    4. Suche Spotify View
    Suche Spotify View
    • DJMarc75
      DJMarc75 @stefu87_CH last edited by DJMarc75
      @stefu87_ch
      Was für ein Device ist es denn ? Ein Echo ?
      EDIT:
      Und schau mal bitte nach ob auch die richtigen Einträge in den Datenpunten drin stehen
      spotify-premium.0.player.device
        stefu87_CH @DJMarc75 last edited by
        @djmarc75 sagte in Suche Spotify View:
        @stefu87_ch
        Ja sind Alexa Echo Dot Geräte
        EDIT:
        Ja da steht der richtige Echo Dot drin mit allen richtigen Infos wie auf der Visu ausgewählt werden.
        • DJMarc75
          @stefu87_ch
          Importiere Dir mal bitte folgendes Widget in Deine VISU
          [{"tpl":"i-vis-slider-simple","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"iMinVal":"0","iMaxVal":"100","iStepVal":"5","iVisibleStepVal":"5","iSliderRotation":"0","iSliderHeight":"10","iSliderColor":"#ffffff","iSliderCorners":"100","iSliderKnobSize":"20","iSliderKnobColor":"#008A00","iSliderKnobCorners":"100","iSliderTextColor":"#ffffff","iValueTextColor":"#008A00","iTextSize":"20","iStepTextSize":"12","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"spotify-premium.0.player.volume","iSliderLabel":"Lautstärke","iShowValue":true,"iChangeOnRelease":true,"iShowMinMax":true,"iShowSteps":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"446px","top":"351px","width":"500px","height":"63px"},"widgetSet":"vis-inventwo"}]
            @djmarc75 Auch da passiert nichts.
            Nur wenn ich
            spotify-premium.0.player.device.volume
            nehme dann funktioniert es, schreibt mir aber dafür in den Log
            • DJMarc75
              @stefu87_ch
              hmpf....
              Werden denn beim jeweiligen Echo im Ordner
              alexa2.0.Echo-Devices.DEINECHO.Player
              die sonstigen Werte von Spotify angezeigt? also Titel, Artist, usw.
                @stefu87_ch
                hmpf....
                Ja da werden alle Infos angezeigt wie: Artist, Title, Länge, ProviderName, Volume, Cover
                • DJMarc75
                  @stefu87_ch
                  OK,
                  dann kommunizieren die beiden Adapter ja miteinander.
                  Volume ist auch das selbe bei beiden ?
                    @djmarc75
                    Ich habe folgende Daten:
                    spotify-premium.0.player.volume   =45
                    spotify-premium.0.player.device.volume   = 21
                    alexa2.0.Echo-Devices.G090XG1214350KXT.Player.volume    =22
                    • DJMarc75
                      @stefu87_ch
                      ok, die beiden letzten Werte können leichte Differenzen aufweichen weil manche Echos in 3er Schritten arbeiten, also 0 ist 1, 3 ist 4 und 21 dann halt 22. Das ist nunmal so, aber der erste Wert müsste mit dem dritten gleich sein.
                      Adapter neu gestartet? Oder vll liegt das auch irgendwie am Spotify Family dass der Adapter da irgendwie andere Werte ausliest. Alles erstmal reine Vermutung. Ich würde den Spotifyadapter nochmal neu installieren und die Steuerung erstmal NICHT über VIS machen sondern rein über die Datenpunkte in den Objekten.
                      EDIT: findet die Soundausgabe über eine Lautsprechergruppe statt? - wahrscheinlich aber nicht
                        @djmarc75
                        Ok werde es später mal austesten.
                        Ne laufen nicht über eine gruppe sondern jeder Einzeln.
                          @djmarc75
                          Also habe folgendes versucht:
                          Wert ändern über Datenpunkt bringt nur eine Veränderung bei
                          alexa2.0.Echo-Devices.G090XG1214xxxxXT.Player.volume
                          Beim Datenpunkt
                          ändert sich nichts an der Lautstärke
                          DJMarc75 2 Replies Last reply Reply Quote 0
                          • DJMarc75
                            @stefu87_ch
                            Wie sieht denn Deine Konfig in der Spotifyinstanz aus ?
                              @stefu87_ch
                              • DJMarc75
                                @stefu87_ch said in Suche Spotify View:
                                Den Wert hier ändern bringt? Also jetzt nicht grad von 21 auf 22 ändern sondern gleich mal extrem ändern.
                                  Auch wenn ich von 21 auf 53 gehe passiert nichts bei der Alexa
                                  • DJMarc75
                                    @stefu87_ch
                                    ok. und wenn Du in der Spotify APP mal mit dem Volume rumspielst? Welche Werte ändern sich ?
                                      @djmarc75
                                      Wenn ich die Lautstärke über die Spotify App ändere, dann verändert sich folgende Datenpunkte:
                                      alexa2.0.Echo-Devices.G090XG12xxxx0KXT.Player.volume
                                      • DJMarc75
                                        @stefu87_ch
                                        Dann funktioniert eigentlich alles wie es soll.
                                        Der Datenpunkt
                                        ändert sich ja nicht wenn man am Device die Lautstärke ändert.
                                        Abgefragt wird da nur dieser
                                        Aber jetzt nochmal während Musik läuft diesen Datenpunkt ändern, z.B. um 20 verändern, und dann kurz danach nochmal um 20 ändern
                                          Habe jetzt mal mit 20 hoch, mit 30 runter, dann mit 40 hoch und mit 20 runter aber die Lautstärke bleibt immer gleich laut.
                                          • DJMarc75
                                            @stefu87_ch
                                            puh...
                                            Beide Adapter haste bestimmt schon neu gestartet ?!
                                            Steht was im LOG wenn Du den Wert änderst? Also DEBUG.
                                            107
                                            23406
