Fritzbox mit Grafana visualisieren [Version 2022]
@thomas-braun Grafana habe ich per Anleitung bei smarthome-tricks: Grafana und Influxdb installieren gemacht
Jetzt habe ich versucht das ganze fritzcollectd mit dem Befehlpip uninstall fritzcollectdzu löschen und bekomme dies:
pi@homebridge:~ $ pip uninstall fritzcollectd Found existing installation: fritzcollectd 0.7.0 Uninstalling fritzcollectd-0.7.0: Would remove: /usr/local/lib/python3.9/dist-packages/fritzcollectd-0.7.0.dist-info/* /usr/local/lib/python3.9/dist-packages/fritzcollectd/* Proceed (y/n)? y ERROR: Exception: Traceback (most recent call last): File "/usr/lib/python3.9/shutil.py", line 806, in move os.rename(src, real_dst) PermissionError: [Errno 13] Permission denied: '/usr/local/lib/python3.9/dist-packages/fritzcollectd-0.7.0.dist-info/' -> '/tmp/pip-uninstall-t5dydebm' During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/pip/_internal/cli/base_command.py", line 223, in _main status = self.run(options, args) File "/usr/lib/python3/dist-packages/pip/_internal/commands/uninstall.py", line 89, in run uninstall_pathset = req.uninstall( File "/usr/lib/python3/dist-packages/pip/_internal/req/req_install.py", line 694, in uninstall uninstalled_pathset.remove(auto_confirm, verbose) File "/usr/lib/python3/dist-packages/pip/_internal/req/req_uninstall.py", line 403, in remove moved.stash(path) File "/usr/lib/python3/dist-packages/pip/_internal/req/req_uninstall.py", line 292, in stash renames(path, new_path) File "/usr/lib/python3/dist-packages/pip/_internal/utils/misc.py", line 355, in renames shutil.move(old, new) File "/usr/lib/python3.9/shutil.py", line 818, in move rmtree(src) File "/usr/lib/python3.9/shutil.py", line 718, in rmtree _rmtree_safe_fd(fd, path, onerror) File "/usr/lib/python3.9/shutil.py", line 675, in _rmtree_safe_fd onerror(os.unlink, fullname, sys.exc_info()) File "/usr/lib/python3.9/shutil.py", line 673, in _rmtree_safe_fd os.unlink(entry.name, dir_fd=topfd) PermissionError: [Errno 13] Permission denied: 'INSTALLER' pi@homebridge:~ $Bin nun echt ratlos
@damrak2022 sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
Muss wohl mit root-Rechten rausgeklopft werden:
sudo pip uninstall fritzcollectd -
@thomas-braun sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
Das mit dem sudo vergesse ich immer - ja hat geklappt.
Kannst Du mir noch sagen wie ich das mit Grafana hinbekomme? Seltsamerweise komme ich ja noch zur Grafana .iniWenn das dann wieder läuft möchte ich die FritzBox laut dieser Anleitung einbinden
AnleitungBei dieser Anleitung bin ich beim letzten Versuch an diesem Punkt gescheitert:
# Erst die INI kopieren: sudo cp /opt/fritzinfluxdb/./fritzinfluxdb.ini-sample /opt/fritzinfluxdb/fritzinfluxdb.ini # In der INI die Einstellungen zur Fritzbox vornehmen (am besten einen neuen Benutzer in der Fritzbox anlegen und die Credentials hier verwenden): sudo nano /opt/fritzinfluxdb/fritzinfluxdb.iniWie muss ich andieser Stelle exakt vorgehen?
Ich hab grafana nicht im Einsatz. Aber grafana.ini hört sich nach einer der config files an, nicht mehr.
apt policy grafana*liefert?
apt policy grafana*
pi@homebridge:~ $ apt policy grafana* grafana-enterprise: Installed: 8.4.6 Candidate: 8.4.7 Version table: 8.4.7 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages *** 8.4.6 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 100 /var/lib/dpkg/status 8.4.5 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.4.4 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.4.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.4.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.4.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.4.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.3.7 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.3.6 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.3.5 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.3.4 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.3.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.3.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.3.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.2.7 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.2.6 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.2.5 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.2.4 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.2.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.2.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.2.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.2.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.1.8 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.1.7 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.1.6 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.1.5 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.1.4 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.1.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.1.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.1.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.1.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.0.7 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.0.6 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.0.5 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.0.4 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.0.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.0.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.0.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 8.0.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.15 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.13 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.12 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.11 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.10 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.9 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.8 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.7 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.6 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.5 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.4 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.5.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.4.5 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.4.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.4.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.4.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.4.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.3.10 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.3.7 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.3.6 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.3.5 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.3.4 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.3.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.3.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.3.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.3.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.2.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.2.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.2.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.1.5 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.1.4 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.1.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.1.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.1.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.1.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.6 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.5 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.4 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.7.6 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.7.5 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.7.4 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.7.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.7.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.7.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.7.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.6.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.6.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.6.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.5.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages grafana-zabbix: Installed: (none) Candidate: 2.5.1-1 Version table: 2.5.1-1 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages grafana: Installed: (none) Candidate: 7.0.0 Version table: 7.0.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages grafana-enterprise-rpi: Installed: (none) Candidate: 7.4.0 Version table: 7.4.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.3.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.3.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.3.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.3.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.2.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.2.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.2.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.1.5 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.1.4 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.1.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.1.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.1.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.1.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.6 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.5 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.4 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 7.0.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.7.6 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.7.4 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.7.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.7.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.7.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.7.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.6.2 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.6.1 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.6.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages 6.5.3 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages grafana-rpi: Installed: (none) Candidate: 7.0.0 Version table: 7.0.0 500 500 https://packages.grafana.com/enterprise/deb stable/main armhf Packages pi@homebridge:~ $ -
grafana-enterprise:
Installed: 8.4.6
Da hast du deine Installation.
Statt grafana ist da grafana-enterprise installiert. -
@thomas-braun Okay, wie lösche ich die komplett? Die Dashboards kann ich neu machen
@damrak2022 du hast die enterprise installiert
Für den Heimanwender eigentlich die OSS Version -
@damrak2022 eigentlich so wie ich es dir weiter oben zuerst gezeigt hatte https://forum.iobroker.net/post/793443
Für eine Raspberry kann man auch die grafana-rpi einsetzen. Zumindest verstehe ich das so, dass das eine auf den Pi besser angepasste Variante ist.
Aber da ich grafana nicht im Einsatz habe kann ich da nix wirklich fundiertes zu sagen.
@crunchip sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
Ich weiß, aber da kommt dann halt das
pi@homebridge:~ $ pi@homebridge:~ $ sudo apt-get purge --auto-remove grafana Reading package lists... Done Building dependency tree... Done Reading state information... Done Package 'grafana' is not installed, so not removed 0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.Muss der Befehl angepasst werden?
@damrak2022 dan füge mal noch das -enterprise mit an
@crunchip Das hat anscheinend geklappt
pi@homebridge:~ $ sudo apt-get purge --auto-remove grafana-enterprise Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages will be REMOVED: grafana-enterprise* 0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded. After this operation, 263 MB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 71794 files and directories currently installed.) Removing grafana-enterprise (8.4.6) ... (Reading database ... 65389 files and directories currently installed.) Purging configuration files for grafana-enterprise (8.4.6) ... dpkg: warning: while removing grafana-enterprise, directory '/etc/grafana' not empty so not removed dpkg: warning: while removing grafana-enterprise, directory '/usr/lib/systemd/system' not empty so not removedAber ein paar Daten sind anscheinend nicht entfernt worden, da nicht leer. Wie bekomme ich die weg, oder kann ich das so lassen?
Lass das so. Insbesondere die Finger von /usr/lib/systemd/system lassen.
@thomas-braun Okay, allerletzte Frage:
kannst Du mal einen Blick hierauf werfen: Anleitungund mir mit einfachen Worten erklären, was ich genau bei dem Punkt
# Erst die INI kopieren: sudo cp /opt/fritzinfluxdb/./fritzinfluxdb.ini-sample /opt/fritzinfluxdb/fritzinfluxdb.ini # In der INI die Einstellungen zur Fritzbox vornehmen (am besten einen neuen Benutzer in der Fritzbox anlegen und die Credentials hier verwenden): sudo nano /opt/fritzinfluxdb/fritzinfluxdb.iniAlso besonders mit "Erst die Ini" kopieren" da habe ich gestern wohl was falsch gemacht.
Mit
sudo cp /opt/fritzinfluxdb/./fritzinfluxdb.ini-sample /opt/fritzinfluxdb/fritzinfluxdb.iniwird eine Vorlage nach /opt/fritzinfluxdb/fritzinfludb.ini kopiert, die muss dann noch entsprechend ausgefüllt werden.
Wobei
/opt/fritzinfluxdb/./fritzinfluxdb.ini-sampleeine ungewöhnliche Pfadangabe ist. Ich vermute eher, das müsste
/opt/fritzinfluxdb/fritzinfluxdb.ini-samplelauten.
@thomas-braun Okay, falls ich andieser Stelle wieder ein Problem habe, melde ich mich.
Jetzt installiere ich erstmal das passende Grafana nach der Anleitung welche mir @crunchip geschickt hat.
Euch möchte ich vielen, vielen Dank für die tolle Hilfe sagen. -
Lass das so.
Wenn ich mich jetzt nicht täusche, liegt da ja die config drin.... in /etc/grafana. Und die ist ja sein Problem, die verfummelte .ini
So bringt eine Neu installation nichts -
Bei einer Neuinstallation wird die aber auch mit einer frischen Version überschrieben.
@crunchip Bei dem ersten Befehl für die Neuinstallation von Grafana laut der Anleitung von Dir bekomme ich diesen Fehler:
wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add - Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)). OKEinfach weitermachen, oder besser das Problem erstmal beheben?
