negalein
                                  Dann muss das auch in den *.list-files focal lauten, nicht jammy.
                                  Stell das richtig, dann
                                  sudo apt update
                                  • Negalein
                                    dann
                                    Get:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
                                    Get:5 http://archive.ubuntu.com/ubuntu focal-security InRelease [114 kB]
                                    Get:6 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1744 kB]
                                    Get:7 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [918 kB]
                                    Hit:4 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal InRelease
                                    Fetched 2891 kB in 2s (1669 kB/s)
                                    154 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                    speedtest:
                                      Installed: (none)
                                      Version table:
                                            500 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal/main amd64 Packages
                                      Bist du des Wahnsinns?
                                      Updaten, aber schnell!
                                      sudo apt full-upgrade
                                      sudo reboot
                                      • Damrak2022
                                        Damrak2022 @Damrak2022 last edited by
                                        @damrak2022 Jetzt so
                                        pi@homebridge:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
                                        Get:5 https://deb.nodesource.com/node_14.x bullseye InRelease [4,586 B]
                                        Get:7 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages [780 B]
                                        Fetched 5,366 B in 2s (2,687 B/s)
                                        1 package can be upgraded. Run 'apt list --upgradable' to see it.
                                        speedtest:
                                          Version table:
                                        pi@homebridge:~ $ apt list --upgradable
                                        Listing... Done
                                        nodejs/unknown 14.19.1-deb-1nodesource1 armhf [upgradable from: 12.22.12-deb-1nodesource1]
                                        N: There are 2 additional versions. Please use the '-a' switch to see them.
                                        pi@homebridge:~ $
                                          @damrak2022
                                          Ja, passt.
                                          iobroker stoppen, updates einspielen
                                          , iobroker wieder starten.
                                          • Negalein
                                            Aye, aye, Käpt’n! 😉
                                            Und dann wie weiter?
                                            1.0k
                                            391
                                            72568
