    3. Off Topic
    4. Grafana
    5. Grafana Update Probleme
      Thomas Braun Most Active @crunchip last edited by
      This post is deleted!
      • Damrak2022
        Damrak2022 @Thomas Braun last edited by
        @thomas-braun sagte in [Linux Shell-Skript] WLAN-Wetterstation:
        sudo
        pi@homebridge:~ $ sudo apt install grafana
        Reading package lists... Done
        Building dependency tree... Done
        The following NEW packages will be installed:
          grafana
        0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
        Need to get 0 B/74.0 MB of archives.
        After this operation, 243 MB of additional disk space will be used.
        Selecting previously unselected package grafana.
        (Reading database ... 67659 files and directories currently installed.)
        Preparing to unpack .../grafana_8.5.0_armhf.deb ...
        Unpacking grafana (8.5.0) ...
        Replaced by files in installed package grafana-rpi (7.4.3) ...
        Setting up grafana (8.5.0) ...
        ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
         sudo /bin/systemctl daemon-reload
         sudo /bin/systemctl enable grafana-server
        ### You can start grafana-server by executing
         sudo /bin/systemctl start grafana-server
          Thomas Braun Most Active @Damrak2022 last edited by Thomas Braun
          @damrak2022 sagte in [Linux Shell-Skript] WLAN-Wetterstation:
          Dann schau mal ob das auch nach einem reboot wieder auf die Füße kommt.
          • Negalein
            Negalein Global Moderator last edited by Negalein
            Mach einen eigenen Thread dafür auf.
            @Damrak2022
            hier bitte weitermachen!
            • Damrak2022
              @thomas-braun Der Reboot war gar kein Problem
              In der
              sudo nano /etc/apt/sources.list.d/grafana.list
              sieht es so aus:
              deb https://packages.grafana.com/oss/deb stable main
              und in der
              so
              deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
              # Uncomment line below then 'apt-get update' to enable 'apt-get source'
              deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-fre>
              Danach habe ich nochmal ein
              sudo apt update
              sudo apt upgrade
              gemacht - Browsercache und anderen Browser genutzt, aber bei Grafana steht immer noch Version 7.4.3 drin
                @damrak2022
                Bitte auch die Ausgaben zu den Befehlen posten.
                So kann man damit nix anfangen.
                • Damrak2022
                  Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                  permitted by applicable law.
                  Last login: Mon Apr 25 08:43:39 2022 from 192.168.178.22
                  pi@homebridge:~ $ sudo nano /etc/apt/sources.list
                  pi@homebridge:~ $ sudo nano /etc/apt/sources.list.d/grafana.list
                  pi@homebridge:~ $ sudo apt update
                  Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:3 https://packages.grafana.com/oss/deb stable InRelease
                  Hit:4 https://repos.influxdata.com/debian bullseye InRelease
                  Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
                  Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                  All packages are up to date.
                  pi@homebridge:~ $ sudo apt upgrade
                  Calculating upgrade... Done
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  pi@homebridge:~ $
                    @damrak2022
                    apt policy grafana-rpi grafana
                    • Damrak2022
                      @thomas-braun sagte in Grafana Update Probleme:
                      pi@homebridge:~ $ apt policy grafana-rpi grafana
                      grafana-rpi:
                        Installed: 7.4.3
                        Candidate: 7.4.3
                        Version table:
                       *** 7.4.3 100
                              100 /var/lib/dpkg/status
                           7.4.0 500
                              500 https://packages.grafana.com/oss/deb stable/main armhf Packages
                           7.3.3 500
                           7.3.2 500
                           7.3.1 500
                           7.3.0 500
                           7.2.2 500
                           7.2.1 500
                           7.2.0 500
                           7.1.5 500
                           7.1.4 500
                           7.1.3 500
                           7.1.2 500
                           7.1.1 500
                           7.1.0 500
                           7.0.6 500
                           7.0.5 500
                           7.0.4 500
                           7.0.3 500
                           7.0.2 500
                           7.0.1 500
                           7.0.0 500
                           6.7.6 500
                           6.7.4 500
                           6.7.3 500
                           6.7.2 500
                           6.7.1 500
                           6.7.0 500
                           6.6.2 500
                           6.6.1 500
                           6.6.0 500
                           6.5.3 500
                           6.5.2 500
                           6.5.1 500
                           6.5.0 500
                           6.4.5 500
                           6.4.4 500
                           6.4.3 500
                           6.4.2 500
                           6.4.1 500
                           6.4.0 500
                           6.3.7 500
                           6.3.6 500
                           6.3.5 500
                           6.3.4 500
                           6.3.3 500
                           6.3.2 500
                           6.3.1 500
                           6.3.0 500
                           6.2.5 500
                           6.2.4 500
                           6.2.3 500
                           6.2.2 500
                           6.2.1 500
                           6.2.0 500
                           6.1.6 500
                           6.1.5 500
                           6.1.4 500
                           6.1.3 500
                           6.1.2 500
                           6.1.1 500
                           6.1.0 500
                      grafana:
                        Installed: 8.5.0
                        Candidate: 8.5.0
                        Version table:
                       *** 8.5.0 500
                           8.4.7 500
                           8.4.6 500
                           8.4.5 500
                           8.4.4 500
                           8.4.3 500
                           8.4.2 500
                           8.4.1 500
                           8.4.0 500
                           8.3.7 500
                           8.3.6 500
                           8.3.5 500
                           8.3.4 500
                           8.3.3 500
                           8.3.2 500
                           8.3.1 500
                           8.3.0 500
                           8.2.7 500
                           8.2.6 500
                           8.2.5 500
                           8.2.4 500
                           8.2.3 500
                           8.2.2 500
                           8.2.1 500
                           8.2.0 500
                           8.1.8 500
                           8.1.7 500
                           8.1.6 500
                           8.1.5 500
                           8.1.4 500
                           8.1.3 500
                           8.1.2 500
                           8.1.1 500
                           8.1.0 500
                           8.0.7 500
                           8.0.6 500
                           8.0.5 500
                           8.0.4 500
                           8.0.3 500
                           8.0.2 500
                           8.0.1 500
                           8.0.0 500
                           7.5.15 500
                           7.5.13 500
                           7.5.12 500
                           7.5.11 500
                           7.5.10 500
                           7.5.9 500
                           7.5.8 500
                           7.5.7 500
                           7.5.6 500
                           7.5.5 500
                           7.5.4 500
                           7.5.3 500
                           7.5.2 500
                           7.5.1 500
                           7.5.0 500
                           7.4.5 500
                           7.4.3 500
                           7.4.2 500
                           7.4.1 500
                           7.4.0 500
                           7.3.10 500
                           7.3.7 500
                           7.3.6 500
                           7.3.5 500
                           7.3.4 500
                           7.3.3 500
                           7.3.2 500
                           7.3.1 500
                           7.3.0 500
                           7.2.2 500
                           7.2.1 500
                           7.2.0 500
                           7.1.5 500
                           7.1.4 500
                           7.1.3 500
                           7.1.2 500
                           7.1.1 500
                           7.1.0 500
                           7.0.6 500
                           7.0.5 500
                           7.0.4 500
                           7.0.3 500
                           7.0.2 500
                           7.0.1 500
                           7.0.0 500
                           6.7.6 500
                           6.7.5 500
                           6.7.4 500
                           6.7.3 500
                           6.7.2 500
                           6.7.1 500
                           6.7.0 500
                           6.6.2 500
                           6.6.1 500
                           6.6.0 500
                           6.5.3 500
                           6.5.2 500
                           6.5.1 500
                           6.5.0 500
                           6.4.5 500
                           6.4.4 500
                           6.4.3 500
                           6.4.2 500
                           6.4.1 500
                           6.4.0 500
                           6.3.7 500
                           6.3.6 500
                           6.3.5 500
                           6.3.4 500
                           6.3.3 500
                           6.3.2 500
                           6.3.1 500
                           6.3.0 500
                           6.2.5 500
                           6.2.4 500
                           6.2.3 500
                           6.2.2 500
                           6.2.1 500
                           6.2.0 500
                           6.1.6 500
                           6.1.5 500
                           6.1.4 500
                           6.1.3 500
                           6.1.2 500
                           6.1.1 500
                           6.1.0 500
                           6.0.2 500
                           6.0.1 500
                           6.0.0 500
                           5.4.5 500
                           5.4.4 500
                           5.4.3 500
                           5.4.2 500
                           5.4.1 500
                           5.4.0 500
                           5.3.4 500
                           5.3.3 500
                           5.3.2 500
                           5.3.1 500
                           5.3.0 500
                           5.2.5 500
                           5.2.4 500
                           5.2.3 500
                           5.2.2 500
                           5.2.1 500
                           5.2.0 500
                      pi@homebridge:~ $
                      Sieht aus als ob das Update nicht drin ist
                        @damrak2022 sagte in Grafana Update Probleme:
                        sudo apt remove grafana-rpi
                        Du hast jetzt beide Pakete installiert.
                        • Damrak2022
                          Damrak2022 @Thomas Braun last edited by Damrak2022
                          Da muss ich nächstes Mal besser aufpassen, zumal ich nicht weiß wie das passiert ist
                          pi@homebridge:~ $ sudo apt remove grafana-rpi
                          The following packages will be REMOVED:
                            grafana-rpi
                          0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                          After this operation, 159 MB disk space will be freed.
                          Do you want to continue? [Y/n] y
                          (Reading database ... 72020 files and directories currently installed.)
                          Removing grafana-rpi (7.4.3) ...
                          pi@homebridge:~ $
                          Und jetzt kommt der Teil den ich nicht begreife:
                          In der
                          steht die
                          drin. Trotzdem wird über sudo apt update und sudo apt upgrade nicht auf die nächste Version aktualisiert
                          Warum nicht😧
                            @damrak2022
                            grafana 8.5.0 ist doch installiert, oder nicht?
                            apt policy grafana grafana-rpi
                            Starte das System mal durch, damit die Services gestartet werden.
                            • Damrak2022
                              Ja installiert ist es:
                              pi@homebridge:~ $ apt policy grafana grafana-rpi
                              grafana:
                                Installed: 8.5.0
                                Candidate: 8.5.0
                                Version table:
                               *** 8.5.0 500
                                   8.4.7 500
                                   8.4.6 500
                                   8.4.5 500
                                   8.4.4 500
                                   8.4.3 500
                                   8.4.2 500
                                   8.4.1 500
                                   8.4.0 500
                                   8.3.7 500
                                   8.3.6 500
                                   8.3.5 500
                                   8.3.4 500
                                   8.3.3 500
                                   8.3.2 500
                                   8.3.1 500
                                   8.3.0 500
                                   8.2.7 500
                                   8.2.6 500
                                   8.2.5 500
                                   8.2.4 500
                                   8.2.3 500
                                   8.2.2 500
                                   8.2.1 500
                                   8.2.0 500
                                   8.1.8 500
                                   8.1.7 500
                                   8.1.6 500
                                   8.1.5 500
                                   8.1.4 500
                                   8.1.3 500
                                   8.1.2 500
                                   8.1.1 500
                                   8.1.0 500
                                   8.0.7 500
                                   8.0.6 500
                                   8.0.5 500
                                   8.0.4 500
                                   8.0.3 500
                                   8.0.2 500
                                   8.0.1 500
                                   8.0.0 500
                                   7.5.15 500
                                   7.5.13 500
                                   7.5.12 500
                                   7.5.11 500
                                   7.5.10 500
                                   7.5.9 500
                                   7.5.8 500
                                   7.5.7 500
                                   7.5.6 500
                                   7.5.5 500
                                   7.5.4 500
                                   7.5.3 500
                                   7.5.2 500
                                   7.5.1 500
                                   7.5.0 500
                                   7.4.5 500
                                   7.4.3 500
                                   7.4.2 500
                                   7.4.1 500
                                   7.4.0 500
                                   7.3.10 500
                                   7.3.7 500
                                   7.3.6 500
                                   7.3.5 500
                                   7.3.4 500
                                   7.3.3 500
                                   7.3.2 500
                                   7.3.1 500
                                   7.3.0 500
                                   7.2.2 500
                                   7.2.1 500
                                   7.2.0 500
                                   7.1.5 500
                                   7.1.4 500
                                   7.1.3 500
                                   7.1.2 500
                                   7.1.1 500
                                   7.1.0 500
                                   7.0.6 500
                                   7.0.5 500
                                   7.0.4 500
                                   7.0.3 500
                                   7.0.2 500
                                   7.0.1 500
                                   7.0.0 500
                                   6.7.6 500
                                   6.7.5 500
                                   6.7.4 500
                                   6.7.3 500
                                   6.7.2 500
                                   6.7.1 500
                                   6.7.0 500
                                   6.6.2 500
                                   6.6.1 500
                                   6.6.0 500
                                   6.5.3 500
                                   6.5.2 500
                                   6.5.1 500
                                   6.5.0 500
                                   6.4.5 500
                                   6.4.4 500
                                   6.4.3 500
                                   6.4.2 500
                                   6.4.1 500
                                   6.4.0 500
                                   6.3.7 500
                                   6.3.6 500
                                   6.3.5 500
                                   6.3.4 500
                                   6.3.3 500
                                   6.3.2 500
                                   6.3.1 500
                                   6.3.0 500
                                   6.2.5 500
                                   6.2.4 500
                                   6.2.3 500
                                   6.2.2 500
                                   6.2.1 500
                                   6.2.0 500
                                   6.1.6 500
                                   6.1.5 500
                                   6.1.4 500
                                   6.1.3 500
                                   6.1.2 500
                                   6.1.1 500
                                   6.1.0 500
                                   6.0.2 500
                                   6.0.1 500
                                   6.0.0 500
                                   5.4.5 500
                                   5.4.4 500
                                   5.4.3 500
                                   5.4.2 500
                                   5.4.1 500
                                   5.4.0 500
                                   5.3.4 500
                                   5.3.3 500
                                   5.3.2 500
                                   5.3.1 500
                                   5.3.0 500
                                   5.2.5 500
                                   5.2.4 500
                                   5.2.3 500
                                   5.2.2 500
                                   5.2.1 500
                                   5.2.0 500
                              grafana-rpi:
                                Installed: (none)
                                Candidate: 7.4.0
                                Version table:
                                   7.4.3 -1
                                   7.4.0 500
                                   7.3.3 500
                                   7.3.2 500
                                   7.3.1 500
                                   7.3.0 500
                                   7.2.2 500
                                   7.2.1 500
                                   7.2.0 500
                                   7.1.5 500
                                   7.1.4 500
                                   7.1.3 500
                                   7.1.2 500
                                   7.1.1 500
                                   7.1.0 500
                                   7.0.6 500
                                   7.0.5 500
                                   7.0.4 500
                                   7.0.3 500
                                   7.0.2 500
                                   7.0.1 500
                                   7.0.0 500
                                   6.7.6 500
                                   6.7.4 500
                                   6.7.3 500
                                   6.7.2 500
                                   6.7.1 500
                                   6.7.0 500
                                   6.6.2 500
                                   6.6.1 500
                                   6.6.0 500
                                   6.5.3 500
                                   6.5.2 500
                                   6.5.1 500
                                   6.5.0 500
                                   6.4.5 500
                                   6.4.4 500
                                   6.4.3 500
                                   6.4.2 500
                                   6.4.1 500
                                   6.4.0 500
                                   6.3.7 500
                                   6.3.6 500
                                   6.3.5 500
                                   6.3.4 500
                                   6.3.3 500
                                   6.3.2 500
                                   6.3.1 500
                                   6.3.0 500
                                   6.2.5 500
                                   6.2.4 500
                                   6.2.3 500
                                   6.2.2 500
                                   6.2.1 500
                                   6.2.0 500
                                   6.1.6 500
                                   6.1.5 500
                                   6.1.4 500
                                   6.1.3 500
                                   6.1.2 500
                                   6.1.1 500
                                   6.1.0 500
                              pi@homebridge:~ $
                              Du meinst einen Reboot?
                                Ja.
                                • Damrak2022
                                  @thomas-braun Ich verstehe garnichts mehr. Jetzt komme ich nicht mehr auf die Webseite von Grafana
                                  pi@homebridge:~ $ sudo reboot
                                  Connection to homebridge closed by remote host.
                                  Connection to homebridge closed.
                                  damrak2021@Andreass-iMac ~ % ssh pi@homebridge
                                  pi@homebridge's password:
                                  Linux homebridge 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l
                                  The programs included with the Debian GNU/Linux system are free software;
                                  the exact distribution terms for each program are described in the
                                  individual files in /usr/share/doc/*/copyright.
                                  Last login: Mon Apr 25 09:03:38 2022 from 2a02:908:171:e900:5da1:8f55:5199:833
                                  pi@homebridge:~ $ sudo /bin/systemctl daemon-reload
                                  pi@homebridge:~ $ sudo /bin/systemctl enable grafana-server
                                  Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
                                  Executing: /lib/systemd/systemd-sysv-install enable grafana-server
                                  pi@homebridge:~ $ sudo /bin/systemctl start grafana-server
                                  pi@homebridge:~ $
                                  Ich schaue mal was in der ini steht
                                    @damrak2022
                                    systemctl status grafana-server
                                    • Damrak2022
                                      pi@homebridge:~ $ systemctl status grafana-server
                                      ● grafana-server.service - Grafana instance
                                           Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
                                           Active: failed (Result: exit-code) since Mon 2022-04-25 10:15:03 BST; 4min>
                                             Docs: http://docs.grafana.org
                                          Process: 3609 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pi>
                                         Main PID: 3609 (code=exited, status=203/EXEC)
                                              CPU: 7ms
                                      Apr 25 10:15:03 homebridge systemd[1]: grafana-server.service: Scheduled restar>
                                      Apr 25 10:15:03 homebridge systemd[1]: Stopped Grafana instance.
                                      Apr 25 10:15:03 homebridge systemd[1]: grafana-server.service: Start request re>
                                      Apr 25 10:15:03 homebridge systemd[1]: grafana-server.service: Failed with resu>
                                      Apr 25 10:15:03 homebridge systemd[1]: Failed to start Grafana instance.
                                      lines 1-13/13 (END)
                                        @damrak2022
                                        Bitte vollständig.
                                        Probier die Vorversion:
                                        sudo apt install grafana=8.4.7
                                        • Damrak2022
                                          pi@homebridge:~ $ sudo apt install grafana=8.4.7
                                          The following packages will be DOWNGRADED:
                                            grafana
                                          0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
                                          Need to get 71.9 MB of archives.
                                          After this operation, 9,899 kB disk space will be freed.
                                          Get:1 https://packages.grafana.com/oss/deb stable/main armhf grafana armhf 8.4.7 [71.9 MB]
                                          Fetched 71.9 MB in 7s (10.5 MB/s)
                                          dpkg: warning: downgrading grafana from 8.5.0 to 8.4.7
                                          (Reading database ... 69307 files and directories currently installed.)
                                          Preparing to unpack .../grafana_8.4.7_armhf.deb ...
                                          Unpacking grafana (8.4.7) over (8.5.0) ...
                                          Setting up grafana (8.4.7) ...
                                          Installing new version of config file /etc/default/grafana-server ...
                                          Installing new version of config file /usr/lib/systemd/system/grafana-server.service ...
                                          Restarting grafana-server service... OK
                                          pi@homebridge:~ $
                                          Das Problem war doch schon mal da, das ich Grafana nicht mehr aufrufen konnte. Ich weiß nur nicht mehr wie wir das neulich hinbekommen haben.
                                            crunchip Forum Testing Most Active @Damrak2022 last edited by
                                            @damrak2022 die 8.5 scheint ein Problem zu haben, daher eine Version zurückspringen.
                                            Sollte es nach einem reboot immer noch nicht starten, dann manuell nochmal nachlegen.
                                            RoddiEF Damrak2022 2 Replies Last reply Reply Quote 0
                                            6587
