    3. Einsteigerfragen
    4. Npm Fehler / ioBroker startet nicht
      Thomas Braun Most Active @ChrisNett last edited by
      @christian-sandkaulen sagte in Npm Fehler / ioBroker startet nicht:
      mv /opt/iobroker/iobroker-data/iobroker.json /opt/iobroker/iobroker-data/iobroker.jsonbak
      ChrisNett 1 Reply Last reply Reply Quote 0
      • ChrisNett
        ChrisNett @Thomas Braun last edited by ChrisNett
        @thomas-braun sagte in Npm Fehler / ioBroker startet nicht:
        pi@PI4:/opt/iobroker $ mv /opt/iobroker/iobroker-data/iobroker.json /opt/iobroker/iobroker-data/iobroker.jsonbak
        pi@PI4:/opt/iobroker $ iobroker start
        pi@PI4:/opt/iobroker $ ^C
        pi@PI4:/opt/iobroker $ iobroker list instances
        Uncaught Rejection: Error: /opt/iobroker/iobroker-data/iobroker.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/iobroker.json'
            at Object.openSync (node:fs:585:3)
            at Object.readFileSync (node:fs:453:35)
            at Object.readFileSync (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/jsonfile/index.js:50:22)
            at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3088:23)
            at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1308:13)
            at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3314:5)
            at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
            at Module._compile (node:internal/modules/cjs/loader:1103:14)
            at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10)
            at Module.load (node:internal/modules/cjs/loader:981:32)
          Keine Ahnung wie oder wer die iobroker.json anlegt.
          Versuch mal
          iobroker setup first
          • ChrisNett
            danke, scheinbar war es das er fährt hoch
            pi@PI4:/opt/iobroker $ iobroker setup first
            creating conf/iobroker.json
            Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
            + system.adapter.admin.1                  : admin                 : PI4                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.1                 : alexa2                : PI4                                      -  enabled
              system.adapter.backitup.0               : backitup              : PI4                                      -  enabled
            + system.adapter.broadlink2.0             : broadlink2            : PI4                                      -  enabled
            + system.adapter.cloud.0                  : cloud                 : PI4                                      -  enabled
              system.adapter.coronavirus-statistics.0 : coronavirus-statistics: PI4                                      -  enabled
            + system.adapter.denon.0                  : denon                 : PI4                                      -  enabled
              system.adapter.devices.0                : devices               : PI4                                      - disabled
              system.adapter.discovery.0              : discovery             : PI4                                      - disabled
            + system.adapter.dwd.0                    : dwd                   : PI4                                      -  enabled
              system.adapter.echarts.0                : echarts               : PI4                                      -  enabled
              system.adapter.fahrplan.0               : fahrplan              : PI4                                      -  enabled
              system.adapter.fb-checkpresence.0       : fb-checkpresence      : PI4                                      -  enabled
            + system.adapter.feiertage.0              : feiertage             : PI4                                      -  enabled
              system.adapter.flot.0                   : flot                  : PI4                                      - disabled
            + system.adapter.history.0                : history               : PI4                                      -  enabled
            + system.adapter.hmip.0                   : hmip                  : PI4                                      -  enabled
              system.adapter.ical.0                   : ical                  : PI4                                      -  enabled
              system.adapter.ical.1                   : ical                  : PI4                                      -  enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: PI4                                      - disabled
              system.adapter.icons-icons8.0           : icons-icons8          : PI4                                      - disabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : PI4                                      - disabled
              system.adapter.info.0                   : info                  : PI4                                      -  enabled
              system.adapter.iot.0                    : iot                   : PI4                                      -  enabled
            + system.adapter.javascript.0             : javascript            : PI4                                      -  enabled
            + system.adapter.klf200.0                 : klf200                : PI4                                      -  enabled
              system.adapter.logparser.0              : logparser             : PI4                                      - disabled
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : PI4                                      -  enabled, port: 54321
            + system.adapter.mihome-vacuum.1          : mihome-vacuum         : PI4                                      -  enabled, port: 54321
            + system.adapter.mihome-vacuum.2          : mihome-vacuum         : PI4                                      -  enabled, port: 54321
              system.adapter.mqtt.0                   : mqtt                  : PI4                                      - disabled, port: 1893, bind: 0.0.0.0
              system.adapter.onvif.0                  : onvif                 : PI4                                      - disabled
              system.adapter.parcel.0                 : parcel                : PI4                                      -  enabled
              system.adapter.parser.0                 : parser                : PI4                                      - disabled
            + system.adapter.pegelalarm.0             : pegelalarm            : PI4                                      -  enabled
              system.adapter.pi-hole.0                : pi-hole               : PI4                                      -  enabled
            + system.adapter.ping.0                   : ping                  : PI4                                      -  enabled
            + system.adapter.pollenflug.0             : pollenflug            : PI4                                      -  enabled
              system.adapter.pvforecast.0             : pvforecast            : PI4                                      -  enabled
            + system.adapter.rpi2.0                   : rpi2                  : PI4                                      -  enabled
            + system.adapter.samsung.0                : samsung               : PI4                                      -  enabled
            + system.adapter.shelly.0                 : shelly                : PI4                                      -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : PI4                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : PI4                                      -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.sourceanalytix.0         : sourceanalytix        : PI4                                      - disabled
              system.adapter.tankerkoenig.0           : tankerkoenig          : PI4                                      -  enabled
            + system.adapter.telegram.0               : telegram              : PI4                                      -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.text2command.0           : text2command          : PI4                                      -  enabled
            + system.adapter.tr-064.0                 : tr-064                : PI4                                      -  enabled
              system.adapter.trashschedule.0          : trashschedule         : PI4                                      -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : PI4                                      - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : PI4                                      - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : PI4                                      - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : PI4                                      - disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : PI4                                      -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : PI4                                      - disabled
              system.adapter.vis-material-webfont.0   : vis-material-webfont  : PI4                                      - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : PI4                                      - disabled
              system.adapter.vis-metro.0              : vis-metro             : PI4                                      - disabled
              system.adapter.vis.0                    : vis                   : PI4                                      -  enabled
            + system.adapter.weatherunderground.0     : weatherunderground    : PI4                                      -  enabled
              system.adapter.web-speedy.0             : web-speedy            : PI4                                      - disabled
              system.adapter.web.0                    : web                   : PI4                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.worx.0                   : worx                  : PI4                                      -  enabled
            + system.adapter.zigbee.0                 : zigbee                : PI4                                      -  enabled, port: /dev/ttyUSB0
            + instance is alive
            • ChrisNett
              ChrisNett @ChrisNett last edited by
              kommt jetzt muss ich da noch was machen?
                Thomas Braun Most Active @ChrisNett last edited by Thomas Braun
                Das heißt, du warst noch gar nicht auf jsonl?
                Dann ist es jetzt wohl so weit.
                iobroker status
                sagt?
                iobroker update -i
                • ChrisNett
                  pi@PI4:/opt/iobroker $ iobroker status
                  Objects type: jsonl
                  States  type: jsonl
                  pi@PI4:/opt/iobroker $ iobroker update -i
                  Used repository: Stable (default)
                  Adapter    "admin"        : 5.3.8    , installed 5.3.8
                  Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
                  Adapter    "backitup"     : 2.4.6    , installed 2.4.6
                  Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                  Adapter    "cloud"        : 4.1.1    , installed 4.1.1
                  Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                  Adapter    "denon"        : 1.13.3   , installed 1.13.3
                  Adapter    "devices"      : 1.0.10   , installed 1.0.10
                  Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                  Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                  Adapter    "echarts"      : 1.0.3    , installed 1.0.3
                  Adapter    "fahrplan"     : 1.2.0    , installed 1.2.0
                  Adapter    "fb-checkpresence": 1.1.14, installed 1.1.14
                  Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                  Adapter    "flot"         : 1.10.7   , installed 1.10.7
                  Adapter    "history"      : 1.11.1   , installed 1.11.1
                  Adapter    "hmip"         : 1.15.4   , installed 1.15.4
                  Adapter    "hs100"        : 2.0.6    , installed 2.0.6
                  Adapter    "ical"         : 1.12.1   , installed 1.12.1
                  Adapter    "info"         : 1.9.18   , installed 1.9.18
                  Adapter    "iot"          : 1.11.4   , installed 1.11.4
                  Adapter    "javascript"   : 5.2.21   , installed 5.2.21
                  Controller "js-controller": 4.0.21   , installed 4.0.21
                  Adapter    "klf200"       : 1.0.1    , installed 1.0.1
                  Adapter    "km200"        : 2.0.3    , installed 2.0.3
                  Adapter    "landroid"     : 1.0.3    , installed 1.0.3
                  Adapter    "logparser"    : 1.1.0    , installed 1.1.0
                  Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                  Adapter    "mihome-vacuum": 3.3.1    , installed 3.3.1
                  Adapter    "moma"         : 1.2.9    , installed 1.2.9
                  Adapter    "mqtt"         : 2.7.4    , installed 2.7.4
                  Adapter    "onvif"        : 0.4.4    , installed 0.4.4
                  Adapter    "parcel"       : 0.0.15   , installed 0.0.15
                  Adapter    "parser"       : 1.1.4    , installed 1.1.4
                  Adapter    "pegelalarm"   : 1.2.5    , installed 1.2.5
                  Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
                  Adapter    "ping"         : 1.5.3    , installed 1.5.3
                  Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                  Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                  Adapter    "samsung"      : 0.2.9    , installed 0.2.9
                  Adapter    "seq"          : 0.2.10   , installed 0.2.10
                  Adapter    "shelly"       : 5.3.2    , installed 5.3.2
                  Adapter    "simple-api"   : 2.6.4    , installed 2.6.4
                  Adapter    "sonoff"       : 2.5.0    , installed 2.5.0
                  Adapter    "spotify-premium": 1.0.0  , installed 1.1.3
                  Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                  Adapter    "telegram"     : 1.12.2   , installed 1.12.2
                  Adapter    "text2command" : 2.2.1    , installed 2.2.1
                  Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                  Adapter    "trashschedule": 1.4.5    , installed 1.4.5
                  Adapter    "unifi"        : 0.5.10   , installed 0.5.10
                  Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                  Adapter    "vis"          : 1.4.5    , installed 1.4.5
                  Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                  Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
                  Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                  Adapter    "weatherunderground": 3.4.1, installed 3.4.1
                  Adapter    "web"          : 4.2.3    , installed 4.2.3
                  Adapter    "wifilight"    : 1.1.0    , installed 1.1.0
                  Adapter    "worx"         : 1.5.5    , installed 1.5.5
                  Adapter    "ws"           : 1.2.0    , installed 1.3.0
                  Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
                    Gut. Sollte laufen.
                    • ChrisNett
                      danke, die Visualisierung ist nur weg, kann ich dir irgendwie aus dem backup wieder herstellen?
                        Ich hab keine Vis laufen. Ich kann dir nicht sagen ob und wie die gebackupt wird.
                          Homoran Global Moderator Administrators @ChrisNett last edited by
                          irgendwo müsste die vis-views.json liegen. Da sind alle Views drin
                          • ChrisNett
                            ChrisNett @Homoran last edited by
                            @homoran sagte in Npm Fehler / ioBroker startet nicht:
                            danke die habe ich gefunden aber wie spiele ich das wieder ein? Import? View
                              Austauschen!
                              Da sind alle Views und Projekte drin
                              • ChrisNett
                                Austauschen!
                                okay als nicht linux user was ist der einfachtse weg? FTP oder geht das auch per ssh?
                                  Als Nicht Linux User kann ich dir nicht sagen, wie es mit SSH geht.
                                  Dazu könnte @Thomas-Braun etwas sagen.
                                  Ich mache es mit filezilla, aber als user, der auch in der Gruppe iobroker ist, auf keinen Fall als root
                                  • ChrisNett
                                    also nicht der "pi" std user?
                                      bei mir ist der user pi in der Gruppe iobroker drin
                                      Aber warte doch mal auf die Antwort von Thomas
                                      • ChrisNett
                                        @thomasBraun
                                        könntest du mir helfen?
                                          Wo liegt die Datei denn nun?
                                          cp /pfad/zur/quelle /pfad/zum/ziel
                                          Vorausgesetzt dein Standarduser ist in der Gruppe 'iobroker' drin.
                                          Sonst:
                                          sudo -u iobroker cp /pfad/zur/quelle /pfad/zum/ziel
                                          • ChrisNett
                                            Sonst:
                                            ähm vom Windows PC zum pi ?
                                            npm err
                                            3090
