    4. javascript.0 Fehlermeldung beim Starten der Instanz
      Thomas Braun Most Active last edited by
      @mguenther
      Welche?
        mguenther @Thomas Braun last edited by
        die 2 error Meldungen beim Starten der javascript Instanz - beide von oben aus dem ersten Beitrag
          wodkab @mguenther last edited by
          @mguenther
          Ich habe bei mir die beiden gleichen Fehlermeldungen im Log, wenn ich javascript.0 restarte oder den Pi4 reboote:
          2022-04-16 10:50:23.745 - info: javascript.0 (6665) AR(target) Release/obj.target/deps/cpu_features/cpu_features.a
          2022-04-16 10:50:23.776 - info: javascript.0 (6665) COPY Release/cpu_features.a
          2022-04-16 10:50:23.802 - info: javascript.0 (6665) CXX(target) Release/obj.target/cpufeatures/src/binding.o
          2022-04-16 10:50:26.277 - error: javascript.0 (6665) In file included from ../src/binding.cc:1:
          /opt/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type]
          793 | (node::addon_register_func) (regfunc), \
          /opt/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
          827 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
          ../src/binding.cc:152:1: note: in expansion of macro ‘NODE_MODULE’
          152 | NODE_MODULE(cpufeatures, init)
          2022-04-16 10:50:27.088 - info: javascript.0 (6665) SOLINK_MODULE(target) Release/obj.target/cpufeatures.node
          2022-04-16 10:50:27.410 - info: javascript.0 (6665) COPY Release/cpufeatures.node
          2022-04-16 10:50:27.428 - info: javascript.0 (6665) make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build'
          2022-04-16 10:50:27.461 - info: javascript.0 (6665)
          > ssh2@1.9.0 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2
          > node install.js
          2022-04-16 10:50:29.372 - info: javascript.0 (6665) make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build'
          2022-04-16 10:50:29.374 - info: javascript.0 (6665) CXX(target) Release/obj.target/sshcrypto/src/binding.o
          2022-04-16 10:50:31.325 - error: javascript.0 (6665) In file included from ../src/binding.cc:5:
          ../src/binding.cc:2148:1: note: in expansion of macro ‘NODE_MODULE’
          2148 | NODE_MODULE(sshcrypto, init)
          2022-04-16 10:50:35.335 - info: javascript.0 (6665) SOLINK_MODULE(target) Release/obj.target/sshcrypto.node
          2022-04-16 10:50:35.631 - info: javascript.0 (6665) COPY Release/sshcrypto.node
          2022-04-16 10:50:35.649 - info: javascript.0 (6665) make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build'
          2022-04-16 10:50:35.675 - info: javascript.0 (6665) Succeeded in building optional crypto binding
          Gibt es Neuigkeiten, wie ich das wieder fixen kann?
          M Thomas Braun 2 Replies Last reply Reply Quote 0
            mguenther @wodkab last edited by
            @wodkab
            habe keine Lösung (bekommen)
              @mguenther Ich habe eigentlich nichts geändert ... aber bei mir kommt die Fehlermeldung jetzt nicht mehr 😕 aber soll mir rechts sein. So oft restarte/reboote ich ja auch nicht. Zur Info ... bei mir läuft iobroker in einem Docker-Container.
                Thomas Braun Most Active @wodkab last edited by
                @wodkab sagte in javascript.0 Fehlermeldung beim Starten der Instanz:
                ssh2@1.9.0
                Wo hängt denn das Modul?
                cd /opt/iobroker
                npm ls ssh2
                  wodkab @Thomas Braun last edited by
                    Thomas Braun Most Active @wodkab last edited by Thomas Braun
                    @wodkab
                    Okay, also als manuelles Modul im javaskript-Adapter.
                    Brauchst du das wirklich? Ich würde das sonst rauswerfen.
                    Wenn wirklich benötigt, dann muss das vielleicht nochmal reinstalliert oder neugebaut werden.
                      @thomas-braun @thomas-braun Ok ... Danke, dann weiß ich schon mal woher der Fehler kommt. Brauchen tue ich es schon, ich führe damit ssh-Kommandos auf meinen LibreEelecs, NAS, RaspPis etc. aus.
                        @wodkab
                        Ich hab jetzt erst genauer geschaut... Mea culpa!
                        Aber das sind gar keine 'Fehler', das sind ganz normale Meldungen, wenn Module neugebaut werden. Wird ja auch erfolgreich abgeschlossen:
                          @thomas-braun Cool ... Danke, das erklärt auch, warum die "Fehler", die eigentlich Build-Warnings aus dem Modul-Build sind nicht mehr kommen ... Modul wird ja (denke ich) nicht dauernd neu gebaut 😉
                          771
