    3. Off Topic
    4. Grafana
    5. Fritzbox mit Grafana visualisieren [Version 2022]
    • Damrak2022
      Damrak2022 @Damrak2022 last edited by Damrak2022
      @damrak2022 Ich weiß nicht warum, aber anscheinend ist meine Grafana .ini leer:
      Was ist der Unterschied zwischen den beiden damit ich das mal begreife.
      Und wo müsste ich nun genau nachschauen, damit ich wieder auf die Grafana Webseite komme?
      • Damrak2022
        Damrak2022 @crunchip last edited by Damrak2022
        @crunchip Okay, habe eine Fehlermeldung entdeckt:
        pi@homebridge:~ $ sudo systemctl status grafana-server
        ● grafana-server.service - Grafana instance
             Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
             Active: failed (Result: exit-code) since Thu 2022-04-21 07:29:06 BST; 14mi>
               Docs: http://docs.grafana.org
            Process: 18558 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --p>
           Main PID: 18558 (code=exited, status=1/FAILURE)
                CPU: 356ms
        Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Scheduled restar>
        Apr 21 07:29:06 homebridge systemd[1]: Stopped Grafana instance.
        Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Start request re>
        Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Failed with resu>
        Apr 21 07:29:06 homebridge systemd[1]: Failed to start Grafana instance.
        lines 1-13/13 (END)
             Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor>
             Active: failed (Result: exit-code) since Thu 2022-04-21 07:29:06 BST; 14min>
            Process: 18558 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pi>
                CPU: 356ms
        Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Scheduled restart>
        Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Start request rep>
        Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Failed with resul>
        lines 1-13/13 (END)
             Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
             Active: failed (Result: exit-code) since Thu 2022-04-21 07:29:06 BST; 14min ago
            Process: 18558 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR>
                CPU: 356ms
        Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Scheduled restart job, restart counte>
        Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Start request repeated too quickly.
        Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Failed with result 'exit-code'.
        lines 1-13/13 (END)
            Process: 18558 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafan>
                CPU: 356ms
        Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at >
        lines 1-13/13 (END)
        Kannst Du mir bitte sagen was ich jetzt machen muss?
        crunchip 2 Replies Last reply Reply Quote 0
          crunchip Forum Testing Most Active @Damrak2022 last edited by
          @damrak2022 sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
          In der Grafana .ini steht das:
          ja was jetzt, leer oder nicht leer, hattest du falsch aufgerufen?
          • Damrak2022
            @crunchip ja, und jetzt einen Fehler gefunden - siehe Post darüber
              da gab es mal einen Versionssprung da gab es Probleme mit dem startscript, sollte bei dir allerdings jetzt nicht zu treffen, ist ja ne frische installation.
              Fakt ist, dein Grafana Service startet nicht, somit kommst du auch nicht auf die Seite.
              möglicherweise hast du irgend etwas in der .ini verfummelt.
              am einfachsten ist, du löscht Grafana incl Config und installierst es neu
              • Damrak2022
                @crunchip Sind dann alle Dashboards weg, wahrscheinlich ja, oder? ( wäre nicht ganz so dramatisch )
                Mit welchem Befehl kann ich deinstallieren und dann wieder neu installieren?
                  ja, was hast du denn bis jetzt alles für dashboards? du hast doch gerade erst begonnen
                  sudo apt-get purge --auto-remove grafana
                  • Damrak2022
                    @crunchip 4 Stück mit insgesamt 11 Panels, aber das ist nicht schlimm.
                    Und wie installiere ich dann sauber?
                    Damrak2022 crunchip 2 Replies Last reply Reply Quote 0
                    • Damrak2022
                      @damrak2022 Wieso nicht installiert? Ich konnte doch die .ini aufrufen
                      Reading package lists... Done
                      Building dependency tree... Done
                      Package 'grafana' is not installed, so not removed
                      0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.```
                        wie haste denn zuvor installiert?
                        • Damrak2022
                          @crunchip Via Anleitung bei smarthome-tricks
                            @damrak2022 https://grafana.com/tutorials/install-grafana-on-raspberry-pi/
                            • Damrak2022
                              @crunchip okay und was ist mit der Meldung das Grafana nicht installiert sei - kann ja wohl nicht stimmen. Ich kann die .ini immer noch aufrufen und da steht z.B. auch der Secret Sexy drin, also muss ja was vorhanden sein. Das möchte ich halt erst wegbekommen.
                                crunchip Forum Testing Most Active @Damrak2022 last edited by crunchip
                                was kommt wenn du es so probierst?
                                sudo apt-get remove --auto-remove grafana
                                bzw zeig mal zuvor die Ausgabe von
                                apt policy grafana
                                framp 1 Reply Last reply Reply Quote 0
                                • RoddiEF
                                  RoddiEF last edited by
                                  Ich hab das ganze mal aus Interesse nach dem hier auf einem Pi-4 4GB installiert, was auch Anfänglich funktioniert hat.
                                  Aber, die Services laufen zwar , eine Verbindung zur Fritzbox kommt nicht zustande da " Unhandled python exception in init callback: OSError: fritzcollectd: Failed to connect to fritz.box", was mir sagt das mein FritzOS wohl zu neu ist.
                                  Ach und was mir noch Einfällt, ich musste bei "sudo apt-get install -y python-pip" bei python-pip nach python eine 3 mit angeben also "sudo apt-get install -y python3-pip" da es sonst nicht Funktionierte.
                                  Ansonsten lief alles , wie gesagt , ohne Problem durch.
                                  Mfg.
                                  crunchip Damrak2022 2 Replies Last reply Reply Quote 0
                                    crunchip Forum Testing Most Active @RoddiEF last edited by
                                    @roddief theoretisch kann man sich die Werte auch mit dem upnp Adapter direkt im iobroker holen. Hatte das damals so laufen.
                                    • Damrak2022
                                      Damrak2022 @RoddiEF last edited by
                                      @roddief Das mit der 3 angeben habe ich gemacht
                                      Nun hat mir ja @crunchip empfohlen, mein gesamtes Grafana zu löschen, weil ich nicht mehr auf die Webseite komme.
                                      Wenn ich allerdings den Befehl
                                      eingebe bekomme ich folgendes:
                                      pi@homebridge:~ $ sudo apt-get remove --auto-remove grafana
                                      Allerdings komme ich noch in die Grafana.ini was ich garnicht verstehe
                                      Mit dem Befehl:
                                      apt policy grafana
                                      zeigt er mir folgendes:
                                      pi@homebridge:~ $ apt policy grafana
                                      grafana:
                                        Installed: (none)
                                        Candidate: 7.0.0
                                        Version table:
                                           7.0.0 500
                                              500 https://packages.grafana.com/enterprise/deb stable/main armhf Packag
                                      Und nun schreibst Du das Fritz=s wohl zu neu ist.
                                      Wie mache ich nun weiter?
                                      Wie bekomme ich die ganzen schon installierten Pakete vorn fritz Collectd weg, falls notwendig
                                      Und vor allem, wie komme ich wieder auf die Grafana Oberfläche?
                                        Thomas Braun Most Active @Damrak2022 last edited by
                                        @damrak2022
                                        config-Dateien werden nicht unbedingt gelöscht.
                                        Da müsste man prunen.
                                        Hast du grafana immer schön über apt / einen Paketmanager installiert oder mal 'irgendwie' am System vorbei?
                                        Zum Fritz-Zeuch:
                                        '/home/pi/.local/bin' which is not on PATH.
                                        bedeutet, dass die Befehle zwar direkt aufrufbar sind, aber nicht per simplem Konsolenkommando, weil an der Stelle nicht danach gesucht wird, weil nicht im default $PATH.
                                        • Damrak2022
                                          Damrak2022 @Thomas Braun last edited by
                                          @thomas-braun Grafana habe ich per Anleitung bei smarthome-tricks: Grafana und Influxdb installieren gemacht
                                          Jetzt habe ich versucht das ganze fritzcollectd mit dem Befehl
                                          pip uninstall fritzcollectd
                                          zu löschen und bekomme dies:
                                          pi@homebridge:~ $ pip uninstall fritzcollectd
                                          Found existing installation: fritzcollectd 0.7.0
                                          Uninstalling fritzcollectd-0.7.0:
                                            Would remove:
                                              /usr/local/lib/python3.9/dist-packages/fritzcollectd-0.7.0.dist-info/*
                                              /usr/local/lib/python3.9/dist-packages/fritzcollectd/*
                                          Proceed (y/n)? y
                                          ERROR: Exception:
                                          Traceback (most recent call last):
                                            File "/usr/lib/python3.9/shutil.py", line 806, in move
                                              os.rename(src, real_dst)
                                          PermissionError: [Errno 13] Permission denied: '/usr/local/lib/python3.9/dist-packages/fritzcollectd-0.7.0.dist-info/' -> '/tmp/pip-uninstall-t5dydebm'
                                          During handling of the above exception, another exception occurred:
                                            File "/usr/lib/python3/dist-packages/pip/_internal/cli/base_command.py", line 223, in _main
                                              status = self.run(options, args)
                                            File "/usr/lib/python3/dist-packages/pip/_internal/commands/uninstall.py", line 89, in run
                                              uninstall_pathset = req.uninstall(
                                            File "/usr/lib/python3/dist-packages/pip/_internal/req/req_install.py", line 694, in uninstall
                                              uninstalled_pathset.remove(auto_confirm, verbose)
                                            File "/usr/lib/python3/dist-packages/pip/_internal/req/req_uninstall.py", line 403, in remove
                                              moved.stash(path)
                                            File "/usr/lib/python3/dist-packages/pip/_internal/req/req_uninstall.py", line 292, in stash
                                              renames(path, new_path)
                                            File "/usr/lib/python3/dist-packages/pip/_internal/utils/misc.py", line 355, in renames
                                              shutil.move(old, new)
                                            File "/usr/lib/python3.9/shutil.py", line 818, in move
                                              rmtree(src)
                                            File "/usr/lib/python3.9/shutil.py", line 718, in rmtree
                                              _rmtree_safe_fd(fd, path, onerror)
                                            File "/usr/lib/python3.9/shutil.py", line 675, in _rmtree_safe_fd
                                              onerror(os.unlink, fullname, sys.exc_info())
                                            File "/usr/lib/python3.9/shutil.py", line 673, in _rmtree_safe_fd
                                              os.unlink(entry.name, dir_fd=topfd)
                                          PermissionError: [Errno 13] Permission denied: 'INSTALLER'
                                          pi@homebridge:~ $
                                          Bin nun echt ratlos
                                            Muss wohl mit root-Rechten rausgeklopft werden:
                                            sudo pip uninstall fritzcollectd
                                            144
                                            20516
