    4. Suche Spotify View
    Suche Spotify View
      stefu87_CH @DJMarc75 last edited by
      @djmarc75 ja die läuft und wenn ich den Regler verändere passiert nix
      • DJMarc75
        DJMarc75 @stefu87_CH last edited by DJMarc75
        @stefu87_ch
        Was für ein Device ist es denn ? Ein Echo ?
        EDIT:
        Und schau mal bitte nach ob auch die richtigen Einträge in den Datenpunten drin stehen
        spotify-premium.0.player.device
          @djmarc75 sagte in Suche Spotify View:
          @stefu87_ch
          Ja sind Alexa Echo Dot Geräte
          EDIT:
          Ja da steht der richtige Echo Dot drin mit allen richtigen Infos wie auf der Visu ausgewählt werden.
          • DJMarc75
            @stefu87_ch
            Importiere Dir mal bitte folgendes Widget in Deine VISU
            [{"tpl":"i-vis-slider-simple","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"iMinVal":"0","iMaxVal":"100","iStepVal":"5","iVisibleStepVal":"5","iSliderRotation":"0","iSliderHeight":"10","iSliderColor":"#ffffff","iSliderCorners":"100","iSliderKnobSize":"20","iSliderKnobColor":"#008A00","iSliderKnobCorners":"100","iSliderTextColor":"#ffffff","iValueTextColor":"#008A00","iTextSize":"20","iStepTextSize":"12","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"spotify-premium.0.player.volume","iSliderLabel":"Lautstärke","iShowValue":true,"iChangeOnRelease":true,"iShowMinMax":true,"iShowSteps":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"446px","top":"351px","width":"500px","height":"63px"},"widgetSet":"vis-inventwo"}]
              @djmarc75 Auch da passiert nichts.
              Nur wenn ich
              spotify-premium.0.player.device.volume
              nehme dann funktioniert es, schreibt mir aber dafür in den Log
              • DJMarc75
                @stefu87_ch
                hmpf....
                Werden denn beim jeweiligen Echo im Ordner
                alexa2.0.Echo-Devices.DEINECHO.Player
                die sonstigen Werte von Spotify angezeigt? also Titel, Artist, usw.
                  @stefu87_ch
                  hmpf....
                  Ja da werden alle Infos angezeigt wie: Artist, Title, Länge, ProviderName, Volume, Cover
                  • DJMarc75
                    @stefu87_ch
                    OK,
                    dann kommunizieren die beiden Adapter ja miteinander.
                    Volume ist auch das selbe bei beiden ?
                      @djmarc75
                      Ich habe folgende Daten:
                      spotify-premium.0.player.volume   =45
                      spotify-premium.0.player.device.volume   = 21
                      alexa2.0.Echo-Devices.G090XG1214350KXT.Player.volume    =22
                      • DJMarc75
                        @stefu87_ch
                        ok, die beiden letzten Werte können leichte Differenzen aufweichen weil manche Echos in 3er Schritten arbeiten, also 0 ist 1, 3 ist 4 und 21 dann halt 22. Das ist nunmal so, aber der erste Wert müsste mit dem dritten gleich sein.
                        Adapter neu gestartet? Oder vll liegt das auch irgendwie am Spotify Family dass der Adapter da irgendwie andere Werte ausliest. Alles erstmal reine Vermutung. Ich würde den Spotifyadapter nochmal neu installieren und die Steuerung erstmal NICHT über VIS machen sondern rein über die Datenpunkte in den Objekten.
                        EDIT: findet die Soundausgabe über eine Lautsprechergruppe statt? - wahrscheinlich aber nicht
                          @djmarc75
                          Ok werde es später mal austesten.
                          Ne laufen nicht über eine gruppe sondern jeder Einzeln.
                            @djmarc75
                            Also habe folgendes versucht:
                            Wert ändern über Datenpunkt bringt nur eine Veränderung bei
                            alexa2.0.Echo-Devices.G090XG1214xxxxXT.Player.volume
                            Beim Datenpunkt
                            ändert sich nichts an der Lautstärke
                            DJMarc75 2 Replies Last reply Reply Quote 0
                            • DJMarc75
                              @stefu87_ch
                              Wie sieht denn Deine Konfig in der Spotifyinstanz aus ?
                                @stefu87_ch
                                • DJMarc75
                                  @stefu87_ch said in Suche Spotify View:
                                  Den Wert hier ändern bringt? Also jetzt nicht grad von 21 auf 22 ändern sondern gleich mal extrem ändern.
                                    Auch wenn ich von 21 auf 53 gehe passiert nichts bei der Alexa
                                    • DJMarc75
                                      @stefu87_ch
                                      ok. und wenn Du in der Spotify APP mal mit dem Volume rumspielst? Welche Werte ändern sich ?
                                        @djmarc75
                                        Wenn ich die Lautstärke über die Spotify App ändere, dann verändert sich folgende Datenpunkte:
                                        alexa2.0.Echo-Devices.G090XG12xxxx0KXT.Player.volume
                                        • DJMarc75
                                          @stefu87_ch
                                          Dann funktioniert eigentlich alles wie es soll.
                                          Der Datenpunkt
                                          ändert sich ja nicht wenn man am Device die Lautstärke ändert.
                                          Abgefragt wird da nur dieser
                                          Aber jetzt nochmal während Musik läuft diesen Datenpunkt ändern, z.B. um 20 verändern, und dann kurz danach nochmal um 20 ändern
                                            Habe jetzt mal mit 20 hoch, mit 30 runter, dann mit 40 hoch und mit 20 runter aber die Lautstärke bleibt immer gleich laut.
                                            107
                                            23406
