    3. Off Topic
    4. Grafana
    5. Fritzbox mit Grafana visualisieren [Version 2022]
      Thomas Braun Most Active @Damrak2022 last edited by
      @damrak2022
      Wenn die Datei richtig ist:
      sudo apt update
      sudo apt autoremove
      sudo apt full-upgrade
        crunchip Forum Testing Most Active @Damrak2022 last edited by
        @damrak2022 sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
        pi@homebridge:/opt/fritzinfluxdb $ ./fritzinfluxdb.py Traceback (most recent call last): File "/opt/fritzinfluxdb/./fritzinfluxdb.py", line 18, in <module> import fritzconnection ModuleNotFoundError: No module named 'fritzconnection' pi@homebridge:/opt/fritzinfluxdb $
        also bist du doch da im richtigen Verzeichnis, pi@homebridge:/opt/fritzinfluxdb $ ./fritzinfluxdb.py
        so wie ich das lese, fehlt dir fritzconnection
        pip install fritzconnection
        • Damrak2022
          Damrak2022 @Thomas Braun last edited by Damrak2022
          @thomas-braun sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
          pi@homebridge:~ $ sudo nano /etc/apt/sources.list.d/grafana.list
          pi@homebridge:~ $ sudo apt update
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 https://packages.grafana.com/oss/deb stable InRelease
          Hit:4 https://repos.influxdata.com/debian bullseye InRelease
          Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
          Hit:6 https://archive.raspbian.org/raspbian buster InRelease
          Hit:7 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
          Reading package lists... Done
          Building dependency tree... Done
          5 packages can be upgraded. Run 'apt list --upgradable' to see them.
          pi@homebridge:~ $ sudo apt autoremove
          The following packages will be REMOVED:
            libpython2-dev libpython2-stdlib libpython2.7 libpython2.7-dev
            libpython2.7-minimal libpython2.7-stdlib python2 python2-dev python2-minimal
            python2.7 python2.7-dev python2.7-minimal
          0 upgraded, 0 newly installed, 12 to remove and 5 not upgraded.
          After this operation, 27.2 MB disk space will be freed.
          Do you want to continue? [Y/n] y
          (Reading database ... 68557 files and directories currently installed.)
          Removing python2-dev (2.7.18-3) ...
          Removing libpython2-dev:armhf (2.7.18-3) ...
          Removing python2 (2.7.18-3) ...
          Removing libpython2-stdlib:armhf (2.7.18-3) ...
          Removing python2.7-dev (2.7.18-8) ...
          Removing libpython2.7-dev:armhf (2.7.18-8) ...
          Removing libpython2.7:armhf (2.7.18-8) ...
          Removing python2.7 (2.7.18-8) ...
          Removing libpython2.7-stdlib:armhf (2.7.18-8) ...
          Removing python2-minimal (2.7.18-3) ...
          Removing python2.7-minimal (2.7.18-8) ...
          Unlinking and removing bytecode for runtime python2.7
          Removing libpython2.7-minimal:armhf (2.7.18-8) ...
          Processing triggers for man-db (2.9.4-2) ...
          Processing triggers for mailcap (3.69) ...
          Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u2) ...
          pi@homebridge:~ $ sudo apt full-upgrade
          Calculating upgrade... Done
          The following packages will be upgraded:
            libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0
            pi-bluetooth
          5 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          Need to get 501 kB of archives.
          After this operation, 5,120 B of additional disk space will be used.
          Get:1 http://archive.raspberrypi.org/debian bullseye/main armhf libraspberrypi-dev armhf 1:2+git20220324~090146+c4fd1b8-1 [177 kB]
          Get:2 http://archive.raspberrypi.org/debian bullseye/main armhf libraspberrypi-bin armhf 1:2+git20220324~090146+c4fd1b8-1 [149 kB]
          Get:3 http://archive.raspberrypi.org/debian bullseye/main armhf libraspberrypi0 armhf 1:2+git20220324~090146+c4fd1b8-1 [167 kB]
          Get:4 http://archive.raspberrypi.org/debian bullseye/main armhf libraspberrypi-doc all 1:2+git20220324~090146+c4fd1b8-1 [1,908 B]
          Get:5 http://archive.raspberrypi.org/debian bullseye/main armhf pi-bluetooth all 0.1.19 [5,764 B]
          Fetched 501 kB in 0s (1,731 kB/s)
          Reading changelogs... Done
          (Reading database ... 67657 files and directories currently installed.)
          Preparing to unpack .../libraspberrypi-dev_1%3a2+git20220324~090146+c4fd1b8-1_armhf.deb ...
          Unpacking libraspberrypi-dev (1:2+git20220324~090146+c4fd1b8-1) over (1:2+git20211125~155417+14b90ff-3) ...
          Preparing to unpack .../libraspberrypi-bin_1%3a2+git20220324~090146+c4fd1b8-1_armhf.deb ...
          Unpacking libraspberrypi-bin (1:2+git20220324~090146+c4fd1b8-1) over (1:2+git20211125~155417+14b90ff-3) ...
          Preparing to unpack .../libraspberrypi0_1%3a2+git20220324~090146+c4fd1b8-1_armhf.deb ...
          Unpacking libraspberrypi0:armhf (1:2+git20220324~090146+c4fd1b8-1) over (1:2+git20211125~155417+14b90ff-3) ...
          Preparing to unpack .../libraspberrypi-doc_1%3a2+git20220324~090146+c4fd1b8-1_all.deb ...
          Unpacking libraspberrypi-doc (1:2+git20220324~090146+c4fd1b8-1) over (1:2+git20211125~155417+14b90ff-3) ...
          Preparing to unpack .../pi-bluetooth_0.1.19_all.deb ...
          Unpacking pi-bluetooth (0.1.19) over (0.1.18) ...
          Setting up pi-bluetooth (0.1.19) ...
          Setting up libraspberrypi0:armhf (1:2+git20220324~090146+c4fd1b8-1) ...
          Setting up libraspberrypi-bin (1:2+git20220324~090146+c4fd1b8-1) ...
          Setting up libraspberrypi-dev (1:2+git20220324~090146+c4fd1b8-1) ...
          Setting up libraspberrypi-doc (1:2+git20220324~090146+c4fd1b8-1) ...
          pi@homebridge:~ $
            @damrak2022
            Da fehlt wie @crunchip (und die verlinkte Anleitung) schreibt
            • Damrak2022
              Damrak2022 @crunchip last edited by
              @crunchip sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
              pip
              pi@homebridge:/opt/fritzinfluxdb $ pip install fritzconnection
              Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
              Requirement already satisfied: fritzconnection in /home/pi/.local/lib/python3.9/site-packages (1.3.3)
              Requirement already satisfied: requests>=2.22.0 in /usr/local/lib/python3.9/dist-packages (from fritzconnection) (2.22.0)
              Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /usr/local/lib/python3.9/dist-packages (from requests>=2.22.0->fritzconnection) (1.25.11)
              Requirement already satisfied: idna<2.9,>=2.5 in /usr/local/lib/python3.9/dist-packages (from requests>=2.22.0->fritzconnection) (2.8)
              Requirement already satisfied: certifi>=2017.4.17 in /usr/lib/python3/dist-packages (from requests>=2.22.0->fritzconnection) (2020.6.20)
              Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /usr/local/lib/python3.9/dist-packages (from requests>=2.22.0->fritzconnection) (3.0.4)
              Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                Ich vermute, das liegt in /home/pi/.local falsch.
                Von python hab ich aber offen gesagt nicht viel Ahnung.
                Weiß nicht ob das da einfach weggelöscht werden kann oder ob das per
                pip uninstall fritzconnection
                Im Home von pi zu deinstallieren ist.
                • Damrak2022
                  Also da ist es jetzt raus
                  pi@homebridge:~ $ pip uninstall fritzconnection
                  Found existing installation: fritzconnection 1.3.3
                  Uninstalling fritzconnection-1.3.3:
                    Would remove:
                      /home/pi/.local/lib/python3.9/site-packages/fritzconnection-1.3.3.dist-info/*
                  Proceed (y/n)? y
                    Successfully uninstalled fritzconnection-1.3.3
                  pi@homebridge:~ $
                  Also installiere ich es jetzt unter fritzinfluxdb direkt?
                    Hier zu installieren, wäre aber das falsche Verzeichnis
                    • Damrak2022
                      Damrak2022 @crunchip last edited by Damrak2022
                      @crunchip Dann verstehe ich die gesamte Anleitung nicht. Hast Du dir die mal angeschaut?
                      https://blog.gwarg.de/2022/01/22/fritzbox-mit-grafana-visualisieren-version-2022/
                      Ich habe zwar nicht viel Ahnung, kann mir aber nicht vorstellen das ich da soviel missverstanden habe.
                        Nein, das gibt es doch noch gar nicht, das verzeichnis wird doch erst später erstellt
                          @damrak2022
                          export PATH=/home/pi/.local/lib:$PATH
                            Ja, da steht
                            Erst Fritzconnection
                            sudo apt install python3-pip
                            • Damrak2022
                              @crunchip Genau so habe ich das der Reihe nach installiert
                                @damrak2022
                                Bei mir läuft's durch:
                                Successfully installed fritzconnection-1.9.1 influxdb-5.3.1 msgpack-1.0.3 python-dateutil-2.8.2 pytz-2022.1
                                • Damrak2022
                                  @thomas-braun Wenn ich den exakt so eingebe springt er sofort zum nächsten
                                  pi@homebridge:~ $ export PATH=/home/pi/.local/lib:$PATH
                                  pi@homebridge:~ $
                                    Das soll so sein.
                                      @damrak2022 les mal nochmal deinen ersten Beitrag, zwecks warnmeldung
                                      Damrak2022 I 2 Replies Last reply Reply Quote 0
                                      • Damrak2022
                                        @crunchip Ich werde jetzt nochmal die 5 Befehle aus der Anleitung nacheinander eingeben.
                                        Ansonsten mache ich morgen weiter
                                        # Erst Fritzconnection
                                        # Dann Fritz InfluxDB
                                        sudo apt install virtualenv python3-lxml git
                                        cd /opt
                                        sudo git clone https://github.com/yunity/fritzinfluxdb.git
                                        cd fritzinfluxdb
                                        sudo virtualenv --system-site-packages -p python3 .venv
                                        . .venv/bin/activate
                                        # ab hier im (.venv)-modus
                                        pip3 install -r requirements.txt
                                        Vielleicht bringt es ja was
                                        Erstmal DANKE an Euch
                                          @damrak2022 @crunchip
                                          Ich merk gerade, das mit dem export in den $PATH war unnötig. Wird ja über die venv gemacht.
                                          Naja, egal, ist beim nächsten Neustart eh weg.
                                          • Damrak2022
                                            @thomas-braun Es hat bei mir wahrscheinlich was mit der Warnmeldung nach dem Befehl der frzconnection installation zu tun:
                                            pi@homebridge:~ $ pip install fritzconnection
                                            Collecting fritzconnection
                                              Using cached https://www.piwheels.org/simple/fritzconnection/fritzconnection-1.9.1-py3-none-any.whl (50 kB)
                                            Installing collected packages: fritzconnection
                                              WARNING: The scripts fritzcall, fritzconnection, fritzhomeauto, fritzhosts, fritzmonitor, fritzphonebook, fritzstatus and fritzwlan are installed in '/home/pi/.local/bin' which is not on PATH.
                                              Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
                                            Anscheinen muss ich hier was korrigieren, obwohl es seit die Installation sei erfolgreich
                                            144
                                            20525
