    4. Sonoff NSPanel
    Sonoff NSPanel
    • Armilar
      Armilar Most Active Forum Testing @Dexxter last edited by
      @dexxter sehe ich mir morgen mal an. Musste mal die Stadt verlassen 😉 und bin nur noch mobil
        Dexxter @Armilar last edited by
        @armilar
        Alles klar, dann wünsch ich Dir mal noch einen schönen RestSonntag 😊
        • Great SUN
          Great SUN @Armilar last edited by Great SUN
          @armilar @joBr99 : OK, also... ich hab jetzt alles soweit fertig gemacht, aber ich komme zu einem Problem, das vielleicht auch keines ist..
          15:49:23.163 MQT: tele/tasmota_0CD9C0/RESULT = {"Flashing":{"complete": 0, "time_elapsed": 0}}
          15:49:28.010 MQT: tele/tasmota_0CD9C0/RESULT = {"Flashing":{"complete": 1, "time_elapsed": 5}}
          15:49:32.434 MQT: tele/tasmota_0CD9C0/RESULT = {"Flashing":{"complete": 2, "time_elapsed": 9}}
          15:49:37.691 MQT: tele/tasmota_0CD9C0/RESULT = {"Flashing":{"complete": 3, "time_elapsed": 14}}
          15:50:13.769 MQT: tele/tasmota_0CD9C0/STATE = {"Time":"2022-04-24T15:50:13","Uptime":"0T00:15:09","UptimeSec":909,"Heap":166,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":1,"Berry":{"HeapUsed":14,"Objects":223},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"SVGCast2","BSSId":"F0:2F:74:55:CF:E0","Channel":10,"Mode":"11n","RSSI":100,"Signal":-46,"LinkCount":1,"Downtime":"0T00:00:03"}}
          15:50:13.782 MQT: tele/tasmota_0CD9C0/SENSOR = {"Time":"2022-04-24T15:50:13","ANALOG":{"Temperature1":2.0},"ESP32":{"Temperature":38.9},"TempUnit":"C"}
          15:55:13.761 MQT: tele/tasmota_0CD9C0/STATE = {"Time":"2022-04-24T15:55:13","Uptime":"0T00:20:09","UptimeSec":1209,"Heap":166,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":1,"Berry":{"HeapUsed":14,"Objects":223},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"SVGCast2","BSSId":"F0:2F:74:55:CF:E0","Channel":10,"Mode":"11n","RSSI":100,"Signal":-50,"LinkCount":1,"Downtime":"0T00:00:03"}}
          15:55:13.781 MQT: tele/tasmota_0CD9C0/SENSOR = {"Time":"2022-04-24T15:55:13","ANALOG":{"Temperature1":2.4},"ESP32":{"Temperature":38.3},"TempUnit":"C"}
          Ist das normal, dass der nach 3 % dann ewig braucht, bis er wieder was von sich gibt?
          Der steht jetzt bei etwa 10min auf den 3%...
          Die Tasmota Console reagiert aber noch, Status0 funktioniert und kommt zurück.
          Great SUN 1 Reply Last reply Reply Quote 0
          • Great SUN
            Great SUN @Great SUN last edited by
            Also, da geht gar nichts mehr. Nicht einmal ein Reset 😞
            Jemand ne Ahnung, wie ich das wieder unbricked bekomme?
            • Armilar
              Armilar Most Active Forum Testing @Great SUN last edited by Armilar
              @great-sun sagte in Sonoff NSPanel:
              um 17:00 Uhr war die Tasmota-Konsole noch da - ist das immer noch so?
              Falls ja,
              • lösch mal in "Verwalte Dateisystem" (Tasmota Konsolen) alle Files raus. autoexec.be/bec
              • lege die "autoexec.be": https://github.com/joBr99/nspanel-lovelace-ui/blob/main/tasmota/autoexec.be neu an
              • "FlashNextion http://nspanel.pky.eu/lui.tft" in der Tasmota Konsole ausführen
              Falls nein, (dann ist dein Tasmota wohl hin; Der ESP32 wird sicher noch okay sein)
              • Panel neu mit Tasmota tasmota32-nspanel.bin neu flashen
              • die 3 Punkte unter "Falls ja" ausführen
              Great SUN 2 Replies Last reply Reply Quote 0
              • Great SUN
                @armilar Tasmota ist alles noch da. Mach ich dann heute Abend oder so mal.
                Vielen lieben Dank!
                • Armilar
                  Armilar Most Active Forum Testing @Dexxter last edited by Armilar
                  @dexxter
                  Deine eigenen Versuche waren im Prinzip nicht schlecht. Wenn du den "type PageItem" entsprechend erweitert hättest (sehr weit unten), hätte es sogar fast funktioniert.
                  Habe jetzt zusätzlich minValueBrightness/maxValueBrightness und minValueColorTemp/maxValueColorTemp neu hinzugefügt. Wir würden irgendwann mit den Bezeichnern durcheinander kommen. minValue und maxValue können weiterhin verwendet werden, um z.B. Infos zu visualisieren (Batteriezustand, etc.)
                  Wie im Beispiel (Alias HUE, Brightness auf 70% begrenzt, Farbtemperatur zwischen 500 und 6500K):
                  <PageItem>{ id: "alias.0.NSPanel_1.TestCTmitHUE", name: "HUE-Light-CT", minValueBrightness: 0, maxValueBrightness: 70, minValueColorTemp: 500, maxValueColorTemp: 6500},
                  Das Ergebnis (vollständiges TypeScript):
                  var Icons = new IconsSelector();
                  const Months = ["Januar", "Februar", "März", "April", "Mai", "Juni", "Juli", "August", "September", "Oktober", "November", "Dezember"];
                  const Days = ["Sonntag", "Montag", "Dienstag", "Mittwoch", "Donnerstag", "Freitag", "Samstag"];
                  //const Off: RGB = { red: 68, green: 115, blue: 158 }; //Blau-Off
                  const Off: RGB = { red: 253, green: 128, blue: 0 }; //Orange-Off
                  const On: RGB = { red: 253, green: 216, blue: 53 };
                  const MSRed: RGB = { red: 251, green: 105, blue: 98 };
                  const MSGreen: RGB = { red: 121, green: 222, blue: 121 };
                  const Red: RGB = { red: 255, green: 0, blue: 0 };
                  const White: RGB = { red: 255, green: 255, blue: 255 };
                  const Yellow: RGB = { red: 255, green: 255, blue: 0 };
                  const Green: RGB = { red: 0, green: 255, blue: 0 };
                  const Blue: RGB = { red: 0, green: 0, blue: 255 };
                  const Gray: RGB = { red: 136, green: 136, blue: 136 };
                  const Black: RGB = { red: 0, green: 0, blue: 0 };
                  const colorSpotify: RGB = { red: 30, green: 215, blue: 96 };
                  const colorAlexa: RGB = { red: 49, green: 196, blue: 243 };
                  const colorRadio: RGB = { red: 255, green: 127, blue: 0 };
                  const BatteryFull: RGB = { red: 96, green: 176, blue: 62 };
                  const BatteryEmpty: RGB = { red: 179, green: 45, blue: 25 };
                  //----Möglichkeit, im Screensaver zwischen Accu-Weather Forecast oder selbstdefinierten Werten zu wählen---------------------------------
                  var weatherForecast = true; //true = WheatherForecast 5 Days --- false = Config --> firstScreensaverEntity - fourthScreensaverEntity ...
                  //Alexa-Instanz
                  var alexaInstanz = "alexa2.0"
                  var alexaDevice = "G0XXXXXXXXXXXXXXX"; //Primär zu steuendes Device
                  // Wenn alexaSpeakerList definiert, dann werden Einträge verwendet, sonst alle relevanten Devices aus Alexa-Instanz
                  // Speakerwechsel funktioniert nicht bei Radio/TuneIn sonden bei Playlists
                  const alexaSpeakerList = []; //Beispiel ["Echo Spot Buero","Überall","Gartenhaus","Esszimmer","Heimkino"];
                  //const alexaSpeakerList = ["Echo Spot Buero","Überall","Gartenhaus","Esszimmer","Heimkino","Echo Dot Küche"];
                  //Datenpunkte für Nachricht an Screensaver
                  var popupNotifyHeading = "0_userdata.0.NSPanel.1.popupNotifyHeading";
                  var popupNotifyText = "0_userdata.0.NSPanel.1.popupNotifyText";
                  var Test_Licht: PageEntities =
                      "type": "cardEntities",
                      "heading": "Büro",
                      "useColor": true,
                      "items": [
                          <PageItem>{ id: "alias.0.NSPanel_1.Schreibtischlampe", interpolateColor: true},
                          <PageItem>{ id: "alias.0.NSPanel_1.TestRGBLicht", name: "RGB-Licht", minValueBrightness: 0, maxValueBrightness: 70, interpolateColor: true},
                          <PageItem>{ id: "alias.0.NSPanel_1.TestCTmitHUE", name: "HUE-Licht-CT", minValueBrightness: 0, maxValueBrightness: 70, minValueColorTemp: 500, maxValueColorTemp: 6500, interpolateColor: true},
                          <PageItem>{ id: "alias.0.NSPanel_1.TestHUELicht", name: "HUE-Licht-Color", minValueColorTemp: 500, maxValueColorTemp: 6500, interpolateColor: true}
                  var Buero_Seite_1: PageEntities =
                      "heading": "Büro",
                      "useColor": true,
                      "items": [
                          <PageItem>{ id: "alias.0.NSPanel_1.Deckenbeleuchtung"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Testlampe2", name: "Filamentlampe", minValueBrightness: 0, maxValueBrightness: 70, interpolateColor: true},
                          <PageItem>{ id: "alias.0.NSPanel_1.Luftreiniger", icon: "power", offColor: MSRed, onColor: MSGreen}
                  var Fenster_1: PageEntities =
                      "heading": "Fenster und Türen",
                      "useColor": true,
                      "items": [
                          <PageItem>{ id: "alias.0.NSPanel_1.TestFenster", offColor: MSRed, onColor: MSGreen, name: "Büro Fenster"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Haustuer", offColor: MSRed, onColor: MSGreen, name: "Haustür"},
                          <PageItem>{ id: "alias.0.NSPanel_1.TestBlind", onColor: White, name: "IKEA Fyrtur"}
                  var Abfall: PageEntities =
                      "heading": "Abfallkalender",
                      "useColor": true,
                      "items": [
                          <PageItem>{ id: "alias.0.NSPanel_1.Abfall.event1",icon: "trash-can"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Abfall.event2",icon: "trash-can"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Abfall.event3",icon: "trash-can"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Abfall.event4",icon: "trash-can"}
                  var Buero_Seite_2: PageGrid =
                      "type": "cardGrid",
                      "heading": "Büro 2",
                      "useColor": true,
                      "items": [
                          <PageItem>{ id: "alias.0.NSPanel_1.Schreibtischlampe", name: "Schreibtisch"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Deckenbeleuchtung", name: "Deckenlampe"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Luftreiniger", icon: "power", offColor: MSRed, onColor: MSGreen},
                          <PageItem>{ id: "alias.0.NSPanel_1.TestBlind", icon: "projector-screen", onColor: White, name: "Beamer"},
                          <PageItem>{ id: "alias.0.NSPanel_1.Radio.TuneIn", icon: "play", onColor: White}
                  var Alexa: PageMedia =
                      "type": "cardMedia",
                      "heading": "Alexa",
                      "useColor": true,
                      "items": [<PageItem>{ id: "alias.0.NSPanel_1.Alexa.PlayerBuero" }]
                  var Buero_Themostat: PageThermo =
                      "type": "cardThermo",
                      "heading": "Thermostat",
                      "useColor": true,
                      "items": [<PageItem>{ id: "alias.0.NSPanel_1.Thermostat_Büro" }]
                  var Buero_Alarm: PageAlarm =
                      "type": "cardAlarm",
                      "heading": "Alarm",
                      "useColor": true,
                      "items": [<PageItem>{ id: "alias.0.NSPanel_1.Alarm" }]
                  var button1Page: PageGrid =
                      "type": "cardGrid",
                      "heading": "Radio",
                      "useColor": true,
                      "items": [
                          <PageItem>{ id: "alias.0.NSPanel_1.Radio.FFN", icon: "radio", name: "FFN", onColor: colorRadio},
                          <PageItem>{ id: "alias.0.NSPanel_1.Radio.Antenne" , icon: "radio", name: "Antenne Nds.", onColor: colorRadio},
                          <PageItem>{ id: "alias.0.NSPanel_1.Radio.NDR2", icon: "radio", name: "NDR2", onColor: colorRadio},
                          <PageItem>{ id: "alias.0.NSPanel_1.Radio.Bob", icon: "radio", name: "Radio BOB", onColor: colorRadio},
                          <PageItem>{ id: "alias.0.NSPanel_1.Radio.Spotify", icon: "spotify", name: "Party Playlist", onColor: colorSpotify},
                          <PageItem>{ id: "alias.0.NSPanel_1.Radio.Alexa", icon: "playlist-music", name: "Playlist 2021", onColor: colorAlexa}
                  var button2Page: PageEntities =
                      "heading": "Büro",
                      "useColor": true,
                      "items": [
                          <PageItem>{ id: "alias.0.NSPanel_1.Schreibtischlampe"},
                  export const config: Config = {
                      panelRecvTopic: "mqtt.0.SmartHome.NSPanel_1.tele.RESULT",       //anpassen
                      panelSendTopic: "mqtt.0.SmartHome.NSPanel_1.cmnd.CustomSend",   //anpassen
                      firstScreensaverEntity: { ScreensaverEntity: "hmip.0.devices.3014F711A000185BE9922BCF.channels.1.humidity", ScreensaverEntityIcon: "water-percent", ScreensaverEntityText: "Luft", ScreensaverEntityUnitText: "%" },
                      secondScreensaverEntity: { ScreensaverEntity: "accuweather.0.Daily.Day1.Day.PrecipitationProbability", ScreensaverEntityIcon: "weather-pouring", ScreensaverEntityText: "Regen", ScreensaverEntityUnitText: "%" },
                      thirdScreensaverEntity: { ScreensaverEntity: "0_userdata.0.Wetter.Windstaerke_homaticIP", ScreensaverEntityIcon: "weather-windy", ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: "bft" },
                      fourthScreensaverEntity: { ScreensaverEntity: "accuweather.0.Current.UVIndex", ScreensaverEntityIcon: "solar-power", ScreensaverEntityText: "UV", ScreensaverEntityUnitText: "" },
                      timeoutScreensaver: 15,
                      dimmode: 8,
                      screenSaverDoubleClick: false,
                      locale: "de_DE",
                      timeFormat: "%H:%M",
                      dateFormat: "%A, %d. %B %Y",
                      weatherEntity: "alias.0.Wetter.Wetter",
                      defaultOffColor: Off,
                      defaultOnColor: On,
                      defaultColor: Off,
                      temperatureUnit: "°C",
                      pages: [
                              Buero_Seite_1,
                              Test_Licht,
                              Fenster_1,
                              Abfall,
                              Buero_Seite_2,
                              Alexa,
                              Buero_Themostat,
                              Buero_Alarm
                      button1Page: button1Page,
                      button2Page: button2Page
                  // _________________________________ Ab hier keine Konfiguration mehr _____________________________________
                  //Notification an Screensaver
                  on({id: [popupNotifyHeading, popupNotifyText], change: "ne"}, async function (obj) {
                      setState(config.panelSendTopic,(['notify~',getState(popupNotifyHeading).val,'~',getState(popupNotifyText).val].join('')));
                  var subscriptions: any = {};
                  var screensaverEnabled : boolean = false;
                  var pageId = 0;
                  schedule("* * * * *", function () {
                      SendTime();
                  schedule("0 * * * *", function () {
                      SendDate();
                  // Only monitor the extra nodes if present
                  var updateArray: string[] = [];
                  if (config.firstScreensaverEntity !== null && config.firstScreensaverEntity.ScreensaverEntity != null && existsState(config.firstScreensaverEntity.ScreensaverEntity)) {
                      updateArray.push(config.firstScreensaverEntity.ScreensaverEntity)
                  if (config.secondScreensaverEntity !== null && config.secondScreensaverEntity.ScreensaverEntity != null && existsState(config.secondScreensaverEntity.ScreensaverEntity)) {
                      updateArray.push(config.secondScreensaverEntity.ScreensaverEntity)
                  if (config.thirdScreensaverEntity !== null && config.thirdScreensaverEntity.ScreensaverEntity != null && existsState(config.thirdScreensaverEntity.ScreensaverEntity)) {
                      updateArray.push(config.thirdScreensaverEntity.ScreensaverEntity)
                  if (config.fourthScreensaverEntity !== null && config.fourthScreensaverEntity.ScreensaverEntity != null && existsState(config.fourthScreensaverEntity.ScreensaverEntity)) {
                      updateArray.push(config.fourthScreensaverEntity.ScreensaverEntity)
                  if (updateArray.length > 0) {
                      on(updateArray, function () {
                          HandleScreensaverUpdate();
                  on({ id: config.panelRecvTopic }, function (obj) {
                      if (obj.state.val.startsWith('\{"CustomRecv":')) {
                          var json = JSON.parse(obj.state.val);
                          var split = json.CustomRecv.split(",");
                          HandleMessage(split[0], split[1], parseInt(split[2]), split);
                  function SendToPanel(val: Payload | Payload[]): void {
                      if (Array.isArray(val)) {
                          val.forEach(function (id, i) {
                              setState(config.panelSendTopic, id.payload);
                      else
                          setState(config.panelSendTopic, val.payload);
                  function HandleMessage(typ: string, method: string, page: number, words: Array<string>): void {
                      if (typ == "event") {
                          switch (method) {
                              case "startup":
                                  screensaverEnabled = false;
                                  UnsubscribeWatcher();
                                  HandleStartupProcess();
                                  pageId = 0;
                                  GeneratePage(config.pages[0]);
                                  break;
                              case "sleepReached":
                                  screensaverEnabled = true;
                                  if (pageId < 0)
                                      pageId = 0;
                                  HandleScreensaver();
                                  break;
                              case "pageOpenDetail":
                                  let pageItem = config.pages[pageId].items.find(e => e.id === words[3]);
                                  if (pageItem !== undefined)
                                      SendToPanel(GenerateDetailPage(words[2], pageItem));
                              case "buttonPress2":
                                  HandleButtonEvent(words);
                                  break;
                              case "button1":
                              case "button2":
                                  HandleHardwareButton(method);
                              default:
                                  break;
                  function GeneratePage(page: Page): void {
                      switch (page.type) {
                          case "cardEntities":
                              SendToPanel(GenerateEntitiesPage(<PageEntities>page));
                              break;
                          case "cardThermo":
                              SendToPanel(GenerateThermoPage(<PageThermo>page));
                              break;
                          case "cardGrid":
                              SendToPanel(GenerateGridPage(<PageGrid>page));
                              break;
                          case "cardMedia":
                              SendToPanel(GenerateMediaPage(<PageMedia>page));
                              break;
                          case "cardAlarm":
                              SendToPanel(GenerateAlarmPage(<PageAlarm>page));
                              break;
                  function HandleHardwareButton(method: string): void {
                      let page: (PageThermo | PageMedia | PageAlarm | PageEntities | PageGrid);
                      if (config.button1Page !== null && method == "button1") {
                          page = config.button1Page;
                          pageId = -1;
                      else if (config.button2Page !== null && method == "button2") {
                          page = config.button2Page;
                          pageId = -2;
                      else {
                          return;
                      GeneratePage(page);
                  function HandleStartupProcess(): void {
                      SendDate();
                      SendTime();
                      SendToPanel({ payload: "timeout~" + config.timeoutScreensaver });
                      SendToPanel({ payload: "dimmode~" + config.dimmode });
                  function SendDate(): void {
                      var d = new Date();
                      var day = Days[d.getDay()];
                      var date = d.getDate();
                      var month = Months[d.getMonth()];
                      var year = d.getFullYear();
                      var _sendDate = "date~" + day + " " + date + " " + month + " " + year;
                      SendToPanel(<Payload>{ payload: _sendDate });
                  function SendTime(): void {
                      var d = new Date();
                      var hr = d.getHours().toString();
                      var min = d.getMinutes().toString();
                      if (d.getHours() < 10) {
                          hr = "0" + d.getHours().toString();
                      if (d.getMinutes() < 10) {
                          min = "0" + d.getMinutes().toString();
                      SendToPanel(<Payload>{ payload: "time~" + hr + ":" + min });
                  function GenerateEntitiesPage(page: PageEntities): Payload[] {
                      var out_msgs: Array<Payload> = [];
                      out_msgs = [{ payload: "pageType~cardEntities" }]
                      out_msgs.push({ payload: GeneratePageElements(page) });
                      return out_msgs
                  function GenerateGridPage(page: PageGrid): Payload[] {
                      out_msgs = [{ payload: "pageType~cardGrid" }]
                      return out_msgs
                  function GeneratePageElements(page: Page): string {
                      let maxItems = 0;
                          case "cardThermo":
                              maxItems = 1;
                              break;
                          case "cardAlarm":
                              maxItems = 1;
                              break;
                          case "cardMedia":
                              maxItems = 1;
                              break;
                              maxItems = 4;
                              break;
                          case "cardGrid":
                              maxItems = 6;
                              break;
                      let pageData = "entityUpd~" + page.heading + "~" + GetNavigationString(pageId)
                      for (let index = 0; index < maxItems; index++) {
                          if (page.items[index] !== undefined) {
                              pageData += CreateEntity(page.items[index], index + 1, page.useColor);
                          else {
                              pageData += CreateEntity(<PageItem>{ id: "delete" }, index + 1);
                      return pageData;
                  function CreateEntity(pageItem: PageItem, placeId: number, useColors: boolean = false): string {
                      var iconId = "0"
                      if (pageItem.id == "delete") {
                          return "~delete~~~~~"
                      var name: string;
                      var type: string;
                      // ioBroker
                      if (existsObject(pageItem.id)) {
                          let o = getObject(pageItem.id)
                          var val = null;
                          name = pageItem.name !== undefined ? pageItem.name : o.common.name.de
                          if (existsState(pageItem.id + ".GET")) {
                              val = getState(pageItem.id + ".GET").val;
                              RegisterEntityWatcher(pageItem.id + ".GET");
                          else if (existsState(pageItem.id + ".SET")) {
                              val = getState(pageItem.id + ".SET").val;
                              RegisterEntityWatcher(pageItem.id + ".SET");
                          var iconColor = rgb_dec565(config.defaultColor);
                          switch (o.common.role) {
                              case "socket":
                              case "light":
                                  type = "light"
                                  iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : o.common.role == "socket"  ? Icons.GetIcon("power-socket-de") : Icons.GetIcon("lightbulb");
                                  var optVal = "0"
                                  if (val === true || val === "true") {
                                      optVal = "1"
                                      iconColor = GetIconColor(pageItem, true, useColors);
                                  } else {
                                      iconColor = GetIconColor(pageItem, false, useColors);
                                  return "~" + type + "~" + pageItem.id + "~" + iconId + "~" + iconColor + "~" + name + "~" + optVal;
                              case "hue":
                                  type = "light"
                                  iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon("lightbulb");
                                  var optVal = "0"
                                  if (existsState(pageItem.id + ".ON_ACTUAL")) {
                                      val = getState(pageItem.id + ".ON_ACTUAL").val;
                                      RegisterEntityWatcher(pageItem.id + ".ON_ACTUAL");
                                      optVal = "1"
                                      iconColor = GetIconColor(pageItem, existsState(pageItem.id + ".DIMMER") ? 100 - getState(pageItem.id + ".DIMMER").val : true, useColors);
                                  if (existsState(pageItem.id + ".HUE")) {
                                      if (getState(pageItem.id + ".HUE").val != null) {
                                          let huecolor = hsv2rgb(getState(pageItem.id + ".HUE").val,1,1);
                                          let rgb = <RGB>{ red: Math.round(huecolor[0]), green: Math.round(huecolor[1]), blue: Math.round(huecolor[2])}
                                          iconColor = rgb_dec565(pageItem.interpolateColor !== undefined ? rgb : config.defaultOnColor);
                                          //RegisterDetailEntityWatcher(id + ".HUE", pageItem, type);
                              case "rgb":
                                  type = "light"
                                  var optVal = "0"
                                      optVal = "1"
                                  if (existsState(pageItem.id + ".RED") && existsState(pageItem.id + ".GREEN") && existsState(pageItem.id + ".BLUE")) {
                                      if (getState(pageItem.id + ".RED").val != null && getState(pageItem.id + ".GREEN").val != null && getState(pageItem.id + ".BLUE").val != null) {
                                          let rgbRed = getState(pageItem.id + ".RED").val;
                                          let rgbGreen = getState(pageItem.id + ".GREEN").val;
                                          let rgbBlue = getState(pageItem.id + ".BLUE").val;
                                          let rgb = <RGB>{ red: Math.round(rgbRed), green: Math.round(rgbGreen), blue: Math.round(rgbBlue)}
                              case "dimmer":
                                  type = "light"
                                  var optVal = "0"
                                  else if (existsState(pageItem.id + ".ON_SET")) {
                                      val = getState(pageItem.id + ".ON_SET").val;
                                      RegisterEntityWatcher(pageItem.id + ".ON_SET");
                                      optVal = "1"
                                      iconColor = GetIconColor(pageItem, existsState(pageItem.id + ".ACTUAL") ? 100 - getState(pageItem.id + ".ACTUAL").val : true, useColors);
                              case "blind":
                                  type = "shutter"
                                  iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon("window-open");
                                  iconColor = GetIconColor(pageItem, existsState(pageItem.id + ".ACTUAL") ? getState(pageItem.id + ".ACTUAL").val : true, useColors);
                              case "door":
                              case "window":
                                  type = "text";
                                  if (existsState(pageItem.id + ".ACTUAL")) {
                                      if (getState(pageItem.id + ".ACTUAL").val) {
                                          iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : o.common.role == "door"  ? Icons.GetIcon("door-open") : Icons.GetIcon("window-open-variant");
                                          var windowState = "opened"
                                      } else {
                                          iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : o.common.role == "door"  ? Icons.GetIcon("door-closed") : Icons.GetIcon("window-closed-variant");
                                          //iconId = Icons.GetIcon("window-closed-variant");
                                          var windowState = "closed"
                                      RegisterEntityWatcher(pageItem.id + ".ACTUAL");
                                  return "~" + type + "~" + pageItem.id + "~" + iconId + "~" + iconColor + "~" + name + "~" + windowState;
                              case "info":
                              case "humidity":
                              case "value.temperature":
                              case "value.humidity":
                              case "sensor.door":
                              case "sensor.window":
                              case "thermostat":
                                  type = "text";
                                  iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : o.common.role == "value.temperature" || o.common.role == "thermostat" ? Icons.GetIcon("thermometer") : Icons.GetIcon("information-outline");
                                  let unit = "";
                                  var optVal = "0"
                                      optVal = getState(pageItem.id + ".ON_ACTUAL").val;
                                      unit = pageItem.unit !== undefined ? pageItem.unit : GetUnitOfMeasurement(pageItem.id + ".ON_ACTUAL");
                                  else if (existsState(pageItem.id + ".ACTUAL")) {
                                      optVal = getState(pageItem.id + ".ACTUAL").val;
                                      unit = pageItem.unit !== undefined ? pageItem.unit : GetUnitOfMeasurement(pageItem.id + ".ACTUAL");
                                  if (o.common.role == "value.temperature") {
                                      iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon("thermometer");
                                  iconColor = GetIconColor(pageItem, parseInt(optVal), useColors);
                                  return "~" + type + "~" + pageItem.id + "~" + iconId + "~" + iconColor + "~" + name + "~" + optVal + " " + unit;
                              case "button":
                                  type = "button";
                                  iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon("gesture-tap-button");
                                  let buttonText = pageItem.name !== undefined ? pageItem.name : "PRESS";
                                  return "~" + type + "~" + pageItem.id + "~" + iconId + "~" + iconColor + "~" + name + "~" + buttonText;
                              case "warning":
                                  type = "text";
                                  iconId = pageItem.icon !== undefined ? Icons.GetIcon(pageItem.icon) : Icons.GetIcon("alert-outline");
                                  iconColor = getState(([pageItem.id,'.LEVEL'].join(''))).val;
                                  let itemName = getState(([pageItem.id,'.TITLE'].join(''))).val;
                                  let itemInfo = getState(([pageItem.id,'.INFO'].join(''))).val;
                                  return "~" + type + "~" + itemName + "~" + iconId + "~" + iconColor + "~" + itemName + "~" + itemInfo;
                              default:
                                  return "~delete~~~~~";
                  function GetIconColor(pageItem: PageItem, value: (boolean | number), useColors: boolean): number {
                      // dimmer
                      if ((pageItem.useColor || useColors) && pageItem.interpolateColor && typeof (value) === "number") {
                          let maxValue = pageItem.maxValueBrightness !== undefined ? pageItem.maxValueBrightness : 100;
                          let minValue = pageItem.minValueBrightness !== undefined ? pageItem.minValueBrightness : 0;
                          if (pageItem.maxValue !== undefined) maxValue = pageItem.maxValue;
                          if (pageItem.minValue !== undefined) minValue = pageItem.minValue;
                          value = value > maxValue ? maxValue : value;
                          value = value < minValue ? minValue : value;
                          return rgb_dec565(
                              Interpolate(
                                  pageItem.offColor !== undefined ? pageItem.offColor : config.defaultOffColor,
                                  pageItem.onColor !== undefined ? pageItem.onColor : config.defaultOnColor,
                                  scale(value, minValue, maxValue, 0, 1)
                      if ((pageItem.useColor || useColors) && ((typeof (value) === "boolean" && value) || value > (pageItem.minValueBrightness !== undefined ? pageItem.minValueBrightness : 0))) {
                          return rgb_dec565(pageItem.onColor !== undefined ? pageItem.onColor : config.defaultOnColor)
                      return rgb_dec565(pageItem.offColor !== undefined ? pageItem.offColor : config.defaultOffColor);
                  function RegisterEntityWatcher(id: string): void {
                      if (subscriptions.hasOwnProperty(id)) {
                          return;
                      subscriptions[id] = (on({ id: id, change: 'any' }, function (data) {
                          if(pageId >= 0)
                              SendToPanel({ payload: GeneratePageElements(config.pages[pageId]) });
                          if(pageId == -1 && config.button1Page != undefined)
                              SendToPanel({ payload: GeneratePageElements(config.button1Page) });
                          if(pageId == -2 && config.button2Page != undefined)
                              SendToPanel({ payload: GeneratePageElements(config.button2Page) });
                  function RegisterDetailEntityWatcher(id: string, pageItem: PageItem, type: string): void {
                          return;
                      subscriptions[id] = (on({ id: id, change: 'any' }, function () {
                          SendToPanel(GenerateDetailPage(type, pageItem));
                  function GetUnitOfMeasurement(id: string): string {
                      if (!existsObject(id))
                          return "";
                      let obj = getObject(id);
                      if (typeof obj.common.unit !== 'undefined') {
                          return obj.common.unit
                      if (typeof obj.common.alias !== 'undefined' && typeof obj.common.alias.id !== 'undefined') {
                          return GetUnitOfMeasurement(obj.common.alias.id);
                      return "";
                  function GenerateThermoPage(page: PageThermo): Payload[] {
                      var id = page.items[0].id
                      out_msgs.push({ payload: "pageType~cardThermo" });
                      // ioBroker
                      if (existsObject(id)) {
                          let o = getObject(id)
                          let name = page.items[0].name !== undefined ? page.items[0].name : o.common.name.de
                          let currentTemp = 0;
                          if (existsState(id + ".ACTUAL"))
                              currentTemp = (Math.round(parseFloat(getState(id + ".ACTUAL").val) * 10)/10)*10;
                          let destTemp = 0;
                          if (existsState(id + ".SET")) {
                              destTemp = getState(id + ".SET").val.toFixed(2) * 10;
                          let status = ""
                          if (existsState(id + ".MODE"))
                              status = getState(id + ".MODE").val;
                          let minTemp = 50 //Min Temp 5°C
                          let maxTemp = 300 //Max Temp 30°C
                          let stepTemp = 5
                          //0-4 verwendet bei ungerader Anzahl Parametern
                          let bt0 = "~~~~"; //verwendet bei ungleichen Parametern
                          let bt1 = "~~~~"; //verwendet bei ungleichen Parametern
                          let bt2 = "~~~~"; //verwendet bei ungleichen Parametern
                          let bt3 = "~~~~"; //verwendet bei ungleichen Parametern
                          let bt4 = "~~~~"; //verwendet bei ungleichen Parametern
                          //5-8 verwendet bei gerader Anzahl Parametern
                          let bt5 = Icons.GetIcon("water-percent") + "~0~1~~";
                          let bt6 = Icons.GetIcon("fire") + "~0~1~~";
                          let bt7 = Icons.GetIcon("wifi") + "~0~1~~";
                          let bt8 = Icons.GetIcon("battery-high") + "~0~1~~";
                          if (existsState(id + ".HUMIDITY")){
                              bt5 =  Icons.GetIcon("water-percent") + "~2016~1~bt8~";
                              if (parseInt(getState(id + ".HUMIDITY").val) < 40) {
                                  bt5 =  Icons.GetIcon("water-percent") + "~65504~1~bt8~";
                              } else if (parseInt(getState(id + ".HUMIDITY").val) < 30) {
                                  bt5 =  Icons.GetIcon("water-percent") + "~63488~1~bt8~";
                              } else if (parseInt(getState(id + ".HUMIDITY").val) > 65) {
                              } else if (parseInt(getState(id + ".HUMIDITY").val) > 75) {
                          if (existsState(id + ".MAINTAIN")){
                              if (getState(id + ".MAINTAIN").val >> .1) {
                                  bt6 =  Icons.GetIcon("fire") + "~60897~1~bt8~";
                              } else {
                                  bt6 =  Icons.GetIcon("fire") + "~33840~0~bt8~";
                          if (existsState(id + ".UNREACH")){
                              if (getState(id + ".UNREACH").val) {
                                  bt7 =  Icons.GetIcon("wifi-off") + "~63488~1~bt8~";
                              } else {
                                  bt7 =  Icons.GetIcon("wifi") + "~2016~1~bt8~";
                          if (existsState(id + ".LOWBAT")){
                              if (getState(id + ".LOWBAT").val) {
                                  bt8 =  Icons.GetIcon("battery-low") + "~63488~1~bt8~";
                              } else {
                                  bt8 =  Icons.GetIcon("battery-high") + "~2016~1~bt8~";
                          let icon_res = bt0 + bt1 + bt2 + bt3 + bt4 + bt5 + bt6 + bt7 + bt8;
                          out_msgs.push({ payload: "entityUpd~" + name + "~" + GetNavigationString(pageId) + "~" + id + "~" + currentTemp + "~" + destTemp + "~" + status + "~" + minTemp + "~" + maxTemp + "~" + stepTemp + "~" +icon_res})
                      return out_msgs
                  function GenerateMediaPage(page: PageMedia): Payload[] {
                      out_msgs.push({ payload: "pageType~cardMedia" });
                          let name = getState(id + ".ALBUM").val;
                          let media_icon = Icons.GetIcon("playlist-music");
                          let title = getState(id + ".TITLE").val;
                          let author = getState(id + ".ARTIST").val;
                          let volume = getState(id + ".VOLUME").val;
                          var iconplaypause = Icons.GetIcon("pause"); //pause
                          var onoffbutton = 1374;
                          if (getState(id + ".STATE").val) {
                              onoffbutton = 65535;
                          } else {
                              iconplaypause = Icons.GetIcon("play"); //play
                          let currentSpeaker = getState(([alexaInstanz,'.Echo-Devices.',alexaDevice,'.Info.name'].join(''))).val;
                          //console.log(id);
                  // nachfolgend alle Alexa-Devices (ist Online / Player- und Commands-Verzeichnis vorhanden) auflisten und verketten
                  // Wenn Konstante alexaSpeakerList mind. einen Eintrag enthält, wird die Konstante verwendet - ansonsten Alle Devices aus dem Alexa Adapter
                          let speakerlist = "";
                          if (alexaSpeakerList.length > 0) {
                              for (let i_index in alexaSpeakerList) {
                                  speakerlist = speakerlist + alexaSpeakerList[i_index] + "?";
                          } else {
                              let i_list = Array.prototype.slice.apply($('[state.id="' + alexaInstanz + '.Echo-Devices.*.Info.name"]'));
                              for (let i_index in i_list) {
                                  let i = i_list[i_index];
                                  let deviceId = i;
                                  deviceId = deviceId.split('.');
                                  if (getState(([alexaInstanz,'.Echo-Devices.',deviceId[3],'.online'].join(''))).val &&
                                      existsObject(([alexaInstanz,'.Echo-Devices.',deviceId[3],'.Player'].join(''))) &&
                                      existsObject(([alexaInstanz,'.Echo-Devices.',deviceId[3],'.Commands'].join('')))) {
                                          speakerlist = speakerlist + getState(i).val + "?";
                          speakerlist = speakerlist.substring(0,speakerlist.length-1);
                                                    name + "~" +
                                                    id + "~" +
                                                    id + "~" +         //????
                                                    media_icon + "~" +
                                                    title + "~" +
                                                    author + "~" +
                                                    volume + "~" +
                                                    iconplaypause + "~" +
                                                    currentSpeaker + "~" +
                                                    speakerlist + "~" +
                                                    onoffbutton});
                      return out_msgs
                  function GenerateAlarmPage(page: PageAlarm): Payload[] {
                      out_msgs.push({ payload: "pageType~cardAlarm" });
                      var armed: boolean = true;
                      if (armed) {
                          var arm1 = "Deaktivieren";                  //arm1*~*
                          var arm1ActionName = "D1";                  //arm1ActionName*~*
                          var arm2 = "";                              //arm2*~*
                          var arm2ActionName = "";                    //arm2ActionName*~*
                          var arm3 = "";                              //arm3*~*
                          var arm3ActionName = "";                    //arm3ActionName*~*
                          var arm4 = "";                              //arm4*~*
                          var arm4ActionName = "";                    //arm4ActionName*~*
                          var icon = Icons.GetIcon("shield-home");    //icon*~*
                          var iconcolor = 63488;                      //iconcolor*~*
                          var numpadStatus = 1;                       //numpadStatus*~*
                          var flashing = 1;                           //flashing*
                      else {
                          var arm1 = "Alarm 1";                       //arm1*~*
                          var arm1ActionName = "A1";                  //arm1ActionName*~*
                          var arm2 = "Alarm 2";                       //arm2*~*
                          var arm2ActionName = "A2";                  //arm2ActionName*~*
                          var arm3 = "Alarm 3";                       //arm3*~*
                          var arm3ActionName = "A3";                  //arm3ActionName*~*
                          var arm4 = "Alarm 4";                       //arm4*~*
                          var arm4ActionName = "A4";                  //arm4ActionName*~*
                          var icon = Icons.GetIcon("shield-off");     //icon*~*
                          var iconcolor = 2016;                       //iconcolor*~*
                      out_msgs.push({ payload:    "entityUpd~" +             //entityUpd~*
                                                  id + "~" +                 //internalNameEntity*~* //navigation*~*
                                                  arm1 + "~" +               //arm1*~*
                                                  arm1ActionName + "~" +     //arm1ActionName*~*
                                                  arm2 + "~" +               //arm2*~*
                                                  arm2ActionName + "~" +     //arm2ActionName*~*
                                                  arm3 + "~" +               //arm3*~*
                                                  arm3ActionName + "~" +     //arm3ActionName*~*
                                                  arm4 + "~" +               //arm4*~*
                                                  arm4ActionName + "~" +     //arm4ActionName*~*
                                                  icon + "~" +               //icon*~* 39=Disarmed 35=Shield_Home, 40
                                                  iconcolor + "~" +          //iconcolor*~* 2016=green  63488=red
                                                  numpadStatus + "~" +       //numpadStatus*~*
                                                  flashing});                //flashing*
                      return out_msgs
                  function setIfExists(id: string, value: any, type: string | null = null): boolean {
                      if (type === null) {
                          if (existsState(id)) {
                              setState(id, value);
                              return true;
                      else {
                          if (existsState(id) && obj.common.type !== undefined && obj.common.type === type) {
                              return true;
                      return false;
                  function toggleState(id: string): boolean {
                      if (existsState(id) && obj.common.type !== undefined && obj.common.type === "boolean") {
                          setState(id, !getState(id).val);
                          return true;
                      return false;
                  function HandleButtonEvent(words): void {
                      let id = words[2]
                      let buttonAction = words[3];
                      //console.log(words[0] + " - " + words[1] + " - " + words[2] + " - " + words[3] + " - " + words[4] + " - PageId: " + pageId);
                      switch (buttonAction) {
                          case "bNext":
                              var pageNum = ((pageId + 1) % config.pages.length);
                              pageId = Math.abs(pageNum);
                              GeneratePage(config.pages[pageId]);
                              break;
                          case "bPrev":
                              var pageNum = ((pageId - 1) % config.pages.length);
                              break;
                          case "bExit":
                              if (config.screenSaverDoubleClick) {
                                  if (words[4] == 2)
                              else
                              break;
                          case "OnOff":
                                  var action = false
                                  if (words[4] == "1")
                                      action = true
                                      case "light":
                                          setIfExists(id + ".SET", action);
                                          break;
                                      case "dimmer":
                                          setIfExists(id + ".ON_SET", action) ? true : setIfExists(id + ".ON_ACTUAL", action);
                                          break;
                                      case "hue": // Armilar
                              break;
                          case "up":
                              setIfExists(id + ".OPEN", true)
                              break;
                          case "stop":
                              setIfExists(id + ".STOP", true)
                              break;
                          case "down":
                              setIfExists(id + ".CLOSE", true)
                              break;
                          case "button":
                              toggleState(id + ".SET") ? true : toggleState(id + ".ON_SET")
                              break;
                          case "positionSlider":
                              setIfExists(id + ".SET", parseInt(words[4])) ? true : setIfExists(id + ".ACTUAL", parseInt(words[4]));
                              break;
                          case "brightnessSlider":
                                  let o = getObject(id);
                                  let pageItem = config.pages[pageId].items.find(e => e.id === id);
                                      case "dimmer":
                                          if (pageItem.minValueBrightness != undefined && pageItem.maxValueBrightness != undefined) {
                                              let sliderPos = Math.trunc(scale(parseInt(words[4]), 0, 100, pageItem.maxValueBrightness, pageItem.minValueBrightness))
                                              setIfExists(id + ".SET", sliderPos) ? true : setIfExists(id + ".ACTUAL", sliderPos);
                                          } else {
                                          break;
                                      case "hue":
                                      case "rgb":
                                          setIfExists(id + ".DIMMER", parseInt(words[4]));
                              break;
                          case "colorTempSlider": // Armilar - Slider tickt verkehrt - Hell = 0 / Dunkel = 100 -> Korrektur
                              if (pageItem.minValueColorTemp !== undefined && pageItem.minValueColorTemp !== undefined) {
                                  let colorTempK = Math.trunc(scale(parseInt(words[4]), 0, 100, pageItem.minValueColorTemp, pageItem.maxValueColorTemp));
                                  setIfExists(id + ".TEMPERATURE", (colorTempK));
                              } else {
                                  setIfExists(id + ".TEMPERATURE", 100 - words[4]);
                              break;
                          case "colorWheel":
                              let colorCoordinates = words[4].split('|');
                              let rgb = pos_to_color(colorCoordinates[0], colorCoordinates[1]);
                              //console.log(rgb);
                              //console.log(getHue(rgb.red, rgb.green, rgb.blue));
                                  case "hue":
                                      setIfExists(id + ".HUE", getHue(rgb.red, rgb.green, rgb.blue));
                                      break;
                                  case "rgb":
                                      setIfExists(id + ".RED", rgb.red);
                                      setIfExists(id + ".GREEN", rgb.green);
                                      setIfExists(id + ".BLUE", rgb.blue);
                              break;
                          case "tempUpd":
                              setIfExists(id + ".SET", parseInt(words[4]) / 10)
                              break;
                          case "media-back":
                              setIfExists(id + ".PREV", true)
                              break;
                          case "media-pause":
                              if (getState(id + ".STATE").val === true) {
                                  setIfExists(id + ".PAUSE", true)
                              } else {
                                  setIfExists(id + ".PLAY", true)
                              break;
                          case "media-next":
                              setIfExists(id + ".NEXT", true)
                              break;
                          case "volumeSlider":
                              setIfExists(id + ".VOLUME", parseInt(words[4]))
                              break;
                          case "speaker-sel":
                                  if ((getState(i).val) === words[4]){
                                      let deviceId = i;
                                      setIfExists(alexaInstanz + ".Echo-Devices." + alexaDevice + ".Commands.textCommand", "Schiebe meine Musik auf " + words[4]);
                                      alexaDevice = deviceId[3]
                              break;
                          case "media-OnOff":
                              break;
                          case "A1": //Alarm-Page Alarm 1 aktivieren
                              console.log("auf mediaAlarm - Alarm 1 - Wert: " + words[4] + " - reagieren - noch nicht implementiert");
                              break;
                          case "A2": //Alarm-Page Alarm 2 aktivieren
                              break;
                          case "A3": //Alarm-Page Alarm 3 aktivieren
                              break;
                          case "A4": //Alarm-Page Alarm 4 aktivieren
                              break;
                          case "D1": //Alarm-Page Alarm Deaktivieren
                              break;
                          default:
                              break;
                  function GetNavigationString(pageId: number): string {
                      switch (pageId) {
                          case 0:
                              return "0|1";
                          case config.pages.length - 1:
                              return "1|0";
                          case -1:
                              return "0|0";
                          default:
                              return "1|1";
                  function GenerateDetailPage(type: string, pageItem: PageItem): Payload[] {
                      let id = pageItem.id
                          var o = getObject(id)
                          var val: (boolean | number) = 0;
                          let icon = Icons.GetIcon("lightbulb");
                          if (type == "popupLight") {
                              let switchVal = "0"
                              let brightness = 0;
                              if (o.common.role == "light") {
                                  if (existsState(id + ".GET")) {
                                      val = getState(id + ".GET").val;
                                      RegisterDetailEntityWatcher(id + ".GET", pageItem, type);
                                  else if (existsState(id + ".SET")) {
                                      val = getState(id + ".SET").val;
                                      RegisterDetailEntityWatcher(id + ".SET", pageItem, type);
                                  if (val) {
                                      switchVal = "1";
                                      iconColor = GetIconColor(pageItem, true, false);
                                  out_msgs.push({ payload: "entityUpdateDetail~" + icon + "~" + + iconColor + "~" + switchVal + ",disable,disable,disable" })
                              if (o.common.role == "dimmer") {
                                  if (existsState(id + ".ON_ACTUAL")) {
                                      val = getState(id + ".ON_ACTUAL").val;
                                      RegisterDetailEntityWatcher(id + ".ON_ACTUAL", pageItem, type);
                                  else if (existsState(id + ".ON_SET")) {
                                      val = getState(id + ".ON_SET").val;
                                      RegisterDetailEntityWatcher(id + ".ON_SET", pageItem, type);
                                  if (val === true) {
                                      var iconColor = GetIconColor(pageItem, val, false);
                                      switchVal = "1"
                                  if (existsState(id + ".ACTUAL")) {
                                          brightness = Math.trunc(scale(getState(id + ".ACTUAL").val, pageItem.minValueBrightness, pageItem.maxValueBrightness, 100, 0));
                                      } else {
                                          brightness = getState(id + ".ACTUAL").val;
                                  } else {
                                      console.warn("Alisas-Datenpunkt: " + id + ".ACTUAL could not be read");
                                  if (val === true) {
                                      iconColor = GetIconColor(pageItem, 100 - brightness, true);
                                      switchVal = "1";
                                  } else {
                                      iconColor = GetIconColor(pageItem, false, true);
                                  RegisterDetailEntityWatcher(id + ".ACTUAL", pageItem, type);
                                  let colorTemp = "disable"
                                  let colorMode = "disable"
                                  out_msgs.push({ payload: "entityUpdateDetail~" + icon + "~" + iconColor + "~" + switchVal + "~" + brightness + "~" + colorTemp + "~" + colorMode })
                              //HUE-Licht
                              if (o.common.role == "hue") {
                                  if (existsState(id + ".DIMMER")) {
                                          brightness = Math.trunc(scale(getState(id + ".DIMMER").val, pageItem.minValueBrightness, pageItem.maxValueBrightness, 100, 0));
                                      } else {
                                          brightness = getState(id + ".DIMMER").val;
                                      RegisterDetailEntityWatcher(id + ".DIMMER", pageItem, type);
                                  } else {
                                      console.warn("Alias-Datenpunkt: " + id + ".DIMMER could not be read");
                                  if (val === true) {
                                      switchVal = "1";
                                  } else {
                                  var colorMode = "disable"
                                  if (existsState(id + ".HUE")) {
                                      if (getState(id + ".HUE").val != null) {
                                          colorMode = "enable";
                                          let huecolor = hsv2rgb(getState(id + ".HUE").val,1,1);
                                  var colorTemp = 0;
                                  if (existsState(id + ".TEMPERATURE")) {
                                      if (getState(id + ".TEMPERATURE").val != null) {
                                              colorTemp = Math.trunc(scale(getState(id + ".TEMPERATURE").val, pageItem.minValueColorTemp, pageItem.maxValueColorTemp, 0, 100));
                                          } else {
                                              colorTemp = 100 - getState(id + ".TEMPERATURE").val;
                                          //RegisterDetailEntityWatcher(id + ".TEMPERATURE", pageItem, type);
                                  } else {
                                      console.warn("Alias-Datenpunkt: " + id + ".TEMPERATURE could not be read");
                              //RGB-Licht
                              if (o.common.role == "rgb") {
                                      } else {
                                  } else {
                                  if (val === true) {
                                      switchVal = "1";
                                  } else {
                                  if (existsState(id + ".RED") && existsState(id + ".GREEN") && existsState(id + ".BLUE")) {
                                      if (getState(id + ".RED").val != null && getState(id + ".GREEN").val != null && getState(id + ".BLUE").val != null) {
                                          let rgb = <RGB>{ red: Math.round(getState(id + ".RED").val), green: Math.round(getState(id + ".GREEN").val), blue: Math.round(getState(id + ".BLUE").val)}
                                  var colorTemp = 0;
                                          } else {
                                  } else {
                          if (type == "popupShutter") {
                                  val = getState(id + ".ACTUAL").val;
                              } else if (existsState(id + ".SET")) {
                              out_msgs.push({ payload: "entityUpdateDetail~" + val })
                      return out_msgs
                  function scale(number: number, inMin: number, inMax: number, outMin: number, outMax: number): number {
                      return (outMax+outMin)-((number - inMin) * (outMax - outMin) / (inMax - inMin) + outMin);
                  function UnsubscribeWatcher(): void {
                      for (const [key, value] of Object.entries(subscriptions)) {
                          unsubscribe(value);
                          delete subscriptions[key]
                  function HandleScreensaver(): void {
                      SendToPanel({ payload: "pageType~screensaver"})
                  function HandleScreensaverUpdate(): void {
                      if (screensaverEnabled && config.weatherEntity != null && existsObject(config.weatherEntity)) {
                          var icon = getState(config.weatherEntity + ".ICON").val;
                          let temperature: string =
                              existsState(config.weatherEntity + ".ACTUAL") ? getState(config.weatherEntity + ".ACTUAL").val :
                                  existsState(config.weatherEntity + ".TEMP") ? getState(config.weatherEntity + ".TEMP").val : "null";
                          let payloadString =
                              "weatherUpdate~" + Icons.GetIcon(GetAccuWeatherIcon(parseInt(icon))) + "~"
                              + temperature + " " + config.temperatureUnit + "~"
                          if (weatherForecast == true) {
                              // Accu-Weather Forecast Tag 2 - Tag 5 -- Wenn weatherForecast = true
                              for (let i = 2; i < 6; i++) {
                                  let TempMax = getState("accuweather.0.Summary.TempMax_d" + i).val;
                                  let DayOfWeek = getState("accuweather.0.Summary.DayOfWeek_d" + i).val;
                                  let WeatherIcon = GetAccuWeatherIcon(getState("accuweather.0.Summary.WeatherIcon_d" + i).val);
                                  payloadString += DayOfWeek + "~" + Icons.GetIcon(WeatherIcon) + "~" + TempMax + " °C~";
                          else {
                              //In Config definierte Zustände wenn weatherForecast = false
                              payloadString += GetScreenSaverEntityString(config.firstScreensaverEntity);
                              payloadString += GetScreenSaverEntityString(config.secondScreensaverEntity);
                              payloadString += GetScreenSaverEntityString(config.thirdScreensaverEntity);
                              payloadString += GetScreenSaverEntityString(config.fourthScreensaverEntity);
                          SendToPanel(<Payload>{ payload: payloadString });
                  function GetScreenSaverEntityString(configElement: ScreenSaverElement | null): string {
                      if (configElement != null && configElement.ScreensaverEntity != null && existsState(configElement.ScreensaverEntity)) {
                          let u1 = getState(configElement.ScreensaverEntity).val;
                          return configElement.ScreensaverEntityText + "~" + Icons.GetIcon(configElement.ScreensaverEntityIcon) + "~" + u1 + " " + configElement.ScreensaverEntityUnitText + "~";
                      else {
                          return "~~~";
                  function GetAccuWeatherIcon(icon: number): string {
                      switch (icon) {
                          case 24:        // Ice
                          case 30:        // Hot
                          case 31:        // Cold
                              return "window-open";  // exceptional
                          case 7:         // Cloudy
                          case 8:         // Dreary (Overcast)
                          case 38:        // Mostly Cloudy
                              return "weather-cloudy";  // cloudy
                          case 11:        // fog
                              return "weather-fog";  // fog
                          case 25:        // Sleet
                              return "weather-hail";  // Hail
                          case 15:        // T-Storms
                              return "weather-lightning";  // lightning
                          case 16:        // Mostly Cloudy w/ T-Storms
                          case 17:        // Partly Sunny w/ T-Storms
                          case 41:        // Partly Cloudy w/ T-Storms
                          case 42:        // Mostly Cloudy w/ T-Storms
                              return "weather-lightning-rainy";  // lightning-rainy
                          case 33:        // Clear
                          case 34:        // Mostly Clear
                          case 37:        // Hazy Moonlight
                              return "weather-night";
                          case 3:         // Partly Sunny
                          case 4:         // Intermittent Clouds
                          case 6:         // Mostly Cloudy
                          case 35: 	    // Partly Cloudy
                          case 36: 	    // Intermittent Clouds
                              return "weather-partly-cloudy";  // partlycloudy
                          case 18:        // pouring
                              return "weather-pouring";  // pouring
                          case 12:        // Showers
                          case 13:        // Mostly Cloudy w/ Showers
                          case 14:        // Partly Sunny w/ Showers
                          case 26:        // Freezing Rain
                          case 39:        // Partly Cloudy w/ Showers
                          case 40:        // Mostly Cloudy w/ Showers
                              return "weather-rainy";  // rainy
                          case 19:        // Flurries
                          case 20:        // Mostly Cloudy w/ Flurries
                          case 21:        // Partly Sunny w/ Flurries
                          case 22:        // Snow
                          case 23:        // Mostly Cloudy w/ Snow
                          case 43:        // Mostly Cloudy w/ Flurries
                          case 44:        // Mostly Cloudy w/ Snow
                              return "weather-snowy";  // snowy
                          case 29:        // Rain and Snow
                              return "weather-snowy-rainy";  // snowy-rainy
                          case 1:         // Sunny
                          case 2: 	    // Mostly Sunny
                          case 5:         // Hazy Sunshine
                              return "weather-sunny";  // sunny
                          case 32:        // windy
                              return "weather-windy";  // windy
                          default:
                              return "alert-circle-outline";
                  function GetBlendedColor(percentage: number): RGB {
                      if (percentage < 50)
                          return Interpolate(config.defaultOffColor, config.defaultOnColor, percentage / 50.0);
                      return Interpolate(Red, White, (percentage - 50) / 50.0);
                  function Interpolate(color1: RGB, color2: RGB, fraction: number): RGB {
                      var r: number = InterpolateNum(color1.red, color2.red, fraction);
                      var g: number = InterpolateNum(color1.green, color2.green, fraction);
                      var b: number = InterpolateNum(color1.blue, color2.blue, fraction);
                      return <RGB>{ red: Math.round(r), green: Math.round(g), blue: Math.round(b) };
                  function InterpolateNum(d1: number, d2: number, fraction: number): number {
                      return d1 + (d2 - d1) * fraction;
                  function rgb_dec565(rgb: RGB): number {
                      return ((Math.floor(rgb.red / 255 * 31) << 11) | (Math.floor(rgb.green / 255 * 63) << 5) | (Math.floor(rgb.blue / 255 * 31)));
                  /* Convert radians to degrees
                  rad - radians to convert, expects rad in range +/- PI per Math.atan2
                  returns {number} degrees equivalent of rad
                  function rad2deg(rad) {
                    return (360 + 180 * rad / Math.PI) % 360;
                  /* Convert h,s,v values to r,g,b
                  hue - in range [0, 360]
                  saturation - in range 0 to 1
                  value - in range 0 to 1
                  returns {Array|number} [r, g,b] in range 0 to 255
                  function hsv2rgb(hue: number, saturation: number, value: number) {
                    hue /= 60;
                    let chroma = value * saturation;
                    let x = chroma * (1 - Math.abs((hue % 2) - 1));
                    let rgb = hue <= 1? [chroma, x, 0]:
                              hue <= 2? [x, chroma, 0]:
                              hue <= 3? [0, chroma, x]:
                              hue <= 4? [0, x, chroma]:
                              hue <= 5? [x, 0, chroma]:
                                        [chroma, 0, x];
                    return rgb.map(v => (v + value - chroma) * 255);
                  function getHue(red: number, green: number, blue:number) {
                      var min = Math.min(Math.min(red, green), blue);
                      var max = Math.max(Math.max(red, green), blue);
                      if (min == max) {
                          return 0;
                      var hue = 0;
                      if (max == red) {
                          hue = (green - blue) / (max - min);
                      } else if (max == green) {
                          hue = 2 + (blue - red) / (max - min);
                      } else {
                          hue = 4 + (red - green) / (max - min);
                      hue = hue * 60;
                      if (hue < 0) hue = hue + 360;
                      return Math.round(hue);
                  function pos_to_color(x: number, y: number): RGB {
                      var r = 160/2;
                      var x = Math.round((x - r) / r * 100) / 100;
                      var y = Math.round((r - y) / r * 100) / 100;
                      r = Math.sqrt(x*x + y*y);
                      let sat = 0
                      if (r > 1) {
                          sat = 0;
                      } else {
                          sat = r;
                      var hsv = rad2deg(Math.atan2(y, x));
                      var rgb = hsv2rgb(hsv,sat,1);
                      return <RGB>{ red: Math.round(rgb[0]), green: Math.round(rgb[1]), blue: Math.round(rgb[2]) };
                  type RGB = {
                      red: number,
                      green: number,
                      blue: number
                  type Payload = {
                      payload: string;
                  type Page = {
                      type: string,
                      heading: string,
                      items: PageItem[],
                      useColor: boolean
                  interface PageEntities extends Page {
                      type: "cardEntities",
                      items: PageItem[],
                  interface PageGrid extends Page {
                      type: "cardGrid",
                      items: PageItem[],
                  interface PageThermo extends Page {
                      type: "cardThermo",
                      items: PageItem[],
                  interface PageMedia extends Page {
                      type: "cardMedia",
                      items: PageItem[],
                  interface PageAlarm extends Page {
                      type: "cardAlarm",
                      items: PageItem[],
                  type PageItem = {
                      icon: (string | undefined),
                      onColor: (RGB | undefined),
                      offColor: (RGB | undefined),
                      useColor: (boolean | undefined),
                      interpolateColor: (boolean | undefined),
                      minValueBrightness: (number | undefined),
                      maxValueBrightness: (number | undefined),
                      minValueColorTemp: (number | undefined),
                      maxValueColorTemp: (number | undefined),
                      minValue: (number | undefined),
                      maxValue: (number | undefined),
                      name: (string | undefined),
                      unit: (string | undefined)
                  type Config = {
                      panelRecvTopic: string,
                      panelSendTopic: string,
                      timeoutScreensaver: number,
                      dimmode: number,
                      //brightnessScreensaver:
                      locale: string,
                      timeFormat: string,
                      dateFormat: string,
                      weatherEntity: string | null,
                      screenSaverDoubleClick: boolean,
                      temperatureUnit: string,
                      firstScreensaverEntity: ScreenSaverElement | null,
                      secondScreensaverEntity: ScreenSaverElement | null,
                      thirdScreensaverEntity: ScreenSaverElement | null,
                      fourthScreensaverEntity: ScreenSaverElement | null,
                      defaultColor: RGB,
                      defaultOnColor: RGB,
                      defaultOffColor: RGB,
                      pages: (PageThermo | PageMedia | PageAlarm | PageEntities | PageGrid)[],
                      button1Page: (PageThermo | PageMedia | PageAlarm | PageEntities | PageGrid | null),
                      button2Page: (PageThermo | PageMedia | PageAlarm | PageEntities | PageGrid | null),
                  type ScreenSaverElement = {
                      ScreensaverEntity: string | null,
                      ScreensaverEntityIcon: string | null,
                      ScreensaverEntityText: string | null,
                      ScreensaverEntityUnitText: string | null,
                  P.S.: Der Alias-Typ "RGB-Licht" sollte jetzt auch gehen...
                    @armilar
                    Kann es sein das Du den case "hue" vergessen hast?
                    minValueBrightness und maxValueBrightness funktionieren beim Dimmer super aber beim Hue
                    haben sie keine Funktion.
                    kann das vielleicht daran liegen?
                    • Armilar
                      @dexxter sagte in Sonoff NSPanel:
                      @armilar
                      Ist wohl so 👍
                      Habe den RBG-Licht-einzeln (HEX) gleich mit eingebaut
                      //Alexa-Instanz
                      var alexaDevice = "G0XXXXXXXXXXXXXXXX"; //Primär zu steuendes Device
                          "heading": "Büro",
                          "useColor": true,
                          "items": [
                              <PageItem>{ id: "alias.0.NSPanel_1.TestRGBLichteinzeln", name: "RGB-Licht Hex-Color", interpolateColor: true},
                          "heading": "Büro",
                          "useColor": true,
                          "items": [
                          "useColor": true,
                          "items": [
                          "useColor": true,
                          "items": [
                          "type": "cardGrid",
                          "useColor": true,
                          "items": [
                          "heading": "Alexa",
                          "useColor": true,
                          "useColor": true,
                          "heading": "Alarm",
                          "useColor": true,
                          "type": "cardGrid",
                          "heading": "Radio",
                          "useColor": true,
                          "items": [
                          "heading": "Büro",
                          "useColor": true,
                          "items": [
                          dimmode: 8,
                          locale: "de_DE",
                          defaultOnColor: On,
                          defaultColor: Off,
                          pages: [
                                  Buero_Seite_1,
                                  Test_Licht,
                                  Fenster_1,
                                  Abfall,
                                  Buero_Seite_2,
                                  Alexa,
                                  Buero_Themostat,
                                  Buero_Alarm
                      var pageId = 0;
                          SendTime();
                          SendDate();
                          else
                              switch (method) {
                                  case "startup":
                                      pageId = 0;
                                      break;
                                      if (pageId < 0)
                                          pageId = 0;
                                      break;
                                      break;
                                  case "button1":
                                  case "button2":
                                  default:
                                      break;
                                  break;
                              case "cardThermo":
                                  break;
                              case "cardGrid":
                                  break;
                              case "cardMedia":
                                  break;
                              case "cardAlarm":
                                  break;
                              pageId = -1;
                              pageId = -2;
                          else {
                              return;
                          GeneratePage(page);
                          SendDate();
                          SendTime();
                          var d = new Date();
                          var d = new Date();
                          return out_msgs
                          return out_msgs
                          let maxItems = 0;
                              case "cardThermo":
                                  maxItems = 1;
                                  break;
                              case "cardAlarm":
                                  maxItems = 1;
                                  break;
                              case "cardMedia":
                                  maxItems = 1;
                                  break;
                                  maxItems = 4;
                                  break;
                              case "cardGrid":
                                  maxItems = 6;
                                  break;
                              else {
                          return pageData;
                          var iconId = "0"
                          var name: string;
                          var type: string;
                          // ioBroker
                              var val = null;
                                  case "socket":
                                  case "light":
                                      type = "light"
                                      var optVal = "0"
                                          optVal = "1"
                                      } else {
                                  case "hue":
                                      type = "light"
                                      var optVal = "0"
                                          optVal = "1"
                                  case "rgb":
                                      type = "light"
                                      var optVal = "0"
                                          optVal = "1"
                                  case "rgbSingle":
                                      type = "light"
                                      var optVal = "0"
                                          optVal = "1"
                                      if (existsState(pageItem.id + ".RGB")) {
                                          if (getState(pageItem.id + ".RGB").val != null) {
                                              var hex = getState(pageItem.id + ".RGB").val;
                                              var hexRed = parseInt(hex[1]+hex[2],16);
                                              var hexGreen = parseInt(hex[3]+hex[4],16);
                                              var hexBlue = parseInt(hex[5]+hex[6],16);
                                              let rgb = <RGB>{ red: Math.round(hexRed), green: Math.round(hexGreen), blue: Math.round(hexBlue)}
                                  case "dimmer":
                                      type = "light"
                                      var optVal = "0"
                                          optVal = "1"
                                  case "blind":
                                      type = "shutter"
                                  case "door":
                                  case "window":
                                      type = "text";
                                          } else {
                                  case "info":
                                  case "humidity":
                                  case "sensor.door":
                                  case "thermostat":
                                      type = "text";
                                      let unit = "";
                                      var optVal = "0"
                                  case "button":
                                      type = "button";
                                  case "warning":
                                      type = "text";
                                  default:
                          // dimmer
                              return rgb_dec565(
                                  Interpolate(
                              return;
                              if(pageId >= 0)
                              return;
                              return "";
                          return "";
                          // ioBroker
                              let destTemp = 0;
                              let status = ""
                              let stepTemp = 5
                                  } else {
                                  } else {
                                  } else {
                          return out_msgs
                              } else {
                              //console.log(id);
                              } else {
                                      let deviceId = i;
                                                        name + "~" +
                                                        id + "~" +
                                                        id + "~" +         //????
                                                        media_icon + "~" +
                                                        title + "~" +
                                                        author + "~" +
                                                        volume + "~" +
                                                        speakerlist + "~" +
                                                        onoffbutton});
                          return out_msgs
                          if (armed) {
                          else {
                          return out_msgs
                                  return true;
                          else {
                                  return true;
                          return false;
                              return true;
                          return false;
                          let id = words[2]
                              case "bNext":
                                  break;
                              case "bPrev":
                                  break;
                              case "bExit":
                                      if (words[4] == 2)
                                  else
                                  break;
                              case "OnOff":
                                      var action = false
                                          action = true
                                          case "light":
                                              break;
                                          case "dimmer":
                                              break;
                                          case "rgb":
                                          case "rgbSingle":
                                  break;
                              case "up":
                                  break;
                              case "stop":
                                  break;
                              case "down":
                                  break;
                              case "button":
                                  break;
                                  break;
                                          case "dimmer":
                                              } else {
                                              break;
                                          case "rgb":
                                          case "rgbSingle":
                                          case "hue":
                                                  setIfExists(id + ".DIMMER", sliderPos);
                                              } else {
                                                  setIfExists(id + ".DIMMER", parseInt(words[4])) ? true : setIfExists(id + ".ACTUAL", parseInt(words[4]));
                                              break;
                                  break;
                                  } else {
                                  break;
                              case "colorWheel":
                                  //console.log(rgb);
                                      case "hue":
                                          break;
                                      case "rgb":
                                          break;
                                      case "rgbSingle":
                                          setIfExists(id + ".RGB", ConvertRGBtoHex(rgb.red, rgb.green, rgb.blue));
                                  break;
                              case "tempUpd":
                                  break;
                              case "media-back":
                                  break;
                              case "media-pause":
                                  } else {
                                  break;
                              case "media-next":
                                  break;
                                  break;
                              case "speaker-sel":
                                          let deviceId = i;
                                  break;
                              case "media-OnOff":
                                  break;
                                  break;
                                  break;
                                  break;
                                  break;
                                  break;
                              default:
                                  break;
                          switch (pageId) {
                              case 0:
                                  return "0|1";
                                  return "1|0";
                              case -1:
                                  return "0|0";
                              default:
                                  return "1|1";
                                  let switchVal = "0"
                                  let brightness = 0;
                                      if (val) {
                                          switchVal = "1";
                                      if (val === true) {
                                          switchVal = "1"
                                          } else {
                                      } else {
                                      if (val === true) {
                                          switchVal = "1";
                                      } else {
                                  //HUE-Licht
                                          } else {
                                      } else {
                                      if (val === true) {
                                          switchVal = "1";
                                      } else {
                                      var colorTemp = 0;
                                              } else {
                                      } else {
                                  //RGB-Licht
                                          } else {
                                      } else {
                                      if (val === true) {
                                          switchVal = "1";
                                      } else {
                                      var colorTemp = 0;
                                              } else {
                                      } else {
                                  //RGB-Licht-einzeln (HEX)
                                  if (o.common.role == "rgbSingle") {
                                          } else {
                                      } else {
                                      if (val === true) {
                                          switchVal = "1";
                                      } else {
                                      if (existsState(id + ".RGB")) {
                                          if (getState(id + ".RGB").val != null) {
                                              var hex = getState(id + ".RGB").val;
                                      var colorTemp = 0;
                                              } else {
                                      } else {
                          return out_msgs
                              unsubscribe(value);
                              let payloadString =
                              else {
                          else {
                              return "~~~";
                          switch (icon) {
                              case 24:        // Ice
                              case 30:        // Hot
                              case 31:        // Cold
                              case 7:         // Cloudy
                              case 11:        // fog
                              case 25:        // Sleet
                              case 33:        // Clear
                              case 18:        // pouring
                              case 12:        // Showers
                              case 22:        // Snow
                              case 1:         // Sunny
                              case 32:        // windy
                              default:
                      function ColorToHex(color) {
                        var hexadecimal = color.toString(16);
                        return hexadecimal.length == 1 ? "0" + hexadecimal : hexadecimal;
                      function ConvertRGBtoHex(red: number, green: number, blue: Number) {
                        return "#" + ColorToHex(red) + ColorToHex(green) + ColorToHex(blue);
                        hue /= 60;
                                            [chroma, 0, x];
                          if (min == max) {
                              return 0;
                          var hue = 0;
                          if (max == red) {
                          } else {
                          hue = hue * 60;
                          var r = 160/2;
                          let sat = 0
                          if (r > 1) {
                              sat = 0;
                          } else {
                              sat = r;
                      type RGB = {
                          red: number,
                          green: number,
                          blue: number
                      type Payload = {
                          payload: string;
                      type Page = {
                          type: string,
                          heading: string,
                          items: PageItem[],
                          useColor: boolean
                          items: PageItem[],
                          type: "cardGrid",
                          items: PageItem[],
                          type: "cardThermo",
                          items: PageItem[],
                          type: "cardMedia",
                          items: PageItem[],
                          type: "cardAlarm",
                          items: PageItem[],
                      type PageItem = {
                      type Config = {
                          dimmode: number,
                          locale: string,
                          timeFormat: string,
                          dateFormat: string,
                          defaultColor: RGB,
                        Dexxter @Armilar last edited by Dexxter
                        @armilar
                        Perfekt, so läuft es bei mir super 👍 😊
                        Vielen Dank bis hier hin, ich hoffe ich bin Dir nicht zu sehr auf die Nerven gegangen.
                        Code lesen und verstehen wird bei mir langsam besser aber vom schreiben bin ich noch meilenweit entfernt😏
                        Jetzt spinnt zwar mein Controller etwas rum aber das hat mit dem Code nix zu tun.
                        Ist es eigentlich möglich mit dem Alexa case auch etwas anderes zu steuern?
                        Ich bin nämlich in der Teufel Raumfeld ecke unterwegs.
                        EDIT: Hat schon jemand das Panel einbauen wollen? Ich hab meins gestern eingebaut und das passt ja mal so gar nicht in eine normale UP Dose!
                        Ich musste echt ein paar Stücke der Dose raus schneiden bevor ich das Ding rein bekommen hab 😕
                        Armilar 2 Replies Last reply Reply Quote 0
                        • Armilar
                          Armilar Most Active Forum Testing last edited by
                          Nee, ganz im Gegenteil - perfekter Tester - ich wünschte, es gäbe mehr wie dich 👍 . Genau die bringen die Ideen und runden das Produkt ab. Mit echten Use-Cases macht es ohnehin mehr Spaß.
                          Gibt es dazu einen Adapter? Was hat der für Datenpunkte? Die Readme ist ja sehr bescheiden.
                          Was gibt es noch für Möglichkeiten für den Mediaplayer?:
                          • Ich hatte kurz vor dem Wechsel auf Alexa den Spotify-Premium-Adapter drin. Funktionierte ebenso gut (Sourcen weiter am Anfang). Hab mich dann dazu entschieden, den Alexa2-Adapter anzugraben, da der doch etwas flexibler ist. Das was der Spotify-Premium steuert, sieht der Alexa2-Adapter auch (und weitere wie TuneIn, Amazon-Music- und Spotify-Playlists, etc.).
                          • Ich denke, das sich der Media-Alias ebenso mit Google steuern lässt - ich kann es nur nicht testen
                          • Ebenso sollte der Media-Alias mit Kodi oder evtl. mit Raumfeld (siehe Datenpunkte) oder andern Marken laufen.
                          • Folgende Datenpunkte (On/Off; Play; Stop; Previous; Next; Artist; Track; Playlist) können über den Media-Alias übergeben werden
                          • Die Speaker-List kann auch deaktiviert werden
                          • Armilar
                            Nee, ist noch ein Testobjekt, wobei ich wohl auch noch eins bestellen werde. Das kann dann schon aktiv rennen. Mal sehen, was da mit der Dose auf uns zukommt. China ist halt nicht in Europa 😊
                            • Great SUN
                              @armilar @Dexxter
                              Die ganzen Schalter und Co. von Sonoff/ITEAD sind für mich super schön, aber sie sind grundsätzlich alle größer als die Norm bei uns.
                              Normal passen sie in die Dosen in der Wand (evtl. nicht bei den kleinen orangenen... Aber ich hab grundsätzlich Probleme damit bestehende zu ersetzen:
                              Aus drei Dosen werden 2,5 ?!? Was soll man da noch machen?
                              Ich mach das normal immer so, dass ich da dann einen RF-Schalter drüber klebe, dann habe ich kein Loch und muss nix an den Dosen ändern... Obwohl die Verbindung, wenn es einzelne Dosen in der Wand sind, die muss man dann zerstören...
                              Oder wie seht Ihr das?
                              D Armilar 2 Replies Last reply Reply Quote 0
                                Dexxter @Great SUN last edited by
                                @great-sun
                                Also ich hab solche schwarzen mit so`nem verbindungskamin damit man 2 zusammen stecken kann und da passt das Panel definitiv nicht.
                                Ich hab dann mit nem Cuttermesser unten 2 Steifen raus geschnitten und den Gips etwas entfernt damit die Ecken von dem Panel in die Dose passen.
                                Nicht schön aber funktioniert.
                                  @armilar said in Sonoff NSPanel:
                                  Einen Adapter gibt es nicht aber Nodes für Node-Red.
                                  Mit denen arbeite ich.
                                  Grundsätzlich kann ich also mit jedem vorhandenen Alias auskommen und den für mich umbiegen.
                                  Müsste nur wissen welche Aliase alles benutzt werden, dann kann ich das testen.
                                  • Armilar
                                    @dexxter
                                    Da sind doch schon ein paar brauchbare dabei, die zu gebrauchen wären. Stimmt Volume habe ich vergessen. Versuch mal einen Media-Alias mit dem Alias-Manager anzulegen. Ich habe den direkt auf dem Playerverzeichnis automatisch erstellt. Hatte auch vor ein paar Posts dazu geschrieben. Der ließ sich, wenn man mindestens eine Alexa hat, recht schnell anlegen. Ansonsten musst du dir eine bauen und die restlichen Datenpunkte dazu adden.
                                    • Armilar
                                      @armilar @Dexxter
                                      Ich weiß noch nicht wo das Ding reinkommt - denke etwas höher, da meine Lichtschalter alle etwas tiefer verbaut sind und ich die eh nicht zum Licht anschalten per Hardwarebuttons nutzen möchte. Außerdem finde ich es besser, wenn man das Display ordentlich sehen kann (Etwas unter Kopf - Augenhöhe. Habe eben noch ein Video gesehen, wo es einer problemlos in eine orange-farbende Dose bekommen hat. Probiere es mal aus und werde dann eine zusätzliche Leitung/Dose im Rahmen anstehender Renovierungsarbeiten ziehen.
                                      • Armilar
                                        Das sind die Datenpunkte in meinem Media-Alias (wurden so automatisch angelegt)
                                        Einige werde aber gar nicht benötigt (Cover, Duration, Elapsed, Repeat, Shuffle). Der Rest kann in der cardMedia verwendet werden.
                                        • Great SUN
                                          @armilar Ich hab so welche sowieso nicht hier... alles schwarz 😄
                                          • Great SUN
                                            @armilar (oder auch gern andere)
                                            ALLE files? Also auch hidden?
                                            Ich hab da die folgenden:
                                            • _persist.json
                                            • .settings
                                            • .settings.lkg
                                            • autoexec.be[c]*
                                            • nspanel.be[c]*
                                            • nxpanel.be[c]*
                                            Ja, ich weiß... was hab ich nur getan? Nachdem der kram bricked war hab ich alles versucht 😄
                                            Danke für Eure Unterstützung!
                                            1548
                                            631392
