    4. ioBroker startet nicht mehr
      fraso @fastfoot last edited by
      @fastfoot
      hier die aktuelle iobroker.json
      ich habe die 60G Datei gelöscht und iobroker neu gestartet und jetzt aus dem Backup heute nacht wieder hergestellt. läuft gleich, dann sende ich die anderen Infos.
        "system": {
          "memoryLimitMB": 0,
          "hostname": "",
          "statisticsInterval": 15000,
          "statisticsIntervalComment": "Interval how often the counters for input/output in adapters and controller will be updated",
          "checkDiskInterval": 300000,
          "checkDiskIntervalComment": "Interval how often the disk size will be checked",
          "instanceStartInterval": 2000,
          "noChmodComment": "Flag to test new feature with no chmod call. Must be deleted later and noChmod must be mainline (2018.06.04)",
          "compact": false,
          "compactComment": "Controller will try to start the instances as a part of the same process. No spawn will be done. Only by adapters that support it and have flag compact flag in io-package.json",
          "allowShellCommands": false,
          "allowShellCommandsComment": "Allow execution of \"shell\" sendToHost commands",
          "memLimitWarn": 100,
          "memLimitWarnComment": "If the available RAM is below this threshold on adapter start, a warning will be logged.",
          "memLimitError": 50,
          "memLimitErrorComment": "If the available RAM is below this threshold on adapter start, an error will be logged."
        "multihostService": {
          "enabled": false,
          "secure": true,
          "password": ""
        "objects": {
          "type": "jsonl",
          "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
          "host": "127.0.0.1",
          "port": 9001,
          "noFileCache": false,
          "maxQueue": 1000,
          "connectTimeout": 2000,
          "writeFileInterval": 5000,
          "dataDir": "",
          "options": {
            "auth_pass": null,
            "retry_max_delay": 5000,
            "retry_max_count": 19,
            "db": 0,
            "family": 0
          "backup": {
            "disabled": false,
            "files": 24,
            "filesComment": "Minimal number of backup files, after the deletion will be executed according to backupTime settings",
            "hours": 48,
            "hoursComment": "All backups older than 48 hours will be deleted. But only if the number of files is greater than of backupNumber",
            "period": 120,
            "periodComment": "by default backup every 2 hours. Time is in minutes. To disable backup set the value to 0",
            "path": "",
            "pathComment": "Absolute path to backup directory or empty to backup in data directory"
        "states": {
          "type": "jsonl",
          "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
          "port": 9000,
          "writeFileInterval": 30000,
          "dataDir": "",
          "options": {
            "auth_pass": null,
            "db": 0,
            "family": 0
          "backup": {
            "disabled": false,
            "files": 24,
            "hours": 48,
            "period": 120,
            "path": "",
        "log": {
          "level": "info",
          "maxDays": 3,
          "noStdout": true,
          "transport": {
            "file1": {
              "type": "file",
              "enabled": true,
              "filename": "log/iobroker",
              "fileext": ".log",
              "maxsize": null,
              "maxFiles": null,
              "maxSize": null,
              "level": ""
            "syslog1": {
              "type": "syslog",
              "enabled": false,
              "host": "localhost",
              "hostComment": "The host running syslogd, defaults to localhost.",
              "portComment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
              "protocol": "udp4",
              "protocolComment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
              "pathComment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
              "facilityComment": "Syslog facility to use (Default: local0).",
              "localhost": "iobroker",
              "localhostComment": "Host to indicate that log messages are coming from (Default: localhost).",
              "sysLogTypeComment": "The type of the syslog protocol to use (Default: BSD).",
              "app_nameComment": "The name of the application (Default: process.title).",
              "eolComment": "The end of line character to be added to the end of the message (Default: Message without modifications).",
              "level": "",
              "facility": ""
            "seq1": {
              "type": "seq",
              "enabled": false,
              "serverUrl": "http://IP:PORT",
              "serverUrlComment": "The http(s) URL including port of the seq server. If you use HTTPS a real certificate is needed; self signed certs are ot accepted.",
              "apiKey": "",
              "apiKeyComment": "The apiKey of the seq system",
              "level": "",
              "eol": ""
        "plugins": {},
        "dataDir": "../../iobroker-data/"
        @fastfoot
        Info zum System:
        e6iob@NUCioBroker:/opt/iobroker/iobroker-data$ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.19.0
        v14.19.0
        [sudo] Passwort für e6iob:
        8.6.0
        nodejs:
          Installiert:           14.19.0-deb-1nodesource1
          Installationskandidat: 14.19.1-deb-1nodesource1
          Versionstabelle:
             14.19.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
         *** 14.19.0-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             12.22.5~dfsg-2~11u1 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
          Thomas Braun Most Active @fraso last edited by
          @fraso
          npm ist nicht die Version aus dem Paket.
          Und halt nodejs aktuell.
            fastfoot @fraso last edited by
            @fraso die leeren jsonlOptions sind nicht da, so wie es sein soll. War nur so eine Idee. die js-controller version bekommst du unter Hosts angezeigt oder auf der Konsole mit iob -v
              @fastfoot sagte in ioBroker startet nicht mehr:
              iob -v
              e6iob@NUCioBroker:/opt/iobroker/iobroker-data$ iob -v
              4.0.21
                fraso @Thomas Braun last edited by
                Hi Thomas,
                habe in Deiner Signatur geschaut aber dort nicht gefunden wie man die npm "korrigiert".
                Gibt es hier eine korrekte Anleitung die ich abarbeiten kann ?
                Danke.
                  @fraso
                  Installier das Update, dann wird npm gleich richtig mitinstalliert.
                  Und lass die Finger davon npm global an der Paketverwaltung vorbei ins System zu knüppeln.
                  F F 2 Replies Last reply Reply Quote 0
                    apollon77 @fraso last edited by apollon77
                    @fraso sagte in ioBroker startet nicht mehr:
                    Jemand eine Idee wieso das passiert? Die oben genannten Tips hatte ich umgesetzt.
                    Ja, Bitte js-controller 4.0.23 installieren (ggf states.jsonl einmalig löschen... kannst gern das states.json.migrated_save nach states.json umbenennen dasnn hast du den States stand.
                    EDIT: Da aber bei dir die defekte EInstellung nicht da war ist das komisch. Bitte nach dem contreoller Update beobachten das es nicht wieder sooo grioss wird - ggf melden
                      @fraso da gibt es die 4.0.23 welche genau dieses Problem behebt(obwohl das manuelle Entfernen der jsonlOptions das eig. auch behoben haben sollte)
                        nur damit ich das nicht verschlimmert:
                        iobroker update
                        das machen?
                        Thomas Braun F 2 Replies Last reply Reply Quote 0
                          @fraso
                          Nein. Über die Paketverwaltung. Wie alle andere Updates des Betriebssystems auch.
                          sudo apt upgrade
                          sudo apt full-upgrade
                          Falls das noch nie gemacht wurde...
                            @fraso iob update && iob upgrade self für den js-controller
                            apt update && apt upgrade für node. zuvor iobroker natürlich stoppen. iob stop
                              fastfoot @Thomas Braun last edited by
                              @thomas-braun sagte in ioBroker startet nicht mehr:
                              npm selbst empfiehlt das aber wenn es zB ein minor update gibt. Gibt es da einen Grund für deine Empfehlung?
                                iob upgrade self
                                sudo apt upgrade gemacht
                                sudo apt full-upgrade gemacht
                                iob update listet ed mir die "updateable"´s auf aber updated nicht
                                iob upgrade self gemacht
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v14.19.1
                                v14.19.1
                                6.14.16
                                nodejs:
                                  Installiert:           14.19.1-deb-1nodesource1
                                  Versionstabelle:
                                 *** 14.19.1-deb-1nodesource1 500
                                  Thomas Braun Most Active @fastfoot last edited by
                                  Die empfehlen das auch für Major Upgrades.
                                  Hat in der Vergangenheit regelmäßig für Probleme gesorgt. Upstream wird npm ja auch immer mit einer bestimmten Version von nodejs zusammengepackt.
                                    fraso @fastfoot last edited by fraso
                                    @fastfoot
                                    ... und wie kriege ich die 4.0.23 drauf?
                                    Controller "js-controller": 4.0.21   , installed 4.0.21
                                      @fraso
                                      4.0.23 ist über das Beta-Repo verfügbar.
                                        Ist mir jetzt peinlich zu fragen - aber der Controller wird wie über das Beta-Repo gezogen? Das ist ja kein Adapter den ich updaten kann - oder?
                                          @fraso
                                          Ich würde das Repo kurz aktivieren.
                                          Dann
                                          iobroker stop
                                          iobroker update
                                          iobroker upgrade self
                                          iobroker start
                                          Dann Repo wieder deaktivieren.
                                          Zuvor würde ich aber die allgemeinen Adapter aktualisieren. Das funktioniert aber bei dir auch nicht, wenn ich das oben richtig gelesen habe.
                                            du meinst minor? ich sehe das manchmal nach npm Operationen, da meldet npm dann dass es ein Update gäbe und man möge es via npm i -g .... installieren.
                                            Hätte das auch beinahe hier empfohlen, allerdings deinen Unmut gefürchtet 🙂 Zu Recht, wie ich lese, denn ich verlasse mich da lieber auf deine kompetente Aussagen
                                            123
                                            12458
