    4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    • Merlin123
      Merlin123 last edited by
      So.... Nach 2 Tagen Waschen und Trocknen ist der Adapter sauber durchgelaufen 🙂
        genau_der last edited by
        der Adapter läuft bei mir grundsätzlich, wenn jedoch unser Geschirrspüler läuft, bekomme ich immer folgende Warnungen im Log:
        2022-04-18 10:39:44.755 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "18" greater than max "null"
        2022-04-18 10:39:44.795 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4680" greater than max "null"
        2022-04-18 10:40:44.757 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "19" greater than max "null"
        2022-04-18 10:40:44.799 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4620" greater than max "null"
        2022-04-18 10:41:44.747 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "20" greater than max "null"
        2022-04-18 10:41:44.787 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4560" greater than max "null"
        2022-04-18 10:42:44.763 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "21" greater than max "null"
        2022-04-18 10:42:44.803 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4500" greater than max "null"
        2022-04-18 10:43:44.727 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "22" greater than max "null"
        2022-04-18 10:43:44.767 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4440" greater than max "null"
        2022-04-18 10:44:44.758 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "23" greater than max "null"
        2022-04-18 10:44:44.799 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4380" greater than max "null"
        2022-04-18 10:45:44.755 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "24" greater than max "null"
        2022-04-18 10:45:44.795 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4320" greater than max "null"
        2022-04-18 10:46:44.761 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "25" greater than max "null"
        2022-04-18 10:46:44.803 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4260" greater than max "null"
        2022-04-18 10:47:44.755 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "26" greater than max "null"
        2022-04-18 10:47:44.799 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4200" greater than max "null"
        2022-04-18 10:48:44.763 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "27" greater than max "null"
        2022-04-18 10:48:44.803 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4140" greater than max "null"
        2022-04-18 10:49:44.761 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "28" greater than max "null"
        2022-04-18 10:49:44.803 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4080" greater than max "null"
        2022-04-18 10:50:44.770 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "29" greater than max "null"
        2022-04-18 10:50:44.811 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "4020" greater than max "null"
        2022-04-18 10:51:44.742 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "31" greater than max "null"
        2022-04-18 10:51:44.783 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "3960" greater than max "null"
        2022-04-18 10:52:44.767 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "32" greater than max "null"
        2022-04-18 10:52:44.807 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "3900" greater than max "null"
        2022-04-18 10:53:44.751 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_ProgramProgress" has value "33" greater than max "null"
        2022-04-18 10:53:44.791 - warn: homeconnect.0 (1903) State value to set for "homeconnect.0.010090386564000321.programs.active.options.BSH_Common_Option_RemainingProgramTime" has value "3840" greater than max "null"
        Was kann ich hier tun um das abzustellen?
        Vielen Dank und beste Grüße!
        Gargano T 2 Replies Last reply Reply Quote 0
        • Gargano
          Gargano @genau_der last edited by
          @genau_der Unter dem jeweiligen Object einen max Wert reinschreiben. Oder den log Level von der Instanz auf Error setzen
            tombox @genau_der last edited by tombox
            @genau_der Das kann eigentlich nicht passieren. Seit welcher Version ist das. Hast du was an den objekten geändert. Es sollte helfen homeconnect.0.010090386564000321.programs.active.options zu löschen
              genau_der @Gargano last edited by genau_der
              @gargano Das sollte dann wahrscheinlich dokumentiert sein, wenn man da generell von Hand nacharbeiten muss, oder? Das mit dem Loglevel wäre wahrscheinlich nur eine kosmetische Lösung, aber ich befürchte dass es die Ursache nicht behebt.
              @tombox Versuche mal das Objekt zu löschen und melde mich dann nochmal nach dem nächsten Spülgang. Der Fehler taucht so oder so ähnlich schon länger auf, aber hatte jetzt erst die Muse der Sache mal nachzugehen. Mit welcher Version das losging, kann ich nicht sagen, denke auch nicht, dass meine Logs so weit zurück reichen, als dass ich das auf dem Wege noch nachvollziehen könnte.
              Hab auch noch eine andere Fehlermeldung im Log entdeckt, wahrscheinlich unabhängig davon:
              2022-04-20 13:13:29.549 - info: homeconnect.0 (14125) State value to set for "homeconnect.0.010090386564000321.general.connected" has to be stringified but received type "boolean"
              2022-04-20 13:13:38.640 - info: homeconnect.0 (14125) State value to set for "homeconnect.0.010090386564000321.general.connected" has to be stringified but received type "boolean"
              Vielleicht fällt dir dazu auch noch was ein.
                @genau_der Ja klar empfehlung homeconnect.0. zu löschen und den Adapter neu zustarten
                G werner2000x 2 Replies Last reply Reply Quote 0
                  genau_der @tombox last edited by
                  @tombox Das scheint geholfen zu haben. Konnte keine Fehlermeldungen mehr im Log entdecken.
                    RicoGesch last edited by
                    Hey Leute,
                    ich stehe auf dem Schlauch....
                    ich bekomme den Homeconnect Adapter einfach nicht auf grün. Ich habe alle Schritte ausgeführt wie beschrieben...
                    Im Log steht folgendes:
                    2022-04-24 20:57:56.194 - error: homeconnect.0 (12559) Please check username and password check manually here: https://api.home-connect.com/security/oauth/device_verify?user_code=GKU4-MC5F
                    2022-04-24 20:57:56.195 - error: homeconnect.0 (12559) Error: Request failed with status code 400
                    2022-04-24 20:57:56.195 - error: homeconnect.0 (12559) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
                    habe den Link aufgerufen und auch dort alle Schritte durchgeführt, auch da gab es keine Fehlermeldung.
                    Trotz allem wird er nicht grün..
                    habt ihr noch eine Idee?
                    Gruß Rico
                    Great SUN 1 Reply Last reply Reply Quote 0
                    • Great SUN
                      Great SUN @RicoGesch last edited by
                      @ricogesch welche Version des Adapters hast Du denn?
                      Great SUN R 2 Replies Last reply Reply Quote 0
                      • Great SUN
                        Great SUN @Great SUN last edited by
                        @tombox Ich kann über die App verschiedene Programme steuern, die ich im Adapter nicht ansteuern kann. Meinst, wir können da mal zusammen rauf schauen? Vielleicht kann ich ja irgendwo unterstützen?!
                        T arteck 2 Replies Last reply Reply Quote 0
                          tombox @Great SUN last edited by
                          @great-sun Das ist normal ist limitiert durch die offizielle API
                          https://api-docs.home-connect.com/programs-and-options
                            arteck Developer Most Active @Great SUN last edited by
                            @great-sun mal im ernst.. was willst da am Programm noch steuern.. entweder ist die Spülmaschiene für Programm X gefüllt oder nicht.. zumindest bei uns.. also ich steh da nicht noch rum und denk mir " ahh heute nehm ich weills mir passt dies und jenes programm"
                            und ich finde man muss nicht ALLES steuerbar machen.. nur weil es geht. die Meldung Maschiene ist fertig oder Maschiene ist fertig in..evtl. starte die Maschiene weil die Sonne gerade scheint (PV Anlage) reicht vollkommen...
                            da ist mir wichtiger dass der Adapter durchläuft..
                            • Great SUN
                              Great SUN @arteck last edited by
                              @arteck Ich möchte automatisiert Brot backen. Erst Dünsten und dann backen, ohne dass ich nochmal ran muss.
                              arteck B 2 Replies Last reply Reply Quote 0
                                @great-sun sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                                Erst Dünsten
                                nix dünsten.. Schwaden wenn schon 🙂
                                ahh ok .. dann lag ich mit der Spüllmaschiene daneben.
                                  RicoGesch @Great SUN last edited by
                                  @great-sun Hat sich erledigt, habs hinbekommen.... Manchmal sieht man den Wald vor lauter Bäumen nicht 🙂
                                  Trotzdem Danke
                                  T A D F 4 Replies Last reply Reply Quote 0
                                    tombox @RicoGesch last edited by
                                    @ricogesch Was war es denn vielleicht kann man die fehlermeldung verbessern
                                      Ritschy2000 @tombox last edited by
                                      @tombox
                                      Seit dem Update auf 1.0.1 bekomme ich ständig die Meldung, dass zu viele
                                      Anfragen gemacht wurden :
                                      homeconnect.0 Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
                                      homeconnect.0 	2022-05-02 19:36:40.207	error	429 Too Many Requests
                                      ohne, dass der Adapter neu gestartet wird. Kann ich irgendetwas dagegen tun?
                                        tombox @Ritschy2000 last edited by
                                        @ritschy2000 Welche Geräte hast du in deinem Account wie oft dritt die Meldung auf bzw in welchen Abständen
                                          Ritschy2000 @tombox last edited by Ritschy2000
                                          @tombox
                                          SIEMENS-HM676G0S6- Backofen
                                          SIEMENS-KI86SHD40- Kühl-Gefrier-Kombi
                                          SIEMENS-SX678X36UE -Geschirrspüler
                                          SIEMENS-WT47XM40-Trockner
                                          Habe das Update Sonntag Nachmittag durchgeführt, nach wenigen Stunden kam schon die Meldung, dachte es lag am Update und den Adapter-Neustarts.
                                          Heute Vormittag dann erneut aktiviert und irgendwann Nachmittags wieder die Fehlermeldung. Sind also nur ein paar Stunden.
                                          Morgen mache ich einen neuen Versuch, dann werde ich etwas genauer hinschauen.
                                          kann ich "pollintervall" selbständig ändern?
                                            @ritschy2000 Es gibt kein Pollinterval sondern nur wenn Geräte eingeschaltet werden dann kommt es zu request
                                            1.0k
                                            bsh bsh home connect home connect homeconnect adapter
                                            195
                                            1373
                                            499093
