    3. Off Topic
    4. Proxmox
    5. Proxmox spinnt - brauche Hilfe - auch mit Unifi
      Homoran Global Moderator Administrators @crunchip last edited by
      @crunchip sieht nicht gut aus:
        Homoran Global Moderator Administrators @JLeg last edited by
        @jleg
        root@pve-neu:~# vgdisplay -v pve
          --- Volume group ---
          VG Name               pve
          System ID
          Format                lvm2
          Metadata Areas        1
          Metadata Sequence No  15
          VG Access             read/write
          VG Status             resizable
          MAX LV                0
          Cur LV                5
          Open LV               3
          Max PV                0
          Cur PV                1
          Act PV                1
          VG Size               <223.07 GiB
          PE Size               4.00 MiB
          Total PE              57105
          Alloc PE / Size       53010 / 207.07 GiB
          Free  PE / Size       4095 / <16.00 GiB
          VG UUID               QxE0vt-KnKS-Z92t-L53i-YOyT-4PEr-9THeBz
          --- Logical volume ---
          LV Path                /dev/pve/swap
          LV Name                swap
          VG Name                pve
          LV UUID                u0kopG-fi9N-sqEn-YgpO-u82L-mAQp-RHpd38
          LV Write Access        read/write
          LV Creation host, time proxmox, 2021-12-13 15:30:10 +0100
          LV Status              available
          # open                 2
          LV Size                7.00 GiB
          Current LE             1792
          Segments               1
          Allocation             inherit
          Read ahead sectors     auto
          - currently set to     256
          Block device           253:0
          LV Path                /dev/pve/root
          LV Name                root
          VG Name                pve
          LV UUID                k8bNxN-ss4P-V1vf-Zeqm-reIp-9cRj-B2AnfY
          LV Status              available
          # open                 1
          LV Size                55.75 GiB
          Current LE             14272
          Segments               1
          Allocation             inherit
          Block device           253:1
          LV Name                data
          VG Name                pve
          LV UUID                AP1yuy-r0H8-jsq0-rvy9-DBnu-K0TB-5Qkt0M
          LV Write Access        read/write (activated read only)
          LV Creation host, time proxmox, 2021-12-13 15:30:15 +0100
          LV Pool metadata       data_tmeta
          LV Pool data           data_tdata
          LV Status              available
          # open                 0
          LV Size                <141.43 GiB
          Allocated pool data    100.00%
          Allocated metadata     5.40%
          Current LE             36206
          Segments               1
          Allocation             inherit
          Block device           253:5
          LV Path                /dev/pve/vm-100-disk-0
          LV Name                vm-100-disk-0
          VG Name                pve
          LV UUID                yVqmMo-lQFx-zeIW-VpEB-aC52-FQR9-dbjNZI
          LV Creation host, time pve-neu, 2021-12-13 17:44:06 +0100
          LV Pool name           data
          LV Status              available
          # open                 1
          LV Size                140.00 GiB
          Mapped size            95.47%
          Current LE             35840
          Segments               1
          Allocation             inherit
          Block device           253:6
          LV Path                /dev/pve/vm-101-disk-0
          LV Name                vm-101-disk-0
          VG Name                pve
          LV UUID                RZsqpX-CwHp-Obe9-nQYE-78F3-Jva5-lYRlRY
          LV Creation host, time pve-neu, 2021-12-13 18:05:41 +0100
          LV Pool name           data
          LV Status              available
          # open                 0
          LV Size                32.00 GiB
          Mapped size            24.30%
          Current LE             8192
          Segments               1
          Allocation             inherit
          Block device           253:7
          --- Physical volumes ---
          PV Name               /dev/sda3
          PV UUID               AY1yhR-LBud-ZdQO-hN5N-n05P-Yrhd-zjt1Ii
          PV Status             allocatable
          Total PE / Free PE    57105 / 4095
        JLeg 1 Reply Last reply Reply Quote 0
          crunchip Forum Testing Most Active @Homoran last edited by
          @homoran ist doch gestoppt
            Homoran Global Moderator Administrators @crunchip last edited by Homoran
            @crunchip jepp gerade eben
            und jetzt auch die ander
              @crunchip jetzt habe ich auch beide wieder starten können....
              101 hängt schon wieder
              • JLeg
                JLeg @Homoran last edited by
                @homoran tja, dein lvm-thin-metadata-Storage ist vollgelaufen. Gründe für sowas gibt's einige, wenn du keine Snapshots benutzt, sind's vielleicht zu kleine Chunk-Sizes (beim Einrichten gewählt) oder so...
                Schnellste Abhilfe wäre, das tmeta-LV zu vergrössern - blöderweise ist deine Volumegroup (pve) aber auch schon bis fast zum Anschlag ausgereizt (ich würde da immer bissel Luft lassen), du hast nur noch 6GB zur Verfügung. Das könnte aber schonmal helfen, zumindest für ein paar Wochen oder so..
                Hier steht der Aufruf zum Vergrössern: https://pve.proxmox.com/wiki/LVM2#Resize_metadata_pool
                  @homoran mein handy hängt die ganze Zeit, kann nicht scrollen in dem Thread.
                  Aber wenn ich es richtig sehe ist deine VM 140Gb?
                  Und dein LVM ebenfalls
                    Danke euch beiden - keine Panik - die habe ich.
                    @crunchip sagte in Proxmox spinnt - brauche Hilfe - auch mit Unifi:
                    passt wahrscheinlich zu
                    @jleg sagte in Proxmox spinnt - brauche Hilfe - auch mit Unifi:
                    und ich nutze keine Snapshots
                    Habe schon den nächsten NUC vorbereitet gehabt, der 5PPYH sollte nur den Neuaufbau des i3 überbrücken.
                    und wie das so ist dauert ein Provisorium zu lange
                      wenn ich wüsste wovon du redest 🙂 würde ich das wohl auch
                      reicht 🙂
                      DANKE
                      sehe ich mir an
                        Könntest du so nett sein und das für mich übersetzen?
                        lvresize --poolmetadatasize +<size[M,G]> <VG>/<LVThin_pool>
                        • JLeg
                          @homoran müsste sowas wie hier sein:
                          lvresize --poolmetadatasize +5G pve/data
                            ich glaube das ist bei der Installation passiert. Ich wollte das LVM-thin viel kleiner haben, damit mehr übrigbleibt.
                            Irgendwie ist das schiefgegangen - und dann hatte ich gedacht, dass es reicht
                              Da ich keinsterlei Ahnung habe, prügel ich das jetzt mal so rein???
                                @homoran sagte in Proxmox spinnt - brauche Hilfe - auch mit Unifi:
                                wie du siehst
                                Wie ich sehe, hattest du wohl eine Standard Installation gemacht, nach Proxmox automatischen Vorgaben. Daher dein root und swap so groß.
                                Ich würde Proxmox neu aufsetzen und backups einspielen, bei Gelegenheit
                                • JLeg
                                  @homoran ja, ist ungefährlich (TM) 😉 - im schlimmsten Fall wird er meckern, dass er "data" nicht findet (bin nicht sicher, ob er da nicht den kompletten LV-Pfad haben will)
                                    schon für nach der Rückkehr geplant!
                                    gerade schon mal das aktuelle ISO heruntergeladen
                                    Kannstt du mir noch sagen, ob Unifi auch ohne controller problemlos weiterläuft?
                                      @jleg Augen zu und durch
                                        @homoran ja, den controller braucht man nicht zwingend, läuft auch so
                                          @crunchip Das beruhigt mich schon mal.
                                          Nicht das das Netz jetzt offen ist 🙂
                                          @JLeg
                                            WARNING: Sum of all thin volume sizes (172.00 GiB) exceeds the size of thin pools and the amount of free space in volume group (<11.00 GiB).
                                            WARNING: You have not turned on protection against thin pools running out of space.
                                            WARNING: Set activation/thin_pool_autoextend_threshold below 100 to trigger automatic extension of thin pools before they get full.
                                            Size of logical volume pve/data_tmeta changed from <1.45 GiB (370 extents) to <6.45 GiB (1650 extents).
                                            Logical volume pve/data_tmeta successfully resized.
                                          EDIT:
                                          die 101 läuft nicht durch.
                                          Muss ich rebooten?
                                          • JLeg
                                            @homoran was sagt denn jetzt
                                            vgdisplay -v pve
                                            81.1k
                                            8111
