    4. JavaScript
    5. HowTo: Zusatz-Programme fuer jarvis v3
      sigi234 Forum Testing Most Active @apollon77 last edited by sigi234
      @apollon77 sagte in HowTo: Zusatz-Programme fuer jarvis v3:
      @sigi234 Bitte GitHub version versuchen. Ists da weg?
      Nein, warning0 wird nicht angelegt
      dwd.0
      2022-03-23 18:23:04.202	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      dwd.0
      2022-03-23 18:23:04.201	debug	Plugin sentry destroyed
      dwd.0
      2022-03-23 18:23:04.186	debug	Add warning "dwd.0.warning9":
      dwd.0
      2022-03-23 18:23:04.136	debug	Write warnings for 9: dwd.0.warning9 = undefined
      dwd.0
      2022-03-23 18:23:04.119	debug	Add warning "dwd.0.warning8":
      dwd.0
      2022-03-23 18:23:04.089	debug	Write warnings for 8: dwd.0.warning8 = undefined
      dwd.0
      2022-03-23 18:23:04.072	debug	Add warning "dwd.0.warning7":
      dwd.0
      2022-03-23 18:23:04.042	debug	Write warnings for 7: dwd.0.warning7 = undefined
      dwd.0
      2022-03-23 18:23:04.025	debug	Add warning "dwd.0.warning6":
      dwd.0
      2022-03-23 18:23:03.993	debug	Write warnings for 6: dwd.0.warning6 = undefined
      dwd.0
      2022-03-23 18:23:03.975	debug	Add warning "dwd.0.warning5":
      dwd.0
      2022-03-23 18:23:03.942	debug	Write warnings for 5: dwd.0.warning5 = undefined
      dwd.0
      2022-03-23 18:23:03.924	debug	Add warning "dwd.0.warning4":
      dwd.0
      2022-03-23 18:23:03.804	debug	Write warnings for 4: dwd.0.warning4 = undefined
      dwd.0
      2022-03-23 18:23:03.788	debug	Add warning "dwd.0.warning3":
      dwd.0
      2022-03-23 18:23:03.759	debug	Write warnings for 3: dwd.0.warning3 = undefined
      dwd.0
      2022-03-23 18:23:03.741	debug	Add warning "dwd.0.warning2":
      dwd.0
      2022-03-23 18:23:03.711	debug	Write warnings for 2: dwd.0.warning2 = undefined
      dwd.0
      2022-03-23 18:23:03.696	debug	Add warning "dwd.0.warning1":
      dwd.0
      2022-03-23 18:23:03.669	debug	Write warnings for 1: dwd.0.warning1 = undefined
      dwd.0
      2022-03-23 18:23:03.653	debug	Add warning "dwd.0.warning": 2022-03-23T22:00:00.000Z
      dwd.0
      2022-03-23 18:23:03.524	debug	Write warnings for 0: dwd.0.warning = {"regionName":"Kreis und Stadt Passau","type":5,"state":"Bayern","end":1648105200000,"start":1648072800000,"level":2,"description":"Es tritt leichter Frost zwischen 0 °C und -4 °C auf. In Tal- und Muldenlagen sinken die Temperaturen auf Werte bis -6 °C.","instruction":"","stateShort":"BY","altitudeStart":null,"altitudeEnd":null,"headline":"Amtliche WARNUNG vor FROST","event":"FROST"}
      dwd.0
      2022-03-23 18:23:03.496	debug	Sorted Warnings: [{"regionName":"Kreis und Stadt Passau","type":5,"state":"Bayern","end":1648105200000,"start":1648072800000,"level":2,"description":"Es tritt leichter Frost zwischen 0 °C und -4 °C auf. In Tal- und Muldenlagen sinken die Temperaturen auf Werte bis -6 °C.","instruction":"","stateShort":"BY","altitudeStart":null,"altitudeEnd":null,"headline":"Amtliche WARNUNG vor FROST","event":"FROST"}]
      dwd.0
      2022-03-23 18:23:03.495	debug	Find Warnings for Region: Kreis und Stadt Passau
        MCU @sigi234 last edited by MCU
        @sigi234 Soll ja auch nicht. warning = "warning0". So war es ja vorher auch.
          apollon77 @MCU last edited by
          @mcu Ja, Ich hab nicht aufgepasst ... kommt davon wenn man soviel an Adaptern rumfummelt die man selbst nicht geschrieben hat. Da kann man solche Kleinigkeiten übersehen 😞
            MCU @apollon77 last edited by
            @apollon77 Wir sind alle dankbar, dass du es kannst und machst. Da passieren auch mal Kleinigkeiten. Also DANKE.
              Bloody last edited by
              @MCU
              Ich hatte bereits Combined, feed und short probiert, funktioniert bei keinem Wert.
                MCU @Bloody last edited by
                @bloody Falls es dir um die günstigste geht, ist im Adapter schon drin:
                  MCU @Bloody last edited by MCU
                  @bloody Also funktioniert bei mir mit dem feed-Wert. Du warst nicht gleichzeitig in der Bearbeitung von jarvis im FrontEnd?
                  statelistSort('0','13c88101-c6bb-48b6-9347-5122a3ef3bbe','number',false);
                  statelistSort('0','13c88101-c6bb-48b6-9347-5122a3ef3bbe','number',true);
                  Habe die Doku nochmal angepasst:
                  https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/system-effektprog./v3-systemprogramme/statelistsort
                  evtl F5 drücken.
                    Bloody @MCU last edited by
                    @mcu
                    Danke für die Rückmeldung.
                    Das Problem war, dass ich zwar den feed Datenpunkt benutzt habe aber noch in den Datenpunkt Eigenschaften gerundet hatte ({"value":"val => parseFloat(val).toFixed(2)"}).
                    Keine Ahnung, wieso ich das so gemacht hatte, weil es ja den DP short auch gibt. Gabs den schon immer? Naja egal, es geht jetzt.
                    Hab es jetzt so gelöst.
                    https://forum.iobroker.net/topic/49776/jarvis-v3-0-0-just-another-remarkable-vis/2364
                    Dankeschön.
                      Moin @MCU,
                      hab doch noch ein Problem.
                      Es steht nicht immer der billigste Preis oben. Erst wenn ich das Skript neustarte, passt es wieder.
                      Aber da ist doch ein Trigger drin, falls sich ein Preis ändert, soll sich die Reihenfolge anpassen
                      oder liege ich falsch?
                        @bloody Das soll ja so. Soll der teuerste oben sein dann muss man false setzen.
                          @mcu
                          Kann leider gerade kein Screenshot machen, da es aktuell mit der Reihenfolge passt (von klein nach groß). Hätte ich vielleicht dazu sagen sollen... Bei mir ist es dann nicht von klein nach groß oder von groß nach klein sortiert, sondern die Preise sind durcheinander gewürfelt.
                          Beispielsweise so:
                          1.91
                          1.95
                          1.98
                          1.89
                          1.70
                            MCU last edited by MCU
                            @bloody Dann zeig mal bitte das Programm, welches du nutzt. Bitte in CodeTags (</>), also auf e07c2e6c-780f-4d2b-ba36-33ce9491c295-image.png klicken und den COde einfügen. Danke. Mir reicht der Trigger Teil, nicht die function().
                            Kann es sein, dass du nur einmal um 01:00 Uhr die Funktion laufen lässt?
                              Bloody @MCU last edited by Bloody
                              @mcu
                              Hier nochmal, der aktuelle Stand.
                              Ich sehe gar keinen Trigger 😕
                              // stateListSort
                              statelistSort('0','hier ist die id drin','number',true);
                              function statelistSort(instance,widgetId,valType,sortUp){
                                  // insbesondere für trashschedule
                                  let widgetsDP = 'jarvis.' + instance + '.widgets';
                                  let widgets = getState(widgetsDP).val;
                                  widgets = JSON.parse(widgets);
                                  let arr = [];
                                  for (let id in widgets){
                                      if (id == widgetId ){
                                          for (let key in widgets[id].items){
                                              // Type vom item prüfen
                                              if (widgets[id].items[key].type == 'device'){
                                                  let objId =getStateFromDevice(instance, widgets[id].items[key].deviceId, widgets[id].items[key].primaryStateKey);
                                                  let objVal = getState(objId).val;
                                                  if (typeof(objVal) == valType){
                                                      arr.push({'objVal':objVal,'key':key, 'all': widgets[id].items[key]});
                                                  }else{
                                                      arr.push({'objVal':0,'key':key, 'all': widgets[id].items[key]});
                                                      //log('Abbruch, da Wert nicht stimmt: objVal: '+ objVal +' - '+typeof(objVal));
                                                      // arr= [];
                                                      // break;
                                              }else{
                                                  log('Liste nicht sinnvoll sortierbar, da divider vorhanden');
                                                  arr =[];
                                                  break;
                                          // Sort arr
                                          if (arr.length>0){
                                              if (valType == 'boolean'){
                                                  if (sortUp || sortUp == undefined){
                                                      arr.sort((a, b) => (toBoolean(a.objVal) > toBoolean (b.objVal)) ? 1 : -1);
                                                  }else{
                                                      arr.sort((a, b) => (toBoolean(a.objVal) < toBoolean (b.objVal)) ? 1 : -1);
                                               if (valType == 'number'){
                                                      arr.sort((a, b) => (a.objVal > b.objVal ) ? 1 : -1);
                                                  }else{
                                                      arr.sort((a, b) => (a.objVal < b.objVal) ? 1 : -1);
                                          }else{
                                              log('Abbruch der Sortierung');
                                          break;
                                  let widgetArr = [];
                                  for (let i=0;i<arr.length;i++){
                                      log(i+' - '+arr[i].objVal+' - key: '+arr[i].key);
                                      widgetArr.push(arr[i].all);
                                          widgets[id].items = widgetArr;
                                          log ('Nachher:'+JSON.stringify(widgets[id].items));
                                          break;
                                  setState(widgetsDP,JSON.stringify(widgets),false);
                              function getStateFromDevice(instance, deviceId, devState){
                                  let devicesDP = 'jarvis.' + instance + '.devices';
                                  let devices = getState(devicesDP).val;
                                  devices = JSON.parse(devices);
                                  for (let key in devices){
                                      let devicesArr = devices[key];
                                      for (let key2 in devicesArr){
                                          if (deviceId ==devicesArr[key2].id){
                                              let devicesStates =devicesArr[key2].states;
                                              for (let key3 in devicesStates){
                                                  if (devState == key3){
                                                      return devicesStates[key3].state;
                              Nachtrag:
                              Ich habs jetzt. Hatte nicht gesehen, dass es bereits einen weiteren Eintrag und Trigger gibt.
                              https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/system-effektprog./v3-systemprogramme/statelistsort/javascript-zusatz-tankerkoenig
                              Habs jetzt so:
                              // stateListSort
                              statelistSort('0','id','number',true);
                                  let arr = [];
                                                  }else{
                                                      // arr= [];
                                                      // break;
                                              }else{
                                                  arr =[];
                                                  break;
                                          // Sort arr
                                          if (arr.length>0){
                                                  }else{
                                                  }else{
                                          }else{
                                          break;
                                  let widgetArr = [];
                                          break;
                              // tankerkoenig Zusatz
                              // Möchte man die Preis in einem Widget sortiert haben
                              // kann man direkt nach Änderung der Preise für die Spritsorten
                              // die Sortierung neu anstossen
                              // Beide Script stateListSort und tankerkoenigSort muessen in einem Script zusammen sein
                              // Spritart anpassen e10 , diesel oder e5
                              // Hier zurzeit e10 gezeigt
                              // Fall man möchte bei jeder Preisänderung eine Sortierung
                              let tankerkoenigDPs = 'tankerkoenig.0.stations.*.e10.feed';
                              $(tankerkoenigDPs).on(function (obj) {
                                  if (obj.deviceId != 'tankerkoenig.0.stations.cheapest'){
                              Sorry für die Umstände und Danke!
                                @bloody
                                Zeile 6 statelistSort('0','Hier muss die Nummer vom Widget rein','number',true);
                                Auch in Zeile 91 statt id -> Auch DEINE WIDGETID z.B.:8dd7dd58-7b35-4efa-ac7f-e262df17f1f9
                                Wie im Beispiel
                                // statelistSort('0','8dd7dd58-7b35-4efa-ac7f-e262df17f1f9','number',true);
                                https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/system-effektprog./v3-systemprogramme/statelistsort#widgetid-aus-dem-layout
                                • CarstenDerGroße
                                  CarstenDerGroße last edited by CarstenDerGroße
                                  Hallo zusammen, hallo @MCU
                                  ich hatte ja im Hauptthread von Jarvis schonmal wegen der Spotify-Tracklist geschrieben und feststellen müssen das ein Titelwechsel ohne vis und iframe aktuell noch nicht möglich ist...
                                  Nun hatte ich etwas zeit und habe einen Fork des Spotify-Adapters anleget und dort die Einstellungsmöglichkeit geschaffen die htmlDPs Jarvis konform erstellen zu lassen (heißt auch das Script für die Bilder kann entfallen sobald mein Pullrequest gemerged ist).
                                  Einen entsprechenden pullrequest hab ich natürlich auf den Adapter gestellt.
                                  Für alle die es Testen und nutzen wollen:
                                  • Spotiy-premium-Adapter von https://github.com/mericon/ioBroker.spotify-premium installieren
                                  • Bilder aus dem ordner iobroker.spotify-premium/widgets/spotify-premium/img
                                    nach vis.0/spotify kopieren
                                  gruß
                                  Carsten
                                  • U
                                    Urknall last edited by Urknall
                                    Ich hoffe hier bin ich richtig.....
                                    Ich bin dabei das Projekt von OpenLigaDB von @MCU umzusetzen. Leider komme ich Aktuell nicht weiter. Habe die Anleitung schon 2-3 mal durch, und DP kontrolliert....aber es klappt nicht. Das Script füllt die Anzeigenvarianten in liga und team nicht.
                                    Folgende Fehlermeldung sagt das Script, weiss jemand rat?
                                    23.7.2022, 16:49:23.494	[info ]: javascript.0 (14922) Stop script script.js.common.Buli
                                    23.7.2022, 16:49:23.520	[info ]: javascript.0 (14922) Start javascript script.js.common.Buli
                                    23.7.2022, 16:49:23.527	[info ]: javascript.0 (14922) script.js.common.Buli: Create Ligen Script Start
                                    23.7.2022, 16:49:23.528	[info ]: javascript.0 (14922) script.js.common.Buli: registered 8 subscriptions and 0 schedules
                                    23.7.2022, 16:49:26.531	[warn ]: javascript.0 (14922) script.js.common.Buli: Eintrag für JARVIS (Anzeigevariante DP liga): {"openligadb.0.bl1.2022.allmatches":"1. Bundesliga 2022","openligadb.0.bl2.2022.allmatches":"2. Bundesliga 2022","openligadb.0.dfb2022.2022.allmatches":"DFB-Pokal 2022"}
                                    23.7.2022, 16:49:26.534	[info ]: javascript.0 (14922) script.js.common.Buli: DevState: liga gefunden!
                                    23.7.2022, 16:49:26.537	[error]: javascript.0 (14922)     at setDeviceIdState (script.js.common.Buli:676:57)
                                    23.7.2022, 16:49:26.538	[error]: javascript.0 (14922)     at createLigen (script.js.common.Buli:355:13)
                                    23.7.2022, 16:49:26.538	[error]: javascript.0 (14922)     at Object.<anonymous> (script.js.common.Buli:61:13)
                                    23.7.2022, 16:49:29.574	[info ]: javascript.0 (14922) script.js.common.Buli: bdlLigaDP: openligadb.0.bl1.2022.allmatches
                                    23.7.2022, 16:49:29.575	[info ]: javascript.0 (14922) script.js.common.Buli: Create Team Liga-Änderung
                                    23.7.2022, 16:49:29.576	[info ]: javascript.0 (14922) script.js.common.Buli: Liga create Teams: openligadb.0.bl1.2022.allmatches
                                    23.7.2022, 16:49:29.591	[warn ]: javascript.0 (14922) script.js.common.Buli: Eintrag für JARVIS (Anzeigevariante DP team): {"6":"Bayer Leverkusen","7":"Borussia Dortmund","9":"FC Schalke 04","16":"VfB Stuttgart","40":"FC Bayern München","54":"Hertha BSC","65":"1. FC Köln","80":"1. FC Union Berlin","81":"1. FSV Mainz 05","87":"Borussia Mönchengladbach","91":"Eintracht Frankfurt","95":"FC Augsburg","112":"SC Freiburg","129":"VfL Bochum","131":"VfL Wolfsburg","134":"Werder Bremen","175":"TSG 1899 Hoffenheim","1635":"RB Leipzig","":"Keine Auswahl"}
                                    23.7.2022, 16:49:32.624	[info ]: javascript.0 (14922) script.js.common.Buli: TeamDP -> Keine Auswahl ausgewählt
                                    23.7.2022, 16:49:32.625	[info ]: javascript.0 (14922) script.js.common.Buli: bdlLigaDP: openligadb.0.bl1.2022.allmatches
                                    23.7.2022, 16:49:34.593	[info ]: javascript.0 (14922) script.js.common.Buli: bdlLigaDP -> createTeams: openligadb.0.bl1.2022.allmatches
                                    23.7.2022, 16:49:34.613	[info ]: javascript.0 (14922) script.js.common.Buli: bdlLigaDP -> configStates: {"6":"Bayer Leverkusen","7":"Borussia Dortmund","9":"FC Schalke 04","16":"VfB Stuttgart","40":"FC Bayern München","54":"Hertha BSC","65":"1. FC Köln","80":"1. FC Union Berlin","81":"1. FSV Mainz 05","87":"Borussia Mönchengladbach","91":"Eintracht Frankfurt","95":"FC Augsburg","112":"SC Freiburg","129":"VfL Bochum","131":"VfL Wolfsburg","134":"Werder Bremen","175":"TSG 1899 Hoffenheim","1635":"RB Leipzig","":"Keine Auswahl"}
                                    23.7.2022, 16:49:34.614	[info ]: javascript.0 (14922) script.js.common.Buli: DevState: team gefunden!
                                    23.7.2022, 16:49:34.618	[error]: javascript.0 (14922)     at setDeviceIdState (script.js.common.Buli:676:57)
                                    23.7.2022, 16:49:34.618	[error]: javascript.0 (14922)     at Object.<anonymous> (script.js.common.Buli:199:21)
                                    Link: Anleitung
                                    Die Geräte ID "Bundesliga" wird vom Scan richtig erkannte und hinterlegt.
                                      MCU @Urknall last edited by MCU
                                      @urknall Zeig mal bitte den stateDP von jarvis liga.
                                      Hattest du dort etwas eingetragen?
                                      • U
                                        Urknall @MCU last edited by Urknall
                                        @mcu sagte in HowTo: Zusatz-Programme fuer jarvis v3:
                                        Nein da habe ich nix eingetragen da durch script ausgefüllt wird.
                                        Meintest du:
                                        0_userdata.0.jarvis.bdl.liga
                                          @urknall Nein, den DP in jarvis
                                          Zeig mal bitte die Objektstruktur von
                                          • U
                                            81.1k
                                            javascript
                                            33
                                            889
                                            207150
