    3. Einsteigerfragen
    4. Npm Fehler / ioBroker startet nicht
      Thomas Braun Most Active @ChrisNett last edited by Thomas Braun
      @christian-sandkaulen
      Das heißt, du warst noch gar nicht auf jsonl?
      Dann ist es jetzt wohl so weit.
      iobroker status
      sagt?
      iobroker update -i
      ChrisNett 1 Reply Last reply Reply Quote 0
      • ChrisNett
        ChrisNett @Thomas Braun last edited by ChrisNett
        @thomas-braun sagte in Npm Fehler / ioBroker startet nicht:
        pi@PI4:/opt/iobroker $ iobroker status
        Objects type: jsonl
        States  type: jsonl
        pi@PI4:/opt/iobroker $ iobroker update -i
        Used repository: Stable (default)
        Adapter    "admin"        : 5.3.8    , installed 5.3.8
        Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
        Adapter    "backitup"     : 2.4.6    , installed 2.4.6
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "cloud"        : 4.1.1    , installed 4.1.1
        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
        Adapter    "denon"        : 1.13.3   , installed 1.13.3
        Adapter    "devices"      : 1.0.10   , installed 1.0.10
        Adapter    "discovery"    : 3.0.3    , installed 3.0.3
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "echarts"      : 1.0.3    , installed 1.0.3
        Adapter    "fahrplan"     : 1.2.0    , installed 1.2.0
        Adapter    "fb-checkpresence": 1.1.14, installed 1.1.14
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "flot"         : 1.10.7   , installed 1.10.7
        Adapter    "history"      : 1.11.1   , installed 1.11.1
        Adapter    "hmip"         : 1.15.4   , installed 1.15.4
        Adapter    "hs100"        : 2.0.6    , installed 2.0.6
        Adapter    "ical"         : 1.12.1   , installed 1.12.1
        Adapter    "info"         : 1.9.18   , installed 1.9.18
        Adapter    "iot"          : 1.11.4   , installed 1.11.4
        Adapter    "javascript"   : 5.2.21   , installed 5.2.21
        Controller "js-controller": 4.0.21   , installed 4.0.21
        Adapter    "klf200"       : 1.0.1    , installed 1.0.1
        Adapter    "km200"        : 2.0.3    , installed 2.0.3
        Adapter    "landroid"     : 1.0.3    , installed 1.0.3
        Adapter    "logparser"    : 1.1.0    , installed 1.1.0
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mihome-vacuum": 3.3.1    , installed 3.3.1
        Adapter    "moma"         : 1.2.9    , installed 1.2.9
        Adapter    "mqtt"         : 2.7.4    , installed 2.7.4
        Adapter    "onvif"        : 0.4.4    , installed 0.4.4
        Adapter    "parcel"       : 0.0.15   , installed 0.0.15
        Adapter    "parser"       : 1.1.4    , installed 1.1.4
        Adapter    "pegelalarm"   : 1.2.5    , installed 1.2.5
        Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "radar2"       : 2.0.3    , installed 2.0.3
        Adapter    "samsung"      : 0.2.9    , installed 0.2.9
        Adapter    "seq"          : 0.2.10   , installed 0.2.10
        Adapter    "shelly"       : 5.3.2    , installed 5.3.2
        Adapter    "simple-api"   : 2.6.4    , installed 2.6.4
        Adapter    "sonoff"       : 2.5.0    , installed 2.5.0
        Adapter    "spotify-premium": 1.0.0  , installed 1.1.3
        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
        Adapter    "telegram"     : 1.12.2   , installed 1.12.2
        Adapter    "text2command" : 2.2.1    , installed 2.2.1
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "trashschedule": 1.4.5    , installed 1.4.5
        Adapter    "unifi"        : 0.5.10   , installed 0.5.10
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis"          : 1.4.5    , installed 1.4.5
        Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
        Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
        Adapter    "weatherunderground": 3.4.1, installed 3.4.1
        Adapter    "web"          : 4.2.3    , installed 4.2.3
        Adapter    "wifilight"    : 1.1.0    , installed 1.1.0
        Adapter    "worx"         : 1.5.5    , installed 1.5.5
        Adapter    "ws"           : 1.2.0    , installed 1.3.0
        Adapter    "zigbee"       : 1.6.16   , installed 1.6.16
          Gut. Sollte laufen.
          • ChrisNett
            danke, die Visualisierung ist nur weg, kann ich dir irgendwie aus dem backup wieder herstellen?
              Ich hab keine Vis laufen. Ich kann dir nicht sagen ob und wie die gebackupt wird.
                Homoran Global Moderator Administrators @ChrisNett last edited by
                @christian-sandkaulen sagte in Npm Fehler / ioBroker startet nicht:
                irgendwo müsste die vis-views.json liegen. Da sind alle Views drin
                • ChrisNett
                  ChrisNett @Homoran last edited by
                  @homoran sagte in Npm Fehler / ioBroker startet nicht:
                  danke die habe ich gefunden aber wie spiele ich das wieder ein? Import? View
                    Austauschen!
                    Da sind alle Views und Projekte drin
                    • ChrisNett
                      Austauschen!
                      okay als nicht linux user was ist der einfachtse weg? FTP oder geht das auch per ssh?
                        Als Nicht Linux User kann ich dir nicht sagen, wie es mit SSH geht.
                        Dazu könnte @Thomas-Braun etwas sagen.
                        Ich mache es mit filezilla, aber als user, der auch in der Gruppe iobroker ist, auf keinen Fall als root
                        • ChrisNett
                          also nicht der "pi" std user?
                            bei mir ist der user pi in der Gruppe iobroker drin
                            Aber warte doch mal auf die Antwort von Thomas
                            • ChrisNett
                              @thomasBraun
                              könntest du mir helfen?
                                Wo liegt die Datei denn nun?
                                cp /pfad/zur/quelle /pfad/zum/ziel
                                Vorausgesetzt dein Standarduser ist in der Gruppe 'iobroker' drin.
                                Sonst:
                                sudo -u iobroker cp /pfad/zur/quelle /pfad/zum/ziel
                                • ChrisNett
                                  Sonst:
                                  ähm vom Windows PC zum pi ?
                                    Machs mit Filezilla... 😄
                                    Ich würde mir vermutlich eine SMB-Freigabe auf dem Windows einrichten und die in den Raspberry mounten und dann von dort wegkopieren.
                                    • ChrisNett
                                      🙂 in welchem verzeichnis liegt die datei ? /home/pi... und dann ?
                                        Ich dachte die liegt auf einem Windows?
                                        • ChrisNett
                                          ja ich habe aus dem goole backup die datei gezogen und muss die doch jetzt auf dem pi spielen oder?
                                            Da ich keine vis laufen habe kann ich dir auch nicht sagen wo die json liegen muss.
                                            npm err
                                            2078
