    3. Einsteigerfragen
    4. Zigbee Adapter Wechsel Conbee 2
      Thomas Braun Most Active @Dunadanlk last edited by
      @dunadanlk
      Trag schon mal
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2451654-if00
      als Gerätelink im Adapter ein
        Dunadanlk @Thomas Braun last edited by
        erledigt👍
        Achso,weiß nicht ob es möglicherweise zusammen hängen kann... habe seit einigen Tagen einen Restart Loop im Systeminfo Adapter.
        systeminfo.0
        2022-04-24 20:43:58.623	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        systeminfo.0
        2022-04-24 20:43:58.621	info	terminating
        systeminfo.0
        2022-04-24 20:43:58.087	error	Cannot read property 'getObjectList' of undefined
        systeminfo.0
        2022-04-24 20:43:58.085	error	TypeError: Cannot read property 'getObjectList' of undefined at Function.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37) at Adapter.emit (events.js:314:20) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8226:26
        systeminfo.0
        2022-04-24 20:43:58.082	error	unhandled promise rejection: Cannot read property 'getObjectList' of undefined
        systeminfo.0
        2022-04-24 20:43:58.081	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        systeminfo.0
        2022-04-24 20:43:58.039	info	starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v12.22.10, js-controller: 4.0.21
          @dunadanlk
          Nein.
          Aber bring deine node-Installation auf Version 14.
          • Asgothian
            Asgothian Developer @Dunadanlk last edited by
            @dunadanlk
            Bitte mach das folgende:
            • zigbee adapter anhalten
            • log löschen
            • zigbee adapter starten
            • 30 sekunden warten
            • alle Log Meldungen des Zigbee Adapters als text posten.
            A.
              Dunadanlk @Asgothian last edited by
              @asgothian 2022-04-24 21:12:32.005 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
              2022-04-24 21:12:32.152 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 10827
              2022-04-24 21:12:35.646 - info: zigbee.0 (10827) starting. Version 1.6.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.21
              2022-04-24 21:12:35.756 - info: zigbee.0 (10827) Starting Zigbee npm ...
              2022-04-24 21:12:36.391 - error: zigbee.0 (10827) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2451654-if00'"
              2022-04-24 21:12:36.392 - error: zigbee.0 (10827) Failed to start Zigbee
              2022-04-24 21:12:36.393 - error: zigbee.0 (10827) Error herdsman start
              2022-04-24 21:12:36.396 - info: zigbee.0 (10827) Installed Version: iobroker.zigbee@1.6.16
              2022-04-24 21:12:46.396 - info: zigbee.0 (10827) Try to reconnect. 1 attempts left
              2022-04-24 21:12:46.397 - info: zigbee.0 (10827) Starting Zigbee npm ...
              2022-04-24 21:12:46.419 - info: zigbee.0 (10827) Installed Version: iobroker.zigbee@1.6.16
              2022-04-24 21:12:46.652 - error: zigbee.0 (10827) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2451654-if00'"
              2022-04-24 21:12:46.653 - error: zigbee.0 (10827) Failed to start Zigbee
              2022-04-24 21:12:46.654 - error: zigbee.0 (10827) Error herdsman start
              2022-04-24 21:13:06.266 - error: zigbee.0 (10827) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2022-04-24 21:13:06.267 - error: zigbee.0 (10827) unhandled promise rejection: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2451654-if00'
              2022-04-24 21:13:06.268 - error: zigbee.0 (10827) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2451654-if00'
              at SerialPort. (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28)
              at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
              at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
              2022-04-24 21:13:06.268 - error: zigbee.0 (10827) Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2451654-if00'
              2022-04-24 21:13:06.283 - info: zigbee.0 (10827) cleaned everything up...
              2022-04-24 21:13:06.286 - info: zigbee.0 (10827) Zigbee: disabling joining new devices.
              2022-04-24 21:13:06.290 - info: zigbee.0 (10827) terminating
              2022-04-24 21:13:06.292 - warn: zigbee.0 (10827) Terminated (UNCAUGHT_EXCEPTION): Without reason
                @dunadanlk
                Hast du eigentlich deconz zuvor gestoppt oder deinstalliert?
                  @thomas-braun erst nicht... Als es nicht funktionierte habe ich erst zigbee deinstalliert, dann deconz deinstalliert und dann zigbee wieder installiert. Brachte aber keine Veränderung
                    @dunadanlk
                    systemctl status deconz deconz-gui
                      ● deconz.service - deCONZ: ZigBee gateway -- REST API
                      Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
                      Active: active (running) since Sun 2022-04-24 14:17:04 CEST; 7h ago
                      Main PID: 407 (deCONZ)
                      Tasks: 4 (limit: 4915)
                      CGroup: /system.slice/deconz.service
                      └─407 /usr/bin/deCONZ -platform minimal --http-port=80
                      Apr 24 14:17:04 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
                      Apr 24 14:17:05 raspberrypi deCONZ[407]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                      Apr 24 14:17:06 raspberrypi deCONZ[407]: libpng warning: iCCP: known incorrect sRGB profile
                      Apr 24 14:17:07 raspberrypi deCONZ[407]: This plugin does not support propagateSizeHints()
                      Apr 24 14:17:09 raspberrypi deCONZ[407]: This plugin does not support propagateSizeHints()
                      ● deconz-gui.service - deCONZ: ZigBee gateway -- GUI/REST API
                      Loaded: loaded (/lib/systemd/system/deconz-gui.service; disabled; vendor preset: enabled)
                      Active: inactive (dead)
                      Apr 24 21:30:24 raspberrypi systemd[1]: /lib/systemd/system/deconz-gui.service:10: Unknown lvalue 'StartLimitIntervalSec' in section 'Service', ignoring
                      Apr 24 21:32:52 raspberrypi systemd[1]: /lib/systemd/system/deconz-gui.service:10: Unknown lvalue 'StartLimitIntervalSec' in section 'Service', ignoring
                        Thomas Braun Most Active @Dunadanlk last edited by Thomas Braun
                        @dunadanlk
                        deconz läuft noch
                        sudo systemctl stop deconz
                        sudo systemctl disable deconz
                        Bitte setze Konsolenoutput in CodeTags.
                          @thomas-braun ....verrückt.. danke... Scheint alles zu funktionieren wie es soll. pairing läuft. also für dummys, der Fehler war letztlich, dass ich Deconz vor dem deinstallieren im IOB hätte... Stoppen müssen? Grüße
                            @dunadanlk
                            Der Service lief noch. Es kann auf ein serielles Gerät immer nur ein Prozess zugreifen.
                            1.0k
                            780
