    3. Off Topic
    4. Grafana
    5. Grafana Update Probleme
    • Damrak2022
      Damrak2022 @Thomas Braun last edited by Damrak2022
      @thomas-braun Ich verstehe garnichts mehr. Jetzt komme ich nicht mehr auf die Webseite von Grafana
      pi@homebridge:~ $ sudo reboot
      Connection to homebridge closed by remote host.
      Connection to homebridge closed.
      damrak2021@Andreass-iMac ~ % ssh pi@homebridge
      pi@homebridge's password:
      Linux homebridge 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Mon Apr 25 09:03:38 2022 from 2a02:908:171:e900:5da1:8f55:5199:833
      pi@homebridge:~ $ sudo /bin/systemctl daemon-reload
      pi@homebridge:~ $ sudo /bin/systemctl enable grafana-server
      Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
      Executing: /lib/systemd/systemd-sysv-install enable grafana-server
      pi@homebridge:~ $ sudo /bin/systemctl start grafana-server
      pi@homebridge:~ $
      Ich schaue mal was in der ini steht
        Thomas Braun Most Active @Damrak2022 last edited by Thomas Braun
        @damrak2022
        systemctl status grafana-server
        • Damrak2022
          @thomas-braun sagte in Grafana Update Probleme:
          pi@homebridge:~ $ systemctl status grafana-server
          ● grafana-server.service - Grafana instance
               Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
               Active: failed (Result: exit-code) since Mon 2022-04-25 10:15:03 BST; 4min>
                 Docs: http://docs.grafana.org
              Process: 3609 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pi>
             Main PID: 3609 (code=exited, status=203/EXEC)
                  CPU: 7ms
          Apr 25 10:15:03 homebridge systemd[1]: grafana-server.service: Scheduled restar>
          Apr 25 10:15:03 homebridge systemd[1]: Stopped Grafana instance.
          Apr 25 10:15:03 homebridge systemd[1]: grafana-server.service: Start request re>
          Apr 25 10:15:03 homebridge systemd[1]: grafana-server.service: Failed with resu>
          Apr 25 10:15:03 homebridge systemd[1]: Failed to start Grafana instance.
          lines 1-13/13 (END)
            @damrak2022
            Bitte vollständig.
            Probier die Vorversion:
            sudo apt install grafana=8.4.7
            • Damrak2022
              pi@homebridge:~ $ sudo apt install grafana=8.4.7
              Reading package lists... Done
              Building dependency tree... Done
              The following packages will be DOWNGRADED:
                grafana
              0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
              Need to get 71.9 MB of archives.
              After this operation, 9,899 kB disk space will be freed.
              Do you want to continue? [Y/n] y
              Get:1 https://packages.grafana.com/oss/deb stable/main armhf grafana armhf 8.4.7 [71.9 MB]
              Fetched 71.9 MB in 7s (10.5 MB/s)
              dpkg: warning: downgrading grafana from 8.5.0 to 8.4.7
              (Reading database ... 69307 files and directories currently installed.)
              Preparing to unpack .../grafana_8.4.7_armhf.deb ...
              Unpacking grafana (8.4.7) over (8.5.0) ...
              Setting up grafana (8.4.7) ...
              Installing new version of config file /etc/default/grafana-server ...
              Installing new version of config file /usr/lib/systemd/system/grafana-server.service ...
              Restarting grafana-server service... OK
              pi@homebridge:~ $
              Das Problem war doch schon mal da, das ich Grafana nicht mehr aufrufen konnte. Ich weiß nur nicht mehr wie wir das neulich hinbekommen haben.
                crunchip Forum Testing Most Active @Damrak2022 last edited by
                @damrak2022 die 8.5 scheint ein Problem zu haben, daher eine Version zurückspringen.
                Sollte es nach einem reboot immer noch nicht starten, dann manuell nochmal nachlegen.
                RoddiEF Damrak2022 2 Replies Last reply Reply Quote 0
                • RoddiEF
                  RoddiEF @crunchip last edited by
                  @crunchip sagte in Grafana Update Probleme:
                  Bei mir läuft die 8.5.0 auf einem Rpi-4-4GB ohne Probleme, denke liegt wohl nicht an Grafana sondern eher an der "verquirlten" Installation....
                    Thomas Braun Most Active @RoddiEF last edited by
                    @roddief
                    64bit oder 32bit System?
                    Auf meinem 64er startet grafana auch, vermutlich ist die 32bit Version betroffen.
                    RoddiEF 1 Reply Last reply Reply Quote 0
                    • RoddiEF
                      RoddiEF @Thomas Braun last edited by
                      @roddief
                      Läuft auf nem 32-Bit System...
                        @roddief
                        Hier melden sich auch user mit dem Phänomen:
                        https://github.com/grafana/grafana/issues/48130
                        Diapolo created this issue in grafana/grafana
                        closed grafana-server doesn't start after recent update to 8.5.0 on openhabian #48130
                        • Damrak2022
                          Damrak2022 @crunchip last edited by
                          Nachdem ich die Befehle eingegeben habe ist dies das Ergebnis
                          pi@homebridge:~ $ systemctl enable grafana-server
                          ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
                          Authentication is required to reload the systemd state.
                          Authenticating as: ,,, (pi)
                          Password:
                          ==== AUTHENTICATION COMPLETE ===
                          Password:
                          ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
                          Authentication is required to manage system service or unit files.
                          Password:
                          Password:
                          pi@homebridge:~ $ systemctl start grafana-server
                          ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
                          Authentication is required to start 'grafana-server.service'.
                          Password:
                               Active: failed (Result: exit-code) since Tue 2022-04-26 02:28:48 BST; 15s >
                              Process: 22671 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --p>
                             Main PID: 22671 (code=exited, status=1/FAILURE)
                                  CPU: 360ms
                          Apr 26 02:28:48 homebridge systemd[1]: grafana-server.service: Scheduled restar>
                          Apr 26 02:28:48 homebridge systemd[1]: Stopped Grafana instance.
                          Apr 26 02:28:48 homebridge systemd[1]: grafana-server.service: Start request re>
                          Apr 26 02:28:48 homebridge systemd[1]: grafana-server.service: Failed with resu>
                          Apr 26 02:28:48 homebridge systemd[1]: Failed to start Grafana instance.
                          lines 1-13/13 (END)
                            @damrak2022 sorry hatte sudo vergessen, bzw probier es so
                            sudo /bin/systemctl status grafana-server
                            • Damrak2022
                              Damrak2022 @crunchip last edited by Damrak2022
                              Das ist das Ergebnis:
                              pi@homebridge:~ $ sudo /bin/systemctl status grafana-server
                                   Active: failed (Result: exit-code) since Tue 2022-04-26 04:26:20 BST; 15s >
                                  Process: 7077 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pi>
                                 Main PID: 7077 (code=exited, status=1/FAILURE)
                                      CPU: 330ms
                              Apr 26 04:26:20 homebridge systemd[1]: grafana-server.service: Scheduled restar>
                              Apr 26 04:26:20 homebridge systemd[1]: Stopped Grafana instance.
                              Apr 26 04:26:20 homebridge systemd[1]: grafana-server.service: Start request re>
                              Apr 26 04:26:20 homebridge systemd[1]: grafana-server.service: Failed with resu>
                              Apr 26 04:26:20 homebridge systemd[1]: Failed to start Grafana instance.
                              lines 1-13/13 (END)
                              Hier lässt Erich garnicht rein, auch nicht mit sudo
                              pi@homebridge:~ $ /usr/lib/systemd/system/grafana-server.service
                              -bash: /usr/lib/systemd/system/grafana-server.service: Permission denied
                                @damrak2022 ich muss mir das in Ruhe heute Nachmittag am Pc ansehen. So früh am Morgen mit dem Handy etwas schwierig.
                                • Damrak2022
                                  @crunchip Hast Du noch irgendeine Idee, denn ich kann Grafana weiterhin nicht aufrufen
                                  crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                                    @damrak2022 ich bin am gucken
                                    • Damrak2022
                                      @crunchip Ich danke Dir. Wenn ich da wieder drauf komme lasse ich erstmal die Finger vom Terminal was Grafana betrifft.
                                        @damrak2022
                                        Ist denn jetzt grafana 8.4.7 die alleinig installierte Version oder spukt da noch was anderes herum?
                                        • Damrak2022
                                          @thomas-braun Nur 8.4.7, aber ich kann nochmal schauen
                                          pi@homebridge:~ $ apt policy grafana
                                          grafana:
                                            Installed: 8.4.7
                                            Candidate: 8.5.0
                                            Version table:
                                               8.5.0 500
                                                  500 https://packages.grafana.com/oss/deb stable/main armhf Packages
                                           *** 8.4.7 500
                                                  100 /var/lib/dpkg/status
                                               8.4.6 500
                                               8.4.5 500
                                               8.4.4 500
                                               8.4.3 500
                                               8.4.2 500
                                               8.4.1 500
                                               8.4.0 500
                                               8.3.7 500
                                               8.3.6 500
                                               8.3.5 500
                                               8.3.4 500
                                               8.3.3 500
                                               8.3.2 500
                                               8.3.1 500
                                               8.3.0 500
                                               8.2.7 500
                                               8.2.6 500
                                               8.2.5 500
                                               8.2.4 500
                                               8.2.3 500
                                               8.2.2 500
                                               8.2.1 500
                                               8.2.0 500
                                               8.1.8 500
                                               8.1.7 500
                                               8.1.6 500
                                               8.1.5 500
                                               8.1.4 500
                                               8.1.3 500
                                               8.1.2 500
                                               8.1.1 500
                                               8.1.0 500
                                               8.0.7 500
                                               8.0.6 500
                                               8.0.5 500
                                               8.0.4 500
                                               8.0.3 500
                                               8.0.2 500
                                               8.0.1 500
                                               8.0.0 500
                                               7.5.15 500
                                               7.5.13 500
                                               7.5.12 500
                                               7.5.11 500
                                               7.5.10 500
                                               7.5.9 500
                                               7.5.8 500
                                               7.5.7 500
                                               7.5.6 500
                                               7.5.5 500
                                               7.5.4 500
                                               7.5.3 500
                                               7.5.2 500
                                               7.5.1 500
                                               7.5.0 500
                                               7.4.5 500
                                               7.4.3 500
                                               7.4.2 500
                                               7.4.1 500
                                               7.4.0 500
                                               7.3.10 500
                                               7.3.7 500
                                               7.3.6 500
                                               7.3.5 500
                                               7.3.4 500
                                               7.3.3 500
                                               7.3.2 500
                                               7.3.1 500
                                               7.3.0 500
                                               7.2.2 500
                                               7.2.1 500
                                               7.2.0 500
                                               7.1.5 500
                                               7.1.4 500
                                               7.1.3 500
                                               7.1.2 500
                                               7.1.1 500
                                               7.1.0 500
                                               7.0.6 500
                                               7.0.5 500
                                               7.0.4 500
                                               7.0.3 500
                                               7.0.2 500
                                               7.0.1 500
                                               7.0.0 500
                                               6.7.6 500
                                               6.7.5 500
                                               6.7.4 500
                                               6.7.3 500
                                               6.7.2 500
                                               6.7.1 500
                                               6.7.0 500
                                               6.6.2 500
                                               6.6.1 500
                                               6.6.0 500
                                               6.5.3 500
                                               6.5.2 500
                                               6.5.1 500
                                               6.5.0 500
                                               6.4.5 500
                                               6.4.4 500
                                               6.4.3 500
                                               6.4.2 500
                                               6.4.1 500
                                               6.4.0 500
                                               6.3.7 500
                                               6.3.6 500
                                               6.3.5 500
                                               6.3.4 500
                                               6.3.3 500
                                               6.3.2 500
                                               6.3.1 500
                                               6.3.0 500
                                               6.2.5 500
                                               6.2.4 500
                                               6.2.3 500
                                               6.2.2 500
                                               6.2.1 500
                                               6.2.0 500
                                               6.1.6 500
                                               6.1.5 500
                                               6.1.4 500
                                               6.1.3 500
                                               6.1.2 500
                                               6.1.1 500
                                               6.1.0 500
                                               6.0.2 500
                                               6.0.1 500
                                               6.0.0 500
                                               5.4.5 500
                                               5.4.4 500
                                               5.4.3 500
                                               5.4.2 500
                                               5.4.1 500
                                               5.4.0 500
                                               5.3.4 500
                                               5.3.3 500
                                               5.3.2 500
                                               5.3.1 500
                                               5.3.0 500
                                               5.2.5 500
                                               5.2.4 500
                                               5.2.3 500
                                               5.2.2 500
                                               5.2.1 500
                                               5.2.0 500
                                          pi@homebridge:~ $
                                          Haben die 3* vor der 8.4.7 was zu bedeuten<<ß
                                            @damrak2022
                                            Die drei Sterne kennzeichnen die installierte Version.
                                            apt policy grafana*
                                            6581
