    3. Off Topic
    4. Proxmox
    5. Proxmox spinnt - brauche Hilfe - auch mit Unifi
      Homoran Global Moderator Administrators @JLeg last edited by
      @jleg Augen zu und durch
        crunchip Forum Testing Most Active @Homoran last edited by
        @homoran ja, den controller braucht man nicht zwingend, läuft auch so
          Homoran Global Moderator Administrators @crunchip last edited by Homoran
          @crunchip Das beruhigt mich schon mal.
          Nicht das das Netz jetzt offen ist 🙂
          @JLeg
            WARNING: Sum of all thin volume sizes (172.00 GiB) exceeds the size of thin pools and the amount of free space in volume group (<11.00 GiB).
            WARNING: You have not turned on protection against thin pools running out of space.
            WARNING: Set activation/thin_pool_autoextend_threshold below 100 to trigger automatic extension of thin pools before they get full.
            Size of logical volume pve/data_tmeta changed from <1.45 GiB (370 extents) to <6.45 GiB (1650 extents).
            Logical volume pve/data_tmeta successfully resized.
          EDIT:
          die 101 läuft nicht durch.
          Muss ich rebooten?
          JLeg 1 Reply Last reply Reply Quote 0
          • JLeg
            JLeg @Homoran last edited by
            @homoran was sagt denn jetzt
            vgdisplay -v pve
              @jleg sagte in Proxmox spinnt - brauche Hilfe - auch mit Unifi:
              vgdisplay -v pve
              root@pve-neu:~# vgdisplay -v pve
                --- Volume group ---
                VG Name               pve
                System ID
                Format                lvm2
                Metadata Areas        1
                Metadata Sequence No  16
                VG Access             read/write
                VG Status             resizable
                MAX LV                0
                Cur LV                5
                Open LV               3
                Max PV                0
                Cur PV                1
                Act PV                1
                VG Size               <223.07 GiB
                PE Size               4.00 MiB
                Total PE              57105
                Alloc PE / Size       55570 / 217.07 GiB
                Free  PE / Size       1535 / <6.00 GiB
                VG UUID               QxE0vt-KnKS-Z92t-L53i-YOyT-4PEr-9THeBz
                --- Logical volume ---
                LV Path                /dev/pve/swap
                LV Name                swap
                VG Name                pve
                LV UUID                u0kopG-fi9N-sqEn-YgpO-u82L-mAQp-RHpd38
                LV Write Access        read/write
                LV Creation host, time proxmox, 2021-12-13 15:30:10 +0100
                LV Status              available
                # open                 2
                LV Size                7.00 GiB
                Current LE             1792
                Segments               1
                Allocation             inherit
                Read ahead sectors     auto
                - currently set to     256
                Block device           253:0
                LV Path                /dev/pve/root
                LV Name                root
                VG Name                pve
                LV UUID                k8bNxN-ss4P-V1vf-Zeqm-reIp-9cRj-B2AnfY
                LV Status              available
                # open                 1
                LV Size                55.75 GiB
                Current LE             14272
                Segments               1
                Allocation             inherit
                Block device           253:1
                LV Name                data
                VG Name                pve
                LV UUID                AP1yuy-r0H8-jsq0-rvy9-DBnu-K0TB-5Qkt0M
                LV Write Access        read/write (activated read only)
                LV Creation host, time proxmox, 2021-12-13 15:30:15 +0100
                LV Pool metadata       data_tmeta
                LV Pool data           data_tdata
                LV Status              available
                # open                 0
                LV Size                <141.43 GiB
                Allocated pool data    100.00%
                Allocated metadata     1.21%
                Current LE             36206
                Segments               1
                Allocation             inherit
                Block device           253:5
                LV Path                /dev/pve/vm-100-disk-0
                LV Name                vm-100-disk-0
                VG Name                pve
                LV UUID                yVqmMo-lQFx-zeIW-VpEB-aC52-FQR9-dbjNZI
                LV Creation host, time pve-neu, 2021-12-13 17:44:06 +0100
                LV Pool name           data
                LV Status              available
                # open                 1
                LV Size                140.00 GiB
                Mapped size            95.47%
                Current LE             35840
                Segments               1
                Allocation             inherit
                Block device           253:6
                LV Path                /dev/pve/vm-101-disk-0
                LV Name                vm-101-disk-0
                VG Name                pve
                LV UUID                RZsqpX-CwHp-Obe9-nQYE-78F3-Jva5-lYRlRY
                LV Creation host, time pve-neu, 2021-12-13 18:05:41 +0100
                LV Pool name           data
                LV Status              available
                # open                 0
                LV Size                32.00 GiB
                Mapped size            24.30%
                Current LE             8192
                Segments               1
                Allocation             inherit
                Block device           253:7
                --- Physical volumes ---
                PV Name               /dev/sda3
                PV UUID               AY1yhR-LBud-ZdQO-hN5N-n05P-Yrhd-zjt1Ii
                PV Status             allocatable
                Total PE / Free PE    57105 / 1535
              • JLeg
                @homoran hm, immer noch 100% - da würde jetzt nur helfen, den Pool "data" insgesamt zu vergrössern - was aber nicht möglich ist, da die Volumegroup voll ist.
                Die andere Möglichkeit wäre, eines der beiden anderen LV-Devices (VMs) zu verkleinern - das ist aber (im Unterschied zum Vergrössern) ein Riesenaufwand. Da ist Neuinstallation einfacher, sorry...
                  Homoran Global Moderator Administrators @JLeg last edited by Homoran
                  sorry...
                  Dafür muss t du dich nicht entschuldigen!!!
                  Neuinstallation mit neuen IPs (ggf. wieder alten zuweisen??) und anpassen der IPs in allen Adaptern/Programmen wird auch nicht gerade ein Kinderspiel.
                  zumal ich die UNIFI nicht ans Laufen bekomme um dort ein Backup zu erzeugen
                  crunchip JLeg 2 Replies Last reply Reply Quote 0
                    @homoran warum neue ip, du kannst doch die gleichen wieder vergeben
                    • JLeg
                      @homoran ...also bei mir wären das 10 Minuten für "neues Proxmox installieren" plus 2 x Restore "Backup von gestern" 🙂
                      crunchip Homoran 2 Replies Last reply Reply Quote 1
                        crunchip Forum Testing Most Active @JLeg last edited by
                        @jleg dann hätte er aber die selbe Vm Gösse wieder
                        Also neue Vm und iobroker backup einspielen
                          wie gesagt habe ich keine Snapshots.
                          ioBroker wird schnell gehen, nur vom Unifi habe ich kein aktuelles Backup. Aber der neue AP und die 2 neuen Geräte werde ich schon wieder reinbekommen 🙂
                          (Wenn ich das letzte Backup finde)
                          NUCi3 steht neben mir - neues ISO brennt gerade - mal sehen.
                          Diesmal mit 500GB M2
                          @crunchip
                          Würdest du mir sagen wie ich die Erstinstallation diesmal richtig machen muss ??
                          • JLeg
                            JLeg @crunchip last edited by
                            @crunchip sagte in Proxmox spinnt - brauche Hilfe - auch mit Unifi:
                            stimmt, aber wenn's die Platte nicht hergibt, kann man trotzdem ja einfach /root kleiner machen, sodass für den Rest genügend übrig bleibt (Ok, habe jetzt nicht gerechnet, wieviel genau Homoran über-provisioniert hatte...)
                              crunchip Forum Testing Most Active @Homoran last edited by crunchip
                              @homoran wenn du backups hast, könntest die iobroker vm löschen, dann kannst dir ein unifi backup ziehen.
                              Anschliesend proxmox neu installieren, vm wieder anlegen, backups einspielen
                              Ja, kann ich, hab es eigentlich in der Anleitung mit erwähnt.
                              Für root so 20Gb, reicht dicke, bei swap reichen 2-4 Gb, den Rest lässt du leer
                              • JLeg
                                JLeg @Homoran last edited by JLeg
                                @homoran sagte in Proxmox spinnt - brauche Hilfe - auch mit Unifi:
                                ich auch nicht - aber ich habe Backups 😉 - zumindest eines pro Tag (Nacht). Das ist erheblich sicherer/schneller/unkomplizierter, als im Falle des Falles erstmal Debian/IOB/Backitup etc. ans Fliegen zu bringen...
                                (ich meine natürlich die "in Proxmox eingebauten" Bsckups)
                                  die hab ich ja auch - kein Problem
                                  Aber von dem Unifi Controller nicht
                                  JLeg crunchip 2 Replies Last reply Reply Quote 0
                                    Ooops - sollte ich vielleicht mal komplett lesen 😞
                                    Sorry!
                                    Seh ich mir nachher an.
                                    in der v6 (oder5) wurde man noch gefragt wie man LVE und LVE-thin verteilen will, in der 7 nicht
                                    • JLeg
                                      ahso; evtl. könntest du auch einfach mal schauen, ob sich die Unifi-VM nicht zumindest mounten lässt - und dir dann den Pfad "/var/lib/unifi" als Tar oder zip wegsichern.
                                        @homoran wenn du nur die unifi vm startest, kannst dir doxg im Controller ein backup erstellen, mit deiner config
                                          jepp - hatte ich vor. Lief nur nicht mehr
                                          Nachdem jetzt die ioBroker VM auch nicht mehr startet will ich es wagen diese zu löschen.
                                            das hat so nicht geklappt, aber nach löschen der ioB-VM
                                            Ihr seid die besten
                                            81.1k
                                            8113
