    3. Off Topic
    4. Grafana
    5. Fritzbox mit Grafana visualisieren [Version 2022]
      Thomas Braun Most Active @Damrak2022 last edited by
      @damrak2022
      cat fritzinfluxdb.py
        @damrak2022
        python --version
        liefert was?
        • Damrak2022
          Damrak2022 @Thomas Braun last edited by
          @thomas-braun sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
          python --version
          pi@homebridge:/opt/fritzinfluxdb $ python --version
          Python 2.7.18
            Thomas Braun Most Active @Damrak2022 last edited by Thomas Braun
            @damrak2022
            Hatte ich mir fast gedacht.
            sudo apt update
            sudo apt install python-is-python3
            python --version
            Vermutlich funktioniert es danach.
            • Damrak2022
              Damrak2022 @Thomas Braun last edited by Damrak2022
              python --version
              pi@homebridge:~ $ sudo apt update
              Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
              Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:3 https://repos.influxdata.com/debian bullseye InRelease
              Hit:4 https://packages.grafana.com/enterprise/deb stable InRelease
              Hit:5 https://packages.grafana.com/oss/deb stable InRelease
              Hit:6 https://deb.nodesource.com/node_14.x bullseye InRelease
              Hit:7 https://archive.raspbian.org/raspbian buster InRelease
              Get:8 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [279 kB]
              Hit:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
              Fetched 302 kB in 7s (42.6 kB/s)
              Reading package lists... Done
              Building dependency tree... Done
              5 packages can be upgraded. Run 'apt list --upgradable' to see them.
              W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:3
              W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:3
              W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:3
              W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:3
              W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:4
              W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:4
              W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:4
              W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:4
              W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:5
              W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:5
              W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:5
              W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:2 and /etc/apt/sources.list.d/grafana.list:5
              pi@homebridge:~ $ sudo apt install python-is-python3
              The following packages were automatically installed and are no longer required:
                libpython2-dev libpython2-stdlib libpython2.7 libpython2.7-dev
                libpython2.7-minimal libpython2.7-stdlib python2 python2-dev python2-minimal
                python2.7 python2.7-dev python2.7-minimal
              Use 'sudo apt autoremove' to remove them.
              The following packages will be REMOVED:
                python-dev-is-python2 python-is-python2
              The following NEW packages will be installed:
                python-is-python3
              0 upgraded, 1 newly installed, 2 to remove and 5 not upgraded.
              Need to get 2,800 B of archives.
              After this operation, 15.4 kB disk space will be freed.
              Do you want to continue? [Y/n] y
              Get:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bullseye/main armhf python-is-python3 all 3.9.2-1 [2,800 B]
              Fetched 2,800 B in 1s (5,450 B/s)
              (Reading database ... 68564 files and directories currently installed.)
              Removing python-dev-is-python2 (2.7.18-9) ...
              Removing python-is-python2 (2.7.18-9) ...
              Selecting previously unselected package python-is-python3.
              (Reading database ... 68552 files and directories currently installed.)
              Preparing to unpack .../python-is-python3_3.9.2-1_all.deb ...
              Unpacking python-is-python3 (3.9.2-1) ...
              Setting up python-is-python3 (3.9.2-1) ...
              Processing triggers for man-db (2.9.4-2) ...
              pi@homebridge:~ $ python --version
              Python 3.9.2
              pi@homebridge:~ $ ./fritzinfluxdb.py
              -bash: ./fritzinfluxdb.py: No such file or directory
              pi@homebridge:~ $ cd /opt/influxdb
              -bash: cd: /opt/influxdb: No such file or directory
              pi@homebridge:~ $ cd /opt/fritzinfluxdb
              pi@homebridge:/opt/fritzinfluxdb $ ./fritzinfluxdb.py
              Traceback (most recent call last):
                File "/opt/fritzinfluxdb/./fritzinfluxdb.py", line 18, in <module>
                  import fritzconnection
              ModuleNotFoundError: No module named 'fritzconnection'
              Das Update hat funktionier, aber der Befehl laut Anleitung nicht (Zeile 79)
              Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                @damrak2022 sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
                Räum die mal auf.
                Da sind Doubletten drin.
                • Damrak2022
                  @thomas-braun Sorry Thomas, da sind meine Kenntnisse noch zu gering. We räume ich das auf?
                    @damrak2022
                    sudo nano /etc/apt/sources.list.d/grafana.list
                    Jede Quelle darf da nur einfach drin stehen.
                      @damrak2022
                      Wenn die Datei richtig ist:
                      sudo apt update
                      sudo apt autoremove
                      sudo apt full-upgrade
                        crunchip Forum Testing Most Active @Damrak2022 last edited by
                        pi@homebridge:/opt/fritzinfluxdb $ ./fritzinfluxdb.py Traceback (most recent call last): File "/opt/fritzinfluxdb/./fritzinfluxdb.py", line 18, in <module> import fritzconnection ModuleNotFoundError: No module named 'fritzconnection' pi@homebridge:/opt/fritzinfluxdb $
                        also bist du doch da im richtigen Verzeichnis, pi@homebridge:/opt/fritzinfluxdb $ ./fritzinfluxdb.py
                        so wie ich das lese, fehlt dir fritzconnection
                        pip install fritzconnection
                        • Damrak2022
                          pi@homebridge:~ $ sudo nano /etc/apt/sources.list.d/grafana.list
                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:3 https://packages.grafana.com/oss/deb stable InRelease
                          Hit:4 https://repos.influxdata.com/debian bullseye InRelease
                          Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
                          Hit:6 https://archive.raspbian.org/raspbian buster InRelease
                          Hit:7 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                          pi@homebridge:~ $ sudo apt autoremove
                          0 upgraded, 0 newly installed, 12 to remove and 5 not upgraded.
                          After this operation, 27.2 MB disk space will be freed.
                          (Reading database ... 68557 files and directories currently installed.)
                          Removing python2-dev (2.7.18-3) ...
                          Removing libpython2-dev:armhf (2.7.18-3) ...
                          Removing python2 (2.7.18-3) ...
                          Removing libpython2-stdlib:armhf (2.7.18-3) ...
                          Removing python2.7-dev (2.7.18-8) ...
                          Removing libpython2.7-dev:armhf (2.7.18-8) ...
                          Removing libpython2.7:armhf (2.7.18-8) ...
                          Removing python2.7 (2.7.18-8) ...
                          Removing libpython2.7-stdlib:armhf (2.7.18-8) ...
                          Removing python2-minimal (2.7.18-3) ...
                          Removing python2.7-minimal (2.7.18-8) ...
                          Unlinking and removing bytecode for runtime python2.7
                          Removing libpython2.7-minimal:armhf (2.7.18-8) ...
                          Processing triggers for mailcap (3.69) ...
                          Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u2) ...
                          pi@homebridge:~ $ sudo apt full-upgrade
                          Calculating upgrade... Done
                          The following packages will be upgraded:
                            libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0
                            pi-bluetooth
                          5 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          Need to get 501 kB of archives.
                          After this operation, 5,120 B of additional disk space will be used.
                          Get:1 http://archive.raspberrypi.org/debian bullseye/main armhf libraspberrypi-dev armhf 1:2+git20220324~090146+c4fd1b8-1 [177 kB]
                          Get:2 http://archive.raspberrypi.org/debian bullseye/main armhf libraspberrypi-bin armhf 1:2+git20220324~090146+c4fd1b8-1 [149 kB]
                          Get:3 http://archive.raspberrypi.org/debian bullseye/main armhf libraspberrypi0 armhf 1:2+git20220324~090146+c4fd1b8-1 [167 kB]
                          Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf libraspberrypi-doc all 1:2+git20220324~090146+c4fd1b8-1 [1,908 B]
                          Get:5 http://archive.raspberrypi.org/debian bullseye/main armhf pi-bluetooth all 0.1.19 [5,764 B]
                          Fetched 501 kB in 0s (1,731 kB/s)
                          Reading changelogs... Done
                          (Reading database ... 67657 files and directories currently installed.)
                          Preparing to unpack .../libraspberrypi-dev_1%3a2+git20220324~090146+c4fd1b8-1_armhf.deb ...
                          Unpacking libraspberrypi-dev (1:2+git20220324~090146+c4fd1b8-1) over (1:2+git20211125~155417+14b90ff-3) ...
                          Preparing to unpack .../libraspberrypi-bin_1%3a2+git20220324~090146+c4fd1b8-1_armhf.deb ...
                          Unpacking libraspberrypi-bin (1:2+git20220324~090146+c4fd1b8-1) over (1:2+git20211125~155417+14b90ff-3) ...
                          Preparing to unpack .../libraspberrypi0_1%3a2+git20220324~090146+c4fd1b8-1_armhf.deb ...
                          Unpacking libraspberrypi0:armhf (1:2+git20220324~090146+c4fd1b8-1) over (1:2+git20211125~155417+14b90ff-3) ...
                          Preparing to unpack .../libraspberrypi-doc_1%3a2+git20220324~090146+c4fd1b8-1_all.deb ...
                          Unpacking libraspberrypi-doc (1:2+git20220324~090146+c4fd1b8-1) over (1:2+git20211125~155417+14b90ff-3) ...
                          Preparing to unpack .../pi-bluetooth_0.1.19_all.deb ...
                          Unpacking pi-bluetooth (0.1.19) over (0.1.18) ...
                          Setting up pi-bluetooth (0.1.19) ...
                          Setting up libraspberrypi0:armhf (1:2+git20220324~090146+c4fd1b8-1) ...
                          Setting up libraspberrypi-bin (1:2+git20220324~090146+c4fd1b8-1) ...
                          Setting up libraspberrypi-dev (1:2+git20220324~090146+c4fd1b8-1) ...
                          Setting up libraspberrypi-doc (1:2+git20220324~090146+c4fd1b8-1) ...
                          pi@homebridge:~ $
                            @damrak2022
                            Da fehlt wie @crunchip (und die verlinkte Anleitung) schreibt
                            • Damrak2022
                              Damrak2022 @crunchip last edited by
                              @crunchip sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
                              pip
                              pi@homebridge:/opt/fritzinfluxdb $ pip install fritzconnection
                              Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                              Requirement already satisfied: fritzconnection in /home/pi/.local/lib/python3.9/site-packages (1.3.3)
                              Requirement already satisfied: requests>=2.22.0 in /usr/local/lib/python3.9/dist-packages (from fritzconnection) (2.22.0)
                              Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /usr/local/lib/python3.9/dist-packages (from requests>=2.22.0->fritzconnection) (1.25.11)
                              Requirement already satisfied: idna<2.9,>=2.5 in /usr/local/lib/python3.9/dist-packages (from requests>=2.22.0->fritzconnection) (2.8)
                              Requirement already satisfied: certifi>=2017.4.17 in /usr/lib/python3/dist-packages (from requests>=2.22.0->fritzconnection) (2020.6.20)
                              Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python3.9/dist-packages (from requests>=2.22.0->fritzconnection) (3.0.4)
                                Ich vermute, das liegt in /home/pi/.local falsch.
                                Von python hab ich aber offen gesagt nicht viel Ahnung.
                                Weiß nicht ob das da einfach weggelöscht werden kann oder ob das per
                                pip uninstall fritzconnection
                                Im Home von pi zu deinstallieren ist.
                                • Damrak2022
                                  Also da ist es jetzt raus
                                  pi@homebridge:~ $ pip uninstall fritzconnection
                                  Found existing installation: fritzconnection 1.3.3
                                  Uninstalling fritzconnection-1.3.3:
                                    Would remove:
                                      /home/pi/.local/lib/python3.9/site-packages/fritzconnection-1.3.3.dist-info/*
                                  Proceed (y/n)? y
                                    Successfully uninstalled fritzconnection-1.3.3
                                  pi@homebridge:~ $
                                  Also installiere ich es jetzt unter fritzinfluxdb direkt?
                                    Hier zu installieren, wäre aber das falsche Verzeichnis
                                    • Damrak2022
                                      Damrak2022 @crunchip last edited by Damrak2022
                                      @crunchip Dann verstehe ich die gesamte Anleitung nicht. Hast Du dir die mal angeschaut?
                                      https://blog.gwarg.de/2022/01/22/fritzbox-mit-grafana-visualisieren-version-2022/
                                      Ich habe zwar nicht viel Ahnung, kann mir aber nicht vorstellen das ich da soviel missverstanden habe.
                                        Nein, das gibt es doch noch gar nicht, das verzeichnis wird doch erst später erstellt
                                          @damrak2022
                                          export PATH=/home/pi/.local/lib:$PATH
                                            Ja, da steht
                                            Erst Fritzconnection
                                            sudo apt install python3-pip
                                            144
                                            20519
