    4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
    • Negalein
      Negalein Global Moderator @Thomas Braun last edited by
      @thomas-braun sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
      dann
      nega@ioBroker:~$ sudo apt update
      Hit:1 https://deb.nodesource.com/node_14.x focal InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
      Get:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
      Get:5 http://archive.ubuntu.com/ubuntu focal-security InRelease [114 kB]
      Get:6 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1744 kB]
      Get:7 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [918 kB]
      Hit:4 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal InRelease
      Fetched 2891 kB in 2s (1669 kB/s)
      Reading package lists... Done
      Building dependency tree
      154 packages can be upgraded. Run 'apt list --upgradable' to see them.
      nega@ioBroker:~$ apt policy speedtest
      speedtest:
        Installed: (none)
        Candidate: 1.1.1.28-1.c732eb82cf
        Version table:
           1.1.1.28-1.c732eb82cf 500
              500 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal/main amd64 Packages
           1.1.0.75-1.810304edbd 500
           1.0.0.2-1.5ae238b 500
        Thomas Braun Most Active @Negalein last edited by
        @negalein sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
        Bist du des Wahnsinns?
        Updaten, aber schnell!
        sudo apt full-upgrade
        sudo reboot
        • Damrak2022
          Damrak2022 @Damrak2022 last edited by
          @damrak2022 Jetzt so
          pi@homebridge:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
          pi@homebridge:~ $ sudo apt update
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 https://packages.grafana.com/enterprise/deb stable InRelease
          Hit:4 https://repos.influxdata.com/debian bullseye InRelease
          Get:5 https://deb.nodesource.com/node_14.x bullseye InRelease [4,586 B]
          Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
          Get:7 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages [780 B]
          Fetched 5,366 B in 2s (2,687 B/s)
          Building dependency tree... Done
          1 package can be upgraded. Run 'apt list --upgradable' to see it.
          pi@homebridge:~ $ apt policy speedtest
          speedtest:
            Installed: 1.1.1.28-1.c732eb82cf
            Version table:
           *** 1.1.1.28-1.c732eb82cf 500
                  500 https://packagecloud.io/ookla/speedtest-cli/debian bullseye/main armhf Packages
                  100 /var/lib/dpkg/status
          pi@homebridge:~ $ apt list --upgradable
          Listing... Done
          nodejs/unknown 14.19.1-deb-1nodesource1 armhf [upgradable from: 12.22.12-deb-1nodesource1]
          N: There are 2 additional versions. Please use the '-a' switch to see them.
          pi@homebridge:~ $
            Thomas Braun Most Active @Damrak2022 last edited by Thomas Braun
            @damrak2022
            Ja, passt.
            iobroker stoppen, updates einspielen
            , iobroker wieder starten.
            • Negalein
              Aye, aye, Käpt’n! 😉
              Und dann wie weiter?
                @negalein
                speedtest installieren? Das Repo passt ja nun.
                sudo apt install speedtest
                  Künftig REGELMÄSSIG das System auf Stand halten.
                  • Negalein
                    nega@ioBroker:~$ sudo apt install speedtest
                    [sudo] password for nega:
                    The following package was automatically installed and is no longer required:
                      libllvm11
                    Use 'sudo apt autoremove' to remove it.
                    The following NEW packages will be installed:
                      speedtest
                    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                    Need to get 0 B/1055 kB of archives.
                    After this operation, 2549 kB of additional disk space will be used.
                    (Reading database ... 36354 files and directories currently installed.)
                    Preparing to unpack .../speedtest_1.1.1.28-1.c732eb82cf_amd64.deb ...
                    Unpacking speedtest (1.1.1.28-1.c732eb82cf) ...
                    dpkg: error processing archive /var/cache/apt/archives/speedtest_1.1.1.28-1.c732eb82cf_amd64.deb (--unpack):
                     trying to overwrite '/usr/bin/speedtest', which is also in package speedtest-cli 2.1.2-2ubuntu0.20.04.1
                    dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
                    Errors were encountered while processing:
                    E: Sub-process /usr/bin/dpkg returned an error code (1)
                    nega@ioBroker:~$ speedtest
                    Retrieving speedtest.net configuration...
                    Testing from Fonira Telekom GmbH (185.129.173.57)...
                    Retrieving speedtest.net server list...
                    Selecting best server based on ping...
                    Hosted by Netprotect (Vienna) [214.89 km]: 13.237 ms
                    Testing download speed................................................................................
                    Download: 743.13 Mbit/s
                    Testing upload speed......................................................................................................
                    Upload: 429.67 Mbit/s
                      Thomas Braun Most Active @Negalein last edited by Thomas Braun
                      sudo apt remove speedtest-cli
                      Damrak2022 Negalein 2 Replies Last reply Reply Quote 0
                      • Damrak2022
                        Damrak2022 @Thomas Braun last edited by
                        @thomas-braun Okay, gemacht
                        pi@homebridge:~ $ sudo apt full-upgrade
                        Calculating upgrade... Done
                        The following packages will be upgraded:
                          nodejs
                        1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        Need to get 23.3 MB of archives.
                        After this operation, 31.2 MB of additional disk space will be used.
                        Do you want to continue? [Y/n] y
                        Get:1 https://deb.nodesource.com/node_14.x bullseye/main armhf nodejs armhf 14.19.1-deb-1nodesource1 [23.3 MB]
                        Fetched 23.3 MB in 1s (15.6 MB/s)
                        Reading changelogs... Done
                        (Reading database ... 62196 files and directories currently installed.)
                        Preparing to unpack .../nodejs_14.19.1-deb-1nodesource1_armhf.deb ...
                        Unpacking nodejs (14.19.1-deb-1nodesource1) over (12.22.12-deb-1nodesource1) ...
                        Setting up nodejs (14.19.1-deb-1nodesource1) ...
                        Processing triggers for man-db (2.9.4-2) ...
                        pi@homebridge:~ $ sudo apt install speedtest
                        speedtest is already the newest version (1.1.1.28-1.c732eb82cf).
                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        pi@homebridge:~ $
                        • Negalein
                          Merci, funktioniert! 🙂
                          10:13:18.127	info	javascript.0 (1887) script.js.Netzwerk.Speedtest: Speedtest mit Server 5476 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
                          10:13:37.909	info	javascript.0 (1887) script.js.Netzwerk.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 92.81 MB/s | Upload: 94.15 MB/s | Ping: 10.806ms
                             Speedtest by Ookla
                               Server: Energie AG Oberoesterreich Telekom GmbH - Gmunden (id = 5476)
                                  ISP: Fonira Telekom GmbH
                              Latency:    10.78 ms   (0.09 ms jitter)
                             Download:   777.98 Mbps (data used: 846.2 MB )
                               Upload:   782.09 Mbps (data used: 850.7 MB )
                          Packet Loss:     0.0%
                           Result URL: https://www.speedtest.net/result/c/7bcefc71-fa63-4b37-8cc4-6515c2bd1a92
                            @negalein
                            Siehste, sogar ein Server aus Oberösterreich.
                              ps1304 @Thomas Braun last edited by
                              Danke für deinen Beitrag - ich habe nach der Webseite installiert und bekomme beim Befehl "sudo apt update" jetzt folgenden Fehler:
                              E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/ubuntu impish Release« enthält keine Release-Datei.
                              N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                              N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                              Hast du nen Tipp?
                              Gruß Peter
                                Thomas Braun Most Active @ps1304 last edited by Thomas Braun
                                @ps1304
                                Hab kein Ubuntu im Einsatz.
                                Aber offenbar bauen die keine Pakete für impish.
                                Könnte sein, dass hier nur für LTS-Versionen gebaut wird. Die Zwischenversionen leben ja nur 9 Monate.
                                Trag mal ausnahmsweise statt impish die Vorversion focal in die Datei
                                /etc/apt/sources.list.d/ookla_speedtest-cli.list ein.
                                  @ps1304
                                  Edit. Siehe oben.
                                  Und daran denken, dass am 14.07.2022 Schluss ist mit 'impish'. Ich würde da auf die jetzt aktuelle LTS-Version wechseln.
                                    super vielen Dank - der Tipp war schon mal gut !!! das Update mache ich gerade.
                                    Gruß Peter
                                    • David G.
                                      David G. last edited by
                                      bei mir mag er das irgendwie nicht installieren.
                                      pi@pi:~ $ curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
                                      Detected operating system as raspbian/bullseye.
                                      Checking for curl...
                                      Detected curl...
                                      Checking for gpg...
                                      Detected gpg...
                                      Running apt-get update... done.
                                      Installing apt-transport-https... done.
                                      Installing /etc/apt/sources.list.d/ookla_speedtest-cli.list...done.Importing packagecloud gpg key... done.
                                      The repository is setup! You can now install packages.
                                      pi@pi:~ $ sudo apt update                                          Ign:1 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease
                                      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Err:4 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release
                                        404  Not Found [IP: 54.183.164.179 443]
                                      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                      E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file.
                                      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                                      N: See apt-secure(8) manpage for repository creation and user configuration details.
                                      pi@pi:~ $ sudo apt install speedtest
                                      E: Unable to locate package speedtest
                                      pi@pi:~ $ lsb_release -a
                                      No LSB modules are available.
                                      Distributor ID: Raspbian
                                      Description:    Raspbian GNU/Linux 11 (bullseye)
                                      Release:        11
                                      Codename:       bullseye
                                      GNU nano 5.4  /etc/apt/sources.list.d/nodesource.list            deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nod>deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb>
                                        Thomas Braun Most Active @David G. last edited by
                                        @david-g
                                        uname -a
                                        cat /etc/apt/sources.list.d/nodesource.list
                                          Thomas Braun Most Active @David G. last edited by Thomas Braun
                                          @david-g
                                          Trag das mal so ein:
                                          echad@chet:~ $ cat /etc/apt/sources.list.d/ookla_speedtest-cli.list
                                          # this file was generated by packagecloud.io for
                                          # the repository at https://packagecloud.io/ookla/speedtest-cli
                                          deb [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                                          deb-src [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                                          echad@chet:~ $
                                          Also statt raspbian debian eintragen. Da ist das Installationsskript immer noch unsauber und passt nicht für Raspberry OS.
                                          • David G.
                                            David G. @Thomas Braun last edited by
                                            So klappt es,
                                            vielen Dank.
                                            Dann begebe ich mich nachher mal an das Skript.
                                            391
                                            72590
