    4. [Aufruf] Zwave - security devices
      Pman last edited by
      Ich konnte es nur mit Geräten testen, welche Security unterstützen, aber nicht zwingend.
      Auf jeden Fall bekomme ich in der Log Datei am Ende Meldungen wie hier beschrieben: https://github.com/OpenZWave/open-zwave … ces-to-OZW
      So sieht es wohl optimalerweise aus:
      2014-06-09 22:59:16.671 Node020,   Secured command classes for node 20:
      2014-06-09 22:59:16.672 Node020,     COMMAND_CLASS_ASSOCIATION (Secured)
      2014-06-09 22:59:16.672 Node020,     COMMAND_CLASS_BASIC (Secured)
      2014-06-09 22:59:16.672 Node020,     COMMAND_CLASS_BATTERY (Secured)
      2014-06-09 22:59:16.672 Node020,     COMMAND_CLASS_DOOR_LOCK (Secured)
      2014-06-09 22:59:16.672 Node020,     Secure CommandClass 0x4c - NOT SUPPORTED
      2014-06-09 22:59:16.672 Node020,     COMMAND_CLASS_MANUFACTURER_SPECIFIC (Secured)
      2014-06-09 22:59:16.672 Node020,     Secure CommandClass 0x4e - NOT SUPPORTED
      2014-06-09 22:59:16.672 Node020,     Secure CommandClass 0x8b - NOT SUPPORTED
      2014-06-09 22:59:16.672 Node020,     COMMAND_CLASS_USER_CODE (Secured)
      2014-06-09 22:59:16.672 Node020,     COMMAND_CLASS_VERSION (Secured)
      2014-06-09 22:59:16.672 Node020,   UnSecured command classes for node 20:
      2014-06-09 22:59:16.672 Node020,     COMMAND_CLASS_NO_OPERATION (Unsecured)
      2014-06-09 22:59:16.672 Node020,     COMMAND_CLASS_SECURITY (Unsecured)
        Pman last edited by
        Anlernen eines "Aeotec ZW074 MultiSensor Gen5":
        2017-05-04 18:03:20.249 Detail,
        2017-05-04 18:03:20.249 Info, Node014, Response RTT 180 Average Response RTT 116
        2017-05-04 18:03:20.249 Info, Node014, Received SecurityCmd_SupportedReport from node 14
        2017-05-04 18:03:20.249 Info, Node014,   Secured command classes for node 14:
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_VERSION (Secured) - InNIF
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_MANUFACTURER_SPECIFIC (Secured) - InNIF
        2017-05-04 18:03:20.250 Info, Node014,     Secure CommandClass 0x59 - NOT SUPPORTED
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_ASSOCIATION (Secured) - InNIF
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_POWERLEVEL (Secured) - InNIF
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_ALARM (Secured) - InNIF
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_BATTERY (Secured) - InNIF
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_SENSOR_BINARY (Secured) - InNIF
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_SENSOR_MULTILEVEL (Secured) - InNIF
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_CONFIGURATION (Secured) - InNIF
        2017-05-04 18:03:20.250 Info, Node014,     Secure CommandClass 0x7a - NOT SUPPORTED
        2017-05-04 18:03:20.250 Info, Node014,     Secure CommandClass 0x4f - NOT SUPPORTED
        2017-05-04 18:03:20.250 Info, Node014,   UnSecured command classes for node 14:
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_NO_OPERATION (Unsecured) - NotInNIF
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_BASIC (Unsecured) - NotInNIF
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_DEVICE_RESET_LOCALLY (Unsecured) - InNIF
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_ZWAVE_PLUS_INFO (Unsecured) - InNIF
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_HAIL (Unsecured) - InNIF
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_WAKE_UP (Unsecured) - InNIF
        2017-05-04 18:03:20.250 Info, Node014,     COMMAND_CLASS_SECURITY (Unsecured) - InNIF
        2017-05-04 18:03:20.250 Detail, Node014,   Expected reply and command class was received
        2017-05-04 18:03:20.251 Detail, Node014,   Message transaction complete
          Stormbringer last edited by
          So Danalock V2, wäre jetzt erfolgreich gepaired sogar secure. Kann nun via ioBroker das Danalock schließen und öffnen 😄
          Würde euch gerne die Datei schicken aber habe sie auch nach dem ausschalten des "Console Outputs" nicht. Vielleicht suche ich ja auch am falschen Ort :?:
          siehe Post
          http://forum.iobroker.net/viewtopic.php … 1&start=20
          Oder reicht euch die Info, dass es funktioniert?
          Top Arbeit, danke 😄
          Der Aeon Multisensor 6 ZW100 werkelt hoffentlich noch. In den Objekten ist er vollständig sichtbar, in der Adapterübersicht taucht er gar nicht auf.
          Dafür ist der vorherige Danalockeintrag (unsecure) in den Objekten noch immer da und in der Adapterübersicht nicht mehr (wie es richtig ist). Löschen von dem Datenpunkt funktioniert nicht. Es kommt keine Fehlermeldung aber Objekt ist auch nach aktualisieren noch da.
            Jetzt bin ich es nochmal… Mir ist gerade was eigenartiges aufgefallen. Bei mir stimmt die RAM Anzeige nicht mehr im Instanzen Reiter. Ich habe normalerweise 8 GB RAM, vor Installation des neuen Z-Wave Adapters hat er das eigentlich immer richtig angezeigt. Jetzt stimmt die Gesamtanzeige nicht mehr und Verbrauch kann eigentlich auch nicht stimmen... Hatte immer 90% RAM frei. Im Log sind keine Warnungen.
              stay cool - immer das selbe Thema:
              frei ist nicht "nicht benutzt"!
              http://www.linuxatemyram.com
              Rainer
                Hi Rainer,
                sicher? Vorher war das nie. Und Gesamt stimmt ja auch nicht mehr 😉
                Im Terminal stimmt Gesamt noch aber der Rechnung kann ich nicht folgen…. wie man bei 1.5936 minus 1023 auf 1406 kommt ist mir ein Rätsel. Sollte lieber schlafen gehen, bis morgen :lol:
                  @Stormbringer:
                  sicher? `
                  99,9% 😉
                  @Stormbringer:
                  Vorher war das nie `
                  ich nehme an du hast irgendeine speicherfressende Aktivität gemacht (Update o.ä.) der wurde der wirklich freie RAM zugeordnet, ist jetzt wieder nicht benötigt, abr Linx lässt ihn erst mal da wo er zuletzt gebraucht wurde, falls du da noch was machen wolltest.
                  @Stormbringer:
                  Und Gesamt stimmt ja auch nicht mehr `
                  Wird ja auch nicht angegeben 😉
                  Used + cached + free = total.
                  cached ist nicht angegeben.
                  Rainer
                    @Homoran:
                    ich nehme an du hast irgendeine speicherfressende Aktivität gemacht (Update o.ä.) `
                    ja den Z-Wave Adapter habe ich geupdated 😉
                    @Stormbringer:
                    Wird ja auch nicht angegeben `
                    Stimmt 😉 Gut, dann war das wohl Fehlalarm. So viel Speicher hat dann vorher noch kein anderer Adapter zum Updaten gefressen 😉 Sorry, mach reboot.
                      @Stormbringer:
                      Sorry, mach reboot. `
                      Warum?
                      Ist alles grün!!!!
                      der "freie" RAM ist absolut unwichtig in Linux!
                      der wird automatisch immer gegen 0 (bei mir normalerweise um die 10%) gehen.
                      Ganz von alleine und langsam.
                      Rainer
                        schon vorbei Rainer aber beim nàchsten Mal dann.
                        Also der Aeon Multisensor 6 ZW100…. habe es jetzt mehrfach probiert. Wenn er mal richtig inkludiert wird im Secure Mode zeigt er immer Bewegung an. Der State bleibt auf "true" hàngen, im dunklen leeren Raum.
                        • AlCalzone
                          @Stormbringer:
                          Der State bleibt auf "true" hàngen, im dunklen leeren Raum. `
                          Was ist in der Konfiguration bei On-Time gesetzt? Standard sind 240s, d.h. der Bewegungsmelder wird 4 Minuten auf true stehen bleiben.
                            Pman last edited by
                            @Stormbringer:
                            Also der Aeon Multisensor 6 ZW100…. habe es jetzt mehrfach probiert. Wenn er mal richtig inkludiert wird im Secure Mode zeigt er immer Bewegung an. Der State bleibt auf "true" hàngen, im dunklen leeren Raum. `
                            Beim Multisensor 5 muss man erstmal in der Sensor-Config auf Binary Report stellen, sonst tut sich bei dem State gar nichts. Beim Konfigurieren außerdem darauf achten, dass der Sensor nicht gerade schläft, sonst bekommt der nichts mit von der Änderung.
                              @AlCalzone:
                              Beim Multisensor 5 muss man erstmal in der Sensor-Config auf Binary Report stellen, sonst tut sich bei dem State gar nichts. Beim Konfigurieren außerdem darauf achten, dass der Sensor nicht gerade schläft, sonst bekommt der nichts mit von der Änderung. `
                              Danke das wars 😄 Frage mich echt woher man das wissen soll ohne euch 😢 Aeon steht wohl nicht auf auspacken, einschalten, geht :lol:
                              • AlCalzone
                                @Stormbringer:
                                Aeon steht wohl nicht auf auspacken, einschalten, geht :lol: `
                                Glaub mir, die Dinger sind ein Traum verglichen mit dem Ärger, den andere Geräte machen.
                                Bei den Greenwave 1-Port Steckdosen muss man 2 nicht/schlecht dokumentierte Parameter schalten, damit nicht nach 2 Minuten ne superhelle LED-Disko beginnt.
                                Bei Funk-Heizkörperthermostaten muss man i.d.R. für jede Konfig-Änderung einen Knopf manuell betätigen oder 15 Minuten warten.
                                  @AlCalzone:
                                  Glaub mir, die Dinger sind ein Traum verglichen mit dem Ärger, den andere Geräte machen. `
                                  Bei mir ist das Fibaro, die ärgern mich gar nicht unter ioBroker. Hab von Aeon nur den Multisensor und den Garage Door Controller. Beim Multisensor wusste ich es mit der Time Out Funktion, dass man auf Binary umstellen muss habe ich nirgends entdeckt. Da wäre ich nie drauf gekommen. Und der Garage Door Controller ärgert mich immer wieder, jetzt streikt er komplett. Aber da muss man auch auf Hail umstellen, von selber geht er wieder nicht. Alle anderen Devices von Fibaro gehen gleich mit den richtigen Parametern. Aber vielleicht gewöhne ich mich noch daran. Als 2. Sensor ist der Aeon wegen der Repeater Funktion und direktem Stromanschluß gut. Designtechnisch ist Geschmackssache..
                                  • AlCalzone
                                    Ja, die Fibaros sind super einfach, wenn man sich an den seltsamen Reset gewöhnt. Beim Relais muss man am Strom spielen (aus, Knopf drücken, an), was mir gar nicht gefällt. Das ist beim Dimmer/RGBW deutlich besser gelöst.
                                      Die Wallmote von Aeon ist aber richtig nice 😉 Löscht ihr jetzt eigentlich alle Devices und added sie wieder secure oder nur die, die ohne nicht gehen (wie das Danalock)?
                                      Meshed das Z Wave Netzwerk eigentlich noch alle Geräte, wenn welche secure und welche non-secure sind?
                                        Pman last edited by
                                        Ohne jetzt genaue Details des Zwave-Protokolls zu kennen: ein unsecure Device sollte die Nachrichten von secure Geräten ohne Probleme weiterleiten können, da normalerweise nur die Payload verschlüsselt wird, nicht der Empfänger.
                                        Anders ist es natürlich, wenn ein unsecure Gerät ein Secure Gerät direkt schalten soll, das wird nicht funktionieren.
                                        • AlCalzone
                                          @Stormbringer:
                                          Die Wallmote von Aeon ist aber richtig nice `
                                          Hast du die mit dem Zwave-Adapter am Laufen?! Meine liegt noch untätig in der Ecke.
                                            Ja der ist eingebunden und läuft. Ist zwar etwas strange zum Einbinden aber werkelt brav. Der sendet nur Parameter 9 + 10 an ioBroker und da auch immer eine andere Zahl. Da muss man dann vorher die Zahlenrange eingrenzen und dann mit einer Wischbewegung assoziieren. Direktes drücken habe ich noch nicht hinbekommen aber brauche ich im Moment auch nicht. Es funktioniert derzeit nur streichen.
                                            Aber jetzt mal was anderes. Seid mir bitte ned böse aber irgendwas stimmt mit dem Adapter wirklich nicht. Das er seine gewissen Tücken aufgrund der Komplexität hat, bin ich ja schon gewohnt. Aber der wird immer schlimmer, schaltet mitten drinnen die Geräte nicht mehr. Dann muss man sie wieder löschen und neu einbinden. Jetzt seit neuestem rappelt er sich nach dem neu Einbinden gar nicht mehr ein. Sprich er zeigt bei keinem Device mehr Empfang an, die vorher alle vollen Empfang hatten. Früher hat öfteres Neustarten geholfen, jetzt mag er gar nimmer. Im Log steht nichts. Wenn ihr mir sagt wo ich sonst noch nachschauen soll oder andere Informationen braucht schicke ich die natürlich gerne.
                                            3490
