    3. Off Topic
    4. Grafana
    5. Fritzbox mit Grafana visualisieren [Version 2022]
      crunchip Forum Testing Most Active @Damrak2022 last edited by
      @damrak2022 ja dein pi darf das nicht, habe aber auch nicht geschrieben, das du es sofort ausführen sollst😉
      • Damrak2022
        Damrak2022 @crunchip last edited by Damrak2022
        @crunchip
        pi@homebridge:~ $ sudo dpkg -r --force-all grafana
        dpkg: warning: ignoring request to remove grafana which isn't installed
        Ich installiere jetzt noch mal neu und wenn es dann wieder nicht geht, kann ich doch gleich diesen Befehl nutzen, oder?
          @damrak2022
          Die Ausgabe von
          sudo apt-get purge --auto-remove grafana-enterprise
          Hattest du nicht gezeigt
          • Damrak2022
            @crunchip Ja, aber enterprise ist doch runter
            • Damrak2022
              Damrak2022 @Damrak2022 last edited by
              @damrak2022
              pi@homebridge:~ $ sudo apt-get install -y grafana
              Reading package lists... Done
              Building dependency tree... Done
              The following NEW packages will be installed:
                grafana
              0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
              Need to get 0 B/74.0 MB of archives.
              After this operation, 243 MB of additional disk space will be used.
              Selecting previously unselected package grafana.
              (Reading database ... 65384 files and directories currently installed.)
              Preparing to unpack .../grafana_8.5.0_armhf.deb ...
              Unpacking grafana (8.5.0) ...
              Setting up grafana (8.5.0) ...
              ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
               sudo /bin/systemctl daemon-reload
               sudo /bin/systemctl enable grafana-server
              ### You can start grafana-server by executing
               sudo /bin/systemctl start grafana-server
              pi@homebridge:~ $ sudo /bin/systemctl start grafana-server
              pi@homebridge:~ $ sudo /bin/systemctl enable grafana-server
              Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
              Executing: /lib/systemd/systemd-sysv-install enable grafana-server
              (Reading database ... 72087 files and directories currently installed.)
              Removing grafana (8.5.0) ...
              pi@homebridge:~ $ sudo apt-get purge --auto-remove grafana
              The following packages will be REMOVED:
                grafana*
              0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
              After this operation, 0 B of additional disk space will be used.
              Do you want to continue? [Y/n] y
              (Reading database ... 65389 files and directories currently installed.)
              Purging configuration files for grafana (8.5.0) ...
              dpkg: warning: while removing grafana, directory '/etc/grafana' not empty so not removed
              dpkg: warning: while removing grafana, directory '/usr/lib/systemd/system' not empty so not removed
              pi@homebridge:~ $
              Wie kann ich mir die restlichen Grafana Dateien anzeigen lassen und endgültig löschen?
                @damrak2022 zeig mal die Ausgabe was da noch so ist
                find -name grafana*
                • Damrak2022
                  @crunchip sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
                  find -name grafana*
                  pi@homebridge:~ $ find -name grafana*
                  pi@homebridge:~ $
                  Anscheinend nichts
                    Thomas Braun Most Active @Damrak2022 last edited by
                    @damrak2022 sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
                    Anscheinend nichts
                    Jedenfalls nichts in deinem /home.
                    Stell dich weiter vorne in den Dateibaum:
                    cd /
                    find -name grafana*
                    Damrak2022 1 Reply Last reply Reply Quote 1
                    • Damrak2022
                      Damrak2022 @Thomas Braun last edited by Damrak2022
                      find: ‘./proc/396/fd’: Permission denied
                      find: ‘./proc/396/map_files’: Permission denied
                      find: ‘./proc/396/ns’: Permission denied
                      find: ‘./proc/401/task/401/fd’: Permission denied
                      find: ‘./proc/401/task/401/ns’: Permission denied
                      find: ‘./proc/401/fd’: Permission denied
                      find: ‘./proc/401/map_files’: Permission denied
                      find: ‘./proc/401/ns’: Permission denied
                      find: ‘./proc/403/task/403/fd’: Permission denied
                      find: ‘./proc/403/task/403/ns’: Permission denied
                      find: ‘./proc/403/fd’: Permission denied
                      find: ‘./proc/403/map_files’: Permission denied
                      find: ‘./proc/403/ns’: Permission denied
                      find: ‘./proc/447/task/447/fd’: Permission denied
                      find: ‘./proc/447/task/447/ns’: Permission denied
                      find: ‘./proc/447/fd’: Permission denied
                      find: ‘./proc/447/map_files’: Permission denied
                      find: ‘./proc/447/ns’: Permission denied
                      find: ‘./proc/456/task/456/fd’: Permission denied
                      find: ‘./proc/456/task/456/ns’: Permission denied
                      find: ‘./proc/456/task/457/fd’: Permission denied
                      find: ‘./proc/456/task/457/ns’: Permission denied
                      find: ‘./proc/456/task/458/fd’: Permission denied
                      find: ‘./proc/456/task/458/ns’: Permission denied
                      find: ‘./proc/456/task/459/fd’: Permission denied
                      find: ‘./proc/456/task/459/ns’: Permission denied
                      find: ‘./proc/456/fd’: Permission denied
                      find: ‘./proc/456/map_files’: Permission denied
                      find: ‘./proc/456/ns’: Permission denied
                      find: ‘./proc/474/task/474/fd’: Permission denied
                      find: ‘./proc/474/task/474/ns’: Permission denied
                      find: ‘./proc/474/task/508/fd’: Permission denied
                      find: ‘./proc/474/task/508/ns’: Permission denied
                      find: ‘./proc/474/fd’: Permission denied
                      find: ‘./proc/474/map_files’: Permission denied
                      find: ‘./proc/474/ns’: Permission denied
                      find: ‘./proc/489/task/489/fd’: Permission denied
                      find: ‘./proc/489/task/489/ns’: Permission denied
                      find: ‘./proc/489/fd’: Permission denied
                      find: ‘./proc/489/map_files’: Permission denied
                      find: ‘./proc/489/ns’: Permission denied
                      find: ‘./proc/579/task/579/fd’: Permission denied
                      find: ‘./proc/579/task/579/ns’: Permission denied
                      find: ‘./proc/579/fd’: Permission denied
                      find: ‘./proc/579/map_files’: Permission denied
                      find: ‘./proc/579/ns’: Permission denied
                      find: ‘./proc/582/task/582/fd’: Permission denied
                      find: ‘./proc/582/task/582/ns’: Permission denied
                      find: ‘./proc/582/fd’: Permission denied
                      find: ‘./proc/582/map_files’: Permission denied
                      find: ‘./proc/582/ns’: Permission denied
                      find: ‘./proc/593/task/593/fd’: Permission denied
                      find: ‘./proc/593/task/593/ns’: Permission denied
                      find: ‘./proc/593/fd’: Permission denied
                      find: ‘./proc/593/map_files’: Permission denied
                      find: ‘./proc/593/ns’: Permission denied
                      find: ‘./proc/599/task/599/fd’: Permission denied
                      find: ‘./proc/599/task/599/ns’: Permission denied
                      find: ‘./proc/599/fd’: Permission denied
                      find: ‘./proc/599/map_files’: Permission denied
                      find: ‘./proc/599/ns’: Permission denied
                      find: ‘./proc/688/task/688/fd’: Permission denied
                      find: ‘./proc/688/task/688/ns’: Permission denied
                      find: ‘./proc/688/task/689/fd’: Permission denied
                      find: ‘./proc/688/task/689/ns’: Permission denied
                      find: ‘./proc/688/fd’: Permission denied
                      find: ‘./proc/688/map_files’: Permission denied
                      find: ‘./proc/688/ns’: Permission denied
                      find: ‘./proc/690/task/690/fd’: Permission denied
                      find: ‘./proc/690/task/690/ns’: Permission denied
                      find: ‘./proc/690/fd’: Permission denied
                      find: ‘./proc/690/map_files’: Permission denied
                      find: ‘./proc/690/ns’: Permission denied
                      find: ‘./proc/695/task/695/fd’: Permission denied
                      find: ‘./proc/695/task/695/ns’: Permission denied
                      find: ‘./proc/695/task/704/fd’: Permission denied
                      find: ‘./proc/695/task/704/ns’: Permission denied
                      find: ‘./proc/695/task/705/fd’: Permission denied
                      find: ‘./proc/695/task/705/ns’: Permission denied
                      find: ‘./proc/695/task/708/fd’: Permission denied
                      find: ‘./proc/695/task/708/ns’: Permission denied
                      find: ‘./proc/695/task/711/fd’: Permission denied
                      find: ‘./proc/695/task/711/ns’: Permission denied
                      find: ‘./proc/695/task/717/fd’: Permission denied
                      find: ‘./proc/695/task/717/ns’: Permission denied
                      find: ‘./proc/695/task/719/fd’: Permission denied
                      find: ‘./proc/695/task/719/ns’: Permission denied
                      find: ‘./proc/695/task/732/fd’: Permission denied
                      find: ‘./proc/695/task/732/ns’: Permission denied
                      find: ‘./proc/695/task/733/fd’: Permission denied
                      find: ‘./proc/695/task/733/ns’: Permission denied
                      find: ‘./proc/695/task/734/fd’: Permission denied
                      find: ‘./proc/695/task/734/ns’: Permission denied
                      find: ‘./proc/695/task/735/fd’: Permission denied
                      find: ‘./proc/695/task/735/ns’: Permission denied
                      find: ‘./proc/695/task/736/fd’: Permission denied
                      find: ‘./proc/695/task/736/ns’: Permission denied
                      find: ‘./proc/695/task/880/fd’: Permission denied
                      find: ‘./proc/695/task/880/ns’: Permission denied
                      find: ‘./proc/695/task/2229/fd’: Permission denied
                      find: ‘./proc/695/task/2229/ns’: Permission denied
                      find: ‘./proc/695/task/22883/fd’: Permission denied
                      find: ‘./proc/695/task/22883/ns’: Permission denied
                      find: ‘./proc/695/fd’: Permission denied
                      find: ‘./proc/695/map_files’: Permission denied
                      find: ‘./proc/695/ns’: Permission denied
                      find: ‘./proc/701/task/701/fd’: Permission denied
                      find: ‘./proc/701/task/701/ns’: Permission denied
                      find: ‘./proc/701/fd’: Permission denied
                      find: ‘./proc/701/map_files’: Permission denied
                      find: ‘./proc/701/ns’: Permission denied
                      find: ‘./proc/744/task/744/fd’: Permission denied
                      find: ‘./proc/744/task/744/ns’: Permission denied
                      find: ‘./proc/744/task/798/fd’: Permission denied
                      find: ‘./proc/744/task/798/ns’: Permission denied
                      find: ‘./proc/744/task/799/fd’: Permission denied
                      find: ‘./proc/744/task/799/ns’: Permission denied
                      find: ‘./proc/744/task/800/fd’: Permission denied
                      find: ‘./proc/744/task/800/ns’: Permission denied
                      find: ‘./proc/744/task/801/fd’: Permission denied
                      find: ‘./proc/744/task/801/ns’: Permission denied
                      find: ‘./proc/744/task/802/fd’: Permission denied
                      find: ‘./proc/744/task/802/ns’: Permission denied
                      find: ‘./proc/744/task/803/fd’: Permission denied
                      find: ‘./proc/744/task/803/ns’: Permission denied
                      find: ‘./proc/744/task/804/fd’: Permission denied
                      find: ‘./proc/744/task/804/ns’: Permission denied
                      find: ‘./proc/744/task/805/fd’: Permission denied
                      find: ‘./proc/744/task/805/ns’: Permission denied
                      find: ‘./proc/744/task/806/fd’: Permission denied
                      find: ‘./proc/744/task/806/ns’: Permission denied
                      find: ‘./proc/744/task/807/fd’: Permission denied
                      find: ‘./proc/744/task/807/ns’: Permission denied
                      find: ‘./proc/744/task/808/fd’: Permission denied
                      find: ‘./proc/744/task/808/ns’: Permission denied
                      find: ‘./proc/744/fd’: Permission denied
                      find: ‘./proc/744/map_files’: Permission denied
                      find: ‘./proc/744/ns’: Permission denied
                      find: ‘./proc/2578/task/2578/fd’: Permission denied
                      find: ‘./proc/2578/task/2578/ns’: Permission denied
                      find: ‘./proc/2578/task/2579/fd’: Permission denied
                      find: ‘./proc/2578/task/2579/ns’: Permission denied
                      find: ‘./proc/2578/task/2580/fd’: Permission denied
                      find: ‘./proc/2578/task/2580/ns’: Permission denied
                      find: ‘./proc/2578/fd’: Permission denied
                      find: ‘./proc/2578/map_files’: Permission denied
                      find: ‘./proc/2578/ns’: Permission denied
                      find: ‘./proc/2582/task/2582/fd’: Permission denied
                      find: ‘./proc/2582/task/2582/ns’: Permission denied
                      find: ‘./proc/2582/task/2583/fd’: Permission denied
                      find: ‘./proc/2582/task/2583/ns’: Permission denied
                      find: ‘./proc/2582/task/2585/fd’: Permission denied
                      find: ‘./proc/2582/task/2585/ns’: Permission denied
                      find: ‘./proc/2582/fd’: Permission denied
                      find: ‘./proc/2582/map_files’: Permission denied
                      find: ‘./proc/2582/ns’: Permission denied
                      find: ‘./proc/3080/task/3080/fd’: Permission denied
                      find: ‘./proc/3080/task/3080/ns’: Permission denied
                      find: ‘./proc/3080/task/3082/fd’: Permission denied
                      find: ‘./proc/3080/task/3082/ns’: Permission denied
                      find: ‘./proc/3080/task/3083/fd’: Permission denied
                      find: ‘./proc/3080/task/3083/ns’: Permission denied
                      find: ‘./proc/3080/task/3084/fd’: Permission denied
                      find: ‘./proc/3080/task/3084/ns’: Permission denied
                      find: ‘./proc/3080/task/3085/fd’: Permission denied
                      find: ‘./proc/3080/task/3085/ns’: Permission denied
                      find: ‘./proc/3080/task/3086/fd’: Permission denied
                      find: ‘./proc/3080/task/3086/ns’: Permission denied
                      find: ‘./proc/3080/task/3087/fd’: Permission denied
                      find: ‘./proc/3080/task/3087/ns’: Permission denied
                      find: ‘./proc/3080/task/3088/fd’: Permission denied
                      find: ‘./proc/3080/task/3088/ns’: Permission denied
                      find: ‘./proc/3080/task/3089/fd’: Permission denied
                      find: ‘./proc/3080/task/3089/ns’: Permission denied
                      find: ‘./proc/3080/task/3090/fd’: Permission denied
                      find: ‘./proc/3080/task/3090/ns’: Permission denied
                      find: ‘./proc/3080/task/3091/fd’: Permission denied
                      find: ‘./proc/3080/task/3091/ns’: Permission denied
                      find: ‘./proc/3080/fd’: Permission denied
                      find: ‘./proc/3080/map_files’: Permission denied
                      find: ‘./proc/3080/ns’: Permission denied
                      find: ‘./proc/3098/task/3098/fd’: Permission denied
                      find: ‘./proc/3098/task/3098/ns’: Permission denied
                      find: ‘./proc/3098/task/3099/fd’: Permission denied
                      find: ‘./proc/3098/task/3099/ns’: Permission denied
                      find: ‘./proc/3098/task/3100/fd’: Permission denied
                      find: ‘./proc/3098/task/3100/ns’: Permission denied
                      find: ‘./proc/3098/task/3101/fd’: Permission denied
                      find: ‘./proc/3098/task/3101/ns’: Permission denied
                      find: ‘./proc/3098/task/3102/fd’: Permission denied
                      find: ‘./proc/3098/task/3102/ns’: Permission denied
                      find: ‘./proc/3098/task/3103/fd’: Permission denied
                      find: ‘./proc/3098/task/3103/ns’: Permission denied
                      find: ‘./proc/3098/task/3104/fd’: Permission denied
                      find: ‘./proc/3098/task/3104/ns’: Permission denied
                      find: ‘./proc/3098/task/3105/fd’: Permission denied
                      find: ‘./proc/3098/task/3105/ns’: Permission denied
                      find: ‘./proc/3098/task/3106/fd’: Permission denied
                      find: ‘./proc/3098/task/3106/ns’: Permission denied
                      find: ‘./proc/3098/task/3107/fd’: Permission denied
                      find: ‘./proc/3098/task/3107/ns’: Permission denied
                      find: ‘./proc/3098/task/3108/fd’: Permission denied
                      find: ‘./proc/3098/task/3108/ns’: Permission denied
                      find: ‘./proc/3098/fd’: Permission denied
                      find: ‘./proc/3098/map_files’: Permission denied
                      find: ‘./proc/3098/ns’: Permission denied
                      find: ‘./proc/3109/task/3109/fd’: Permission denied
                      find: ‘./proc/3109/task/3109/ns’: Permission denied
                      find: ‘./proc/3109/task/3110/fd’: Permission denied
                      find: ‘./proc/3109/task/3110/ns’: Permission denied
                      find: ‘./proc/3109/task/3111/fd’: Permission denied
                      find: ‘./proc/3109/task/3111/ns’: Permission denied
                      find: ‘./proc/3109/task/3112/fd’: Permission denied
                      find: ‘./proc/3109/task/3112/ns’: Permission denied
                      find: ‘./proc/3109/task/3113/fd’: Permission denied
                      find: ‘./proc/3109/task/3113/ns’: Permission denied
                      find: ‘./proc/3109/task/3114/fd’: Permission denied
                      find: ‘./proc/3109/task/3114/ns’: Permission denied
                      find: ‘./proc/3109/task/3115/fd’: Permission denied
                      find: ‘./proc/3109/task/3115/ns’: Permission denied
                      find: ‘./proc/3109/task/3120/fd’: Permission denied
                      find: ‘./proc/3109/task/3120/ns’: Permission denied
                      find: ‘./proc/3109/task/3121/fd’: Permission denied
                      find: ‘./proc/3109/task/3121/ns’: Permission denied
                      find: ‘./proc/3109/task/3122/fd’: Permission denied
                      find: ‘./proc/3109/task/3122/ns’: Permission denied
                      find: ‘./proc/3109/task/3123/fd’: Permission denied
                      find: ‘./proc/3109/task/3123/ns’: Permission denied
                      find: ‘./proc/3109/fd’: Permission denied
                      find: ‘./proc/3109/map_files’: Permission denied
                      find: ‘./proc/3109/ns’: Permission denied
                      find: ‘./proc/3124/task/3124/fd’: Permission denied
                      find: ‘./proc/3124/task/3124/ns’: Permission denied
                      find: ‘./proc/3124/task/3125/fd’: Permission denied
                      find: ‘./proc/3124/task/3125/ns’: Permission denied
                      find: ‘./proc/3124/task/3126/fd’: Permission denied
                      find: ‘./proc/3124/task/3126/ns’: Permission denied
                      find: ‘./proc/3124/task/3127/fd’: Permission denied
                      find: ‘./proc/3124/task/3127/ns’: Permission denied
                      find: ‘./proc/3124/task/3128/fd’: Permission denied
                      find: ‘./proc/3124/task/3128/ns’: Permission denied
                      find: ‘./proc/3124/task/3129/fd’: Permission denied
                      find: ‘./proc/3124/task/3129/ns’: Permission denied
                      find: ‘./proc/3124/task/3131/fd’: Permission denied
                      find: ‘./proc/3124/task/3131/ns’: Permission denied
                      find: ‘./proc/3124/task/3138/fd’: Permission denied
                      find: ‘./proc/3124/task/3138/ns’: Permission denied
                      find: ‘./proc/3124/task/3139/fd’: Permission denied
                      find: ‘./proc/3124/task/3139/ns’: Permission denied
                      find: ‘./proc/3124/task/3140/fd’: Permission denied
                      find: ‘./proc/3124/task/3140/ns’: Permission denied
                      find: ‘./proc/3124/task/3141/fd’: Permission denied
                      find: ‘./proc/3124/task/3141/ns’: Permission denied
                      find: ‘./proc/3124/fd’: Permission denied
                      find: ‘./proc/3124/map_files’: Permission denied
                      find: ‘./proc/3124/ns’: Permission denied
                      find: ‘./proc/3130/task/3130/fd’: Permission denied
                      find: ‘./proc/3130/task/3130/ns’: Permission denied
                      find: ‘./proc/3130/task/3132/fd’: Permission denied
                      find: ‘./proc/3130/task/3132/ns’: Permission denied
                      find: ‘./proc/3130/task/3133/fd’: Permission denied
                      find: ‘./proc/3130/task/3133/ns’: Permission denied
                      find: ‘./proc/3130/task/3134/fd’: Permission denied
                      find: ‘./proc/3130/task/3134/ns’: Permission denied
                      find: ‘./proc/3130/task/3135/fd’: Permission denied
                      find: ‘./proc/3130/task/3135/ns’: Permission denied
                      find: ‘./proc/3130/task/3136/fd’: Permission denied
                      find: ‘./proc/3130/task/3136/ns’: Permission denied
                      find: ‘./proc/3130/task/3137/fd’: Permission denied
                      find: ‘./proc/3130/task/3137/ns’: Permission denied
                      find: ‘./proc/3130/task/3142/fd’: Permission denied
                      find: ‘./proc/3130/task/3142/ns’: Permission denied
                      find: ‘./proc/3130/task/3143/fd’: Permission denied
                      find: ‘./proc/3130/task/3143/ns’: Permission denied
                      find: ‘./proc/3130/task/3144/fd’: Permission denied
                      find: ‘./proc/3130/task/3144/ns’: Permission denied
                      find: ‘./proc/3130/task/3145/fd’: Permission denied
                      find: ‘./proc/3130/task/3145/ns’: Permission denied
                      find: ‘./proc/3130/fd’: Permission denied
                      find: ‘./proc/3130/map_files’: Permission denied
                      find: ‘./proc/3130/ns’: Permission denied
                      find: ‘./proc/3146/task/3146/fd’: Permission denied
                      find: ‘./proc/3146/task/3146/ns’: Permission denied
                      find: ‘./proc/3146/task/3147/fd’: Permission denied
                      find: ‘./proc/3146/task/3147/ns’: Permission denied
                      find: ‘./proc/3146/task/3148/fd’: Permission denied
                      find: ‘./proc/3146/task/3148/ns’: Permission denied
                      find: ‘./proc/3146/task/3149/fd’: Permission denied
                      find: ‘./proc/3146/task/3149/ns’: Permission denied
                      find: ‘./proc/3146/task/3150/fd’: Permission denied
                      find: ‘./proc/3146/task/3150/ns’: Permission denied
                      find: ‘./proc/3146/task/3151/fd’: Permission denied
                      find: ‘./proc/3146/task/3151/ns’: Permission denied
                      find: ‘./proc/3146/task/3152/fd’: Permission denied
                      find: ‘./proc/3146/task/3152/ns’: Permission denied
                      find: ‘./proc/3146/task/3153/fd’: Permission denied
                      find: ‘./proc/3146/task/3153/ns’: Permission denied
                      find: ‘./proc/3146/task/3154/fd’: Permission denied
                      find: ‘./proc/3146/task/3154/ns’: Permission denied
                      find: ‘./proc/3146/task/3155/fd’: Permission denied
                      find: ‘./proc/3146/task/3155/ns’: Permission denied
                      find: ‘./proc/3146/task/3156/fd’: Permission denied
                      find: ‘./proc/3146/task/3156/ns’: Permission denied
                      find: ‘./proc/3146/fd’: Permission denied
                      find: ‘./proc/3146/map_files’: Permission denied
                      find: ‘./proc/3146/ns’: Permission denied
                      find: ‘./proc/3157/task/3157/fd’: Permission denied
                      find: ‘./proc/3157/task/3157/ns’: Permission denied
                      find: ‘./proc/3157/task/3158/fd’: Permission denied
                      find: ‘./proc/3157/task/3158/ns’: Permission denied
                      find: ‘./proc/3157/task/3159/fd’: Permission denied
                      find: ‘./proc/3157/task/3159/ns’: Permission denied
                      find: ‘./proc/3157/task/3160/fd’: Permission denied
                      find: ‘./proc/3157/task/3160/ns’: Permission denied
                      find: ‘./proc/3157/task/3161/fd’: Permission denied
                      find: ‘./proc/3157/task/3161/ns’: Permission denied
                      find: ‘./proc/3157/task/3162/fd’: Permission denied
                      find: ‘./proc/3157/task/3162/ns’: Permission denied
                      find: ‘./proc/3157/task/3163/fd’: Permission denied
                      find: ‘./proc/3157/task/3163/ns’: Permission denied
                      find: ‘./proc/3157/task/3164/fd’: Permission denied
                      find: ‘./proc/3157/task/3164/ns’: Permission denied
                      find: ‘./proc/3157/task/3165/fd’: Permission denied
                      find: ‘./proc/3157/task/3165/ns’: Permission denied
                      find: ‘./proc/3157/task/3166/fd’: Permission denied
                      find: ‘./proc/3157/task/3166/ns’: Permission denied
                      find: ‘./proc/3157/task/3167/fd’: Permission denied
                      find: ‘./proc/3157/task/3167/ns’: Permission denied
                      find: ‘./proc/3157/fd’: Permission denied
                      find: ‘./proc/3157/map_files’: Permission denied
                      find: ‘./proc/3157/ns’: Permission denied
                      find: ‘./proc/3168/task/3168/fd’: Permission denied
                      find: ‘./proc/3168/task/3168/ns’: Permission denied
                      find: ‘./proc/3168/task/3169/fd’: Permission denied
                      find: ‘./proc/3168/task/3169/ns’: Permission denied
                      find: ‘./proc/3168/task/3170/fd’: Permission denied
                      find: ‘./proc/3168/task/3170/ns’: Permission denied
                      find: ‘./proc/3168/task/3171/fd’: Permission denied
                      find: ‘./proc/3168/task/3171/ns’: Permission denied
                      find: ‘./proc/3168/task/3172/fd’: Permission denied
                      find: ‘./proc/3168/task/3172/ns’: Permission denied
                      find: ‘./proc/3168/task/3173/fd’: Permission denied
                      find: ‘./proc/3168/task/3173/ns’: Permission denied
                      find: ‘./proc/3168/task/3174/fd’: Permission denied
                      find: ‘./proc/3168/task/3174/ns’: Permission denied
                      find: ‘./proc/3168/task/3175/fd’: Permission denied
                      find: ‘./proc/3168/task/3175/ns’: Permission denied
                      find: ‘./proc/3168/task/3176/fd’: Permission denied
                      find: ‘./proc/3168/task/3176/ns’: Permission denied
                      find: ‘./proc/3168/task/3177/fd’: Permission denied
                      find: ‘./proc/3168/task/3177/ns’: Permission denied
                      find: ‘./proc/3168/task/3178/fd’: Permission denied
                      find: ‘./proc/3168/task/3178/ns’: Permission denied
                      find: ‘./proc/3168/fd’: Permission denied
                      find: ‘./proc/3168/map_files’: Permission denied
                      find: ‘./proc/3168/ns’: Permission denied
                      find: ‘./proc/3187/task/3187/fd’: Permission denied
                      find: ‘./proc/3187/task/3187/ns’: Permission denied
                      find: ‘./proc/3187/task/3188/fd’: Permission denied
                      find: ‘./proc/3187/task/3188/ns’: Permission denied
                      find: ‘./proc/3187/task/3189/fd’: Permission denied
                      find: ‘./proc/3187/task/3189/ns’: Permission denied
                      find: ‘./proc/3187/task/3190/fd’: Permission denied
                      find: ‘./proc/3187/task/3190/ns’: Permission denied
                      find: ‘./proc/3187/task/3191/fd’: Permission denied
                      find: ‘./proc/3187/task/3191/ns’: Permission denied
                      find: ‘./proc/3187/task/3192/fd’: Permission denied
                      find: ‘./proc/3187/task/3192/ns’: Permission denied
                      find: ‘./proc/3187/task/3193/fd’: Permission denied
                      find: ‘./proc/3187/task/3193/ns’: Permission denied
                      find: ‘./proc/3187/task/3207/fd’: Permission denied
                      find: ‘./proc/3187/task/3207/ns’: Permission denied
                      find: ‘./proc/3187/task/3208/fd’: Permission denied
                      find: ‘./proc/3187/task/3208/ns’: Permission denied
                      find: ‘./proc/3187/task/3209/fd’: Permission denied
                      find: ‘./proc/3187/task/3209/ns’: Permission denied
                      find: ‘./proc/3187/task/3210/fd’: Permission denied
                      find: ‘./proc/3187/task/3210/ns’: Permission denied
                      find: ‘./proc/3187/fd’: Permission denied
                      find: ‘./proc/3187/map_files’: Permission denied
                      find: ‘./proc/3187/ns’: Permission denied
                      find: ‘./proc/3201/task/3201/fd’: Permission denied
                      find: ‘./proc/3201/task/3201/ns’: Permission denied
                      find: ‘./proc/3201/task/3202/fd’: Permission denied
                      find: ‘./proc/3201/task/3202/ns’: Permission denied
                      find: ‘./proc/3201/task/3203/fd’: Permission denied
                      find: ‘./proc/3201/task/3203/ns’: Permission denied
                      find: ‘./proc/3201/task/3204/fd’: Permission denied
                      find: ‘./proc/3201/task/3204/ns’: Permission denied
                      find: ‘./proc/3201/task/3205/fd’: Permission denied
                      find: ‘./proc/3201/task/3205/ns’: Permission denied
                      find: ‘./proc/3201/task/3206/fd’: Permission denied
                      find: ‘./proc/3201/task/3206/ns’: Permission denied
                      find: ‘./proc/3201/task/3211/fd’: Permission denied
                      find: ‘./proc/3201/task/3211/ns’: Permission denied
                      find: ‘./proc/3201/task/3224/fd’: Permission denied
                      find: ‘./proc/3201/task/3224/ns’: Permission denied
                      find: ‘./proc/3201/task/3225/fd’: Permission denied
                      find: ‘./proc/3201/task/3225/ns’: Permission denied
                      find: ‘./proc/3201/task/3226/fd’: Permission denied
                      find: ‘./proc/3201/task/3226/ns’: Permission denied
                      find: ‘./proc/3201/task/3227/fd’: Permission denied
                      find: ‘./proc/3201/task/3227/ns’: Permission denied
                      find: ‘./proc/3201/fd’: Permission denied
                      find: ‘./proc/3201/map_files’: Permission denied
                      find: ‘./proc/3201/ns’: Permission denied
                      find: ‘./proc/3228/task/3228/fd’: Permission denied
                      find: ‘./proc/3228/task/3228/ns’: Permission denied
                      find: ‘./proc/3228/task/3229/fd’: Permission denied
                      find: ‘./proc/3228/task/3229/ns’: Permission denied
                      find: ‘./proc/3228/task/3230/fd’: Permission denied
                      find: ‘./proc/3228/task/3230/ns’: Permission denied
                      find: ‘./proc/3228/task/3231/fd’: Permission denied
                      find: ‘./proc/3228/task/3231/ns’: Permission denied
                      find: ‘./proc/3228/task/3232/fd’: Permission denied
                      find: ‘./proc/3228/task/3232/ns’: Permission denied
                      find: ‘./proc/3228/task/3233/fd’: Permission denied
                      find: ‘./proc/3228/task/3233/ns’: Permission denied
                      find: ‘./proc/3228/task/3234/fd’: Permission denied
                      find: ‘./proc/3228/task/3234/ns’: Permission denied
                      find: ‘./proc/3228/task/3249/fd’: Permission denied
                      find: ‘./proc/3228/task/3249/ns’: Permission denied
                      find: ‘./proc/3228/task/3250/fd’: Permission denied
                      find: ‘./proc/3228/task/3250/ns’: Permission denied
                      find: ‘./proc/3228/task/3251/fd’: Permission denied
                      find: ‘./proc/3228/task/3251/ns’: Permission denied
                      find: ‘./proc/3228/task/3252/fd’: Permission denied
                      find: ‘./proc/3228/task/3252/ns’: Permission denied
                      find: ‘./proc/3228/fd’: Permission denied
                      find: ‘./proc/3228/map_files’: Permission denied
                      find: ‘./proc/3228/ns’: Permission denied
                      find: ‘./proc/3235/task/3235/fd’: Permission denied
                      find: ‘./proc/3235/task/3235/ns’: Permission denied
                      find: ‘./proc/3235/task/3236/fd’: Permission denied
                      find: ‘./proc/3235/task/3236/ns’: Permission denied
                      find: ‘./proc/3235/task/3237/fd’: Permission denied
                      find: ‘./proc/3235/task/3237/ns’: Permission denied
                      find: ‘./proc/3235/task/3238/fd’: Permission denied
                      find: ‘./proc/3235/task/3238/ns’: Permission denied
                      find: ‘./proc/3235/task/3239/fd’: Permission denied
                      find: ‘./proc/3235/task/3239/ns’: Permission denied
                      find: ‘./proc/3235/task/3240/fd’: Permission denied
                      find: ‘./proc/3235/task/3240/ns’: Permission denied
                      find: ‘./proc/3235/task/3242/fd’: Permission denied
                      find: ‘./proc/3235/task/3242/ns’: Permission denied
                      find: ‘./proc/3235/task/3253/fd’: Permission denied
                      find: ‘./proc/3235/task/3253/ns’: Permission denied
                      find: ‘./proc/3235/task/3254/fd’: Permission denied
                      find: ‘./proc/3235/task/3254/ns’: Permission denied
                      find: ‘./proc/3235/task/3255/fd’: Permission denied
                      find: ‘./proc/3235/task/3255/ns’: Permission denied
                      find: ‘./proc/3235/task/3256/fd’: Permission denied
                      find: ‘./proc/3235/task/3256/ns’: Permission denied
                      find: ‘./proc/3235/fd’: Permission denied
                      find: ‘./proc/3235/map_files’: Permission denied
                      find: ‘./proc/3235/ns’: Permission denied
                      find: ‘./proc/3241/task/3241/fd’: Permission denied
                      find: ‘./proc/3241/task/3241/ns’: Permission denied
                      find: ‘./proc/3241/task/3243/fd’: Permission denied
                      find: ‘./proc/3241/task/3243/ns’: Permission denied
                      find: ‘./proc/3241/task/3244/fd’: Permission denied
                      find: ‘./proc/3241/task/3244/ns’: Permission denied
                      find: ‘./proc/3241/task/3245/fd’: Permission denied
                      find: ‘./proc/3241/task/3245/ns’: Permission denied
                      find: ‘./proc/3241/task/3246/fd’: Permission denied
                      find: ‘./proc/3241/task/3246/ns’: Permission denied
                      find: ‘./proc/3241/task/3247/fd’: Permission denied
                      find: ‘./proc/3241/task/3247/ns’: Permission denied
                      find: ‘./proc/3241/task/3248/fd’: Permission denied
                      find: ‘./proc/3241/task/3248/ns’: Permission denied
                      find: ‘./proc/3241/task/3257/fd’: Permission denied
                      find: ‘./proc/3241/task/3257/ns’: Permission denied
                      find: ‘./proc/3241/task/3258/fd’: Permission denied
                      find: ‘./proc/3241/task/3258/ns’: Permission denied
                      find: ‘./proc/3241/task/3259/fd’: Permission denied
                      find: ‘./proc/3241/task/3259/ns’: Permission denied
                      find: ‘./proc/3241/task/3260/fd’: Permission denied
                      find: ‘./proc/3241/task/3260/ns’: Permission denied
                      find: ‘./proc/3241/fd’: Permission denied
                      find: ‘./proc/3241/map_files’: Permission denied
                      find: ‘./proc/3241/ns’: Permission denied
                      find: ‘./proc/3261/task/3261/fd’: Permission denied
                      find: ‘./proc/3261/task/3261/ns’: Permission denied
                      find: ‘./proc/3261/task/3262/fd’: Permission denied
                      find: ‘./proc/3261/task/3262/ns’: Permission denied
                      find: ‘./proc/3261/task/3263/fd’: Permission denied
                      find: ‘./proc/3261/task/3263/ns’: Permission denied
                      find: ‘./proc/3261/task/3264/fd’: Permission denied
                      find: ‘./proc/3261/task/3264/ns’: Permission denied
                      find: ‘./proc/3261/task/3265/fd’: Permission denied
                      find: ‘./proc/3261/task/3265/ns’: Permission denied
                      find: ‘./proc/3261/task/3266/fd’: Permission denied
                      find: ‘./proc/3261/task/3266/ns’: Permission denied
                      find: ‘./proc/3261/task/3267/fd’: Permission denied
                      find: ‘./proc/3261/task/3267/ns’: Permission denied
                      find: ‘./proc/3261/task/3268/fd’: Permission denied
                      find: ‘./proc/3261/task/3268/ns’: Permission denied
                      find: ‘./proc/3261/task/3269/fd’: Permission denied
                      find: ‘./proc/3261/task/3269/ns’: Permission denied
                      find: ‘./proc/3261/task/3270/fd’: Permission denied
                      find: ‘./proc/3261/task/3270/ns’: Permission denied
                      find: ‘./proc/3261/task/3271/fd’: Permission denied
                      find: ‘./proc/3261/task/3271/ns’: Permission denied
                      find: ‘./proc/3261/fd’: Permission denied
                      find: ‘./proc/3261/map_files’: Permission denied
                      find: ‘./proc/3261/ns’: Permission denied
                      find: ‘./proc/3274/task/3274/fd’: Permission denied
                      find: ‘./proc/3274/task/3274/ns’: Permission denied
                      find: ‘./proc/3274/task/3275/fd’: Permission denied
                      find: ‘./proc/3274/task/3275/ns’: Permission denied
                      find: ‘./proc/3274/task/3276/fd’: Permission denied
                      find: ‘./proc/3274/task/3276/ns’: Permission denied
                      find: ‘./proc/3274/task/3277/fd’: Permission denied
                      find: ‘./proc/3274/task/3277/ns’: Permission denied
                      find: ‘./proc/3274/task/3278/fd’: Permission denied
                      find: ‘./proc/3274/task/3278/ns’: Permission denied
                      find: ‘./proc/3274/task/3279/fd’: Permission denied
                      find: ‘./proc/3274/task/3279/ns’: Permission denied
                      find: ‘./proc/3274/task/3280/fd’: Permission denied
                      find: ‘./proc/3274/task/3280/ns’: Permission denied
                      find: ‘./proc/3274/task/3296/fd’: Permission denied
                      find: ‘./proc/3274/task/3296/ns’: Permission denied
                      find: ‘./proc/3274/task/3297/fd’: Permission denied
                      find: ‘./proc/3274/task/3297/ns’: Permission denied
                      find: ‘./proc/3274/task/3298/fd’: Permission denied
                      find: ‘./proc/3274/task/3298/ns’: Permission denied
                      find: ‘./proc/3274/task/3299/fd’: Permission denied
                      find: ‘./proc/3274/task/3299/ns’: Permission denied
                      find: ‘./proc/3274/fd’: Permission denied
                      find: ‘./proc/3274/map_files’: Permission denied
                      find: ‘./proc/3274/ns’: Permission denied
                      find: ‘./proc/3300/task/3300/fd’: Permission denied
                      find: ‘./proc/3300/task/3300/ns’: Permission denied
                      find: ‘./proc/3300/task/3301/fd’: Permission denied
                      find: ‘./proc/3300/task/3301/ns’: Permission denied
                      find: ‘./proc/3300/task/3302/fd’: Permission denied
                      find: ‘./proc/3300/task/3302/ns’: Permission denied
                      find: ‘./proc/3300/task/3303/fd’: Permission denied
                      find: ‘./proc/3300/task/3303/ns’: Permission denied
                      find: ‘./proc/3300/task/3304/fd’: Permission denied
                      find: ‘./proc/3300/task/3304/ns’: Permission denied
                      find: ‘./proc/3300/task/3305/fd’: Permission denied
                      find: ‘./proc/3300/task/3305/ns’: Permission denied
                      find: ‘./proc/3300/task/3306/fd’: Permission denied
                      find: ‘./proc/3300/task/3306/ns’: Permission denied
                      find: ‘./proc/3300/task/3307/fd’: Permission denied
                      find: ‘./proc/3300/task/3307/ns’: Permission denied
                      find: ‘./proc/3300/task/3308/fd’: Permission denied
                      find: ‘./proc/3300/task/3308/ns’: Permission denied
                      find: ‘./proc/3300/task/3309/fd’: Permission denied
                      find: ‘./proc/3300/task/3309/ns’: Permission denied
                      find: ‘./proc/3300/task/3310/fd’: Permission denied
                      find: ‘./proc/3300/task/3310/ns’: Permission denied
                      find: ‘./proc/3300/fd’: Permission denied
                      find: ‘./proc/3300/map_files’: Permission denied
                      find: ‘./proc/3300/ns’: Permission denied
                      find: ‘./proc/3311/task/3311/fd’: Permission denied
                      find: ‘./proc/3311/task/3311/ns’: Permission denied
                      find: ‘./proc/3311/task/3312/fd’: Permission denied
                      find: ‘./proc/3311/task/3312/ns’: Permission denied
                      find: ‘./proc/3311/task/3313/fd’: Permission denied
                      find: ‘./proc/3311/task/3313/ns’: Permission denied
                      find: ‘./proc/3311/task/3314/fd’: Permission denied
                      find: ‘./proc/3311/task/3314/ns’: Permission denied
                      find: ‘./proc/3311/task/3315/fd’: Permission denied
                      find: ‘./proc/3311/task/3315/ns’: Permission denied
                      find: ‘./proc/3311/task/3316/fd’: Permission denied
                      find: ‘./proc/3311/task/3316/ns’: Permission denied
                      find: ‘./proc/3311/task/3317/fd’: Permission denied
                      find: ‘./proc/3311/task/3317/ns’: Permission denied
                      find: ‘./proc/3311/task/3325/fd’: Permission denied
                      find: ‘./proc/3311/task/3325/ns’: Permission denied
                      find: ‘./proc/3311/task/3326/fd’: Permission denied
                      find: ‘./proc/3311/task/3326/ns’: Permission denied
                      find: ‘./proc/3311/task/3327/fd’: Permission denied
                      find: ‘./proc/3311/task/3327/ns’: Permission denied
                      find: ‘./proc/3311/task/3328/fd’: Permission denied
                      find: ‘./proc/3311/task/3328/ns’: Permission denied
                      find: ‘./proc/3311/fd’: Permission denied
                      find: ‘./proc/3311/map_files’: Permission denied
                      find: ‘./proc/3311/ns’: Permission denied
                      find: ‘./proc/3318/task/3318/fd’: Permission denied
                      find: ‘./proc/3318/task/3318/ns’: Permission denied
                      find: ‘./proc/3318/task/3319/fd’: Permission denied
                      find: ‘./proc/3318/task/3319/ns’: Permission denied
                      find: ‘./proc/3318/task/3320/fd’: Permission denied
                      find: ‘./proc/3318/task/3320/ns’: Permission denied
                      find: ‘./proc/3318/task/3321/fd’: Permission denied
                      find: ‘./proc/3318/task/3321/ns’: Permission denied
                      find: ‘./proc/3318/task/3322/fd’: Permission denied
                      find: ‘./proc/3318/task/3322/ns’: Permission denied
                      find: ‘./proc/3318/task/3323/fd’: Permission denied
                      find: ‘./proc/3318/task/3323/ns’: Permission denied
                      find: ‘./proc/3318/task/3324/fd’: Permission denied
                      find: ‘./proc/3318/task/3324/ns’: Permission denied
                      find: ‘./proc/3318/task/3329/fd’: Permission denied
                      find: ‘./proc/3318/task/3329/ns’: Permission denied
                      find: ‘./proc/3318/task/3330/fd’: Permission denied
                      find: ‘./proc/3318/task/3330/ns’: Permission denied
                      find: ‘./proc/3318/task/3331/fd’: Permission denied
                      find: ‘./proc/3318/task/3331/ns’: Permission denied
                      find: ‘./proc/3318/task/3332/fd’: Permission denied
                      find: ‘./proc/3318/task/3332/ns’: Permission denied
                      find: ‘./proc/3318/fd’: Permission denied
                      find: ‘./proc/3318/map_files’: Permission denied
                      find: ‘./proc/3318/ns’: Permission denied
                      find: ‘./proc/3333/task/3333/fd’: Permission denied
                      find: ‘./proc/3333/task/3333/ns’: Permission denied
                      find: ‘./proc/3333/task/3334/fd’: Permission denied
                      find: ‘./proc/3333/task/3334/ns’: Permission denied
                      find: ‘./proc/3333/task/3335/fd’: Permission denied
                      find: ‘./proc/3333/task/3335/ns’: Permission denied
                      find: ‘./proc/3333/task/3336/fd’: Permission denied
                      find: ‘./proc/3333/task/3336/ns’: Permission denied
                      find: ‘./proc/3333/task/3337/fd’: Permission denied
                      find: ‘./proc/3333/task/3337/ns’: Permission denied
                      find: ‘./proc/3333/task/3338/fd’: Permission denied
                      find: ‘./proc/3333/task/3338/ns’: Permission denied
                      find: ‘./proc/3333/task/3339/fd’: Permission denied
                      find: ‘./proc/3333/task/3339/ns’: Permission denied
                      find: ‘./proc/3333/task/3355/fd’: Permission denied
                      find: ‘./proc/3333/task/3355/ns’: Permission denied
                      find: ‘./proc/3333/task/3356/fd’: Permission denied
                      find: ‘./proc/3333/task/3356/ns’: Permission denied
                      find: ‘./proc/3333/task/3357/fd’: Permission denied
                      find: ‘./proc/3333/task/3357/ns’: Permission denied
                      find: ‘./proc/3333/task/3358/fd’: Permission denied
                      find: ‘./proc/3333/task/3358/ns’: Permission denied
                      find: ‘./proc/3333/fd’: Permission denied
                      find: ‘./proc/3333/map_files’: Permission denied
                      find: ‘./proc/3333/ns’: Permission denied
                      find: ‘./proc/3340/task/3340/fd’: Permission denied
                      find: ‘./proc/3340/task/3340/ns’: Permission denied
                      find: ‘./proc/3340/task/3341/fd’: Permission denied
                      find: ‘./proc/3340/task/3341/ns’: Permission denied
                      find: ‘./proc/3340/task/3342/fd’: Permission denied
                      find: ‘./proc/3340/task/3342/ns’: Permission denied
                      find: ‘./proc/3340/task/3343/fd’: Permission denied
                      find: ‘./proc/3340/task/3343/ns’: Permission denied
                      find: ‘./proc/3340/task/3344/fd’: Permission denied
                      find: ‘./proc/3340/task/3344/ns’: Permission denied
                      find: ‘./proc/3340/task/3345/fd’: Permission denied
                      find: ‘./proc/3340/task/3345/ns’: Permission denied
                      find: ‘./proc/3340/task/3346/fd’: Permission denied
                      find: ‘./proc/3340/task/3346/ns’: Permission denied
                      find: ‘./proc/3340/task/3359/fd’: Permission denied
                      find: ‘./proc/3340/task/3359/ns’: Permission denied
                      find: ‘./proc/3340/task/3360/fd’: Permission denied
                      find: ‘./proc/3340/task/3360/ns’: Permission denied
                      find: ‘./proc/3340/task/3361/fd’: Permission denied
                      find: ‘./proc/3340/task/3361/ns’: Permission denied
                      find: ‘./proc/3340/task/3362/fd’: Permission denied
                      find: ‘./proc/3340/task/3362/ns’: Permission denied
                      find: ‘./proc/3340/fd’: Permission denied
                      find: ‘./proc/3340/map_files’: Permission denied
                      find: ‘./proc/3340/ns’: Permission denied
                      find: ‘./proc/3363/task/3363/fd’: Permission denied
                      find: ‘./proc/3363/task/3363/ns’: Permission denied
                      find: ‘./proc/3363/task/3364/fd’: Permission denied
                      find: ‘./proc/3363/task/3364/ns’: Permission denied
                      find: ‘./proc/3363/task/3365/fd’: Permission denied
                      find: ‘./proc/3363/task/3365/ns’: Permission denied
                      find: ‘./proc/3363/task/3366/fd’: Permission denied
                      find: ‘./proc/3363/task/3366/ns’: Permission denied
                      find: ‘./proc/3363/task/3367/fd’: Permission denied
                      find: ‘./proc/3363/task/3367/ns’: Permission denied
                      find: ‘./proc/3363/task/3368/fd’: Permission denied
                      find: ‘./proc/3363/task/3368/ns’: Permission denied
                      find: ‘./proc/3363/task/3369/fd’: Permission denied
                      find: ‘./proc/3363/task/3369/ns’: Permission denied
                      find: ‘./proc/3363/task/3370/fd’: Permission denied
                      find: ‘./proc/3363/task/3370/ns’: Permission denied
                      find: ‘./proc/3363/task/3371/fd’: Permission denied
                      find: ‘./proc/3363/task/3371/ns’: Permission denied
                      find: ‘./proc/3363/task/3372/fd’: Permission denied
                      find: ‘./proc/3363/task/3372/ns’: Permission denied
                      find: ‘./proc/3363/task/3373/fd’: Permission denied
                      find: ‘./proc/3363/task/3373/ns’: Permission denied
                      find: ‘./proc/3363/fd’: Permission denied
                      find: ‘./proc/3363/map_files’: Permission denied
                      find: ‘./proc/3363/ns’: Permission denied
                      find: ‘./proc/3381/task/3381/fd’: Permission denied
                      find: ‘./proc/3381/task/3381/ns’: Permission denied
                      find: ‘./proc/3381/task/3382/fd’: Permission denied
                      find: ‘./proc/3381/task/3382/ns’: Permission denied
                      find: ‘./proc/3381/task/3383/fd’: Permission denied
                      find: ‘./proc/3381/task/3383/ns’: Permission denied
                      find: ‘./proc/3381/task/3384/fd’: Permission denied
                      find: ‘./proc/3381/task/3384/ns’: Permission denied
                      find: ‘./proc/3381/task/3385/fd’: Permission denied
                      find: ‘./proc/3381/task/3385/ns’: Permission denied
                      find: ‘./proc/3381/task/3386/fd’: Permission denied
                      find: ‘./proc/3381/task/3386/ns’: Permission denied
                      find: ‘./proc/3381/task/3387/fd’: Permission denied
                      find: ‘./proc/3381/task/3387/ns’: Permission denied
                      find: ‘./proc/3381/task/3395/fd’: Permission denied
                      find: ‘./proc/3381/task/3395/ns’: Permission denied
                      find: ‘./proc/3381/task/3396/fd’: Permission denied
                      find: ‘./proc/3381/task/3396/ns’: Permission denied
                      find: ‘./proc/3381/task/3397/fd’: Permission denied
                      find: ‘./proc/3381/task/3397/ns’: Permission denied
                      find: ‘./proc/3381/task/3398/fd’: Permission denied
                      find: ‘./proc/3381/task/3398/ns’: Permission denied
                      find: ‘./proc/3381/fd’: Permission denied
                      find: ‘./proc/3381/map_files’: Permission denied
                      find: ‘./proc/3381/ns’: Permission denied
                      find: ‘./proc/3414/task/3414/fd’: Permission denied
                      find: ‘./proc/3414/task/3414/ns’: Permission denied
                      find: ‘./proc/3414/task/3415/fd’: Permission denied
                      find: ‘./proc/3414/task/3415/ns’: Permission denied
                      find: ‘./proc/3414/task/3416/fd’: Permission denied
                      find: ‘./proc/3414/task/3416/ns’: Permission denied
                      find: ‘./proc/3414/task/3417/fd’: Permission denied
                      find: ‘./proc/3414/task/3417/ns’: Permission denied
                      find: ‘./proc/3414/task/3418/fd’: Permission denied
                      find: ‘./proc/3414/task/3418/ns’: Permission denied
                      find: ‘./proc/3414/task/3419/fd’: Permission denied
                      find: ‘./proc/3414/task/3419/ns’: Permission denied
                      find: ‘./proc/3414/task/3424/fd’: Permission denied
                      find: ‘./proc/3414/task/3424/ns’: Permission denied
                      find: ‘./proc/3414/task/3429/fd’: Permission denied
                      find: ‘./proc/3414/task/3429/ns’: Permission denied
                      find: ‘./proc/3414/task/3430/fd’: Permission denied
                      find: ‘./proc/3414/task/3430/ns’: Permission denied
                      find: ‘./proc/3414/task/3431/fd’: Permission denied
                      find: ‘./proc/3414/task/3431/ns’: Permission denied
                      find: ‘./proc/3414/task/3432/fd’: Permission denied
                      find: ‘./proc/3414/task/3432/ns’: Permission denied
                      find: ‘./proc/3414/fd’: Permission denied
                      find: ‘./proc/3414/map_files’: Permission denied
                      find: ‘./proc/3414/ns’: Permission denied
                      find: ‘./proc/3446/task/3446/fd’: Permission denied
                      find: ‘./proc/3446/task/3446/ns’: Permission denied
                      find: ‘./proc/3446/task/3447/fd’: Permission denied
                      find: ‘./proc/3446/task/3447/ns’: Permission denied
                      find: ‘./proc/3446/task/3448/fd’: Permission denied
                      find: ‘./proc/3446/task/3448/ns’: Permission denied
                      find: ‘./proc/3446/task/3449/fd’: Permission denied
                      find: ‘./proc/3446/task/3449/ns’: Permission denied
                      find: ‘./proc/3446/task/3450/fd’: Permission denied
                      find: ‘./proc/3446/task/3450/ns’: Permission denied
                      find: ‘./proc/3446/task/3451/fd’: Permission denied
                      find: ‘./proc/3446/task/3451/ns’: Permission denied
                      find: ‘./proc/3446/task/3452/fd’: Permission denied
                      find: ‘./proc/3446/task/3452/ns’: Permission denied
                      find: ‘./proc/3446/task/3453/fd’: Permission denied
                      find: ‘./proc/3446/task/3453/ns’: Permission denied
                      find: ‘./proc/3446/task/3454/fd’: Permission denied
                      find: ‘./proc/3446/task/3454/ns’: Permission denied
                      find: ‘./proc/3446/task/3455/fd’: Permission denied
                      find: ‘./proc/3446/task/3455/ns’: Permission denied
                      find: ‘./proc/3446/task/3456/fd’: Permission denied
                      find: ‘./proc/3446/task/3456/ns’: Permission denied
                      find: ‘./proc/3446/fd’: Permission denied
                      find: ‘./proc/3446/map_files’: Permission denied
                      find: ‘./proc/3446/ns’: Permission denied
                      find: ‘./proc/3467/task/3467/fd’: Permission denied
                      find: ‘./proc/3467/task/3467/ns’: Permission denied
                      find: ‘./proc/3467/task/3468/fd’: Permission denied
                      find: ‘./proc/3467/task/3468/ns’: Permission denied
                      find: ‘./proc/3467/task/3469/fd’: Permission denied
                      find: ‘./proc/3467/task/3469/ns’: Permission denied
                      find: ‘./proc/3467/task/3470/fd’: Permission denied
                      find: ‘./proc/3467/task/3470/ns’: Permission denied
                      find: ‘./proc/3467/task/3471/fd’: Permission denied
                      find: ‘./proc/3467/task/3471/ns’: Permission denied
                      find: ‘./proc/3467/task/3472/fd’: Permission denied
                      find: ‘./proc/3467/task/3472/ns’: Permission denied
                      find: ‘./proc/3467/task/3473/fd’: Permission denied
                      find: ‘./proc/3467/task/3473/ns’: Permission denied
                      find: ‘./proc/3467/task/3526/fd’: Permission denied
                      find: ‘./proc/3467/task/3526/ns’: Permission denied
                      find: ‘./proc/3467/task/3527/fd’: Permission denied
                      find: ‘./proc/3467/task/3527/ns’: Permission denied
                      find: ‘./proc/3467/task/3528/fd’: Permission denied
                      find: ‘./proc/3467/task/3528/ns’: Permission denied
                      find: ‘./proc/3467/task/3529/fd’: Permission denied
                      find: ‘./proc/3467/task/3529/ns’: Permission denied
                      find: ‘./proc/3467/fd’: Permission denied
                      find: ‘./proc/3467/map_files’: Permission denied
                      find: ‘./proc/3467/ns’: Permission denied
                      find: ‘./proc/3568/task/3568/fd’: Permission denied
                      find: ‘./proc/3568/task/3568/ns’: Permission denied
                      find: ‘./proc/3568/task/3575/fd’: Permission denied
                      find: ‘./proc/3568/task/3575/ns’: Permission denied
                      find: ‘./proc/3568/task/3576/fd’: Permission denied
                      find: ‘./proc/3568/task/3576/ns’: Permission denied
                      find: ‘./proc/3568/task/3577/fd’: Permission denied
                      find: ‘./proc/3568/task/3577/ns’: Permission denied
                      find: ‘./proc/3568/task/3578/fd’: Permission denied
                      find: ‘./proc/3568/task/3578/ns’: Permission denied
                      find: ‘./proc/3568/task/3579/fd’: Permission denied
                      find: ‘./proc/3568/task/3579/ns’: Permission denied
                      find: ‘./proc/3568/task/3580/fd’: Permission denied
                      find: ‘./proc/3568/task/3580/ns’: Permission denied
                      find: ‘./proc/3568/task/3598/fd’: Permission denied
                      find: ‘./proc/3568/task/3598/ns’: Permission denied
                      find: ‘./proc/3568/task/3599/fd’: Permission denied
                      find: ‘./proc/3568/task/3599/ns’: Permission denied
                      find: ‘./proc/3568/task/3600/fd’: Permission denied
                      find: ‘./proc/3568/task/3600/ns’: Permission denied
                      find: ‘./proc/3568/task/3601/fd’: Permission denied
                      find: ‘./proc/3568/task/3601/ns’: Permission denied
                      find: ‘./proc/3568/fd’: Permission denied
                      find: ‘./proc/3568/map_files’: Permission denied
                      find: ‘./proc/3568/ns’: Permission denied
                      find: ‘./proc/3642/task/3642/fd’: Permission denied
                      find: ‘./proc/3642/task/3642/ns’: Permission denied
                      find: ‘./proc/3642/task/3643/fd’: Permission denied
                      find: ‘./proc/3642/task/3643/ns’: Permission denied
                      find: ‘./proc/3642/task/3644/fd’: Permission denied
                      find: ‘./proc/3642/task/3644/ns’: Permission denied
                      find: ‘./proc/3642/task/3645/fd’: Permission denied
                      find: ‘./proc/3642/task/3645/ns’: Permission denied
                      find: ‘./proc/3642/task/3646/fd’: Permission denied
                      find: ‘./proc/3642/task/3646/ns’: Permission denied
                      find: ‘./proc/3642/task/3647/fd’: Permission denied
                      find: ‘./proc/3642/task/3647/ns’: Permission denied
                      find: ‘./proc/3642/task/3648/fd’: Permission denied
                      find: ‘./proc/3642/task/3648/ns’: Permission denied
                      find: ‘./proc/3642/task/3650/fd’: Permission denied
                      find: ‘./proc/3642/task/3650/ns’: Permission denied
                      find: ‘./proc/3642/task/3651/fd’: Permission denied
                      find: ‘./proc/3642/task/3651/ns’: Permission denied
                      find: ‘./proc/3642/task/3652/fd’: Permission denied
                      find: ‘./proc/3642/task/3652/ns’: Permission denied
                      find: ‘./proc/3642/task/3653/fd’: Permission denied
                      find: ‘./proc/3642/task/3653/ns’: Permission denied
                      find: ‘./proc/3642/fd’: Permission denied
                      find: ‘./proc/3642/map_files’: Permission denied
                      find: ‘./proc/3642/ns’: Permission denied
                      find: ‘./proc/3687/task/3687/fd’: Permission denied
                      find: ‘./proc/3687/task/3687/ns’: Permission denied
                      find: ‘./proc/3687/task/3688/fd’: Permission denied
                      find: ‘./proc/3687/task/3688/ns’: Permission denied
                      find: ‘./proc/3687/task/3689/fd’: Permission denied
                      find: ‘./proc/3687/task/3689/ns’: Permission denied
                      find: ‘./proc/3687/task/3690/fd’: Permission denied
                      find: ‘./proc/3687/task/3690/ns’: Permission denied
                      find: ‘./proc/3687/task/3691/fd’: Permission denied
                      find: ‘./proc/3687/task/3691/ns’: Permission denied
                      find: ‘./proc/3687/task/3692/fd’: Permission denied
                      find: ‘./proc/3687/task/3692/ns’: Permission denied
                      find: ‘./proc/3687/task/3693/fd’: Permission denied
                      find: ‘./proc/3687/task/3693/ns’: Permission denied
                      find: ‘./proc/3687/task/3695/fd’: Permission denied
                      find: ‘./proc/3687/task/3695/ns’: Permission denied
                      find: ‘./proc/3687/task/3696/fd’: Permission denied
                      find: ‘./proc/3687/task/3696/ns’: Permission denied
                      find: ‘./proc/3687/task/3697/fd’: Permission denied
                      find: ‘./proc/3687/task/3697/ns’: Permission denied
                      find: ‘./proc/3687/task/3698/fd’: Permission denied
                      find: ‘./proc/3687/task/3698/ns’: Permission denied
                      find: ‘./proc/3687/fd’: Permission denied
                      find: ‘./proc/3687/map_files’: Permission denied
                      find: ‘./proc/3687/ns’: Permission denied
                      find: ‘./proc/3700/task/3700/fd’: Permission denied
                      find: ‘./proc/3700/task/3700/ns’: Permission denied
                      find: ‘./proc/3700/task/3701/fd’: Permission denied
                      find: ‘./proc/3700/task/3701/ns’: Permission denied
                      find: ‘./proc/3700/task/3702/fd’: Permission denied
                      find: ‘./proc/3700/task/3702/ns’: Permission denied
                      find: ‘./proc/3700/task/3703/fd’: Permission denied
                      find: ‘./proc/3700/task/3703/ns’: Permission denied
                      find: ‘./proc/3700/task/3704/fd’: Permission denied
                      find: ‘./proc/3700/task/3704/ns’: Permission denied
                      find: ‘./proc/3700/task/3705/fd’: Permission denied
                      find: ‘./proc/3700/task/3705/ns’: Permission denied
                      find: ‘./proc/3700/task/3706/fd’: Permission denied
                      find: ‘./proc/3700/task/3706/ns’: Permission denied
                      find: ‘./proc/3700/task/3707/fd’: Permission denied
                      find: ‘./proc/3700/task/3707/ns’: Permission denied
                      find: ‘./proc/3700/task/3708/fd’: Permission denied
                      find: ‘./proc/3700/task/3708/ns’: Permission denied
                      find: ‘./proc/3700/task/3709/fd’: Permission denied
                      find: ‘./proc/3700/task/3709/ns’: Permission denied
                      find: ‘./proc/3700/task/3710/fd’: Permission denied
                      find: ‘./proc/3700/task/3710/ns’: Permission denied
                      find: ‘./proc/3700/fd’: Permission denied
                      find: ‘./proc/3700/map_files’: Permission denied
                      find: ‘./proc/3700/ns’: Permission denied
                      find: ‘./proc/3711/task/3711/fd’: Permission denied
                      find: ‘./proc/3711/task/3711/ns’: Permission denied
                      find: ‘./proc/3711/task/3712/fd’: Permission denied
                      find: ‘./proc/3711/task/3712/ns’: Permission denied
                      find: ‘./proc/3711/task/3713/fd’: Permission denied
                      find: ‘./proc/3711/task/3713/ns’: Permission denied
                      find: ‘./proc/3711/task/3714/fd’: Permission denied
                      find: ‘./proc/3711/task/3714/ns’: Permission denied
                      find: ‘./proc/3711/task/3715/fd’: Permission denied
                      find: ‘./proc/3711/task/3715/ns’: Permission denied
                      find: ‘./proc/3711/task/3716/fd’: Permission denied
                      find: ‘./proc/3711/task/3716/ns’: Permission denied
                      find: ‘./proc/3711/task/3717/fd’: Permission denied
                      find: ‘./proc/3711/task/3717/ns’: Permission denied
                      find: ‘./proc/3711/task/3722/fd’: Permission denied
                      find: ‘./proc/3711/task/3722/ns’: Permission denied
                      find: ‘./proc/3711/task/3723/fd’: Permission denied
                      find: ‘./proc/3711/task/3723/ns’: Permission denied
                      find: ‘./proc/3711/task/3724/fd’: Permission denied
                      find: ‘./proc/3711/task/3724/ns’: Permission denied
                      find: ‘./proc/3711/task/3725/fd’: Permission denied
                      find: ‘./proc/3711/task/3725/ns’: Permission denied
                      find: ‘./proc/3711/fd’: Permission denied
                      find: ‘./proc/3711/map_files’: Permission denied
                      find: ‘./proc/3711/ns’: Permission denied
                      find: ‘./proc/22887/task/22887/fd’: Permission denied
                      find: ‘./proc/22887/task/22887/ns’: Permission denied
                      find: ‘./proc/22887/fd’: Permission denied
                      find: ‘./proc/22887/map_files’: Permission denied
                      find: ‘./proc/22887/ns’: Permission denied
                      find: ‘./proc/24479/task/24479/fd’: Permission denied
                      find: ‘./proc/24479/task/24479/ns’: Permission denied
                      find: ‘./proc/24479/fd’: Permission denied
                      find: ‘./proc/24479/map_files’: Permission denied
                      find: ‘./proc/24479/ns’: Permission denied
                      find: ‘./proc/24486/task/24486/fd’: Permission denied
                      find: ‘./proc/24486/task/24486/ns’: Permission denied
                      find: ‘./proc/24486/fd’: Permission denied
                      find: ‘./proc/24486/map_files’: Permission denied
                      find: ‘./proc/24486/ns’: Permission denied
                      find: ‘./proc/24506/task/24506/fd’: Permission denied
                      find: ‘./proc/24506/task/24506/ns’: Permission denied
                      find: ‘./proc/24506/fd’: Permission denied
                      find: ‘./proc/24506/map_files’: Permission denied
                      find: ‘./proc/24506/ns’: Permission denied
                      find: ‘./proc/26263/task/26263/fd’: Permission denied
                      find: ‘./proc/26263/task/26263/ns’: Permission denied
                      find: ‘./proc/26263/fd’: Permission denied
                      find: ‘./proc/26263/map_files’: Permission denied
                      find: ‘./proc/26263/ns’: Permission denied
                      find: ‘./proc/27446/task/27446/fd’: Permission denied
                      find: ‘./proc/27446/task/27446/ns’: Permission denied
                      find: ‘./proc/27446/fd’: Permission denied
                      find: ‘./proc/27446/map_files’: Permission denied
                      find: ‘./proc/27446/ns’: Permission denied
                      find: ‘./proc/27802/task/27802/fd’: Permission denied
                      find: ‘./proc/27802/task/27802/ns’: Permission denied
                      find: ‘./proc/27802/fd’: Permission denied
                      find: ‘./proc/27802/map_files’: Permission denied
                      find: ‘./proc/27802/ns’: Permission denied
                      find: ‘./proc/28022/task/28022/fd’: Permission denied
                      find: ‘./proc/28022/task/28022/ns’: Permission denied
                      find: ‘./proc/28022/fd’: Permission denied
                      find: ‘./proc/28022/map_files’: Permission denied
                      find: ‘./proc/28022/ns’: Permission denied
                      find: ‘./proc/28214/task/28214/fd’: Permission denied
                      find: ‘./proc/28214/task/28214/ns’: Permission denied
                      find: ‘./proc/28214/fd’: Permission denied
                      find: ‘./proc/28214/map_files’: Permission denied
                      find: ‘./proc/28214/ns’: Permission denied
                      find: ‘./proc/28847/task/28847/fd’: Permission denied
                      find: ‘./proc/28847/task/28847/ns’: Permission denied
                      find: ‘./proc/28847/fd’: Permission denied
                      find: ‘./proc/28847/map_files’: Permission denied
                      find: ‘./proc/28847/ns’: Permission denied
                      find: ‘./proc/28878/task/28878/fd’: Permission denied
                      find: ‘./proc/28878/task/28878/ns’: Permission denied
                      find: ‘./proc/28878/fd’: Permission denied
                      find: ‘./proc/28878/map_files’: Permission denied
                      find: ‘./proc/28878/ns’: Permission denied
                      find: ‘./proc/29019/task/29019/fd’: Permission denied
                      find: ‘./proc/29019/task/29019/ns’: Permission denied
                      find: ‘./proc/29019/fd’: Permission denied
                      find: ‘./proc/29019/map_files’: Permission denied
                      find: ‘./proc/29019/ns’: Permission denied
                      find: ‘./proc/29102/task/29102/fd’: Permission denied
                      find: ‘./proc/29102/task/29102/ns’: Permission denied
                      find: ‘./proc/29102/fd’: Permission denied
                      find: ‘./proc/29102/map_files’: Permission denied
                      find: ‘./proc/29102/ns’: Permission denied
                      find: ‘./proc/29310/task/29310/fd’: Permission denied
                      find: ‘./proc/29310/task/29310/ns’: Permission denied
                      find: ‘./proc/29310/fd’: Permission denied
                      find: ‘./proc/29310/map_files’: Permission denied
                      find: ‘./proc/29310/ns’: Permission denied
                      find: ‘./proc/29412/task/29412/fd’: Permission denied
                      find: ‘./proc/29412/task/29412/ns’: Permission denied
                      find: ‘./proc/29412/fd’: Permission denied
                      find: ‘./proc/29412/map_files’: Permission denied
                      find: ‘./proc/29412/ns’: Permission denied
                      find: ‘./proc/29414/task/29414/fd’: Permission denied
                      find: ‘./proc/29414/task/29414/ns’: Permission denied
                      find: ‘./proc/29414/fd’: Permission denied
                      find: ‘./proc/29414/map_files’: Permission denied
                      find: ‘./proc/29414/ns’: Permission denied
                      find: ‘./proc/29428/task/29428/fd’: Permission denied
                      find: ‘./proc/29428/task/29428/ns’: Permission denied
                      find: ‘./proc/29428/fd’: Permission denied
                      find: ‘./proc/29428/map_files’: Permission denied
                      find: ‘./proc/29428/ns’: Permission denied
                      find: ‘./home/iobroker/.config’: Permission denied
                      find: ‘./home/iobroker/.cache/esbuild’: Permission denied
                      find: ‘./lost+found’: Permission denied
                      find: ‘./var/cache/ldconfig’: Permission denied
                      find: ‘./var/cache/apt/archives/partial’: Permission denied
                      find: ‘./var/cache/private’: Permission denied
                      ./var/log/grafana
                      find: ‘./var/log/private’: Permission denied
                      find: ‘./var/lib/apt/lists/partial’: Permission denied
                      find: ‘./var/lib/bluetooth’: Permission denied
                      ./var/lib/grafana
                      find: ‘./var/lib/grafana/plugins’: Permission denied
                      find: ‘./var/lib/grafana/csv’: Permission denied
                      find: ‘./var/lib/grafana/png’: Permission denied
                      find: ‘./var/lib/polkit-1’: Permission denied
                      find: ‘./var/lib/influxdb/wal’: Permission denied
                      find: ‘./var/lib/influxdb/data/iobroker’: Permission denied
                      find: ‘./var/lib/influxdb/data/_internal’: Permission denied
                      find: ‘./var/lib/udisks2’: Permission denied
                      find: ‘./var/lib/private’: Permission denied
                      find: ‘./var/tmp/systemd-private-063f955e078248caaf9323118d87b02c-systemd-timesyncd.service-f9omgi’: Permission denied
                      find: ‘./var/tmp/systemd-private-063f955e078248caaf9323118d87b02c-systemd-logind.service-M5meGg’: Permission denied
                      find: ‘./var/spool/cron/crontabs’: Permission denied
                      find: ‘./var/spool/rsyslog’: Permission denied
                      find: ‘./etc/ssl/private’: Permission denied
                      ./etc/grafana
                      find: ‘./etc/polkit-1/localauthority’: Permission denied
                      find: ‘./tmp/systemd-private-063f955e078248caaf9323118d87b02c-systemd-timesyncd.service-8zgQnh’: Permission denied
                      find: ‘./tmp/systemd-private-063f955e078248caaf9323118d87b02c-systemd-logind.service-TmEDDg’: Permission denied
                      pi@homebridge:/ $
                      Ab Zeile 998 kommt was mit Grafana
                        @damrak2022
                        Die üblichen Verzeichnisse für eine übliche Installation.
                        Mir ist jetzt immer noch nicht klar, was du warum vor hast.
                        Damrak2022 crunchip 2 Replies Last reply Reply Quote 0
                        • Damrak2022
                          @thomas-braun Kurz und knapp, ich möchte Grafana für den Raspi installieren und vor allem wieder auf die Webseite kommen, was aber nicht gelingt weil 192.168.178.XX:3000 anzeigt: Der Server antwortet nicht
                          Das ist das primäre Ziel
                          Meine Anleitung ist diese: Grafana Installation
                            @damrak2022
                            Ist denn grafana jetzt wieder installiert?
                            Und läuft der Service?
                            systemctl status grafana-server
                              crunchip Forum Testing Most Active @Thomas Braun last edited by
                              @thomas-braun weil die ini nicht überschrieben wird und diese hat er vermurxt.
                              Somit kommt er nach einer Installation nicht mehr auf Grafana.
                              Diese .ini steht in '/etc/grafana'
                              Also entweder nur die 'grafana.ini' löschen oder gleich das ganze Verzeichnis '/etc/grafana/'
                              @Damrak2022
                              Grafana ist doch deinstalliert? Dann lösch mal die ini
                              sudo rm -f /etc/grafana/grafana.ini
                              Und dann machst du die Installation neu
                              • Damrak2022
                                @thomas-braun sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
                                pi@homebridge:/ $ systemctl status grafana-server
                                Warning: The unit file, source configuration file or drop-ins of grafana-server>
                                ● grafana-server.service - Grafana instance
                                     Loaded: loaded (/lib/systemd/system/grafana-server.service; bad; vendor pr>
                                     Active: failed (Result: exit-code) since Thu 2022-04-21 15:48:42 BST; 55mi>
                                       Docs: http://docs.grafana.org
                                    Process: 26119 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --p>
                                   Main PID: 26119 (code=exited, status=2)
                                        CPU: 301ms
                                Apr 21 15:48:42 homebridge systemd[1]: grafana-server.service: Scheduled restar>
                                Apr 21 15:48:42 homebridge systemd[1]: Stopped Grafana instance.
                                Apr 21 15:48:42 homebridge systemd[1]: grafana-server.service: Start request re>
                                Apr 21 15:48:42 homebridge systemd[1]: grafana-server.service: Failed with resu>
                                Apr 21 15:48:42 homebridge systemd[1]: Failed to start Grafana instance.
                                lines 1-14/14 (END)
                                Nein, denn eigentlich habe ich Grafana deinstalliert, weil ich ja nicht auf die Seite komme. Diesen Fehler hatte ich glaube ich heute Morgen um 04:00 Uhr auch schonmal. Ich weiß aber nicht wie ich diesen fixe
                                • Damrak2022
                                  @crunchip Ja, versuche ich. Habe ein Erfolgserlebnis dringend nötig
                                  • Damrak2022
                                    @damrak2022 Da kommt sofort der nächste Eingabe Prompt
                                    pi@homebridge:~ $ sudo rm -f /etc/grafana/grafana.ini
                                    pi@homebridge:~ $
                                    Ich vermute ich muss diese usr/share/grafana irgendwas löschen. Wie wäre da der korrekte Befehl?
                                      @damrak2022 na und jetzt installieren
                                      • Damrak2022
                                        @crunchip Gleich, gib mir bitte den richtigen Befehl für die andere .ini
                                        Suche gerade alles durch aber finde die Bezeichnung der anderen .ini nicht
                                          crunchip Forum Testing Most Active @Damrak2022 last edited by crunchip
                                          @damrak2022 du meinst https://forum.iobroker.net/post/793421
                                          Ich bin nur am Handy, musst du selbst abtippen 😉
                                          • Damrak2022
                                            @crunchip Das steht bei Chrome wenn ich versuche die Seite zu öffnen.
                                            143
                                            17839
