    3. Einsteigerfragen
    4. Npm Fehler / ioBroker startet nicht
    • ChrisNett
      ChrisNett @Thomas Braun last edited by ChrisNett
      @thomas-braun sagte in Npm Fehler / ioBroker startet nicht:
      mv /opt/iobroker/iobroker-data/iobroker.json /opt/iobroker/iobroker-data/iobroker.jsonbak
      pi@PI4:/opt/iobroker $ mv /opt/iobroker/iobroker-data/iobroker.json /opt/iobroker/iobroker-data/iobroker.jsonbak
      pi@PI4:/opt/iobroker $ iobroker start
      pi@PI4:/opt/iobroker $ ^C
      pi@PI4:/opt/iobroker $ iobroker list instances
      Uncaught Rejection: Error: /opt/iobroker/iobroker-data/iobroker.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/iobroker.json'
          at Object.openSync (node:fs:585:3)
          at Object.readFileSync (node:fs:453:35)
          at Object.readFileSync (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/jsonfile/index.js:50:22)
          at dbConnect (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3088:23)
          at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1308:13)
          at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3314:5)
          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:24)
          at Module._compile (node:internal/modules/cjs/loader:1103:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10)
          at Module.load (node:internal/modules/cjs/loader:981:32)
        Thomas Braun Most Active @ChrisNett last edited by
        @christian-sandkaulen
        Keine Ahnung wie oder wer die iobroker.json anlegt.
        Versuch mal
        iobroker setup first
        ChrisNett 1 Reply Last reply Reply Quote 0
        • ChrisNett
          danke, scheinbar war es das er fährt hoch
          pi@PI4:/opt/iobroker $ iobroker setup first
          creating conf/iobroker.json
          Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
          + system.adapter.admin.1                  : admin                 : PI4                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.1                 : alexa2                : PI4                                      -  enabled
            system.adapter.backitup.0               : backitup              : PI4                                      -  enabled
          + system.adapter.broadlink2.0             : broadlink2            : PI4                                      -  enabled
          + system.adapter.cloud.0                  : cloud                 : PI4                                      -  enabled
            system.adapter.coronavirus-statistics.0 : coronavirus-statistics: PI4                                      -  enabled
          + system.adapter.denon.0                  : denon                 : PI4                                      -  enabled
            system.adapter.devices.0                : devices               : PI4                                      - disabled
            system.adapter.discovery.0              : discovery             : PI4                                      - disabled
          + system.adapter.dwd.0                    : dwd                   : PI4                                      -  enabled
            system.adapter.echarts.0                : echarts               : PI4                                      -  enabled
            system.adapter.fahrplan.0               : fahrplan              : PI4                                      -  enabled
            system.adapter.fb-checkpresence.0       : fb-checkpresence      : PI4                                      -  enabled
          + system.adapter.feiertage.0              : feiertage             : PI4                                      -  enabled
            system.adapter.flot.0                   : flot                  : PI4                                      - disabled
          + system.adapter.history.0                : history               : PI4                                      -  enabled
          + system.adapter.hmip.0                   : hmip                  : PI4                                      -  enabled
            system.adapter.ical.0                   : ical                  : PI4                                      -  enabled
            system.adapter.ical.1                   : ical                  : PI4                                      -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: PI4                                      - disabled
            system.adapter.icons-icons8.0           : icons-icons8          : PI4                                      - disabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : PI4                                      - disabled
            system.adapter.info.0                   : info                  : PI4                                      -  enabled
            system.adapter.iot.0                    : iot                   : PI4                                      -  enabled
          + system.adapter.javascript.0             : javascript            : PI4                                      -  enabled
          + system.adapter.klf200.0                 : klf200                : PI4                                      -  enabled
            system.adapter.logparser.0              : logparser             : PI4                                      - disabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : PI4                                      -  enabled, port: 54321
          + system.adapter.mihome-vacuum.1          : mihome-vacuum         : PI4                                      -  enabled, port: 54321
          + system.adapter.mihome-vacuum.2          : mihome-vacuum         : PI4                                      -  enabled, port: 54321
            system.adapter.mqtt.0                   : mqtt                  : PI4                                      - disabled, port: 1893, bind: 0.0.0.0
            system.adapter.onvif.0                  : onvif                 : PI4                                      - disabled
            system.adapter.parcel.0                 : parcel                : PI4                                      -  enabled
            system.adapter.parser.0                 : parser                : PI4                                      - disabled
          + system.adapter.pegelalarm.0             : pegelalarm            : PI4                                      -  enabled
            system.adapter.pi-hole.0                : pi-hole               : PI4                                      -  enabled
          + system.adapter.ping.0                   : ping                  : PI4                                      -  enabled
          + system.adapter.pollenflug.0             : pollenflug            : PI4                                      -  enabled
            system.adapter.pvforecast.0             : pvforecast            : PI4                                      -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : PI4                                      -  enabled
          + system.adapter.samsung.0                : samsung               : PI4                                      -  enabled
          + system.adapter.shelly.0                 : shelly                : PI4                                      -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : PI4                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : PI4                                      -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.sourceanalytix.0         : sourceanalytix        : PI4                                      - disabled
            system.adapter.tankerkoenig.0           : tankerkoenig          : PI4                                      -  enabled
          + system.adapter.telegram.0               : telegram              : PI4                                      -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.text2command.0           : text2command          : PI4                                      -  enabled
          + system.adapter.tr-064.0                 : tr-064                : PI4                                      -  enabled
            system.adapter.trashschedule.0          : trashschedule         : PI4                                      -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : PI4                                      - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : PI4                                      - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : PI4                                      - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : PI4                                      - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : PI4                                      -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : PI4                                      - disabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : PI4                                      - disabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : PI4                                      - disabled
            system.adapter.vis-metro.0              : vis-metro             : PI4                                      - disabled
            system.adapter.vis.0                    : vis                   : PI4                                      -  enabled
          + system.adapter.weatherunderground.0     : weatherunderground    : PI4                                      -  enabled
            system.adapter.web-speedy.0             : web-speedy            : PI4                                      - disabled
            system.adapter.web.0                    : web                   : PI4                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.worx.0                   : worx                  : PI4                                      -  enabled
          + system.adapter.zigbee.0                 : zigbee                : PI4                                      -  enabled, port: /dev/ttyUSB0
          + instance is alive
          • ChrisNett
            ChrisNett @ChrisNett last edited by
            kommt jetzt muss ich da noch was machen?
              Thomas Braun Most Active @ChrisNett last edited by Thomas Braun
              Das heißt, du warst noch gar nicht auf jsonl?
              Dann ist es jetzt wohl so weit.
              iobroker status
              sagt?
              iobroker update -i
              • ChrisNett
                pi@PI4:/opt/iobroker $ iobroker status
                Objects type: jsonl
                States  type: jsonl
                pi@PI4:/opt/iobroker $ iobroker update -i
                Used repository: Stable (default)
                Adapter    "admin"        : 5.3.8    , installed 5.3.8
                Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
                Adapter    "backitup"     : 2.4.6    , installed 2.4.6
                Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                Adapter    "cloud"        : 4.1.1    , installed 4.1.1
                Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                Adapter    "denon"        : 1.13.3   , installed 1.13.3
                Adapter    "devices"      : 1.0.10   , installed 1.0.10
                Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                Adapter    "echarts"      : 1.0.3    , installed 1.0.3
                Adapter    "fahrplan"     : 1.2.0    , installed 1.2.0
                Adapter    "fb-checkpresence": 1.1.14, installed 1.1.14
                Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                Adapter    "flot"         : 1.10.7   , installed 1.10.7
                Adapter    "history"      : 1.11.1   , installed 1.11.1
                Adapter    "hmip"         : 1.15.4   , installed 1.15.4
                Adapter    "hs100"        : 2.0.6    , installed 2.0.6
                Adapter    "ical"         : 1.12.1   , installed 1.12.1
                Adapter    "info"         : 1.9.18   , installed 1.9.18
                Adapter    "iot"          : 1.11.4   , installed 1.11.4
                Adapter    "javascript"   : 5.2.21   , installed 5.2.21
                Controller "js-controller": 4.0.21   , installed 4.0.21
                Adapter    "klf200"       : 1.0.1    , installed 1.0.1
                Adapter    "km200"        : 2.0.3    , installed 2.0.3
                Adapter    "landroid"     : 1.0.3    , installed 1.0.3
                Adapter    "logparser"    : 1.1.0    , installed 1.1.0
                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                Adapter    "mihome-vacuum": 3.3.1    , installed 3.3.1
                Adapter    "moma"         : 1.2.9    , installed 1.2.9
                Adapter    "mqtt"         : 2.7.4    , installed 2.7.4
                Adapter    "onvif"        : 0.4.4    , installed 0.4.4
                Adapter    "parcel"       : 0.0.15   , installed 0.0.15
                Adapter    "parser"       : 1.1.4    , installed 1.1.4
                Adapter    "pegelalarm"   : 1.2.5    , installed 1.2.5
                Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
                Adapter    "ping"         : 1.5.3    , installed 1.5.3
                Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                Adapter    "samsung"      : 0.2.9    , installed 0.2.9
                Adapter    "seq"          : 0.2.10   , installed 0.2.10
                Adapter    "shelly"       : 5.3.2    , installed 5.3.2
                Adapter    "simple-api"   : 2.6.4    , installed 2.6.4
                Adapter    "sonoff"       : 2.5.0    , installed 2.5.0
                Adapter    "spotify-premium": 1.0.0  , installed 1.1.3
                Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                Adapter    "telegram"     : 1.12.2   , installed 1.12.2
                Adapter    "text2command" : 2.2.1    , installed 2.2.1
                Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                Adapter    "trashschedule": 1.4.5    , installed 1.4.5
                Adapter    "unifi"        : 0.5.10   , installed 0.5.10
                Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                Adapter    "vis"          : 1.4.5    , installed 1.4.5
                Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
                Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                Adapter    "weatherunderground": 3.4.1, installed 3.4.1
                Adapter    "web"          : 4.2.3    , installed 4.2.3
                Adapter    "wifilight"    : 1.1.0    , installed 1.1.0
                Adapter    "worx"         : 1.5.5    , installed 1.5.5
                Adapter    "ws"           : 1.2.0    , installed 1.3.0
                Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
                  Gut. Sollte laufen.
                  • ChrisNett
                    danke, die Visualisierung ist nur weg, kann ich dir irgendwie aus dem backup wieder herstellen?
                      Ich hab keine Vis laufen. Ich kann dir nicht sagen ob und wie die gebackupt wird.
                        Homoran Global Moderator Administrators @ChrisNett last edited by
                        @christian-sandkaulen sagte in Npm Fehler / ioBroker startet nicht:
                        irgendwo müsste die vis-views.json liegen. Da sind alle Views drin
                        • ChrisNett
                          ChrisNett @Homoran last edited by
                          @homoran sagte in Npm Fehler / ioBroker startet nicht:
                          danke die habe ich gefunden aber wie spiele ich das wieder ein? Import? View
                            Austauschen!
                            Da sind alle Views und Projekte drin
                            • ChrisNett
                              Austauschen!
                              okay als nicht linux user was ist der einfachtse weg? FTP oder geht das auch per ssh?
                                Als Nicht Linux User kann ich dir nicht sagen, wie es mit SSH geht.
                                Dazu könnte @Thomas-Braun etwas sagen.
                                Ich mache es mit filezilla, aber als user, der auch in der Gruppe iobroker ist, auf keinen Fall als root
                                • ChrisNett
                                  also nicht der "pi" std user?
                                    bei mir ist der user pi in der Gruppe iobroker drin
                                    Aber warte doch mal auf die Antwort von Thomas
                                    • ChrisNett
                                      @thomasBraun
                                      könntest du mir helfen?
                                        Wo liegt die Datei denn nun?
                                        cp /pfad/zur/quelle /pfad/zum/ziel
                                        Vorausgesetzt dein Standarduser ist in der Gruppe 'iobroker' drin.
                                        Sonst:
                                        sudo -u iobroker cp /pfad/zur/quelle /pfad/zum/ziel
                                        • ChrisNett
                                          Sonst:
                                          ähm vom Windows PC zum pi ?
                                            Machs mit Filezilla... 😄
                                            Ich würde mir vermutlich eine SMB-Freigabe auf dem Windows einrichten und die in den Raspberry mounten und dann von dort wegkopieren.
                                            npm err
                                            3090
