    3. Off Topic
    4. Grafana
    5. Grafana Update Probleme
    • RoddiEF
      RoddiEF @Thomas Braun last edited by
      @thomas-braun sagte in Grafana Update Probleme:
      @roddief
      64bit oder 32bit System?
      Läuft auf nem 32-Bit System...
        Thomas Braun Most Active @RoddiEF last edited by
        @roddief
        Hier melden sich auch user mit dem Phänomen:
        https://github.com/grafana/grafana/issues/48130
        Diapolo created this issue in grafana/grafana
        closed grafana-server doesn't start after recent update to 8.5.0 on openhabian #48130
        • Damrak2022
          Damrak2022 @crunchip last edited by
          @crunchip sagte in Grafana Update Probleme:
          systemctl status grafana-server
          Nachdem ich die Befehle eingegeben habe ist dies das Ergebnis
          pi@homebridge:~ $ systemctl enable grafana-server
          Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
          Executing: /lib/systemd/systemd-sysv-install enable grafana-server
          ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
          Authentication is required to reload the systemd state.
          Authenticating as: ,,, (pi)
          Password:
          ==== AUTHENTICATION COMPLETE ===
          Password:
          ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
          Authentication is required to manage system service or unit files.
          Password:
          Password:
          pi@homebridge:~ $ systemctl start grafana-server
          ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
          Authentication is required to start 'grafana-server.service'.
          Password:
          pi@homebridge:~ $ systemctl status grafana-server
          ● grafana-server.service - Grafana instance
               Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
               Active: failed (Result: exit-code) since Tue 2022-04-26 02:28:48 BST; 15s >
                 Docs: http://docs.grafana.org
              Process: 22671 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --p>
             Main PID: 22671 (code=exited, status=1/FAILURE)
                  CPU: 360ms
          Apr 26 02:28:48 homebridge systemd[1]: grafana-server.service: Scheduled restar>
          Apr 26 02:28:48 homebridge systemd[1]: Stopped Grafana instance.
          Apr 26 02:28:48 homebridge systemd[1]: grafana-server.service: Start request re>
          Apr 26 02:28:48 homebridge systemd[1]: grafana-server.service: Failed with resu>
          Apr 26 02:28:48 homebridge systemd[1]: Failed to start Grafana instance.
          lines 1-13/13 (END)
            crunchip Forum Testing Most Active @Damrak2022 last edited by
            @damrak2022 sorry hatte sudo vergessen, bzw probier es so
            sudo /bin/systemctl enable grafana-server
            sudo /bin/systemctl start grafana-server
            sudo /bin/systemctl status grafana-server
            • Damrak2022
              Damrak2022 @crunchip last edited by Damrak2022
              Das ist das Ergebnis:
              pi@homebridge:~ $ sudo /bin/systemctl enable grafana-server
              pi@homebridge:~ $ sudo /bin/systemctl start grafana-server
              pi@homebridge:~ $ sudo /bin/systemctl status grafana-server
                   Active: failed (Result: exit-code) since Tue 2022-04-26 04:26:20 BST; 15s >
                  Process: 7077 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pi>
                 Main PID: 7077 (code=exited, status=1/FAILURE)
                      CPU: 330ms
              Apr 26 04:26:20 homebridge systemd[1]: grafana-server.service: Scheduled restar>
              Apr 26 04:26:20 homebridge systemd[1]: Stopped Grafana instance.
              Apr 26 04:26:20 homebridge systemd[1]: grafana-server.service: Start request re>
              Apr 26 04:26:20 homebridge systemd[1]: grafana-server.service: Failed with resu>
              Apr 26 04:26:20 homebridge systemd[1]: Failed to start Grafana instance.
              lines 1-13/13 (END)
              Hier lässt Erich garnicht rein, auch nicht mit sudo
              pi@homebridge:~ $ /usr/lib/systemd/system/grafana-server.service
              -bash: /usr/lib/systemd/system/grafana-server.service: Permission denied
                @damrak2022 ich muss mir das in Ruhe heute Nachmittag am Pc ansehen. So früh am Morgen mit dem Handy etwas schwierig.
                • Damrak2022
                  @crunchip Hast Du noch irgendeine Idee, denn ich kann Grafana weiterhin nicht aufrufen
                  crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                    @damrak2022 ich bin am gucken
                    • Damrak2022
                      @crunchip Ich danke Dir. Wenn ich da wieder drauf komme lasse ich erstmal die Finger vom Terminal was Grafana betrifft.
                        Thomas Braun Most Active @Damrak2022 last edited by
                        @damrak2022
                        Ist denn jetzt grafana 8.4.7 die alleinig installierte Version oder spukt da noch was anderes herum?
                        • Damrak2022
                          Damrak2022 @Thomas Braun last edited by Damrak2022
                          @thomas-braun Nur 8.4.7, aber ich kann nochmal schauen
                          pi@homebridge:~ $ apt policy grafana
                          grafana:
                            Installed: 8.4.7
                            Candidate: 8.5.0
                            Version table:
                               8.5.0 500
                                  500 https://packages.grafana.com/oss/deb stable/main armhf Packages
                           *** 8.4.7 500
                                  100 /var/lib/dpkg/status
                               8.4.6 500
                               8.4.5 500
                               8.4.4 500
                               8.4.3 500
                               8.4.2 500
                               8.4.1 500
                               8.4.0 500
                               8.3.7 500
                               8.3.6 500
                               8.3.5 500
                               8.3.4 500
                               8.3.3 500
                               8.3.2 500
                               8.3.1 500
                               8.3.0 500
                               8.2.7 500
                               8.2.6 500
                               8.2.5 500
                               8.2.4 500
                               8.2.3 500
                               8.2.2 500
                               8.2.1 500
                               8.2.0 500
                               8.1.8 500
                               8.1.7 500
                               8.1.6 500
                               8.1.5 500
                               8.1.4 500
                               8.1.3 500
                               8.1.2 500
                               8.1.1 500
                               8.1.0 500
                               8.0.7 500
                               8.0.6 500
                               8.0.5 500
                               8.0.4 500
                               8.0.3 500
                               8.0.2 500
                               8.0.1 500
                               8.0.0 500
                               7.5.15 500
                               7.5.13 500
                               7.5.12 500
                               7.5.11 500
                               7.5.10 500
                               7.5.9 500
                               7.5.8 500
                               7.5.7 500
                               7.5.6 500
                               7.5.5 500
                               7.5.4 500
                               7.5.3 500
                               7.5.2 500
                               7.5.1 500
                               7.5.0 500
                               7.4.5 500
                               7.4.3 500
                               7.4.2 500
                               7.4.1 500
                               7.4.0 500
                               7.3.10 500
                               7.3.7 500
                               7.3.6 500
                               7.3.5 500
                               7.3.4 500
                               7.3.3 500
                               7.3.2 500
                               7.3.1 500
                               7.3.0 500
                               7.2.2 500
                               7.2.1 500
                               7.2.0 500
                               7.1.5 500
                               7.1.4 500
                               7.1.3 500
                               7.1.2 500
                               7.1.1 500
                               7.1.0 500
                               7.0.6 500
                               7.0.5 500
                               7.0.4 500
                               7.0.3 500
                               7.0.2 500
                               7.0.1 500
                               7.0.0 500
                               6.7.6 500
                               6.7.5 500
                               6.7.4 500
                               6.7.3 500
                               6.7.2 500
                               6.7.1 500
                               6.7.0 500
                               6.6.2 500
                               6.6.1 500
                               6.6.0 500
                               6.5.3 500
                               6.5.2 500
                               6.5.1 500
                               6.5.0 500
                               6.4.5 500
                               6.4.4 500
                               6.4.3 500
                               6.4.2 500
                               6.4.1 500
                               6.4.0 500
                               6.3.7 500
                               6.3.6 500
                               6.3.5 500
                               6.3.4 500
                               6.3.3 500
                               6.3.2 500
                               6.3.1 500
                               6.3.0 500
                               6.2.5 500
                               6.2.4 500
                               6.2.3 500
                               6.2.2 500
                               6.2.1 500
                               6.2.0 500
                               6.1.6 500
                               6.1.5 500
                               6.1.4 500
                               6.1.3 500
                               6.1.2 500
                               6.1.1 500
                               6.1.0 500
                               6.0.2 500
                               6.0.1 500
                               6.0.0 500
                               5.4.5 500
                               5.4.4 500
                               5.4.3 500
                               5.4.2 500
                               5.4.1 500
                               5.4.0 500
                               5.3.4 500
                               5.3.3 500
                               5.3.2 500
                               5.3.1 500
                               5.3.0 500
                               5.2.5 500
                               5.2.4 500
                               5.2.3 500
                               5.2.2 500
                               5.2.1 500
                               5.2.0 500
                          pi@homebridge:~ $
                          Haben die 3* vor der 8.4.7 was zu bedeuten<<ß
                            @damrak2022
                            Die drei Sterne kennzeichnen die installierte Version.
                            apt policy grafana*
                            • Damrak2022
                              apt policy grafana*
                              pi@homebridge:~ $ apt policy grafana*
                              N: Unable to locate package grafana-rpi_7.4.3_armhf.deb
                              pi@homebridge:~ $
                                @damrak2022
                                Da spukt noch irgendwo diese ominöse
                                herum. Wie hast du die denn installiert? Aus dem Paketmanager mit hoher Wahrscheinlichkeit nicht, da ist die nämlich nicht drin. Es sei denn, die ist zurückgezogen worden.
                                • Damrak2022
                                  @thomas-braun Doch alles über das Terminal
                                    @damrak2022
                                    Über das Terminal gibt es mehrere Wege Pakete zu installieren.
                                    Ist die Frage welchen du (nach welcher Anleitung?) genommen hast.
                                      @damrak2022
                                      dpkg -l '*grafana-rpi*'
                                      sagt?
                                      • Damrak2022
                                        @thomas-braun Meiner Meinung nach über die Anleitung Grafana auf einem Raps installieren. Aber mittlerweile sind wir so viele Befehle durchgegangen, das ich es nicht sicher beantworten kann.
                                        Damrak2022 crunchip 2 Replies Last reply Reply Quote 0
                                        • Damrak2022
                                          Damrak2022 @Damrak2022 last edited by
                                          @damrak2022
                                          pi@homebridge:~ $ dpkg -l '*grafana-rpi*'
                                          Desired=Unknown/Install/Remove/Purge/Hold
                                          | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
                                          |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
                                          ||/ Name           Version      Architecture Description
                                          rc  grafana-rpi    7.4.3        armhf        Grafana
                                          pi@homebridge:~ $
                                            @damrak2022 sagte in Grafana Update Probleme:
                                            weil du auch die rpi, dann die enterprise, dann eine bestimmte version, dann die neuste, dann wieder zurück....
                                            langsam hab ich den Überblick verloren, hab auch nochmal deinen andere thread durch gesehen
                                            6581
