    3. Off Topic
    4. Grafana
    5. Grafana Update Probleme
    • Damrak2022
      Damrak2022 @Thomas Braun last edited by Damrak2022
      @thomas-braun Das kommt nach dem Reboot
      pi@homebridge:~ $ sudo reboot
      Connection to homebridge closed by remote host.
      Connection to homebridge closed.
      damrak2021@Andreass-iMac ~ % ssh pi@homebridge
      pi@homebridge's password:
      Linux homebridge 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Tue Apr 26 16:10:45 2022 from 2a02:908:171:e900:258d:1682:dae2:37c3
      pi@homebridge:~ $ apt policy grafana*
      N: Unable to locate package grafana-rpi_7.4.3_armhf.deb
      pi@homebridge:~ $
      Bringt es was einen reinstall für die 7.4.3 zu machen. Werden dann auch alle Abhängigkeiten entfernt
        Thomas Braun Most Active @Damrak2022 last edited by
        @damrak2022
        Hmmmm. Ist der Eintrag wieder da?
        dpkg --list 'grafana*'
        • Damrak2022
          @thomas-braun sagte in Grafana Update Probleme:
          pi@homebridge:~ $ dpkg --list 'grafana*'
          Desired=Unknown/Install/Remove/Purge/Hold
          | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
          |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
          ||/ Name           Version      Architecture Description
          ii  grafana        8.4.7        armhf        Grafana
          pi@homebridge:~ $
            @damrak2022
            Okay, das ist also sauber.
            sudo apt update
            • Damrak2022
              sudo apt update
              pi@homebridge:~ $ sudo apt update
              Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.7 kB]
              Hit:3 https://packages.grafana.com/oss/deb stable InRelease
              Hit:4 https://repos.influxdata.com/debian bullseye InRelease
              Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
              Get:7 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [282 kB]
              Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
              Fetched 306 kB in 2s (147 kB/s)
              Reading package lists... Done
              Building dependency tree... Done
              3 packages can be upgraded. Run 'apt list --upgradable' to see them.
              pi@homebridge:~ $
                @damrak2022
                sudo apt hold grafana
                sudo apt update
                  Thomas Braun Most Active @Damrak2022 last edited by Thomas Braun
                  @damrak2022
                  sudo apt-get clean --dry-run
                  Wenn dry-run gut aussieht:
                  sudo apt-get clean
                  • Damrak2022
                    @thomas-braun Bei dem zweiten Befehl bekomme ich das:
                    pi@homebridge:~ $ apt list --upgradable
                    Listing... Done
                    grafana/stable 8.5.0 armhf [upgradable from: 8.4.7]
                    libcamera0/stable 0~git20220426+18e68a9b-1 armhf [upgradable from: 0~git20220303+e68e0f1e-1]
                    raspi-config/stable 20220425 all [upgradable from: 20220419]
                    pi@homebridge:~ $ sudo apt hold grafana
                    E: Invalid operation hold
                    pi@homebridge:~ $
                      @damrak2022
                      Mein Fehler.
                      Statt
                      muss das
                      sudo apt-mark hold grafana
                      lauten.
                      • Damrak2022
                        Das ist die Ausgabe:
                        pi@homebridge:~ $ sudo apt-mark hold grafana
                        grafana set on hold.
                        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
                        Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                        Hit:6 https://repos.influxdata.com/debian bullseye InRelease
                        Listing... Done
                        pi@homebridge:~ $ sudo apt-get clean --dry-run
                        Del /var/cache/apt/archives/* /var/cache/apt/archives/partial/*
                        Del /var/lib/apt/lists/partial/*
                        Del /var/cache/apt/pkgcache.bin /var/cache/apt/srcpkgcache.bin
                        pi@homebridge:~ $
                        • Damrak2022
                          Damrak2022 @Damrak2022 last edited by
                          @damrak2022 Auf die Oberfläche komme ich noch nicht. Muss ich nochmal
                          systemctl restart grafana-server
                          machen?
                            @damrak2022 sagte in Grafana Update Probleme:
                            sudo systemctl restart grafana-server
                            apt policy grafana*
                            sagt?
                            • Damrak2022
                              apt policy grafana*
                              Leider immer noch das:
                              pi@homebridge:~ $ sudo systemctl restart grafana-server
                              pi@homebridge:~ $
                              crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                                crunchip Forum Testing Most Active @Damrak2022 last edited by
                                und täglich grüsst das Murmeltier
                                  @damrak2022
                                  Dann weiß ich auch nicht wo das noch hängt.
                                  Muss man vielleicht mal mit find über das System schrubben.
                                  Da weiß ich aber so aus dem Kopf nicht die Parameter.
                                  Schau mal mit
                                  sudo grep -rnw / -e 'grafana-rpi_7.4.3_armhf.deb'
                                  danach.
                                  • Damrak2022
                                    Damrak2022 @crunchip last edited by
                                    @crunchip Ich google auch schon die ganze Zeit finde aber nichts zu diesem Problem.
                                    Muss jetzt aufhören, da ich weg muss.
                                    Danke an Euch, ich hoffe wir bekommen das hin
                                    pi@homebridge:~ $ sudo grep -rnw / -e 'grafana-rpi_7.4.3_armhf.deb'
                                    grep: /sys/kernel/tracing/per_cpu/cpu3/snapshot_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/tracing/per_cpu/cpu3/trace_pipe_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/tracing/per_cpu/cpu3/trace_pipe: Resource temporarily unavailable
                                    grep: /sys/kernel/tracing/per_cpu/cpu2/snapshot_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/tracing/per_cpu/cpu2/trace_pipe_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/tracing/per_cpu/cpu2/trace_pipe: Resource temporarily unavailable
                                    grep: /sys/kernel/tracing/per_cpu/cpu1/snapshot_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/tracing/per_cpu/cpu1/trace_pipe_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/tracing/per_cpu/cpu1/trace_pipe: Resource temporarily unavailable
                                    grep: /sys/kernel/tracing/per_cpu/cpu0/snapshot_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/tracing/per_cpu/cpu0/trace_pipe_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/tracing/per_cpu/cpu0/trace_pipe: Resource temporarily unavailable
                                    grep: /sys/kernel/tracing/trace_marker_raw: Invalid argument
                                    grep: /sys/kernel/tracing/trace_marker: Invalid argument
                                    grep: /sys/kernel/tracing/free_buffer: Invalid argument
                                    grep: /sys/kernel/tracing/trace_pipe: Resource temporarily unavailable
                                    grep: /sys/kernel/debug/dri/1/Writeback-1/vrr_range: No such device
                                    grep: /sys/kernel/debug/dri/1/HDMI-A-2/vrr_range: No such device
                                    grep: /sys/kernel/debug/dri/1/HDMI-A-1/vrr_range: No such device
                                    grep: /sys/kernel/debug/clear_warn_once: Permission denied
                                    grep: /sys/kernel/debug/tracing/per_cpu/cpu3/snapshot_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/debug/tracing/per_cpu/cpu3/trace_pipe_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/debug/tracing/per_cpu/cpu3/trace_pipe: Resource temporarily unavailable
                                    grep: /sys/kernel/debug/tracing/per_cpu/cpu2/snapshot_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/debug/tracing/per_cpu/cpu2/trace_pipe_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/debug/tracing/per_cpu/cpu2/trace_pipe: Resource temporarily unavailable
                                    grep: /sys/kernel/debug/tracing/per_cpu/cpu1/snapshot_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/debug/tracing/per_cpu/cpu1/trace_pipe_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/debug/tracing/per_cpu/cpu1/trace_pipe: Resource temporarily unavailable
                                    grep: /sys/kernel/debug/tracing/per_cpu/cpu0/snapshot_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/debug/tracing/per_cpu/cpu0/trace_pipe_raw: Resource temporarily unavailable
                                    grep: /sys/kernel/debug/tracing/per_cpu/cpu0/trace_pipe: Resource temporarily unavailable
                                    grep: /sys/kernel/debug/tracing/trace_marker_raw: Invalid argument
                                    grep: /sys/kernel/debug/tracing/trace_marker: Invalid argument
                                    grep: /sys/kernel/debug/tracing/free_buffer: Invalid argument
                                    grep: /sys/kernel/debug/tracing/trace_pipe: Resource temporarily unavailable
                                    Segmentation fault
                                    pi@homebridge:~ $
                                    Message from syslogd@homebridge at Apr 26 17:43:42 ...
                                     kernel:[ 2407.798031] Internal error: : 1211 [#1] SMP ARM
                                     kernel:[ 2407.798600] Process grep (pid: 6264, stack limit = 0x4f745707)
                                     kernel:[ 2407.798611] Stack: (0xc59c9d80 to 0xc59ca000)
                                     kernel:[ 2407.798622] 9d80: c59c9dac c59c9d90 c0895498 c08953a4 c59c9dbc c59c9da0 c2308200 00000014
                                     kernel:[ 2407.798635] 9da0: c59c9dbc c59c9db0 c088c124 c089546c c59c9dec c59c9dc0 c088f8f4 c088c10c
                                     kernel:[ 2407.798648] 9dc0: 0000002e c2308200 00000014 c59c9e3c c7b80000 00018000 c59c9f58 00000efc
                                     kernel:[ 2407.798660] 9de0: c59c9e0c c59c9df0 c088fa0c c088f890 0000004b c2308200 00000014 c7b80000
                                     kernel:[ 2407.798673] 9e00: c59c9e7c c59c9e10 c0894804 c088f9cc 00000014 3391a86e c3a42010 c1205048
                                     kernel:[ 2407.798685] 9e20: 01a39000 c0e8e918 c0e8e910 00000000 00000046 00000000 c59c9e54 00000000
                                     kernel:[ 2407.798698] 9e40: 00000046 00000000 c59c9ee4 3391a86e c045c164 c3880540 c0894a5c c1c77c38
                                     kernel:[ 2407.798710] 9e60: 01a39000 00018000 c59c9f58 c06545ec c59c9e94 c59c9e80 c0894a94 c08946bc
                                     kernel:[ 2407.798723] 9e80: 00018000 c59c9f58 c59c9ebc c59c9e98 c0654650 c0894a68 c3880540 00018000
                                     kernel:[ 2407.798735] 9ea0: c1205048 00000000 01a39000 c59c9f58 c59c9f54 c59c9ec0 c0455ae0 c06545f8
                                     kernel:[ 2407.798748] 9ec0: c045c4a0 3391a86e c1205048 becee1e0 00000000 00000001 c59c9f94 c59c9ee8
                                     kernel:[ 2407.798760] 9ee0: c045c584 c045bff4 000007ff 00008100 00000001 00001000 00000000 00000000
                                     kernel:[ 2407.798773] 9f00: 00201000 00000000 00001eb5 c047ab64 3391a86e c1205048 b6fba500 7ff00000
                                     kernel:[ 2407.798785] 9f20: 00000003 3391a86e 01a39000 c1205048 c3880540 00000000 00000000 c3880540
                                     kernel:[ 2407.798798] 9f40: 01a39000 00018000 c59c9f94 c59c9f58 c0456240 c0455a38 00000000 00000000
                                     kernel:[ 2407.798810] 9f60: 00000000 3391a86e 00000000 00000003 b6fba500 7ff00000 00000003 c0200244
                                     kernel:[ 2407.798823] 9f80: c59c8000 00000003 c59c9fa4 c59c9f98 c04562d0 c04561e4 00000000 c59c9fa8
                                     kernel:[ 2407.798835] 9fa0: c0200040 c04562c4 00000003 b6fba500 00000003 01a39000 00018000 00000000
                                     kernel:[ 2407.798848] 9fc0: 00000003 b6fba500 7ff00000 00000003 00000003 01a39000 00000003 00018000
                                     kernel:[ 2407.798860] 9fe0: 00046e38 becee138 b6e56134 b6e56150 60000010 00000003 00000000 00000000
                                     kernel:[ 2407.798871] Backtrace:
                                     kernel:[ 2407.798880] [<c0895398>] (regmap_mmio_read32le) from [<c0895498>] (regmap_mmio_read+0x38/0x74)
                                     kernel:[ 2407.798900] [<c0895460>] (regmap_mmio_read) from [<c088c124>] (_regmap_bus_reg_read+0x24/0x28)
                                     kernel:[ 2407.798920]  r5:00000014 r4:c2308200
                                     kernel:[ 2407.798927] [<c088c100>] (_regmap_bus_reg_read) from [<c088f8f4>] (_regmap_read+0x70/0x13c)
                                     kernel:[ 2407.798944] [<c088f884>] (_regmap_read) from [<c088fa0c>] (regmap_read+0x4c/0x6c)
                                     kernel:[ 2407.798962]  r10:00000efc r9:c59c9f58 r8:00018000 r7:c7b80000 r6:c59c9e3c r5:00000014
                                     kernel:[ 2407.798973]  r4:c2308200 r3:0000002e
                                     kernel:[ 2407.798981] [<c088f9c0>] (regmap_read) from [<c0894804>] (regmap_read_debugfs+0x154/0x364)
                                     kernel:[ 2407.799000]  r7:c7b80000 r6:00000014 r5:c2308200 r4:0000004b
                                     kernel:[ 2407.799008] [<c08946b0>] (regmap_read_debugfs) from [<c0894a94>] (regmap_map_read_file+0x38/0x40)
                                     kernel:[ 2407.799029]  r10:c06545ec r9:c59c9f58 r8:00018000 r7:01a39000 r6:c1c77c38 r5:c0894a5c
                                     kernel:[ 2407.799040]  r4:c3880540
                                     kernel:[ 2407.799047] [<c0894a5c>] (regmap_map_read_file) from [<c0654650>] (full_proxy_read+0x64/0x80)
                                     kernel:[ 2407.799065] [<c06545ec>] (full_proxy_read) from [<c0455ae0>] (vfs_read+0xb4/0x344)
                                     kernel:[ 2407.799085]  r9:c59c9f58 r8:01a39000 r7:00000000 r6:c1205048 r5:00018000 r4:c3880540
                                     kernel:[ 2407.799095] [<c0455a2c>] (vfs_read) from [<c0456240>] (ksys_read+0x68/0xe0)
                                     kernel:[ 2407.799111]  r10:00018000 r9:01a39000 r8:c3880540 r7:00000000 r6:00000000 r5:c3880540
                                     kernel:[ 2407.799122]  r4:c1205048
                                     kernel:[ 2407.799129] [<c04561d8>] (ksys_read) from [<c04562d0>] (sys_read+0x18/0x1c)
                                     kernel:[ 2407.799145]  r10:00000003 r9:c59c8000 r8:c0200244 r7:00000003 r6:7ff00000 r5:b6fba500
                                     kernel:[ 2407.799156]  r4:00000003
                                     kernel:[ 2407.799162] [<c04562b8>] (sys_read) from [<c0200040>] (ret_fast_syscall+0x0/0x1c)
                                     kernel:[ 2407.799179] Exception stack(0xc59c9fa8 to 0xc59c9ff0)
                                     kernel:[ 2407.799190] 9fa0:                   00000003 b6fba500 00000003 01a39000 00018000 00000000
                                     kernel:[ 2407.799202] 9fc0: 00000003 b6fba500 7ff00000 00000003 00000003 01a39000 00000003 00018000
                                     kernel:[ 2407.799214] 9fe0: 00046e38 becee138 b6e56134 b6e56150
                                     kernel:[ 2407.799225] Code: e5903000 e0831001 e5910000 f57ff04f (e89da800)
                                    Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                      @damrak2022
                                      Gut, die Idee war jetzt zugegeben nicht meine beste... 😄
                                        crunchip Forum Testing Most Active @Damrak2022 last edited by crunchip
                                        @damrak2022 vllt ist es doch eine Möglichkeit diese grafana-rpi_7.4.3_armhf.deb nochmal von Hand zu installieren und anschliessend deinstallieren.
                                        Zuvor würde ich allerdings , den aktuellen Grafana Ordner wegsichern und die aktuelle Version runterwerfen.
                                        Wenn das klappt, normal per apt wieder instalieren und die Config/Dashboard zurückspielen
                                        Was anderes fällt mit da jetzt auch nicht mehr ein
                                        • Damrak2022
                                          @crunchip ja, das könnte ich probieren. Wie sichere ich den Ordner weg?
                                            @damrak2022
                                            edit:
                                            das zeug liegt ja wo anders, muss ich mal suchen wo das liegt und ob man das überhaupt dann so wiederverwenden kann
                                            z.b. so,
                                            das ist der PATHS_DATA da liegt die grafana.db, die brauchst, denn da sind deine dashboards enthalten
                                            cp  -r /var/lib/grafana/ /tmp/
                                            die anderen Ordner wären
                                            PATHS_CONFIG	/etc/grafana/grafana.ini
                                            PATHS_DATA	/var/lib/grafana
                                            PATHS_HOME	/usr/share/grafana
                                            PATHS_LOGS	/var/log/grafana
                                            PATHS_PLUGINS	/var/lib/grafana/plugins
                                            PATHS_PROVISIONING	/etc/grafana/provisioning
                                            eventuell wäre das eine Möglichkeit
                                            deinstallieren
                                            sudo apt-get remove --auto-remove grafana
                                            Installation dann
                                            sudo apt-get install -y adduser libfontconfig1
                                            wget https://dl.grafana.com/oss/release/grafana-rpi_7.4.3_armhf.deb
                                            sudo dpkg -i grafana-rpi_7.4.3_armhf.deb
                                            anschliessend dies wieder deinstallieren
                                            sudo apt-get purge grafana-rpi
                                            6084
