    4. [gelöst] ioB 120% Auslastung und no connection to database
      Kueppert @Thomas Braun last edited by Kueppert
      @thomas-braun arbeite wieder mit dem User, nicht mehr mit root. Werd ich ab sofort so handhaben 👍
      Reboot tut gut...hab ich auch gerade gemacht. Mal schauen was passiert...
      login as: thorsten
      thorsten@192.168.10.13's password:
      Linux ioBroker2 4.19.0-20-amd64 #1 SMP Debian 4.19.235-1 (2022-03-17) x86_64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Fri Apr 22 12:28:43 2022 from 192.168.1.42
      thorsten@ioBroker2:~$ iob status
      Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      Ausgabe TOP:
      Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
        apollon77 last edited by
        Also die jsonl. Files sind jetzt nicht riesig ...
        Bitte poste mal den Inhalt deiner /opt/iobroker/iobroker-data/iobroker.json
          Thomas Braun Most Active @Kueppert last edited by
          @kueppert sagte in ioBroker mit 120% Auslastung und no connection to database:
          lsof /opt/iobroker/iobroker-data/objects.jsonl
            Kueppert @apollon77 last edited by Kueppert
            @apollon77
              "system": {
                "memoryLimitMB": 0,
                "hostname": "",
                "statisticsInterval": 15000,
                "checkDiskInterval": 300000
              "multihostService": {
                "enabled": false,
                "secure": true,
                "password": "xxxxxxxxxxxxxxxxxx",
                "persist": false
              "network": {
                "IPv4": true,
                "IPv6": true,
                "bindAddress": null,
                "useSystemNpm": true
              "objects": {
                "type": "jsonl",
                "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379],
                "host": "127.0.0.1",
                "port": 9001,
                "user": "",
                "pass": "",
                "noFileCache": false,
                "connectTimeout": 2000,
                "options": {
                  "auth_pass": null,
                  "enableReadyCheck": true,
                  "host": "0.0.0.0",
                  "port": 9001,
                  "db": 0,
                  "family": 0,
                  "password": null,
                  "autoResubscribe": false,
                  "connectionName": "host.ioBroker2",
                  "retry_max_delay": 5000
                "maxQueue": 1000,
                "dataDir": "../../iobroker-data/"
              "states": {
                "type": "jsonl",
                "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379]
                "port": 9000,
                "maxQueue": 1000,
                "writeFileInterval": 300000,
                "options": {
                  "auth_pass": null,
                  "host": "0.0.0.0",
                  "port": 9000,
                  "db": 0,
                  "family": 0,
                  "password": null,
              "log": {
                "level": "warn",
                "maxDays": 7,
                "noStdout": true,
                "transport": {
                  "file1": {
                    "type": "file",
                    "enabled": true,
                    "filename": "log/iobroker",
                    "fileext": ".log",
                    "maxsize": null,
                    "maxFiles": null,
                    "maxSize": null,
                    "level": ""
                  "syslog1": {
                    "type": "syslog",
                    "enabled": true,
                    "host": "192.168.10.10",
                    "host_comment": "The host running syslogd, defaults to localhost.",
                    "port": "520",
                    "port_comment": "The port on the host that syslog is running on, default
                    "pid_comment": "PID of the process that log messages are coming from (De
                    "protocol": "udp4",
                    "protocol_comment": "The network protocol to log over (e.g. tcp4, udp4,
                    "path_comment": "The path to the syslog dgram socket (i.e. /dev/log or /
                    "facility_comment": "Syslog facility to use (Default: local0).",
                    "localhost": "iobroker",
                    "localhost_comment": "Host to indicate that log messages are coming from
                    "sysLogType": "5424",
                    "sysLogType_comment": "The type of the syslog protocol to use (Default:
                    "app_name_comment": "The name of the application (Default: process.title
                    "eol_comment": "The end of line character to be added to the end of the
                    "level": "warn",
                    "facility": "",
                    "app_name": "process.title"
              "dataDir": "../../iobroker-data/",
              "plugins": null
              "system": {
                "memoryLimitMB": 0,
                "hostname": "",
                "enabled": false,
                "secure": true,
                "password": "xxxxxxxxxxxxxxxxxxxx",
                "persist": false
              "network": {
                "IPv4": true,
                "IPv6": true,
              "objects": {
                "type": "jsonl",
                "port": 9001,
                "user": "",
                "pass": "",
                "options": {
                  "auth_pass": null,
                  "host": "0.0.0.0",
                  "port": 9001,
                  "db": 0,
                  "family": 0,
                  "password": null,
                "maxQueue": 1000,
              "states": {
                "type": "jsonl",
                "port": 9000,
                "maxQueue": 1000,
                "options": {
                  "auth_pass": null,
                  "host": "0.0.0.0",
                  "port": 9000,
                  "db": 0,
                  "family": 0,
                  "password": null,
              "log": {
                "level": "warn",
                "maxDays": 7,
                "noStdout": true,
                "transport": {
                  "file1": {
                    "type": "file",
                    "enabled": true,
                    "fileext": ".log",
                    "maxsize": null,
                    "maxFiles": null,
                    "maxSize": null,
                    "level": ""
                  "syslog1": {
                    "type": "syslog",
                    "enabled": true,
                    "port": "520",
                    "protocol": "udp4",
                    "level": "warn",
                    "facility": "",
              "plugins": null
              Homoran Global Moderator Administrators @Kueppert last edited by
              @kueppert
              wo ist hier ein BUG von ioBroker?
                @thomas-braun da passiert nix:
                thorsten@ioBroker2:~$ lsof /opt/iobroker/iobroker-data/objects.jsonl
                  Mit
                  sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                  sollte was kommen.
                    apollon77 @Kueppert last edited by
                    @kueppert Frage zum Top: Da läuft auch ein Redis server??? Wird scheinbar nicht genutzt
                    Ansonsten bitte mal iobroker stoppen und wirklich sicherstellen das er aus ist und ggf rozesse killen und dann bitte mal neu "iob status"
                      thorsten@ioBroker2:~$ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                      [sudo] Passwort für thorsten:
                      COMMAND   PID     USER   FD   TYPE DEVICE SIZE/OFF    NODE NAME
                      iobroker. 874 iobroker   19u   REG    8,1 51272289 1451506 /opt/iobroker/iobroker-data/objects.jsonl
                        @apollon77 für meine Begriffe (command spuckt nix aus) läuft da nix sonst?
                        thorsten@ioBroker2:~$ iobroker stop
                        thorsten@ioBroker2:~$ ps auxww|grep io
                        root        12  0.0  0.0      0     0 ?        S    12:30   0:00 [migration/0]
                        root        16  0.6  0.0      0     0 ?        S    12:30   0:05 [migration/1]
                        message+   377  0.1  0.0   8980  4168 ?        Ss   12:31   0:01 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                        thorsten   914  0.0  0.0   6084   892 pts/0    S+   12:45   0:00 grep io
                        den Redis-Server hab ich bewusst nie selbst installiert manuell...
                          @kueppert Und was sagt "iob status" jetzt?
                            @apollon77
                            No connection to databases possible ...
                              @kueppert
                              Der Hinweis von @apollon77 ist richtig. Wenn redis nicht (mehr) genutzt wird, weg damit.
                              apt policy redis
                              Ggf. deinstallieren.
                              sudo apt remove redis
                                @kueppert Ok, dann ändere bitte mal im iobroker.json die beiden
                                zu 30000
                                dann?
                                  thorsten@ioBroker2:~$ apt policy redis
                                  redis:
                                    Installiert:           (keine)
                                    Installationskandidat: 5:5.0.14-1+deb10u2
                                    Versionstabelle:
                                       5:5.0.14-1+deb10u2 500
                                          500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                                          500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                                  hab noch nicht deinstalliert - steht aber auch da wär nix installiert?
                                    In deinem top sieht man mit PID 422 einen redis-server Prozess.
                                    systemctl status redis-server
                                      @apollon77 hab nur ein connection-timeout gefunden?
                                      iobroker is not running on this host.
                                      Objects type: jsonl
                                      States  type: jsonl
                                        @thomas-braun sagte in ioBroker mit 120% Auslastung und no connection to database:
                                        thorsten@ioBroker2:~$ systemctl status redis-server
                                        ● redis-server.service - Advanced key-value store
                                           Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor pre
                                           Active: active (running) since Fri 2022-04-22 12:31:07 CEST; 23min ago
                                             Docs: http://redis.io/documentation,
                                                   man:redis-server(1)
                                          Process: 383 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exite
                                         Main PID: 422 (redis-server)
                                            Tasks: 4 (limit: 4915)
                                           Memory: 15.3M
                                           CGroup: /system.slice/redis-server.service
                                                   └─422 /usr/bin/redis-server 127.0.0.1:6379
                                        lines 1-11/11 (END)
                                        soll ich den Befehl zum deinstallieren nun ausführen? Redis nutze ich nicht
                                          @kueppert Ok, heisst das die Standard 5s nicht reichen das er die Files lesen kann ... da sist komisch ...
                                          Aber ok ...
                                          iob list instances ?
                                            @kueppert
                                            Bitte das Fenster des Terminals mal größer machen. Da fehlt rechts Text.
                                            sudo systemctl stop redis-server
                                            sudo systemctl disable redis-server
                                            3732
