    4. Updates funktionieren nicht mehr
      Thomas Braun Most Active @mfroeschl last edited by
      @mfroeschl
      which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        mfroeschl @Thomas Braun last edited by
        @thomas-braun said in Updates funktionieren nicht mehr:
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.14.2
        v16.14.2
        Error: Cannot find module 'json-parse-better-errors'
        Require stack:
        - /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/make-fetch-happen/node_modules/node-fetch-npm/src/body.js
        - /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/make-fetch-happen/node_modules/node-fetch-npm/src/index.js
        - /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/make-fetch-happen/index.js
        - /usr/lib/node_modules/npm/node_modules/npm-registry-fetch/lib/index.js
        - /usr/lib/node_modules/npm/node_modules/pacote/lib/remote.js
        - /usr/lib/node_modules/npm/node_modules/pacote/lib/git.js
        - /usr/lib/node_modules/npm/node_modules/pacote/lib/fetcher.js
        - /usr/lib/node_modules/npm/node_modules/pacote/lib/index.js
        - /usr/lib/node_modules/npm/lib/utils/update-notifier.js
        - /usr/lib/node_modules/npm/lib/cli.js
        - /usr/lib/node_modules/npm/bin/npm-cli.js
            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
            at Function.Module._load (node:internal/modules/cjs/loader:778:27)
            at Module.require (node:internal/modules/cjs/loader:1005:19)
            at require (node:internal/modules/cjs/helpers:102:18)
            at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/make-fetch-happen/node_modules/node-fetch-npm/src/body.js:14:19)
            at Module._compile (node:internal/modules/cjs/loader:1103:14)
            at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10)
            at Module.load (node:internal/modules/cjs/loader:981:32)
            at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        pi@raspberrypi-iobroker:~ $
          @mfroeschl sagte in Updates funktionieren nicht mehr:
          Wassn jetzt kaputt?
          /usr/bin/npm -v
            /usr/bin/npm -v
            /usr/bin/npm -v
            Require stack:
              @mfroeschl
              Keine Ahnung was da kaputt ist.
                Schade. Trotzdem Danke für deinen Support.
                Dann mach ich mich mal dran das Backup wieder up-to-date zu bringen.
                  Thomas Braun Most Active @mfroeschl last edited by Thomas Braun
                  @mfroeschl
                  Haste kein gescheites aktuelles Backup? Vom Backitup-Adapter?
                  Ein fullimage aus Januar ist ja nur unwesentlich besser als gar nix.
                  Und die 'krumme Installation von npm und Konsorten' war da noch nicht drin? Sonst knallst du dir den Kram ja wieder per Image auf die Kiste.
                    Eigentlich schon. Ich habe jeden Tage in Backup auf dem FTP abgelegt.
                    Leider funktionert der Restore überhaupt nicht. Ich hatte vorgestern ein neues Image runtergeladen und mittels
                    curl -sL https://iobroker.net/install.sh | bash -
                    den iobroker installiert.
                    ein
                    iobroker restore 0
                    hatte 4x das gleiche ergebnis. Zunächst wurde der Admin und der Backitup Adapter lt. Meldungen deinstalliert, dann wurde der Admin Adapter wieder installiert.
                    Dann kam die Meldung, dass der Restore erfolgreich beendet ist.
                    nach iobroker start und diversen reboots war aber immer der admin adatper nicht mehr erreichbar.
                    Hab dann irgendwann aufgegeben.
                    Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                      ...weiß ich nicht, zumindest kann ich auf diesem Backup alle Adapter prolbemlos updaten
                        Image von was?
                          Ein neues Image von buster für den Raspi.
                            mfroeschl @mfroeschl last edited by
                            @mfroeschl
                            ähh Bullseye
                              Womöglich war der nur nicht gestartet.
                                Ich hatte auch
                                iobroker start all
                                mehrfach probiert
                                  Homoran Global Moderator Administrators @mfroeschl last edited by Homoran
                                  ein
                                  iobroker restore 0
                                  wieso nehmt ihr alle die 0 und nicht den Dateinamen?
                                  und welches Ergebnis genau?
                                    mfroeschl @Homoran last edited by
                                    habe den Befehl im Internet gefunden und mir da nix dabei gedacht.
                                    Das Ergebnis nach der Meldung dass der Restore successful gewesen sein war immer gleich. Der admin Adpater des iobrokers war nicht über 192.xxx.xxx.xxx:8081 erreichbar.
                                    Es wurden auch keine Adapter installiert die im Backup enthalten waren, lediglich der Admin-Adapter, sonst nix.
                                      und wie lange hast du dann gewartet um den admin aufzurufen?
                                      Danach werden erst alle Adapter neu gebaut. Das dauert schon mal gerne 1h+
                                      Allerdings müsste der Admin erreichbar sein.
                                      Wie Thomas schon schreibt war der wahrscheinlich nur nicht gestartet
                                        Hab einige Minuten gewartet, genau weiß ich das aber nicht mehr.
                                        Ist aber kein Problem, hab hier noch einen Pi3B rumlegen, da installier ich jetzt einfach nochmal das aktuelle Image, dann installiere ich den iobroker drauf und mache ein restore.
                                        Ich poste hier dann die Meldungen und Screenshots..
                                          und dann bekommen wir das schon ans laufen!
                                          Welcher Controller läuft auf dem Backup?
                                          Schon mit jsonl oder noch mit file/redis
                                            @homoran said in Updates funktionieren nicht mehr:
                                            Wie finde ich das heraus, das sagt mir nix, sorry
                                            4478
