    4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
      Thomas Braun Most Active @Negalein last edited by
      @negalein
      Dann muss das auch in den *.list-files focal lauten, nicht jammy.
      Stell das richtig, dann
      sudo apt update
      apt policy speedtest
      • Negalein
        Negalein Global Moderator @Thomas Braun last edited by
        @thomas-braun sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
        dann
        nega@ioBroker:~$ sudo apt update
        Hit:1 https://deb.nodesource.com/node_14.x focal InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
        Get:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
        Get:5 http://archive.ubuntu.com/ubuntu focal-security InRelease [114 kB]
        Get:6 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1744 kB]
        Get:7 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [918 kB]
        Hit:4 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal InRelease
        Fetched 2891 kB in 2s (1669 kB/s)
        Reading package lists... Done
        Building dependency tree
        154 packages can be upgraded. Run 'apt list --upgradable' to see them.
        nega@ioBroker:~$ apt policy speedtest
        speedtest:
          Installed: (none)
          Candidate: 1.1.1.28-1.c732eb82cf
          Version table:
             1.1.1.28-1.c732eb82cf 500
                500 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal/main amd64 Packages
             1.1.0.75-1.810304edbd 500
             1.0.0.2-1.5ae238b 500
          @negalein sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
          Bist du des Wahnsinns?
          Updaten, aber schnell!
          sudo apt full-upgrade
          sudo reboot
          • Damrak2022
            Damrak2022 @Damrak2022 last edited by
            @damrak2022 Jetzt so
            pi@homebridge:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
            pi@homebridge:~ $ sudo apt update
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:3 https://packages.grafana.com/enterprise/deb stable InRelease
            Hit:4 https://repos.influxdata.com/debian bullseye InRelease
            Get:5 https://deb.nodesource.com/node_14.x bullseye InRelease [4,586 B]
            Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
            Get:7 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages [780 B]
            Fetched 5,366 B in 2s (2,687 B/s)
            Building dependency tree... Done
            1 package can be upgraded. Run 'apt list --upgradable' to see it.
            pi@homebridge:~ $ apt policy speedtest
            speedtest:
              Installed: 1.1.1.28-1.c732eb82cf
              Version table:
             *** 1.1.1.28-1.c732eb82cf 500
                    500 https://packagecloud.io/ookla/speedtest-cli/debian bullseye/main armhf Packages
                    100 /var/lib/dpkg/status
            pi@homebridge:~ $ apt list --upgradable
            Listing... Done
            nodejs/unknown 14.19.1-deb-1nodesource1 armhf [upgradable from: 12.22.12-deb-1nodesource1]
            N: There are 2 additional versions. Please use the '-a' switch to see them.
            pi@homebridge:~ $
              Thomas Braun Most Active @Damrak2022 last edited by Thomas Braun
              @damrak2022
              Ja, passt.
              iobroker stoppen, updates einspielen
              , iobroker wieder starten.
              • Negalein
                Aye, aye, Käpt’n! 😉
                Und dann wie weiter?
                  @negalein
                  speedtest installieren? Das Repo passt ja nun.
                  sudo apt install speedtest
                    Künftig REGELMÄSSIG das System auf Stand halten.
                    • Negalein
                      nega@ioBroker:~$ sudo apt install speedtest
                      [sudo] password for nega:
                      The following package was automatically installed and is no longer required:
                        libllvm11
                      Use 'sudo apt autoremove' to remove it.
                      The following NEW packages will be installed:
                        speedtest
                      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 0 B/1055 kB of archives.
                      After this operation, 2549 kB of additional disk space will be used.
                      (Reading database ... 36354 files and directories currently installed.)
                      Preparing to unpack .../speedtest_1.1.1.28-1.c732eb82cf_amd64.deb ...
                      Unpacking speedtest (1.1.1.28-1.c732eb82cf) ...
                      dpkg: error processing archive /var/cache/apt/archives/speedtest_1.1.1.28-1.c732eb82cf_amd64.deb (--unpack):
                       trying to overwrite '/usr/bin/speedtest', which is also in package speedtest-cli 2.1.2-2ubuntu0.20.04.1
                      dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
                      Errors were encountered while processing:
                      E: Sub-process /usr/bin/dpkg returned an error code (1)
                      nega@ioBroker:~$ speedtest
                      Retrieving speedtest.net configuration...
                      Testing from Fonira Telekom GmbH (185.129.173.57)...
                      Retrieving speedtest.net server list...
                      Selecting best server based on ping...
                      Hosted by Netprotect (Vienna) [214.89 km]: 13.237 ms
                      Testing download speed................................................................................
                      Download: 743.13 Mbit/s
                      Testing upload speed......................................................................................................
                      Upload: 429.67 Mbit/s
                        Thomas Braun Most Active @Negalein last edited by Thomas Braun
                        sudo apt remove speedtest-cli
                        Damrak2022 Negalein 2 Replies Last reply Reply Quote 0
                        • Damrak2022
                          Damrak2022 @Thomas Braun last edited by
                          @thomas-braun Okay, gemacht
                          pi@homebridge:~ $ sudo apt full-upgrade
                          Calculating upgrade... Done
                          The following packages will be upgraded:
                            nodejs
                          1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          Need to get 23.3 MB of archives.
                          After this operation, 31.2 MB of additional disk space will be used.
                          Do you want to continue? [Y/n] y
                          Get:1 https://deb.nodesource.com/node_14.x bullseye/main armhf nodejs armhf 14.19.1-deb-1nodesource1 [23.3 MB]
                          Fetched 23.3 MB in 1s (15.6 MB/s)
                          Reading changelogs... Done
                          (Reading database ... 62196 files and directories currently installed.)
                          Preparing to unpack .../nodejs_14.19.1-deb-1nodesource1_armhf.deb ...
                          Unpacking nodejs (14.19.1-deb-1nodesource1) over (12.22.12-deb-1nodesource1) ...
                          Setting up nodejs (14.19.1-deb-1nodesource1) ...
                          Processing triggers for man-db (2.9.4-2) ...
                          pi@homebridge:~ $ sudo apt install speedtest
                          speedtest is already the newest version (1.1.1.28-1.c732eb82cf).
                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          pi@homebridge:~ $
                          • Negalein
                            Merci, funktioniert! 🙂
                            10:13:18.127	info	javascript.0 (1887) script.js.Netzwerk.Speedtest: Speedtest mit Server 5476 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
                            10:13:37.909	info	javascript.0 (1887) script.js.Netzwerk.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 92.81 MB/s | Upload: 94.15 MB/s | Ping: 10.806ms
                               Speedtest by Ookla
                                 Server: Energie AG Oberoesterreich Telekom GmbH - Gmunden (id = 5476)
                                    ISP: Fonira Telekom GmbH
                                Latency:    10.78 ms   (0.09 ms jitter)
                               Download:   777.98 Mbps (data used: 846.2 MB )
                                 Upload:   782.09 Mbps (data used: 850.7 MB )
                            Packet Loss:     0.0%
                             Result URL: https://www.speedtest.net/result/c/7bcefc71-fa63-4b37-8cc4-6515c2bd1a92
                              @negalein
                              Siehste, sogar ein Server aus Oberösterreich.
                                ps1304 @Thomas Braun last edited by
                                Danke für deinen Beitrag - ich habe nach der Webseite installiert und bekomme beim Befehl "sudo apt update" jetzt folgenden Fehler:
                                E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/ubuntu impish Release« enthält keine Release-Datei.
                                N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                                N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                                Hast du nen Tipp?
                                Gruß Peter
                                  Thomas Braun Most Active @ps1304 last edited by Thomas Braun
                                  @ps1304
                                  Hab kein Ubuntu im Einsatz.
                                  Aber offenbar bauen die keine Pakete für impish.
                                  Könnte sein, dass hier nur für LTS-Versionen gebaut wird. Die Zwischenversionen leben ja nur 9 Monate.
                                  Trag mal ausnahmsweise statt impish die Vorversion focal in die Datei
                                  /etc/apt/sources.list.d/ookla_speedtest-cli.list ein.
                                    @ps1304
                                    Edit. Siehe oben.
                                    Und daran denken, dass am 14.07.2022 Schluss ist mit 'impish'. Ich würde da auf die jetzt aktuelle LTS-Version wechseln.
                                      super vielen Dank - der Tipp war schon mal gut !!! das Update mache ich gerade.
                                      Gruß Peter
                                      • David G.
                                        David G. last edited by
                                        bei mir mag er das irgendwie nicht installieren.
                                        pi@pi:~ $ curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
                                        Detected operating system as raspbian/bullseye.
                                        Checking for curl...
                                        Detected curl...
                                        Checking for gpg...
                                        Detected gpg...
                                        Running apt-get update... done.
                                        Installing apt-transport-https... done.
                                        Installing /etc/apt/sources.list.d/ookla_speedtest-cli.list...done.Importing packagecloud gpg key... done.
                                        The repository is setup! You can now install packages.
                                        pi@pi:~ $ sudo apt update                                          Ign:1 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease
                                        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Err:4 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release
                                          404  Not Found [IP: 54.183.164.179 443]
                                        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file.
                                        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                                        N: See apt-secure(8) manpage for repository creation and user configuration details.
                                        pi@pi:~ $ sudo apt install speedtest
                                        E: Unable to locate package speedtest
                                        pi@pi:~ $ lsb_release -a
                                        No LSB modules are available.
                                        Distributor ID: Raspbian
                                        Description:    Raspbian GNU/Linux 11 (bullseye)
                                        Release:        11
                                        Codename:       bullseye
                                        GNU nano 5.4  /etc/apt/sources.list.d/nodesource.list            deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nod>deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb>
                                          Thomas Braun Most Active @David G. last edited by
                                          @david-g
                                          uname -a
                                          cat /etc/apt/sources.list.d/nodesource.list
                                            Thomas Braun Most Active @David G. last edited by Thomas Braun
                                            @david-g
                                            Trag das mal so ein:
                                            echad@chet:~ $ cat /etc/apt/sources.list.d/ookla_speedtest-cli.list
                                            # this file was generated by packagecloud.io for
                                            # the repository at https://packagecloud.io/ookla/speedtest-cli
                                            deb [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                                            deb-src [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                                            echad@chet:~ $
                                            Also statt raspbian debian eintragen. Da ist das Installationsskript immer noch unsauber und passt nicht für Raspberry OS.
                                            391
                                            72590
