    3. Off Topic
    4. Proxmox
    5. Proxmox und iobroker
      Thomas Braun Most Active @Marko1974 last edited by
      @marko1974 Mach das über deinen DHCP-Server.
      Marko1974 2 Replies Last reply Reply Quote 0
      • Marko1974
        Marko1974 @Thomas Braun last edited by
        @thomas-braun verstehe....mache ich dann so. also lasse ich das Ding auf DHCP stehen
        • Marko1974
          ich bin auch doof....jetzt weiss ich wieder warum der User nicht iobroker heissen darf
          Installed librsvg2-dev
          Installed net-tools
          Installed python-dev
          Installed cmake
              Creating ioBroker user and directory (2/4)
          User iobroker created
          Created /etc/sudoers.d/iobroker
          Directory /opt/iobroker created
              Installing ioBroker (3/4)
            @marko1974
            Weil es einfacher ist?
            Marko1974 1 Reply Last reply Reply Quote 0
            • Marko1974
              Marko1974 @Thomas Braun last edited by Marko1974
              was ist nun los?
              Komme auch nicht aufs Webif
              gyp ERR! configure error
              gyp ERR! stack Error: getaddrinfo EAI_AGAIN nodejs.org
              gyp ERR! stack     at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:71:26)
              gyp ERR! System Linux 5.13.19-2-pve
              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
              gyp ERR! cwd /opt/iobroker/node_modules/diskusage
              gyp ERR! node -v v14.19.1
              gyp ERR! node-gyp -v v5.1.0
              gyp ERR! not ok
              gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
              gyp ERR! not ok
                  Finalizing installation (4/4)
              Enabling autostart...
              Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service -> /lib/systemd/system/iobroker.service.
              Autostart enabled!
              Fixing directory permissions...
              This system does not support setting default permissions.
              Do not use npm to manually install adapters unless you know what you are doing!
                  ioBroker was installed successfully
                  Open http://192.168.0.36:8081 in a browser and start configuring!
              You need to re-login before doing anything else on the console!
              openhabian@ioBroker:~$
              openhabian@ioBroker:/opt/iobroker$ iobroker status
              Objects type: jsonl
              States  type: jsonl
                @marko1974 sagte in Proxmox und iobroker:
                Hast du gemacht?
                • Marko1974
                  Marko1974 @crunchip last edited by
                  @crunchip yes. Sogar alles mal neu gestartet
                  Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                    @Marko1974
                    Kannst du nodejs.org aus der Kiste heraus erreichen?
                      crunchip Forum Testing Most Active @Marko1974 last edited by crunchip
                      @marko1974 denke, deine Netzwerkeinstellung ist falsch
                      Ping mal google an von deinem iobroker aus
                        crunchip Forum Testing Most Active @Thomas Braun last edited by
                        @thomas-braun ich ziehe allerdings statisch bei Serverbetrieb vor
                          fertig habe quasi in ein anderes netzwerk mit dem Teil wande
                          Was heisst anderes Netzwerk?
                            Thomas Braun Most Active @crunchip last edited by
                            @crunchip
                            Schließt sich ja nicht aus.
                            Die IP bindet der DHCP-Server an die MAC-Adresse.
                              Homoran Global Moderator Administrators @Marko1974 last edited by
                              DNS Problem
                                crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                                @thomas-braun und was machste dann bei einem vlan, Router wechsel etc
                                Gerätschaften, bei denen es nicht egal ist, welche ip Adresse sie haben, liegen bei mir im extra angelegten statischen Adressbereich, geordnet, alles andere, danach im dhcp Bereich
                                Das wäre mir zu umständlich, wenn z.b. eine neue Maschine, Grafana, influx oder iobroker, estellt werden muss, ein backup einspielen, aber dann müsste ich den ganzen Rattenschwanz mit anpassen, wie Scripte, hinterlegte Geräte/Maschinen in gewissen Adapter, ini Dateien...
                                  Thomas Braun Most Active last edited by Thomas Braun
                                  @crunchip hostnames, fertig. In meinem Netzwerk jedenfalls.
                                    @thomas-braun auch dein Netzwerk kann das nicht, ohne alles anpassen zu müssen. Da nützt dir hostnames wenig
                                      Thomas Braun Most Active @crunchip last edited by Thomas Braun
                                      @crunchip
                                      Ich hab auch kein VLAN, keine Geräte, denen es nicht egal ist welche IP sie haben, kein Grafana, kein influx, kein neues iobroker.
                                      Alle Geräte haben hier einen hostname über den DHCP-Server der Fritte, gut ist. Da muss ich dann auch keine handschriftlichen Tabellen/Notizen mit fixen IPs führen. Das wäre mir nämlich alles zu umständlich und zu fehlerträchtig.
                                      • Marko1974
                                        @crunchip said in Proxmox und iobroker:
                                        Das heißt, dass ich hier alles fertig machen möchte und das Ding dann mit zu meinen Eltern nehme.
                                        Bekommt also eine andere IP.
                                        Ich hab hier was mit 192.168.0.1
                                        Und die mit 178.1….wenn mir einer sagen kann wie ich das nachträglich anpasse wäre ich dankbar.
                                        Zu dem Ping an Node.js komme ich gleich. Ich schmeiß das Ding gleich mal an, wenn ich zuhause bin.
                                        crunchip 3 Replies Last reply Reply Quote 0
                                          dann erklär mal, was da jetzt überhaupt läuft
                                          Proxmox, VM, LXC?
                                          • Marko1974
                                            @crunchip
                                            Ich hab Proxmox laufen und hab nen Container angelegt. Aber eben auch nur nen Container. Da ich vorher einen Raspi hatte bin ich da noch nicht so sicher.
                                            Meine Frage ist auch: reicht es nur den Container zu erstellen oder braucht man grundsätzlich auch eine Installation der VM
                                            81.1k
                                            25537
